[petsc-users] GAMG memory consumption
Dave May
dave.mayhem23 at gmail.com
Wed Nov 24 12:51:53 CST 2021
I think your run with -pc_type mg is defining a multigrid hierarchy with a
only single level. (A single level mg PC would also explain the 100+
iterations required to converge.) The gamg configuration is definitely
coarsening your problem and has a deeper hierarchy. A single level
hierarchy will require less memory than a multilevel hierarchy.
Cheers,
Dave
On Wed 24. Nov 2021 at 19:03, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 24, 2021 at 12:26 PM Karthikeyan Chockalingam - STFC UKRI <
> karthikeyan.chockalingam at stfc.ac.uk> wrote:
>> Hello,
>> I would like to understand why more memory is consumed by -pc_type gamg
>> compared to -pc_type mg for the same problem size
>> ksp/ksp/tutorial: ./ex45 -da_grid_x 368 -da_grid_x 368 -da_grid_x 368
>> -ksp_type cg
>> -pc_type mg
>> Maximum (over computational time) process memory: total 1.9399e+10
>> max 9.7000e+09 min 9.6992e+09
>> -pc_type gamg
>> Maximum (over computational time) process memory: total 4.9671e+10
>> max 2.4836e+10 min 2.4835e+10
>> Am I right in understanding that the memory limiting factor is ‘max
>> 2.4836e+10’ as it is the maximum memory used at any given time?
> Yes, I believe so.
> GAMG is using A_C = P^T A P, where P is the prolongation from coarse to
> fine, in order to compute the coarse operator A_C, rather than
> rediscretization, since it does not have any notion of discretization or
> coarse meshes. This takes more memory.
> Thanks,
> Matt
>> I have attached the -log_view output of both the preconditioners.
>> Best regards,
>> Karthik.
>> This email and any attachments are intended solely for the use of the
>> named recipients. If you are not the intended recipient you must not use,
>> disclose, copy or distribute this email or any of its attachments and
>> should notify the sender immediately and delete this email from your
>> system. UK Research and Innovation (UKRI) has taken every reasonable
>> precaution to minimise risk of this email or any attachments containing
>> viruses or malware but the recipient should carry out its own virus and
>> malware checks before opening the attachments. UKRI does not accept any
>> liability for any losses or damages which the recipient may sustain due to
>> presence of any viruses.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211124/8d9f77de/attachment-0001.html>
