[petsc-users] MUMPS error
Bhamidipati, Vikram
vikram.bhamidipati at swri.org
Thu May 6 17:23:10 CDT 2021
The problem did not go away on a second attempt but was overcome with '--with-make-np=1' flag.
Thank you,
Vikram
-----Original Message-----
Sent: Thursday, May 6, 2021 5:03 PM
To: Bhamidipati, Vikram <vikram.bhamidipati at swri.org>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] MUMPS error
[EXTERNAL EMAIL]
Can you retry and see if the problem persists?
There might be an issue with missing dependencies in mumps parallel build..
If it still fails - you can try the additional configure option:
--with-make-np=1
Satish
On Thu, 6 May 2021, Bhamidipati, Vikram wrote:
> I configured a PetSc build to include mumps using '--download-mumps=1'. But it was not successful. I am attaching the relevant portion from configure.log. Could you advise me on what went wrong with the compilation and building of MUMPS library?
> Thanks,
> Vikram
> Vikram Bhamidipati
> Senior Research Engineer
> Computational Material Integrity Section Materials Engineering
> Department Mechanical Engineering Division
> Ph: (210) 522-2576
