[petsc-users] MUMPS error
    Satish Balay
    balay at mcs.anl.gov
    Thu May  6 17:02:41 CDT 2021
Can you retry and see if the problem persists?
There might be an issue with missing dependencies in mumps parallel build..
If it still fails - you can try the additional configure option:
--with-make-np=1
Satish
On Thu, 6 May 2021, Bhamidipati, Vikram wrote:
> I configured a PetSc build to include mumps using '--download-mumps=1'. But it was not successful. I am attaching the relevant portion from configure.log. Could you advise me on what went wrong with the compilation and building of MUMPS library?
> Thanks,
> Vikram
> Vikram Bhamidipati
> Senior Research Engineer
> Computational Material Integrity Section
> Materials Engineering Department
> Mechanical Engineering Division
> Ph: (210) 522-2576
