[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter roland.richter at ntnu.no
Mon Oct 11 07:30:39 CDT 2021
At least according to configure.log mpiexec was defined as
Checking for program /opt/intel/oneapi/mpi/2021.4.0//bin/mpiexec...found
                  Defined make macro "MPIEXECEXECUTABLE" to
"/opt/intel/oneapi/mpi/2021.4.0/bin/mpiexec"
When running ex19 with this mpiexec it fails with the usual error, even
though all configuration steps worked fine. I attached the configuration
log.
Roland
Am 11.10.21 um 14:24 schrieb Stefano Zampini:
> You are most probably using a different mpiexec then the one used to
> compile petsc.
>> On Oct 11, 2021, at 3:23 PM, Roland Richter <roland.richter at ntnu.no>
>> wrote:
>> I tried either /./ex19/ (SNES-example), /mpirun ./ex19/ or /mpirun -n
>> 1 ./ex19/, all with the same result.
>> Regards,
>> Roland
>> Am 11.10.21 um 14:22 schrieb Matthew Knepley:
>>> On Mon, Oct 11, 2021 at 8:07 AM Roland Richter
>>> <roland.richter at ntnu.no> wrote:
>>>     Hei,
>>>     at least in gdb it fails with
>>>     [Inferior 1 (process 7854) exited with code 01]
>>>     (gdb) backtrace
>>>     No stack.
>>> What were you running? If it never makes it into PETSc code, I am
>>> not sure what we are
>>> doing to cause this.
>>>   Thanks,
>>>      Matt
>>>     Regards,
>>>     Roland
>>>     Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>>>>     On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
>>>>         Hei,
>>>>         I compiled PETSc with Intel MPI (MPICH) and GCC as compiler
>>>>         (i.e. using
>>>>         Intel OneAPI together with the supplied mpicxx-compiler).
>>>>         Compilation
>>>>         and installation worked fine, but running the tests
>>>>         resulted in the
>>>>         error "Attempting to use an MPI routine before initializing
>>>>         MPICH". A
>>>>         simple test program (attached) worked fine with the same
>>>>         combination.
>>>>         What could be the reason for that?
>>>>     Hi Roland,
>>>>     Can you get a stack trace for this error using the debugger?
>>>>       Thanks,
>>>>          Matt
>>>>         Thanks!
>>>>         Regards,
>>>>         Roland Richter
>>>>     What most experimenters take for granted before they begin
>>>>     their experiments is infinitely more interesting than any
>>>>     results to which their experiments lead.
>>>>     -- Norbert Wiener
>>>>     https://www.cse.buffalo.edu/~knepley/
>>>>     <http://www.cse.buffalo.edu/~knepley/>
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/a4453cf3/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/a4453cf3/attachment-0001.bin>
