[petsc-users] DMPlex overlap
Matthew Knepley
knepley at gmail.com
Wed Mar 31 15:28:30 CDT 2021
On Wed, Mar 31, 2021 at 4:00 PM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> On 31/03/2021 21:44, Matthew Knepley wrote:
> > On Wed, Mar 31, 2021 at 3:36 PM Nicolas Barral
> > <nicolas.barral at math.u-bordeaux.fr
> > <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> > On 31/03/2021 21:24, Matthew Knepley wrote:
> > > Ok so that's worth clarifying, but my problem is that dm has a
> > > 0-overlap
> > > before DMPlexDistributeOverlap and odm has a 1-overlap even
> > though I
> > > passed "0". If I understand what you just wrote, adding "0"
> > more levels
> > > of overlap to 0-overlap, that should still be 0 overlap ?
> > > Yet when I look at the code of DMPlexDistributeOverlap,
> > you're flagging
> > > points to be added to the overlap whatever "k" is.
> > > Crap. There is a bug handling 0. Evidently, no one ever asks for
> > overlap 0.
> > > Will fix.
> > ok now I'm sure I understand what you explained :) Thanks Matt.
> > Now we can look at the other question: I need to be able to pass the
> > non-overlapping mesh to the remesher. I can either maintain 2
> > plexes, or
> > trim the overlapping plex when I create the arrays I pass to the
> > remesher. I'm not sure which is the best/worst ?
> > I would start with two plexes since it is very easy.
> I'll try that then, hopefully it should keep me busy for a while before
> the next round of questions. Thanks Matt!
Excellent. I have your fix in:
https://gitlab.com/petsc/petsc/-/merge_requests/3796
Matt
> Nicolas
> > Trimming the plex would essentially make another plex anyway, but it is
> > not hard using DMPlexFilter().
> > Thanks,
> > Matt
> > Thanks
> > Nicolas
> > > Thanks,
> > > Matt
> > > Sample code:
> > > static char help[] = "Tests plex distribution and
> overlaps.\n";
> > > #include <petsc/private/dmpleximpl.h>
> > > int main (int argc, char * argv[]) {
> > > DM dm, odm;
> > > MPI_Comm comm;
> > > PetscErrorCode ierr;
> > > ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr)
> > > return ierr;
> > > comm = PETSC_COMM_WORLD;
> > > ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL,
> > NULL, NULL,
> > > NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
> > > ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
> > > ierr = PetscObjectSetName((PetscObject) dm, "DM
> > > before");CHKERRQ(ierr);
> > > ierr = DMViewFromOptions(dm, NULL,
> > "-before_dm_view");CHKERRQ(ierr);
> > > DMPlexDistributeOverlap(dm, 0, NULL, &odm);
> > > ierr = PetscObjectSetName((PetscObject) odm, "DM
> > > after");CHKERRQ(ierr);
> > > ierr = DMViewFromOptions(odm, NULL,
> > "-after_dm_view");CHKERRQ(ierr);
> > > ierr = DMDestroy(&dm);CHKERRQ(ierr);
> > > ierr = DMDestroy(&odm);CHKERRQ(ierr);
> > > ierr = PetscFinalize();
> > > return ierr;
> > > % mpiexec -n 2 ./test_overlapV3 -dm_plex_box_faces 5,5
> > -dm_distribute
> > > -before_dm_view -after_dm_view
> > > DM Object: DM before 2 MPI processes
> > > type: plex
> > > DM before in 2 dimensions:
> > > 0-cells: 21 21
> > > 1-cells: 45 45
> > > 2-cells: 25 25
> > > Labels:
> > > depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
> > > celltype: 3 strata with value/size (0 (21), 1 (45), 3
> (25))
> > > marker: 1 strata with value/size (1 (21))
> > > Face Sets: 1 strata with value/size (1 (10))
> > > DM Object: DM after 2 MPI processes
> > > type: plex
> > > DM after in 2 dimensions:
> > > 0-cells: 29 29
> > > 1-cells: 65 65
> > > 2-cells: 37 37
> > > Labels:
> > > depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
> > > celltype: 3 strata with value/size (0 (29), 1 (65), 3
> (37))
> > > marker: 1 strata with value/size (1 (27))
> > > Face Sets: 1 strata with value/size (1 (13))
> > > > Thanks,
> > > > Matt
> > > > Thanks,
> > > > Nicolas
> > > > > Thanks,
> > > > > Matt
> > > > > if (!dm) {printf("Big problem\n"); dm =
> odm;}
> > > > > else {DMDestroy(&odm);}
> > "Initial
> > > > > DM");CHKERRQ(ierr);
> > > > > "-initial_dm_view");CHKERRQ(ierr);
> > > > > return ierr;
> > > > > called with mpiexec -n 2 ./test_overlapV3
> > -initial_dm_view
> > > > > -dm_plex_box_faces 5,5 -dm_distribute
> > > > > gives:
> > > > > DM Object: Initial DM 2 MPI processes
> > > > > type: plex
> > > > > Initial DM in 2 dimensions:
> > > > > 0-cells: 29 29
> > > > > 1-cells: 65 65
> > > > > 2-cells: 37 37
> > > > > Labels:
> > (65), 2
> > > (37))
> 1
> > > (65), 3 (37))
> > > > > which is not what I expect ?
> > > > > Thanks,
> > > > > Nicolas
> > > > > On 31/03/2021 19:02, Matthew Knepley wrote:
> > > > > > Alright, I think the problem had to do with
> > keeping
> > > track
> > > > of what
> > > > > DM you
> > > > > > were looking at. This code increases the
> > overlap of an
> > > > initial DM:
> > distribution and
> > > > overlaps.\n";
> > > > > > DM dm, dm2;
> > > > > > PetscInt overlap;
> > > > > > MPI_Comm comm;
> > > help);if (ierr)
> > > > > return ierr;
> > PETSC_TRUE,
> > > NULL,
> > > > NULL, NULL,
> > dm, "Initial
> > > > > DM");CHKERRQ(ierr);
> > > > > > ierr = DMPlexGetOverlap(dm,
> > &overlap);CHKERRQ(ierr);
> > > > > > ierr = DMPlexDistributeOverlap(dm,
> > overlap+1, NULL,
> > > > > &dm2);CHKERRQ(ierr);
> dm2,
> > > "More Overlap
> > > > > > DM");CHKERRQ(ierr);
> > > > > > ierr = DMViewFromOptions(dm2, NULL,
> > > > > "-over_dm_view");CHKERRQ(ierr);
> > > > > > ierr = DMDestroy(&dm2);CHKERRQ(ierr);
> > > > > > return ierr;
> > > > > > and when we run it we get the expected result
> > > > > > master *:~/Downloads/tmp/Nicolas$
> > > > /PETSc3/petsc/apple/bin/mpiexec
> > > > > -n 2
> > > > > > ./test_overlap -initial_dm_view
> > > > > -dm_distribute
> > > > > > -dm_distribute_overlap 1 -over_dm_view
> > > > > > type: plex
> > > > > > 0-cells: 29 29
> > > > > > 1-cells: 65 65
> > > > > > 2-cells: 37 37
> > > > > > Labels:
> > 1 (65),
> > > 2 (37))
> (29), 1
> > > (65), 3 (37))
> (13))
> > > > > > DM Object: More Overlap DM 2 MPI processes
> > > > > > type: plex
> > > > > > More Overlap DM in 2 dimensions:
> > > > > > 0-cells: 36 36
> > > > > > 1-cells: 85 85
> > > > > > 2-cells: 50 50
> > > > > > Labels:
> > > > > > depth: 3 strata with value/size (0 (36),
> > 1 (85),
> > > 2 (50))
> (36), 1
> > > (85), 3 (50))
> > > > > > marker: 1 strata with value/size (1 (40))
> (20))
> > > > > > Thanks,
> > > > > > Matt
> > > > > > On Wed, Mar 31, 2021 at 12:57 PM Matthew
> Knepley
> > > > > <knepley at gmail.com <mailto:knepley at gmail.com>
> > <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>
> > <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>
> > <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>>
> > <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>>>>> wrote:
> > > > > > Okay, let me show a really simple
> > example that
> > > gives
> > > > the expected
> > > > > > result before I figure out what is going
> > wrong for
> > > > you. This code
> > distribution and
> > > > overlaps.\n";
> > > > > > DM dm;
> > > > > > MPI_Comm comm;
> > NULL,
> > > help);if
> > > > (ierr)
> > > > > return
> > > > > > ierr;
> > > PETSC_TRUE, NULL,
> > > > > NULL, NULL,
> > > > > > ierr =
> > > > > > ierr =
> > > "Initial
> > > > > > DM");CHKERRQ(ierr);
> > > > > > return ierr;
> > > > > > can do all the overlap tests. For
> > example, you
> > > can run
> > > > it naively
> > > > > > and get a serial mesh
> > > > > /PETSc3/petsc/apple/bin/mpiexec -n
> > > > > > 2 ./test_overlap -initial_dm_view
> > > > > > type: plex
> > > > > > 0-cells: 36 0
> > > > > > 1-cells: 85 0
> > > > > > 2-cells: 50 0
> > > > > > Labels:
> > (36),
> > > 3 (50),
> > > > 1 (85))
> > (36), 1
> > > (85), 2
> > > > (50))
> (40))
> > (1 (20))
> > > > > > Then run it telling Plex to distribute
> after
> > > creating
> > > > the mesh
> > > > > -dm_distribute
> > > > > > type: plex
> > > > > > 0-cells: 21 21
> > > > > > 1-cells: 45 45
> > > > > > 2-cells: 25 25
> > > > > > Labels:
> > (21), 1
> > > (45), 2
> > > > (25))
> > (21),
> > > 1 (45),
> > > > 3 (25))
> (21))
> > (1 (10))
> > > > > > The get the same thing back with overlap
> = 0
> > > > > > -dm_distribute -dm_distribute_overlap 0
> > > > > > type: plex
> > > > > > 0-cells: 21 21
> > > > > > 1-cells: 45 45
> > > > > > 2-cells: 25 25
> > > > > > Labels:
> > (21), 1
> > > (45), 2
> > > > (25))
> > (21),
> > > 1 (45),
> > > > 3 (25))
> (21))
> > (1 (10))
> > > > > > and get larger local meshes with overlap
> = 1
> > > > > > -dm_distribute -dm_distribute_overlap 1
> > > > > > type: plex
> > > > > > 0-cells: 29 29
> > > > > > 1-cells: 65 65
> > > > > > 2-cells: 37 37
> > > > > > Labels:
> > (29), 1
> > > (65), 2
> > > > (37))
> > (29),
> > > 1 (65),
> > > > 3 (37))
> (27))
> > (1 (13))
> > > > > > Thanks,
> > > > > > Matt
> > > > > > On Wed, Mar 31, 2021 at 12:22 PM Nicolas
> > Barral
> > <mailto:nicolas.barral at math.u-bordeaux.fr>>>
> > <mailto:nicolas.barral at math.u-bordeaux.fr>>>>
> > <mailto:nicolas.barral at math.u-bordeaux.fr>>>>>> wrote:
> > > > > > Nicolas
> > > > > > On 31/03/2021 17:51, Matthew Knepley
> > wrote:
> > > > > > > On Sat, Mar 27, 2021 at 9:27 AM
> > Nicolas
> > > Barral
> > <mailto:nicolas.barral at math.u-bordeaux.fr>>>>>>> wrote:
> > > > > > > Hi all,
> > > > > > > First, I'm not sure I
> understand
> > > what the
> > > > overlap
> > > > > > parameter in
> > > > > > > DMPlexDistributeOverlap does.
> I
> > > tried the
> > > > following:
> > > > > > generate a small
> > > > > > > mesh on 1 rank with
> > > DMPlexCreateBoxMesh, then
> > > > > distribute
> > > > > > it with
> > > > > > > DMPlexDistribute. At this
> point I
> > > have two nice
> > > > > > partitions, with shared
> > > > > > > vertices and no overlapping
> > cells.
> > > Then I call
> > > > > > > with the overlap parameter
> > set to 0
> > > or 1,
> > > > and get the
> > > > > > same resulting
> > > > > > > plex in both cases. Why is
> that ?
> > > > > > > The overlap parameter says how
> > many cell
> > > > adjacencies to go
> > > > > > out. You
> > > > > > > should not get the same
> > > > > > > mesh out. We have lots of
> > examples that use
> > > > this. If
> > > > > you send
> > > > > > your small
> > > > > > > example, I can probably
> > > > > > > tell you what is happening.
> > > > > > Ok so I do have a small example on
> > that and the
> > > > DMClone
> > > > > thing I
> > > > > > set up
> > > > > > to understand! I attach it to the
> email.
> > > > > > For the overlap, you can change the
> > overlap
> > > > constant at
> > > > > the top
> > > > > > of the
> > > > > > file. With OVERLAP=0 or 1, the
> > distributed
> > > > overlapping mesh
> > > > > > (shown using
> > > > > > -over_dm_view, it's DMover) are the
> > same, and
> > > > different
> > > > > from the
> > > > > > mesh
> > > > > > before distributing the overlap
> > (shown using
> > > > > -distrib_dm_view). For
> > > > > > larger overlap values they're
> different.
> > > > > > The process is:
> > > > > > 1/ create a DM dm on 1 rank
> > > > > > 2/ clone dm into dm2
> > > > > > 3/ distribute dm
> > > > > > 4/ clone dm into dm3
> > > > > > 5/ distribute dm overlap
> > > > > > I print all the DMs after each step.
> > dm has a
> > > > distributed
> > > > > > overlap, dm2
> > > > > > is not distributed, dm3 is
> > distributed but
> > > without
> > > > > overlap. Since
> > > > > > distribute and distributeOverlap
> > create new
> > > DMs, I
> > > > don't seem
> > > > > > have a
> > > > > > problem with the shallow copies.
> > > > > > > Second, I'm wondering what
> > would be
> > > a good
> > > > way to
> > > > > handle
> > > > > > two overlaps
> > > > > > > and associated local vectors.
> > In my
> > > adaptation
> > > > > code, the
> > > > > > remeshing
> > > > > > > library requires a
> > non-overlapping mesh,
> > > > while the
> > > > > > refinement criterion
> > > > > > > computation is based on
> hessian
> > > > computations, which
> > > > > > require a layer of
> > > > > > > overlap. What I can do is
> > clone the
> > > dm before
> > > > > > distributing the overlap,
> > > > > > > then manage two independent
> plex
> > > objects with
> > > > > their own
> > > > > > local sections
> > > > > > > etc. and copy/trim local
> vectors
> > > manually.
> > > > Is there a
> > > > > > more automatic
> > > > > > > way
> > > > > > > to do this ?
> > > > > > > DMClone() is a shallow copy, so
> that
> > > will not work.
> > > > > You would
> > > > > > maintain
> > > > > > > two different Plexes, overlapping
> > > > > > > and non-overlapping, with their
> > own sections
> > > > and vecs. Are
> > > > > > you sure you
> > > > > > > need to keep around the
> > non-overlapping one?
> > > > > > > Maybe if I understood what
> operations
> > > you want
> > > > to work, I
> > > > > > could say
> > > > > > > something more definitive.
> > > > to the
> > > > > > remesher. I
> > > > > > can either maintain 2 plexes, or
> > trim the
> > > overlapping
> > > > > plex when
> > > > > > I create
> > > > > > the arrays I give to the remesher.
> > I'm not sure
> > > > which is the
> > > > > > best/worst ?
> > > > > > Thanks
> > > > > > Nicolas
> > > > > > > Thanks,
> > > > > > > Matt
> > > > > > > Thanks
> > > > > > > Nicolas
> > > > > > > What most experimenters take for
> > granted
> > > before
> > > > they
> > > > > begin their
> > > > > > > experiments is infinitely more
> > > interesting than any
> > > > > results
> > > > > > to which
> > > > > > > their experiments lead.
> > > > > > > -- Norbert Wiener
> http://www.cse.buffalo.edu/~knepley/>
> > > > > > What most experimenters take for granted
> > before
> > > they
> > > > begin their
> > > > results
> > > > > to which
> > > > > > -- Norbert Wiener
> > > > > > <http://www.cse.buffalo.edu/~knepley/>
> before
> > > they begin
> > > > their
> > > > > > experiments is infinitely more interesting
> > than any
> > > > results to which
> > > > > > -- Norbert Wiener
> > > > > What most experimenters take for granted before
> > they begin
> > > their
> > > > > experiments is infinitely more interesting than any
> > > results to which
> > > > > -- Norbert Wiener
> > > > What most experimenters take for granted before they begin
> > their
> > results to which
> > > > -- Norbert Wiener
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> which
> > > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/9555c4a8/attachment-0001.html>
