[petsc-users] HDF5 corruption
Jed Brown jed at jedbrown.org
Thu Oct 7 15:36:35 CDT 2021
Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> hi,
> One of the users of my PETSc-based code has reported that HDF5 output
> files can be corrupted and unusable if e.g. the run is killed. I've just
> done a bit of reading about this and it appears to be a known issue with
> HDF5.
> Some people suggest flushing the HDF5 file periodically to help prevent
> data loss. I had a look at PetscViewerFlush() but it doesn't seem to be
> implemented for the HDF5 viewer- is that correct?
Correct, but I think we can and should implement it. In your research just now, were there subtleties beyond this call?
https://portal.hdfgroup.org/display/HDF5/H5F_FLUSH
