[petsc-users] GAMG memory consumption
Matthew Knepley
knepley at gmail.com
Wed Nov 24 12:02:52 CST 2021
On Wed, Nov 24, 2021 at 12:26 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello,
> I would like to understand why more memory is consumed by -pc_type gamg
> compared to -pc_type mg for the same problem size
> ksp/ksp/tutorial: ./ex45 -da_grid_x 368 -da_grid_x 368 -da_grid_x 368
> -ksp_type cg
> -pc_type mg
> Maximum (over computational time) process memory: total 1.9399e+10
> max 9.7000e+09 min 9.6992e+09
> -pc_type gamg
> Maximum (over computational time) process memory: total 4.9671e+10
> max 2.4836e+10 min 2.4835e+10
> Am I right in understanding that the memory limiting factor is ‘max
> 2.4836e+10’ as it is the maximum memory used at any given time?
Yes, I believe so.
GAMG is using A_C = P^T A P, where P is the prolongation from coarse to
fine, in order to compute the coarse operator A_C, rather than
rediscretization, since it does not have any notion of discretization or
coarse meshes. This takes more memory.
Matt
> I have attached the -log_view output of both the preconditioners.
> Best regards,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211124/92002c3d/attachment.html>
