[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter
roland.richter at ntnu.no
Mon Oct 11 07:07:45 CDT 2021
Hei,
at least in gdb it fails with
[Inferior 1 (process 7854) exited with code 01]
(gdb) backtrace
No stack.
Roland
Am 11.10.21 um 13:57 schrieb Matthew Knepley:
> On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
> <roland.richter at ntnu.no> wrote:
> Hei,
> I compiled PETSc with Intel MPI (MPICH) and GCC as compiler (i.e.
> using
> Intel OneAPI together with the supplied mpicxx-compiler). Compilation
> and installation worked fine, but running the tests resulted in the
> error "Attempting to use an MPI routine before initializing MPICH". A
> simple test program (attached) worked fine with the same combination.
> What could be the reason for that?
> Hi Roland,
> Can you get a stack trace for this error using the debugger?
> Thanks,
> Matt
> Thanks!
> Regards,
> Roland Richter
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/045692a3/attachment.html>
