[petsc-users] DMPlex overlap
Wed Mar 31 14:44:10 CDT 2021
On Wed, Mar 31, 2021 at 3:36 PM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> On 31/03/2021 21:24, Matthew Knepley wrote:
> >     Ok so that's worth clarifying, but my problem is that dm has a
> >     0-overlap
> >     before DMPlexDistributeOverlap and odm has a 1-overlap even though I
> >     passed "0". If I understand what you just wrote, adding "0" more
> levels
> >     of overlap to 0-overlap, that should still be 0 overlap ?
> >     Yet when I look at the code of DMPlexDistributeOverlap, you're
> flagging
> >     points to be added to the overlap whatever "k" is.
> > Crap. There is a bug handling 0. Evidently, no one ever asks for overlap
> 0.
> > Will fix.
> ok now I'm sure I understand what you explained :) Thanks Matt.
> Now we can look at the other question: I need to be able to pass the
> non-overlapping mesh to the remesher. I can either maintain 2 plexes, or
> trim the overlapping plex when I create the arrays I pass to the
> remesher. I'm not sure which is the best/worst ?
I would start with two plexes since it is very easy.
Trimming the plex would essentially make another plex anyway, but it is not
hard using DMPlexFilter().
     Matt
> Thanks
> Nicolas
> >    Thanks,
> >       Matt
> >     Sample code:
> >     static char help[] = "Tests plex distribution and overlaps.\n";
> >     #include <petsc/private/dmpleximpl.h>
> >     int main (int argc, char * argv[]) {
> >         DM             dm, odm;
> >         MPI_Comm       comm;
> >         PetscErrorCode ierr;
> >         ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr)
> >     return ierr;
> >         comm = PETSC_COMM_WORLD;
> >         ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL,
> >     NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
> >         ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
> >         ierr = PetscObjectSetName((PetscObject) dm, "DM
> >     before");CHKERRQ(ierr);
> >         ierr = DMViewFromOptions(dm, NULL,
> "-before_dm_view");CHKERRQ(ierr);
> >         DMPlexDistributeOverlap(dm, 0, NULL, &odm);
> >         ierr = PetscObjectSetName((PetscObject) odm, "DM
> >     after");CHKERRQ(ierr);
> >         ierr = DMViewFromOptions(odm, NULL,
> "-after_dm_view");CHKERRQ(ierr);
> >         ierr = DMDestroy(&dm);CHKERRQ(ierr);
> >         ierr = DMDestroy(&odm);CHKERRQ(ierr);
> >         ierr = PetscFinalize();
> >         return ierr;
> >     % mpiexec -n 2 ./test_overlapV3 -dm_plex_box_faces 5,5 -dm_distribute
> >     -before_dm_view -after_dm_view
> >     DM Object: DM before 2 MPI processes
> >         type: plex
> >     DM before in 2 dimensions:
> >         0-cells: 21 21
> >         1-cells: 45 45
> >         2-cells: 25 25
> >     Labels:
> >         depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
> >         celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
> >         marker: 1 strata with value/size (1 (21))
> >         Face Sets: 1 strata with value/size (1 (10))
> >     DM Object: DM after 2 MPI processes
> >         type: plex
> >     DM after in 2 dimensions:
> >         0-cells: 29 29
> >         1-cells: 65 65
> >         2-cells: 37 37
> >     Labels:
> >         depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
> >         celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
> >         marker: 1 strata with value/size (1 (27))
> >         Face Sets: 1 strata with value/size (1 (13))
> >      >    Thanks,
> >      >       Matt
> >      >     Thanks,
> >      >     Nicolas
> >      >      >    Thanks,
> >      >      >       Matt
> >      >      >         if (!dm) {printf("Big problem\n"); dm = odm;}
> >      >      >         else     {DMDestroy(&odm);}
> "Initial
> >      >      >     DM");CHKERRQ(ierr);
> >      >      >     "-initial_dm_view");CHKERRQ(ierr);
> >      >      >         return ierr;
> >      >      >     called with mpiexec -n 2 ./test_overlapV3
> -initial_dm_view
> >      >      >     gives:
> >      >      >     DM Object: Initial DM 2 MPI processes
> >      >      >         type: plex
> >      >      >     Initial DM in 2 dimensions:
> >      >      >         0-cells: 29 29
> >      >      >         1-cells: 65 65
> >      >      >         2-cells: 37 37
> >      >      >     Labels:
> >     (37))
> >     (65), 3 (37))
> >      >      >     which is not what I expect ?
> >      >      >     Thanks,
> >      >      >     Nicolas
> >      >      >     On 31/03/2021 19:02, Matthew Knepley wrote:
> >      >      >      > Alright, I think the problem had to do with keeping
> >     track
> >      >     of what
> >      >      >     DM you
> >      >      >      > were looking at. This code increases the overlap of
> an
> >      >     initial DM:
> >      >     overlaps.\n";
> >      >      >      >    DM             dm, dm2;
> >      >      >      >    PetscInt       overlap;
> >      >      >      >    MPI_Comm       comm;
> >     help);if (ierr)
> >      >      >     return ierr;
> >     NULL,
> >      >     NULL, NULL,
> "Initial
> >      >      >     DM");CHKERRQ(ierr);
> >      >      >      >    ierr = DMPlexGetOverlap(dm,
> &overlap);CHKERRQ(ierr);
> >      >      >      >    ierr = DMPlexDistributeOverlap(dm, overlap+1,
> NULL,
> >      >      >     &dm2);CHKERRQ(ierr);
> >      >      >      >    ierr = PetscObjectSetName((PetscObject) dm2,
> >     "More Overlap
> >      >      >      > DM");CHKERRQ(ierr);
> >      >      >      >    ierr = DMViewFromOptions(dm2, NULL,
> >      >      >     "-over_dm_view");CHKERRQ(ierr);
> >      >      >      >    ierr = DMDestroy(&dm2);CHKERRQ(ierr);
> >      >      >      >    return ierr;
> >      >      >      > and when we run it we get the expected result
> >      >      >      > master *:~/Downloads/tmp/Nicolas$
> >      >     /PETSc3/petsc/apple/bin/mpiexec
> >      >      >     -n 2
> >      >      >      > ./test_overlap -initial_dm_view -dm_plex_box_faces
> 5,5
> >      >      >     -dm_distribute
> >      >      >      > -dm_distribute_overlap 1 -over_dm_view
> >      >      >      >    type: plex
> >      >      >      >    0-cells: 29 29
> >      >      >      >    1-cells: 65 65
> >      >      >      >    2-cells: 37 37
> >      >      >      > Labels:
> >     2 (37))
> >     (65), 3 (37))
> >      >      >      > DM Object: More Overlap DM 2 MPI processes
> >      >      >      >    type: plex
> >      >      >      > More Overlap DM in 2 dimensions:
> >      >      >      >    0-cells: 36 36
> >      >      >      >    1-cells: 85 85
> >      >      >      >    2-cells: 50 50
> >      >      >      > Labels:
> >      >      >      >    depth: 3 strata with value/size (0 (36), 1 (85),
> >     2 (50))
> >      >      >      >    celltype: 3 strata with value/size (0 (36), 1
> >     (85), 3 (50))
> >      >      >      >    marker: 1 strata with value/size (1 (40))
> >      >      >      >    Face Sets: 1 strata with value/size (1 (20))
> >      >      >      >    Thanks,
> >      >      >      >       Matt
> >      >      >      > On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley
> >      >      >     <knepley at gmail.com <mailto:knepley at gmail.com>
> >     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>
> >     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>
> >     <mailto:knepley at gmail.com> <mailto:knepley at gmail.com
> >     <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>>> wrote:
> >      >      >      >     Okay, let me show a really simple example that
> >     gives
> >      >     the expected
> >      >      >      >     result before I figure out what is going wrong
> for
> >      >     you. This code
> and
> >      >     overlaps.\n";
> >      >      >      >        DM                    dm;
> >      >      >      >        MPI_Comm       comm;
> >     help);if
> >      >     (ierr)
> >      >      >     return
> >      >      >      >     ierr;
> >     PETSC_TRUE, NULL,
> >      >      >     NULL, NULL,
> >     "Initial
> >      >      >      >     DM");CHKERRQ(ierr);
> >      >      >      >        return ierr;
> >      >      >      >     can do all the overlap tests. For example, you
> >     can run
> >      >     it naively
> >      >      >      >     and get a serial mesh
> >      >      >     /PETSc3/petsc/apple/bin/mpiexec -n
> >      >      >      >     2 ./test_overlap -initial_dm_view
> >      >      >      >        type: plex
> >      >      >      >        0-cells: 36 0
> >      >      >      >        1-cells: 85 0
> >      >      >      >        2-cells: 50 0
> >      >      >      >     Labels:
> >     3 (50),
> >      >     1 (85))
> >     (85), 2
> >      >     (50))
> >      >      >      >     Then run it telling Plex to distribute after
> >     creating
> >      >     the mesh
> >      >      >     -dm_distribute
> >      >      >      >        type: plex
> >      >      >      >        0-cells: 21 21
> >      >      >      >        1-cells: 45 45
> >      >      >      >        2-cells: 25 25
> >      >      >      >     Labels:
> >     (45), 2
> >      >     (25))
> >     1 (45),
> >      >     3 (25))
> >      >      >      >     The get the same thing back with overlap = 0
> >      >      >      >     -dm_distribute -dm_distribute_overlap 0
> >      >      >      >        type: plex
> >      >      >      >        0-cells: 21 21
> >      >      >      >        1-cells: 45 45
> >      >      >      >        2-cells: 25 25
> >      >      >      >     Labels:
> >     (45), 2
> >      >     (25))
> >     1 (45),
> >      >     3 (25))
> >      >      >      >     and get larger local meshes with overlap = 1
> >      >      >      >     -dm_distribute -dm_distribute_overlap 1
> >      >      >      >        type: plex
> >      >      >      >        0-cells: 29 29
> >      >      >      >        1-cells: 65 65
> >      >      >      >        2-cells: 37 37
> >      >      >      >     Labels:
> >     (65), 2
> >      >     (37))
> >     1 (65),
> >      >     3 (37))
> >      >      >      >        Thanks,
> >      >      >      >           Matt
> >      >      >      >     On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral
> >      >      >      >     <nicolas.barral at math.u-bordeaux.fr
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>>
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>>>
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>> wrote:
> >      >      >      >         Nicolas
> >      >      >      >         On 31/03/2021 17:51, Matthew Knepley wrote:
> >      >      >      >          > On Sat, Mar 27, 2021 at 9:27 AM Nicolas
> >     Barral
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>>> wrote:
> >      >      >      >          >     Hi all,
> >      >      >      >          >     First, I'm not sure I understand
> >     what the
> >      >     overlap
> >      >      >      >         parameter in
> >      >      >      >          >     DMPlexDistributeOverlap does. I
> >     tried the
> >      >     following:
> >      >      >      >         generate a small
> >      >      >      >          >     mesh on 1 rank with
> >     DMPlexCreateBoxMesh, then
> >      >      >     distribute
> >      >      >      >         it with
> >      >      >      >          >     DMPlexDistribute. At this point I
> >     have two nice
> >      >      >      >         partitions, with shared
> >      >      >      >          >     vertices and no overlapping cells.
> >     Then I call
> >      >      >      >          >     with the overlap parameter set to 0
> >     or 1,
> >      >     and get the
> >      >      >      >         same resulting
> >      >      >      >          >     plex in both cases. Why is that ?
> >      >      >      >          > The overlap parameter says how many cell
> >      >     adjacencies to go
> >      >      >      >         out. You
> >      >      >      >          > should not get the same
> >      >      >      >          > mesh out. We have lots of examples that
> use
> >      >     this. If
> >      >      >     you send
> >      >      >      >         your small
> >      >      >      >          > example, I can probably
> >      >      >      >          > tell you what is happening.
> >      >      >      >         Ok so I do have a small example on that and
> the
> >      >     DMClone
> >      >      >     thing I
> >      >      >      >         set up
> >      >      >      >         to understand! I attach it to the email.
> >      >      >      >         For the overlap, you can change the overlap
> >      >     constant at
> >      >      >     the top
> >      >      >      >         of the
> >      >      >      >         file. With OVERLAP=0 or 1, the distributed
> >      >     overlapping mesh
> >      >      >      >         (shown using
> >      >      >      >         -over_dm_view, it's DMover) are the same,
> and
> >      >     different
> >      >      >     from the
> >      >      >      >         mesh
> >      >      >      >         before distributing the overlap (shown using
> >      >      >     -distrib_dm_view). For
> >      >      >      >         larger overlap values they're different.
> >      >      >      >         The process is:
> >      >      >      >         1/ create a DM dm on 1 rank
> >      >      >      >         2/ clone dm into dm2
> >      >      >      >         3/ distribute dm
> >      >      >      >         4/ clone dm into dm3
> >      >      >      >         5/ distribute dm overlap
> >      >      >      >         I print all the DMs after each step. dm has
> a
> >      >     distributed
> >      >      >      >         overlap, dm2
> >      >      >      >         is not distributed, dm3 is distributed but
> >     without
> >      >      >     overlap. Since
> >      >      >      >         distribute and distributeOverlap create new
> >     DMs, I
> >      >     don't seem
> >      >      >      >         have a
> >      >      >      >         problem with the shallow copies.
> >      >      >      >          >     Second, I'm wondering what would be
> >     a good
> >      >     way to
> >      >      >     handle
> >      >      >      >         two overlaps
> >      >      >      >          >     and associated local vectors. In my
> >     adaptation
> >      >      >     code, the
> >      >      >      >         remeshing
> >      >      >      >          >     library requires a non-overlapping
> mesh,
> >      >     while the
> >      >      >      >         refinement criterion
> >      >      >      >          >     computation is based on hessian
> >      >     computations, which
> >      >      >      >         require a layer of
> >      >      >      >          >     overlap. What I can do is clone the
> >     dm before
> >      >      >      >         distributing the overlap,
> >      >      >      >          >     then manage two independent plex
> >     objects with
> >      >      >     their own
> >      >      >      >         local sections
> >      >      >      >          >     etc. and copy/trim local vectors
> >     manually.
> >      >     Is there a
> >      >      >      >         more automatic
> >      >      >      >          >     way
> >      >      >      >          >     to do this ?
> >      >      >      >          > DMClone() is a shallow copy, so that
> >     will not work.
> >      >      >     You would
> >      >      >      >         maintain
> >      >      >      >          > two different Plexes, overlapping
> >      >      >      >          > and non-overlapping, with their own
> sections
> >      >     and vecs. Are
> >      >      >      >         you sure you
> >      >      >      >          > need to keep around the non-overlapping
> one?
> >      >      >      >          > Maybe if I understood what operations
> >     you want
> >      >     to work, I
> >      >      >      >         could say
> >      >      >      >          > something more definitive.
> >      >     to the
> >      >      >      >         remesher. I
> >      >      >      >         can either maintain 2 plexes, or trim the
> >     overlapping
> >      >      >     plex when
> >      >      >      >         I create
> >      >      >      >         the arrays I give to the remesher. I'm not
> sure
> >      >     which is the
> >      >      >      >         best/worst ?
> >      >      >      >         Thanks
> >      >      >      >         Nicolas
> >      >      >      >          >    Thanks,
> >      >      >      >          >       Matt
> >      >      >      >          >     Thanks
> >      >      >      >          >     Nicolas
> >      >      >      >          > What most experimenters take for granted
> >     before
> >      >     they
> >      >      >     begin their
> >      >      >      >          > experiments is infinitely more
> >     interesting than any
> >      >      >     results
> >      >      >      >         to which
> >      >      >      >          > their experiments lead.
> >      >      >      >          > -- Norbert Wiener
> >      >      >      >          > https://www.cse.buffalo.edu/~knepley/
> >      >      >      >         <http://www.cse.buffalo.edu/~knepley/>
> >      >      >      >     What most experimenters take for granted before
> >     they
> >      >     begin their
> >      >      >      >     experiments is infinitely more interesting than
> any
> >      >     results
> >      >      >     to which
> >      >      >      >     -- Norbert Wiener
> >     they begin
> >      >     their
> >      >      >      > experiments is infinitely more interesting than any
> >      >     results to which
> >      >      >      > -- Norbert Wiener
> >      >      > What most experimenters take for granted before they begin
> >     their
> >     results to which
> >      >      > -- Norbert Wiener
> >      > What most experimenters take for granted before they begin their
> >      > experiments is infinitely more interesting than any results to
> which
> >      > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/1d6bd1e4/attachment-0001.html>
