[petsc-users] GAMG memory consumption
    Mark Adams
    mfadams at lbl.gov
    Wed Nov 24 12:18:44 CST 2021
As Matt said GAMG uses more memory.
But these numbers look odd: max == min and total = max + min, for both
cases.
I would use
https://petsc.org/release/docs/manualpages/Sys/PetscMallocDump.html to look
at this more closely.
On Wed, Nov 24, 2021 at 1:03 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 24, 2021 at 12:26 PM Karthikeyan Chockalingam - STFC UKRI <
> karthikeyan.chockalingam at stfc.ac.uk> wrote:
>> Hello,
>> I would like to understand why more memory is consumed by -pc_type gamg
>> compared to -pc_type mg for the same problem size
>> ksp/ksp/tutorial: ./ex45 -da_grid_x 368 -da_grid_x 368 -da_grid_x 368
>> -ksp_type cg
>> -pc_type mg
>> Maximum (over computational time) process memory:        total 1.9399e+10
>> max 9.7000e+09 min 9.6992e+09
>> -pc_type gamg
>> Maximum (over computational time) process memory:        total 4.9671e+10
>> max 2.4836e+10 min 2.4835e+10
>> Am I right in understanding that the memory limiting factor is ‘max
>> 2.4836e+10’ as it is the maximum memory used at any given time?
> Yes, I believe so.
> GAMG is using A_C = P^T A P, where P is the prolongation from coarse to
> fine, in order to compute the coarse operator A_C, rather than
> rediscretization, since it does not have any notion of discretization or
> coarse meshes. This takes more memory.
>   Thanks,
>     Matt
>> I have attached the -log_view output of both the preconditioners.
>> Best regards,
>> Karthik.
>> This email and any attachments are intended solely for the use of the
>> named recipients. If you are not the intended recipient you must not use,
>> disclose, copy or distribute this email or any of its attachments and
>> should notify the sender immediately and delete this email from your
>> system. UK Research and Innovation (UKRI) has taken every reasonable
>> precaution to minimise risk of this email or any attachments containing
>> viruses or malware but the recipient should carry out its own virus and
>> malware checks before opening the attachments. UKRI does not accept any
>> liability for any losses or damages which the recipient may sustain due to
>> presence of any viruses.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211124/6ebe16b8/attachment.html>
