[petsc-users] HDF5 corruption
Thu Oct 7 06:39:39 CDT 2021
On Wed, Oct 6, 2021 at 11:05 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi,
> One of the users of my PETSc-based code has reported that HDF5 output
> files can be corrupted and unusable if e.g. the run is killed. I've just
> done a bit of reading about this and it appears to be a known issue with
> HDF5.
> Some people suggest flushing the HDF5 file periodically to help prevent
> data loss. I had a look at PetscViewerFlush() but it doesn't seem to be
> implemented for the HDF5 viewer- is that correct?
> I am currently calling PetscViewerHDF5Open() once at the start of the
> run and closing it at the end. Some other people suggest doing this
> before and after each write instead. Is there likely to be a significant
> performance penalty in doing that?
I don't think so. This is what I did on another project to guard against the
HDF5 issue.
> I gather HDF5 journaling has been promised for a while to get around
> this problem but as far as I can see it hasn't materialised yet...
Don't worry. It will happen right after fusion power and world peace :)
      Matt
> Regards, Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211007/17746b85/attachment-0001.html>
