[petsc-users] DMPlex overlap
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Wed Mar 31 13:59:03 CDT 2021
On 31/03/2021 20:10, Matthew Knepley wrote:
> On Wed, Mar 31, 2021 at 1:41 PM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> Thanks Matt, but sorry I still don't get it. Why does:
> static char help[] = "Tests plex distribution and overlaps.\n";
> #include <petsc/private/dmpleximpl.h>
> int main (int argc, char * argv[]) {
> DM dm;
> MPI_Comm comm;
> PetscErrorCode ierr;
> ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr)
> return ierr;
> comm = PETSC_COMM_WORLD;
> ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL,
> NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
> ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) dm, "Initial
> DM");CHKERRQ(ierr);
> ierr = DMViewFromOptions(dm, NULL,
> "-initial_dm_view");CHKERRQ(ierr);
> ierr = DMDestroy(&dm);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return ierr;
> called with mpiexec -n 2 ./test_overlapV2 -initial_dm_view
> -dm_plex_box_faces 5,5 -dm_distribute -dm_distribute_overlap 0
> give
> DM Object: Initial DM 2 MPI processes
> type: plex
> Initial DM in 2 dimensions:
> 0-cells: 21 21
> 1-cells: 45 45
> 2-cells: 25 25
> Labels:
> depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
> celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
> marker: 1 strata with value/size (1 (21))
> Face Sets: 1 strata with value/size (1 (10))
> which is what I expect, while
> DM dm, odm;
> MPI_Comm comm;
> return ierr;
> odm = dm;
> This is just setting pointers, so no copy.
> DMPlexDistributeOverlap(odm, 0, NULL, &dm);
> Here you have overwritten the DM here. Don't do this.
I just copied what's in plex ex19!
But ok if I change for:
DM dm, odm;
MPI_Comm comm;
ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr) return ierr;
DMPlexDistributeOverlap(dm, 0, NULL, &odm);
ierr = PetscObjectSetName((PetscObject) odm, "Initial DM");CHKERRQ(ierr);
ierr = DMViewFromOptions(odm, NULL, "-initial_dm_view");CHKERRQ(ierr);
ierr = DMDestroy(&odm);CHKERRQ(ierr);
return ierr;
I still get:
type: plex
0-cells: 29 29
1-cells: 65 65
2-cells: 37 37
Labels:
depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
marker: 1 strata with value/size (1 (27))
Face Sets: 1 strata with value/size (1 (13))
which is the mesh with a 1-overlap. So what's wrong now ?
Nicolas
> Thanks,
> Matt
> if (!dm) {printf("Big problem\n"); dm = odm;}
> else {DMDestroy(&odm);}
> DM");CHKERRQ(ierr);
> return ierr;
> called with mpiexec -n 2 ./test_overlapV3 -initial_dm_view
> gives:
> type: plex
> 0-cells: 29 29
> 1-cells: 65 65
> 2-cells: 37 37
> Labels:
> which is not what I expect ?
> Thanks,
> Nicolas
> On 31/03/2021 19:02, Matthew Knepley wrote:
> > Alright, I think the problem had to do with keeping track of what
> DM you
> > were looking at. This code increases the overlap of an initial DM:
> > DM dm, dm2;
> > PetscInt overlap;
> > MPI_Comm comm;
> return ierr;
> DM");CHKERRQ(ierr);
> > ierr = DMPlexGetOverlap(dm, &overlap);CHKERRQ(ierr);
> > ierr = DMPlexDistributeOverlap(dm, overlap+1, NULL,
> &dm2);CHKERRQ(ierr);
> > ierr = PetscObjectSetName((PetscObject) dm2, "More Overlap
> > DM");CHKERRQ(ierr);
> > ierr = DMViewFromOptions(dm2, NULL,
> "-over_dm_view");CHKERRQ(ierr);
> > ierr = DMDestroy(&dm2);CHKERRQ(ierr);
> > return ierr;
> > and when we run it we get the expected result
> > master *:~/Downloads/tmp/Nicolas$ /PETSc3/petsc/apple/bin/mpiexec
> -n 2
> > ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5
> -dm_distribute
> > -dm_distribute_overlap 1 -over_dm_view
> > type: plex
> > 0-cells: 29 29
> > 1-cells: 65 65
> > 2-cells: 37 37
> > Labels:
> > DM Object: More Overlap DM 2 MPI processes
> > type: plex
> > More Overlap DM in 2 dimensions:
> > 0-cells: 36 36
> > 1-cells: 85 85
> > 2-cells: 50 50
> > Labels:
> > depth: 3 strata with value/size (0 (36), 1 (85), 2 (50))
> > celltype: 3 strata with value/size (0 (36), 1 (85), 3 (50))
> > marker: 1 strata with value/size (1 (40))
> > Face Sets: 1 strata with value/size (1 (20))
> > Thanks,
> > Matt
> > On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley
> <knepley at gmail.com <mailto:knepley at gmail.com>
> > <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>> wrote:
> > Okay, let me show a really simple example that gives the expected
> > result before I figure out what is going wrong for you. This code
> > DM dm;
> > MPI_Comm comm;
> return
> > ierr;
> NULL, NULL,
> > DM");CHKERRQ(ierr);
> > return ierr;
> > can do all the overlap tests. For example, you can run it naively
> > and get a serial mesh
> /PETSc3/petsc/apple/bin/mpiexec -n
> > 2 ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5
> > type: plex
> > 0-cells: 36 0
> > 1-cells: 85 0
> > 2-cells: 50 0
> > Labels:
> > celltype: 3 strata with value/size (0 (36), 3 (50), 1 (85))
> > Then run it telling Plex to distribute after creating the mesh
> -dm_distribute
> > type: plex
> > 0-cells: 21 21
> > 1-cells: 45 45
> > 2-cells: 25 25
> > Labels:
> > The get the same thing back with overlap = 0
> > type: plex
> > 0-cells: 21 21
> > 1-cells: 45 45
> > 2-cells: 25 25
> > Labels:
> > and get larger local meshes with overlap = 1
> > -dm_distribute -dm_distribute_overlap 1
> > type: plex
> > 0-cells: 29 29
> > 1-cells: 65 65
> > 2-cells: 37 37
> > Labels:
> > Thanks,
> > Matt
> > On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral
> <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
> > Nicolas
> > On 31/03/2021 17:51, Matthew Knepley wrote:
> > > On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
> <mailto:nicolas.barral at math.u-bordeaux.fr>>>> wrote:
> > > Hi all,
> > > First, I'm not sure I understand what the overlap
> > parameter in
> > > DMPlexDistributeOverlap does. I tried the following:
> > generate a small
> > > mesh on 1 rank with DMPlexCreateBoxMesh, then
> distribute
> > it with
> > > DMPlexDistribute. At this point I have two nice
> > partitions, with shared
> > > vertices and no overlapping cells. Then I call
> > > with the overlap parameter set to 0 or 1, and get the
> > same resulting
> > > plex in both cases. Why is that ?
> > > The overlap parameter says how many cell adjacencies to go
> > out. You
> > > should not get the same
> > > mesh out. We have lots of examples that use this. If
> you send
> > your small
> > > example, I can probably
> > > tell you what is happening.
> > Ok so I do have a small example on that and the DMClone
> thing I
> > set up
> > to understand! I attach it to the email.
> > For the overlap, you can change the overlap constant at
> the top
> > of the
> > file. With OVERLAP=0 or 1, the distributed overlapping mesh
> > (shown using
> > -over_dm_view, it's DMover) are the same, and different
> from the
> > mesh
> > before distributing the overlap (shown using
> -distrib_dm_view). For
> > larger overlap values they're different.
> > The process is:
> > 1/ create a DM dm on 1 rank
> > 2/ clone dm into dm2
> > 3/ distribute dm
> > 4/ clone dm into dm3
> > 5/ distribute dm overlap
> > I print all the DMs after each step. dm has a distributed
> > overlap, dm2
> > is not distributed, dm3 is distributed but without
> overlap. Since
> > distribute and distributeOverlap create new DMs, I don't seem
> > have a
> > problem with the shallow copies.
> > > Second, I'm wondering what would be a good way to
> handle
> > two overlaps
> > > and associated local vectors. In my adaptation
> code, the
> > remeshing
> > > library requires a non-overlapping mesh, while the
> > refinement criterion
> > > computation is based on hessian computations, which
> > require a layer of
> > > overlap. What I can do is clone the dm before
> > distributing the overlap,
> > > then manage two independent plex objects with
> their own
> > local sections
> > > etc. and copy/trim local vectors manually. Is there a
> > more automatic
> > > way
> > > to do this ?
> > > DMClone() is a shallow copy, so that will not work.
> You would
> > maintain
> > > two different Plexes, overlapping
> > > and non-overlapping, with their own sections and vecs. Are
> > you sure you
> > > need to keep around the non-overlapping one?
> > > Maybe if I understood what operations you want to work, I
> > could say
> > > something more definitive.
> > I need to be able to pass the non-overlapping mesh to the
> > remesher. I
> > can either maintain 2 plexes, or trim the overlapping
> plex when
> > I create
> > the arrays I give to the remesher. I'm not sure which is the
> > best/worst ?
> > Thanks
> > Nicolas
> > > Thanks,
> > > Matt
> > > Thanks
> > > Nicolas
> > > What most experimenters take for granted before they
> begin their
> > > experiments is infinitely more interesting than any
> results
> > to which
> > > their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > <http://www.cse.buffalo.edu/~knepley/>
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results
> to which
> > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
