[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Matthew Knepley
knepley at gmail.com
Mon Oct 11 07:22:21 CDT 2021
On Mon, Oct 11, 2021 at 8:07 AM Roland Richter <roland.richter at ntnu.no>
wrote:
> Hei,
> at least in gdb it fails with
> [Inferior 1 (process 7854) exited with code 01]
> (gdb) backtrace
> No stack.
What were you running? If it never makes it into PETSc code, I am not sure
what we are
doing to cause this.
Matt
> Regards,
> Roland
> Am 11.10.21 um 13:57 schrieb Matthew Knepley:
> On Mon, Oct 11, 2021 at 5:24 AM Roland Richter <roland.richter at ntnu.no>
> wrote:
>> Hei,
>> I compiled PETSc with Intel MPI (MPICH) and GCC as compiler (i.e. using
>> Intel OneAPI together with the supplied mpicxx-compiler). Compilation
>> and installation worked fine, but running the tests resulted in the
>> error "Attempting to use an MPI routine before initializing MPICH". A
>> simple test program (attached) worked fine with the same combination.
>> What could be the reason for that?
> Hi Roland,
> Can you get a stack trace for this error using the debugger?
> Thanks,
> Matt
>> Thanks!
>> Regards,
>> Roland Richter
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/5648bc70/attachment.html>
