[petsc-users] DMPlex overlap
Wed Mar 31 13:10:05 CDT 2021
On Wed, Mar 31, 2021 at 1:41 PM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> Thanks Matt, but sorry I still don't get it. Why does:
> static char help[] = "Tests plex distribution and overlaps.\n";
> #include <petsc/private/dmpleximpl.h>
> int main (int argc, char * argv[]) {
>    DM             dm;
>    MPI_Comm       comm;
>    PetscErrorCode ierr;
>    ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr) return ierr;
>    comm = PETSC_COMM_WORLD;
>    ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL,
> NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
>    ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
>    ierr = PetscObjectSetName((PetscObject) dm, "Initial DM");CHKERRQ(ierr);
>    ierr = DMViewFromOptions(dm, NULL, "-initial_dm_view");CHKERRQ(ierr);
>    ierr = DMDestroy(&dm);CHKERRQ(ierr);
>    ierr = PetscFinalize();
>    return ierr;
> called with mpiexec -n 2 ./test_overlapV2 -initial_dm_view
> -dm_plex_box_faces 5,5 -dm_distribute -dm_distribute_overlap 0
> give
> DM Object: Initial DM 2 MPI processes
>    type: plex
> Initial DM in 2 dimensions:
>    0-cells: 21 21
>    1-cells: 45 45
>    2-cells: 25 25
> Labels:
>    depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
>    celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
>    marker: 1 strata with value/size (1 (21))
>    Face Sets: 1 strata with value/size (1 (10))
> which is what I expect, while
>    DM             dm, odm;
>    MPI_Comm       comm;
>    odm = dm;
This is just setting pointers, so no copy.
>    DMPlexDistributeOverlap(odm, 0, NULL, &dm);
Here you have overwritten the DM here. Don't do this.
     Matt
>    if (!dm) {printf("Big problem\n"); dm = odm;}
>    else     {DMDestroy(&odm);}
>    return ierr;
> called with mpiexec -n 2 ./test_overlapV3 -initial_dm_view
> gives:
>    type: plex
>    0-cells: 29 29
>    1-cells: 65 65
>    2-cells: 37 37
> Labels:
>    depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
>    celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
>    marker: 1 strata with value/size (1 (27))
>    Face Sets: 1 strata with value/size (1 (13))
> which is not what I expect ?
> Thanks,
> Nicolas
> On 31/03/2021 19:02, Matthew Knepley wrote:
> > Alright, I think the problem had to do with keeping track of what DM you
> > were looking at. This code increases the overlap of an initial DM:
> >    DM             dm, dm2;
> >    PetscInt       overlap;
> >    MPI_Comm       comm;
> ierr;
> DM");CHKERRQ(ierr);
> >    ierr = DMPlexGetOverlap(dm, &overlap);CHKERRQ(ierr);
> >    ierr = DMPlexDistributeOverlap(dm, overlap+1, NULL,
> &dm2);CHKERRQ(ierr);
> >    ierr = PetscObjectSetName((PetscObject) dm2, "More Overlap
> > DM");CHKERRQ(ierr);
> >    ierr = DMViewFromOptions(dm2, NULL, "-over_dm_view");CHKERRQ(ierr);
> >    ierr = DMDestroy(&dm2);CHKERRQ(ierr);
> >    return ierr;
> > and when we run it we get the expected result
> > master *:~/Downloads/tmp/Nicolas$ /PETSc3/petsc/apple/bin/mpiexec -n 2
> > ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5 -dm_distribute
> > -dm_distribute_overlap 1 -over_dm_view
> >    type: plex
> >    0-cells: 29 29
> >    1-cells: 65 65
> >    2-cells: 37 37
> > Labels:
> > DM Object: More Overlap DM 2 MPI processes
> >    type: plex
> > More Overlap DM in 2 dimensions:
> >    0-cells: 36 36
> >    1-cells: 85 85
> >    2-cells: 50 50
> > Labels:
> >    depth: 3 strata with value/size (0 (36), 1 (85), 2 (50))
> >    celltype: 3 strata with value/size (0 (36), 1 (85), 3 (50))
> >    marker: 1 strata with value/size (1 (40))
> >    Face Sets: 1 strata with value/size (1 (20))
> >    Thanks,
> >       Matt
> > On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley <knepley at gmail.com
> > <mailto:knepley at gmail.com>> wrote:
> >     Okay, let me show a really simple example that gives the expected
> >     result before I figure out what is going wrong for you. This code
> >        DM                    dm;
> >        MPI_Comm       comm;
> >     ierr;
> >     DM");CHKERRQ(ierr);
> >        return ierr;
> >     can do all the overlap tests. For example, you can run it naively
> >     and get a serial mesh
> >     2 ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5
> >        type: plex
> >        0-cells: 36 0
> >        1-cells: 85 0
> >        2-cells: 50 0
> >     Labels:
> >        celltype: 3 strata with value/size (0 (36), 3 (50), 1 (85))
> >     Then run it telling Plex to distribute after creating the mesh
> -dm_distribute
> >        type: plex
> >        0-cells: 21 21
> >        1-cells: 45 45
> >        2-cells: 25 25
> >     Labels:
> >     The get the same thing back with overlap = 0
> >        type: plex
> >        0-cells: 21 21
> >        1-cells: 45 45
> >        2-cells: 25 25
> >     Labels:
> >     and get larger local meshes with overlap = 1
> >     -dm_distribute -dm_distribute_overlap 1
> >        type: plex
> >        0-cells: 29 29
> >        1-cells: 65 65
> >        2-cells: 37 37
> >     Labels:
> >        Thanks,
> >           Matt
> >     On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral
> >     <nicolas.barral at math.u-bordeaux.fr
> >     <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> >         Nicolas
> >         On 31/03/2021 17:51, Matthew Knepley wrote:
> >          > On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
> >         <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
> >          >     Hi all,
> >          >     First, I'm not sure I understand what the overlap
> >         parameter in
> >          >     DMPlexDistributeOverlap does. I tried the following:
> >         generate a small
> >          >     mesh on 1 rank with DMPlexCreateBoxMesh, then distribute
> >         it with
> >          >     DMPlexDistribute. At this point I have two nice
> >         partitions, with shared
> >          >     vertices and no overlapping cells. Then I call
> >          >     with the overlap parameter set to 0 or 1, and get the
> >         same resulting
> >          >     plex in both cases. Why is that ?
> >          > The overlap parameter says how many cell adjacencies to go
> >         out. You
> >          > should not get the same
> >          > mesh out. We have lots of examples that use this. If you send
> >         your small
> >          > example, I can probably
> >          > tell you what is happening.
> >         Ok so I do have a small example on that and the DMClone thing I
> >         set up
> >         to understand! I attach it to the email.
> >         For the overlap, you can change the overlap constant at the top
> >         of the
> >         file. With OVERLAP=0 or 1, the distributed overlapping mesh
> >         (shown using
> >         -over_dm_view, it's DMover) are the same, and different from the
> >         mesh
> >         before distributing the overlap (shown using -distrib_dm_view).
> For
> >         larger overlap values they're different.
> >         The process is:
> >         1/ create a DM dm on 1 rank
> >         2/ clone dm into dm2
> >         3/ distribute dm
> >         4/ clone dm into dm3
> >         5/ distribute dm overlap
> >         I print all the DMs after each step. dm has a distributed
> >         overlap, dm2
> >         is not distributed, dm3 is distributed but without overlap. Since
> >         distribute and distributeOverlap create new DMs, I don't seem
> >         have a
> >         problem with the shallow copies.
> >          >     Second, I'm wondering what would be a good way to handle
> >         two overlaps
> >          >     and associated local vectors. In my adaptation code, the
> >         remeshing
> >          >     library requires a non-overlapping mesh, while the
> >         refinement criterion
> >          >     computation is based on hessian computations, which
> >         require a layer of
> >          >     overlap. What I can do is clone the dm before
> >         distributing the overlap,
> >          >     then manage two independent plex objects with their own
> >         local sections
> >          >     etc. and copy/trim local vectors manually. Is there a
> >         more automatic
> >          >     way
> >          >     to do this ?
> >          > DMClone() is a shallow copy, so that will not work. You would
> >         maintain
> >          > two different Plexes, overlapping
> >          > and non-overlapping, with their own sections and vecs. Are
> >         you sure you
> >          > need to keep around the non-overlapping one?
> >          > Maybe if I understood what operations you want to work, I
> >         could say
> >          > something more definitive.
> >         I need to be able to pass the non-overlapping mesh to the
> >         remesher. I
> >         can either maintain 2 plexes, or trim the overlapping plex when
> >         I create
> >         the arrays I give to the remesher. I'm not sure which is the
> >         best/worst ?
> >         Thanks
> >         Nicolas
> >          >    Thanks,
> >          >       Matt
> >          >     Thanks
> >          >     Nicolas
> >          > What most experimenters take for granted before they begin
> their
> >          > experiments is infinitely more interesting than any results
> >         to which
> >          > their experiments lead.
> >          > -- Norbert Wiener
> >          > https://www.cse.buffalo.edu/~knepley/
> >         <http://www.cse.buffalo.edu/~knepley/>
> >     What most experimenters take for granted before they begin their
> >     experiments is infinitely more interesting than any results to which
> >     -- Norbert Wiener
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/bb89da24/attachment-0001.html>
