[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter
roland.richter at ntnu.no
Mon Oct 11 07:23:37 CDT 2021
I tried either /./ex19/ (SNES-example), /mpirun ./ex19/ or /mpirun -n 1
./ex19/, all with the same result.
Roland
Am 11.10.21 um 14:22 schrieb Matthew Knepley:
> On Mon, Oct 11, 2021 at 8:07 AM Roland Richter
> <roland.richter at ntnu.no> wrote:
> Hei,
> at least in gdb it fails with
> [Inferior 1 (process 7854) exited with code 01]
> (gdb) backtrace
> No stack.
> What were you running? If it never makes it into PETSc code, I am not
> sure what we are
> doing to cause this.
> Thanks,
> Matt
> Regards,
> Roland
> Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>> On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
>> Hei,
>> I compiled PETSc with Intel MPI (MPICH) and GCC as compiler
>> (i.e. using
>> Intel OneAPI together with the supplied mpicxx-compiler).
>> Compilation
>> and installation worked fine, but running the tests resulted
>> in the
>> error "Attempting to use an MPI routine before initializing
>> MPICH". A
>> simple test program (attached) worked fine with the same
>> combination.
>> What could be the reason for that?
>> Hi Roland,
>> Can you get a stack trace for this error using the debugger?
>> Thanks,
>> Matt
>> Thanks!
>> Regards,
>> Roland Richter
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/fa4f62a6/attachment-0001.html>
