[petsc-users] DMPlex overlap
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Wed Mar 31 15:00:46 CDT 2021
On 31/03/2021 21:44, Matthew Knepley wrote:
> On Wed, Mar 31, 2021 at 3:36 PM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>     On 31/03/2021 21:24, Matthew Knepley wrote:
>      >     Ok so that's worth clarifying, but my problem is that dm has a
>      >     0-overlap
>      >     before DMPlexDistributeOverlap and odm has a 1-overlap even
>     though I
>      >     passed "0". If I understand what you just wrote, adding "0"
>     more levels
>      >     of overlap to 0-overlap, that should still be 0 overlap ?
>      >     Yet when I look at the code of DMPlexDistributeOverlap,
>     you're flagging
>      >     points to be added to the overlap whatever "k" is.
>      > Crap. There is a bug handling 0. Evidently, no one ever asks for
>     overlap 0.
>      > Will fix.
>     ok now I'm sure I understand what you explained :) Thanks Matt.
>     Now we can look at the other question: I need to be able to pass the
>     non-overlapping mesh to the remesher. I can either maintain 2
>     plexes, or
>     trim the overlapping plex when I create the arrays I pass to the
>     remesher. I'm not sure which is the best/worst ?
> I would start with two plexes since it is very easy.
I'll try that then, hopefully it should keep me busy for a while before
the next round of questions. Thanks Matt!
Nicolas
> Trimming the plex would essentially make another plex anyway, but it is
> not hard using DMPlexFilter().
>    Thanks,
>       Matt
>     Thanks
>     Nicolas
>      >    Thanks,
>      >       Matt
>      >     Sample code:
>      >     static char help[] = "Tests plex distribution and overlaps.\n";
>      >     #include <petsc/private/dmpleximpl.h>
>      >     int main (int argc, char * argv[]) {
>      >         DM             dm, odm;
>      >         MPI_Comm       comm;
>      >         PetscErrorCode ierr;
>      >         ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr)
>      >     return ierr;
>      >         comm = PETSC_COMM_WORLD;
>      >         ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL,
>     NULL, NULL,
>      >     NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
>      >         ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
>      >         ierr = PetscObjectSetName((PetscObject) dm, "DM
>      >     before");CHKERRQ(ierr);
>      >         ierr = DMViewFromOptions(dm, NULL,
>     "-before_dm_view");CHKERRQ(ierr);
>      >         DMPlexDistributeOverlap(dm, 0, NULL, &odm);
>      >         ierr = PetscObjectSetName((PetscObject) odm, "DM
>      >     after");CHKERRQ(ierr);
>      >         ierr = DMViewFromOptions(odm, NULL,
>     "-after_dm_view");CHKERRQ(ierr);
>      >         ierr = DMDestroy(&dm);CHKERRQ(ierr);
>      >         ierr = DMDestroy(&odm);CHKERRQ(ierr);
>      >         ierr = PetscFinalize();
>      >         return ierr;
>      >     % mpiexec -n 2 ./test_overlapV3 -dm_plex_box_faces 5,5
>     -dm_distribute
>      >     -before_dm_view -after_dm_view
>      >     DM Object: DM before 2 MPI processes
>      >         type: plex
>      >     DM before in 2 dimensions:
>      >         0-cells: 21 21
>      >         1-cells: 45 45
>      >         2-cells: 25 25
>      >     Labels:
>      >         depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
>      >         celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
>      >         marker: 1 strata with value/size (1 (21))
>      >         Face Sets: 1 strata with value/size (1 (10))
>      >     DM Object: DM after 2 MPI processes
>      >         type: plex
>      >     DM after in 2 dimensions:
>      >         0-cells: 29 29
>      >         1-cells: 65 65
>      >         2-cells: 37 37
>      >     Labels:
>      >         depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
>      >         celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
>      >         marker: 1 strata with value/size (1 (27))
>      >         Face Sets: 1 strata with value/size (1 (13))
>      >      >    Thanks,
>      >      >       Matt
>      >      >     Thanks,
>      >      >     Nicolas
>      >      >      >    Thanks,
>      >      >      >       Matt
>      >      >      >         if (!dm) {printf("Big problem\n"); dm = odm;}
>      >      >      >         else     {DMDestroy(&odm);}
>      >      >      >         ierr = PetscObjectSetName((PetscObject) dm,
>     "Initial
>      >      >      >     DM");CHKERRQ(ierr);
>      >      >      >         ierr = DMViewFromOptions(dm, NULL,
>      >      >      >     "-initial_dm_view");CHKERRQ(ierr);
>      >      >      >         ierr = DMDestroy(&dm);CHKERRQ(ierr);
>      >      >      >         ierr = PetscFinalize();
>      >      >      >         return ierr;
>      >      >      >     called with mpiexec -n 2 ./test_overlapV3
>     -initial_dm_view
>      >      >      >     -dm_plex_box_faces 5,5 -dm_distribute
>      >      >      >     gives:
>      >      >      >     DM Object: Initial DM 2 MPI processes
>      >      >      >         type: plex
>      >      >      >     Initial DM in 2 dimensions:
>      >      >      >         0-cells: 29 29
>      >      >      >         1-cells: 65 65
>      >      >      >         2-cells: 37 37
>      >      >      >     Labels:
>      >      >      >         depth: 3 strata with value/size (0 (29), 1
>     (65), 2
>      >     (37))
>      >      >      >         celltype: 3 strata with value/size (0 (29), 1
>      >     (65), 3 (37))
>      >      >      >         marker: 1 strata with value/size (1 (27))
>      >      >      >         Face Sets: 1 strata with value/size (1 (13))
>      >      >      >     which is not what I expect ?
>      >      >      >     Thanks,
>      >      >      >     Nicolas
>      >      >      >     On 31/03/2021 19:02, Matthew Knepley wrote:
>      >      >      >      > Alright, I think the problem had to do with
>     keeping
>      >     track
>      >      >     of what
>      >      >      >     DM you
>      >      >      >      > were looking at. This code increases the
>     overlap of an
>      >      >     initial DM:
>      >      >      >      > static char help[] = "Tests plex
>     distribution and
>      >      >     overlaps.\n";
>      >      >      >      > #include <petsc/private/dmpleximpl.h>
>      >      >      >      > int main (int argc, char * argv[]) {
>      >      >      >      >    DM             dm, dm2;
>      >      >      >      >    PetscInt       overlap;
>      >      >      >      >    MPI_Comm       comm;
>      >      >      >      >    PetscErrorCode ierr;
>      >      >      >      >    ierr = PetscInitialize(&argc, &argv, NULL,
>      >     help);if (ierr)
>      >      >      >     return ierr;
>      >      >      >      >    comm = PETSC_COMM_WORLD;
>      >      >      >      >    ierr = DMPlexCreateBoxMesh(comm, 2,
>     PETSC_TRUE,
>      >     NULL,
>      >      >     NULL, NULL,
>      >      >      >      > NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
>      >      >      >      >    ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
>      >      >      >      >    ierr = PetscObjectSetName((PetscObject)
>     dm, "Initial
>      >      >      >      >    ierr = DMViewFromOptions(dm, NULL,
>      >      >      >      >    ierr = DMPlexGetOverlap(dm,
>     &overlap);CHKERRQ(ierr);
>      >      >      >      >    ierr = DMPlexDistributeOverlap(dm,
>     overlap+1, NULL,
>      >      >      >     &dm2);CHKERRQ(ierr);
>      >      >      >      >    ierr = PetscObjectSetName((PetscObject) dm2,
>      >     "More Overlap
>      >      >      >      > DM");CHKERRQ(ierr);
>      >      >      >      >    ierr = DMViewFromOptions(dm2, NULL,
>      >      >      >     "-over_dm_view");CHKERRQ(ierr);
>      >      >      >      >    ierr = DMDestroy(&dm2);CHKERRQ(ierr);
>      >      >      >      >    ierr = DMDestroy(&dm);CHKERRQ(ierr);
>      >      >      >      >    ierr = PetscFinalize();
>      >      >      >      >    return ierr;
>      >      >      >      > and when we run it we get the expected result
>      >      >      >      > master *:~/Downloads/tmp/Nicolas$
>      >      >     /PETSc3/petsc/apple/bin/mpiexec
>      >      >      >     -n 2
>      >      >      >      > ./test_overlap -initial_dm_view
>      >      >      >     -dm_distribute
>      >      >      >      > -dm_distribute_overlap 1 -over_dm_view
>      >      >      >      > DM Object: Initial DM 2 MPI processes
>      >      >      >      >    type: plex
>      >      >      >      > Initial DM in 2 dimensions:
>      >      >      >      >    0-cells: 29 29
>      >      >      >      >    1-cells: 65 65
>      >      >      >      >    2-cells: 37 37
>      >      >      >      > Labels:
>      >      >      >      >    depth: 3 strata with value/size (0 (29),
>     1 (65),
>      >     2 (37))
>      >      >      >      >    celltype: 3 strata with value/size (0 (29), 1
>      >     (65), 3 (37))
>      >      >      >      >    marker: 1 strata with value/size (1 (27))
>      >      >      >      >    Face Sets: 1 strata with value/size (1 (13))
>      >      >      >      > DM Object: More Overlap DM 2 MPI processes
>      >      >      >      >    type: plex
>      >      >      >      > More Overlap DM in 2 dimensions:
>      >      >      >      >    0-cells: 36 36
>      >      >      >      >    1-cells: 85 85
>      >      >      >      >    2-cells: 50 50
>      >      >      >      > Labels:
>      >      >      >      >    depth: 3 strata with value/size (0 (36),
>     1 (85),
>      >     2 (50))
>      >      >      >      >    celltype: 3 strata with value/size (0 (36), 1
>      >     (85), 3 (50))
>      >      >      >      >    marker: 1 strata with value/size (1 (40))
>      >      >      >      >    Face Sets: 1 strata with value/size (1 (20))
>      >      >      >      >    Thanks,
>      >      >      >      >       Matt
>      >      >      >      > On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley
>      >      >      >     <knepley at gmail.com <mailto:knepley at gmail.com>
>     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>
>     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>
>      >      >     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>
>     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>>
>      >      >      >      > <mailto:knepley at gmail.com
>     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>>>> wrote:
>      >      >      >      >     Okay, let me show a really simple
>     example that
>      >     gives
>      >      >     the expected
>      >      >      >      >     result before I figure out what is going
>     wrong for
>      >      >     you. This code
>     distribution and
>      >      >     overlaps.\n";
>      >      >      >      >        DM                    dm;
>     NULL,
>      >     help);if
>      >      >     (ierr)
>      >      >      >     return
>      >      >      >      >     ierr;
>      >     PETSC_TRUE, NULL,
>      >      >      >     NULL, NULL,
>      >      >      >      >        ierr =
>      >      >      >      >        ierr =
>      >     "Initial
>      >      >      >      >        return ierr;
>      >      >      >      >     can do all the overlap tests. For
>     example, you
>      >     can run
>      >      >     it naively
>      >      >      >      >     and get a serial mesh
>      >      >      >     /PETSc3/petsc/apple/bin/mpiexec -n
>      >      >      >      >     2 ./test_overlap -initial_dm_view
>      >      >      >      >        type: plex
>      >      >      >      >        0-cells: 36 0
>      >      >      >      >        1-cells: 85 0
>      >      >      >      >        2-cells: 50 0
>      >      >      >      >     Labels:
>     (36),
>      >     3 (50),
>      >      >     1 (85))
>     (36), 1
>      >     (85), 2
>      >      >     (50))
>     (1 (20))
>      >      >      >      >     Then run it telling Plex to distribute after
>      >     creating
>      >      >     the mesh
>      >      >      >     -dm_distribute
>      >      >      >      >        type: plex
>      >      >      >      >        0-cells: 21 21
>      >      >      >      >        1-cells: 45 45
>      >      >      >      >        2-cells: 25 25
>      >      >      >      >     Labels:
>     (21), 1
>      >     (45), 2
>      >      >     (25))
>     (21),
>      >     1 (45),
>      >      >     3 (25))
>      >      >      >      >        marker: 1 strata with value/size (1 (21))
>     (1 (10))
>      >      >      >      >     The get the same thing back with overlap = 0
>      >      >      >      >     -dm_distribute -dm_distribute_overlap 0
>      >      >      >      >        type: plex
>      >      >      >      >     Labels:
>     (21), 1
>      >     (45), 2
>      >      >     (25))
>     (21),
>      >     1 (45),
>      >      >     3 (25))
>     (1 (10))
>      >      >      >      >     and get larger local meshes with overlap = 1
>      >      >      >      >     -dm_distribute -dm_distribute_overlap 1
>      >      >      >      >        type: plex
>      >      >      >      >     Labels:
>     (29), 1
>      >     (65), 2
>      >      >     (37))
>     (29),
>      >     1 (65),
>      >      >     3 (37))
>     (1 (13))
>      >      >      >      >        Thanks,
>      >      >      >      >           Matt
>      >      >      >      >     On Wed, Mar 31, 2021 at 12:22 PM Nicolas
>     Barral
>      >      >      >      >     <nicolas.barral at math.u-bordeaux.fr
>      >      >     <mailto:nicolas.barral at math.u-bordeaux.fr
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>
>      >      >      >     <mailto:nicolas.barral at math.u-bordeaux.fr
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>>> wrote:
>      >      >      >      >         Nicolas
>      >      >      >      >         On 31/03/2021 17:51, Matthew Knepley
>     wrote:
>      >      >      >      >          > On Sat, Mar 27, 2021 at 9:27 AM
>     Nicolas
>      >     Barral
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>>>> wrote:
>      >      >      >      >          >     Hi all,
>      >      >      >      >          >     First, I'm not sure I understand
>      >     what the
>      >      >     overlap
>      >      >      >      >         parameter in
>      >      >      >      >          >     DMPlexDistributeOverlap does. I
>      >     tried the
>      >      >     following:
>      >      >      >      >         generate a small
>      >      >      >      >          >     mesh on 1 rank with
>      >     DMPlexCreateBoxMesh, then
>      >      >      >     distribute
>      >      >      >      >         it with
>      >      >      >      >          >     DMPlexDistribute. At this point I
>      >     have two nice
>      >      >      >      >         partitions, with shared
>      >      >      >      >          >     vertices and no overlapping
>     cells.
>      >     Then I call
>      >      >      >      >          >     with the overlap parameter
>     set to 0
>      >     or 1,
>      >      >     and get the
>      >      >      >      >         same resulting
>      >      >      >      >          >     plex in both cases. Why is that ?
>      >      >      >      >          > The overlap parameter says how
>     many cell
>      >      >     adjacencies to go
>      >      >      >      >         out. You
>      >      >      >      >          > should not get the same
>      >      >      >      >          > mesh out. We have lots of
>     examples that use
>      >      >     this. If
>      >      >      >     you send
>      >      >      >      >         your small
>      >      >      >      >          > example, I can probably
>      >      >      >      >          > tell you what is happening.
>      >      >      >      >         Ok so I do have a small example on
>     that and the
>      >      >     DMClone
>      >      >      >     thing I
>      >      >      >      >         set up
>      >      >      >      >         to understand! I attach it to the email.
>      >      >      >      >         For the overlap, you can change the
>     overlap
>      >      >     constant at
>      >      >      >     the top
>      >      >      >      >         of the
>      >      >      >      >         file. With OVERLAP=0 or 1, the
>     distributed
>      >      >     overlapping mesh
>      >      >      >      >         (shown using
>      >      >      >      >         -over_dm_view, it's DMover) are the
>     same, and
>      >      >     different
>      >      >      >     from the
>      >      >      >      >         mesh
>      >      >      >      >         before distributing the overlap
>     (shown using
>      >      >      >     -distrib_dm_view). For
>      >      >      >      >         larger overlap values they're different.
>      >      >      >      >         The process is:
>      >      >      >      >         1/ create a DM dm on 1 rank
>      >      >      >      >         2/ clone dm into dm2
>      >      >      >      >         3/ distribute dm
>      >      >      >      >         4/ clone dm into dm3
>      >      >      >      >         5/ distribute dm overlap
>      >      >      >      >         I print all the DMs after each step.
>     dm has a
>      >      >     distributed
>      >      >      >      >         overlap, dm2
>      >      >      >      >         is not distributed, dm3 is
>     distributed but
>      >     without
>      >      >      >     overlap. Since
>      >      >      >      >         distribute and distributeOverlap
>     create new
>      >     DMs, I
>      >      >     don't seem
>      >      >      >      >         have a
>      >      >      >      >         problem with the shallow copies.
>      >      >      >      >          >     Second, I'm wondering what
>     would be
>      >     a good
>      >      >     way to
>      >      >      >     handle
>      >      >      >      >         two overlaps
>      >      >      >      >          >     and associated local vectors.
>     In my
>      >     adaptation
>      >      >      >     code, the
>      >      >      >      >         remeshing
>      >      >      >      >          >     library requires a
>     non-overlapping mesh,
>      >      >     while the
>      >      >      >      >         refinement criterion
>      >      >      >      >          >     computation is based on hessian
>      >      >     computations, which
>      >      >      >      >         require a layer of
>      >      >      >      >          >     overlap. What I can do is
>     clone the
>      >     dm before
>      >      >      >      >         distributing the overlap,
>      >      >      >      >          >     then manage two independent plex
>      >     objects with
>      >      >      >     their own
>      >      >      >      >         local sections
>      >      >      >      >          >     etc. and copy/trim local vectors
>      >     manually.
>      >      >     Is there a
>      >      >      >      >         more automatic
>      >      >      >      >          >     way
>      >      >      >      >          >     to do this ?
>      >      >      >      >          > DMClone() is a shallow copy, so that
>      >     will not work.
>      >      >      >     You would
>      >      >      >      >         maintain
>      >      >      >      >          > two different Plexes, overlapping
>      >      >      >      >          > and non-overlapping, with their
>     own sections
>      >      >     and vecs. Are
>      >      >      >      >         you sure you
>      >      >      >      >          > need to keep around the
>     non-overlapping one?
>      >      >      >      >          > Maybe if I understood what operations
>      >     you want
>      >      >     to work, I
>      >      >      >      >         could say
>      >      >      >      >          > something more definitive.
>      >      >      >      >         I need to be able to pass the
>      >      >     to the
>      >      >      >      >         remesher. I
>      >      >      >      >         can either maintain 2 plexes, or
>     trim the
>      >     overlapping
>      >      >      >     plex when
>      >      >      >      >         I create
>      >      >      >      >         the arrays I give to the remesher.
>     I'm not sure
>      >      >     which is the
>      >      >      >      >         best/worst ?
>      >      >      >      >         Thanks
>      >      >      >      >         Nicolas
>      >      >      >      >          >    Thanks,
>      >      >      >      >          >       Matt
>      >      >      >      >          >     Thanks
>      >      >      >      >          >     Nicolas
>      >      >      >      >          > What most experimenters take for
>     granted
>      >     before
>      >      >     they
>      >      >      >     begin their
>      >      >      >      >          > experiments is infinitely more
>      >     interesting than any
>      >      >      >     results
>      >      >      >      >         to which
>      >      >      >      >          > their experiments lead.
>      >      >      >      >          > -- Norbert Wiener
>      >      >      >      >          > https://www.cse.buffalo.edu/~knepley/
>      >      >      >      >         <http://www.cse.buffalo.edu/~knepley/>
>      >      >      >      >     What most experimenters take for granted
>     before
>      >     they
>      >      >     begin their
>      >      >     results
>      >      >      >     to which
>      >      >      >      > What most experimenters take for granted before
>      >     they begin
>      >      >     their
>      >      >      >      > experiments is infinitely more interesting
>     than any
>      >      >     results to which
>     they begin
>      >     their
>      >      >      > experiments is infinitely more interesting than any
>      >     results to which
>      >      > What most experimenters take for granted before they begin
>     their
>     results to which
>      >      > -- Norbert Wiener
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
