[petsc-users] DMPlex overlap
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Wed Mar 31 12:41:52 CDT 2021
Thanks Matt, but sorry I still don't get it. Why does:
static char help[] = "Tests plex distribution and overlaps.\n";
#include <petsc/private/dmpleximpl.h>
int main (int argc, char * argv[]) {
DM dm;
MPI_Comm comm;
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr) return ierr;
comm = PETSC_COMM_WORLD;
ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL,
NULL, PETSC_TRUE, &dm);CHKERRQ(ierr);
ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
ierr = PetscObjectSetName((PetscObject) dm, "Initial DM");CHKERRQ(ierr);
ierr = DMViewFromOptions(dm, NULL, "-initial_dm_view");CHKERRQ(ierr);
ierr = DMDestroy(&dm);CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
called with mpiexec -n 2 ./test_overlapV2 -initial_dm_view
-dm_plex_box_faces 5,5 -dm_distribute -dm_distribute_overlap 0
give
DM Object: Initial DM 2 MPI processes
type: plex
Initial DM in 2 dimensions:
0-cells: 21 21
1-cells: 45 45
2-cells: 25 25
Labels:
depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
marker: 1 strata with value/size (1 (21))
Face Sets: 1 strata with value/size (1 (10))
which is what I expect, while
DM dm, odm;
MPI_Comm comm;
odm = dm;
DMPlexDistributeOverlap(odm, 0, NULL, &dm);
if (!dm) {printf("Big problem\n"); dm = odm;}
else {DMDestroy(&odm);}
return ierr;
called with mpiexec -n 2 ./test_overlapV3 -initial_dm_view
gives:
type: plex
0-cells: 29 29
1-cells: 65 65
2-cells: 37 37
Labels:
depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
marker: 1 strata with value/size (1 (27))
Face Sets: 1 strata with value/size (1 (13))
which is not what I expect ?
Nicolas
On 31/03/2021 19:02, Matthew Knepley wrote:
> Alright, I think the problem had to do with keeping track of what DM you
> were looking at. This code increases the overlap of an initial DM:
> DM dm, dm2;
> PetscInt overlap;
> MPI_Comm comm;
> ierr = DMPlexGetOverlap(dm, &overlap);CHKERRQ(ierr);
> ierr = DMPlexDistributeOverlap(dm, overlap+1, NULL, &dm2);CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) dm2, "More Overlap
> DM");CHKERRQ(ierr);
> ierr = DMViewFromOptions(dm2, NULL, "-over_dm_view");CHKERRQ(ierr);
> ierr = DMDestroy(&dm2);CHKERRQ(ierr);
> return ierr;
> and when we run it we get the expected result
> master *:~/Downloads/tmp/Nicolas$ /PETSc3/petsc/apple/bin/mpiexec -n 2
> ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5 -dm_distribute
> -dm_distribute_overlap 1 -over_dm_view
> type: plex
> 0-cells: 29 29
> 1-cells: 65 65
> 2-cells: 37 37
> Labels:
> DM Object: More Overlap DM 2 MPI processes
> type: plex
> More Overlap DM in 2 dimensions:
> 0-cells: 36 36
> 1-cells: 85 85
> 2-cells: 50 50
> Labels:
> depth: 3 strata with value/size (0 (36), 1 (85), 2 (50))
> celltype: 3 strata with value/size (0 (36), 1 (85), 3 (50))
> marker: 1 strata with value/size (1 (40))
> Face Sets: 1 strata with value/size (1 (20))
> Thanks,
> Matt
> On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> Okay, let me show a really simple example that gives the expected
> result before I figure out what is going wrong for you. This code
> DM dm;
> MPI_Comm comm;
> ierr;
> DM");CHKERRQ(ierr);
> return ierr;
> can do all the overlap tests. For example, you can run it naively
> and get a serial mesh
> 2 ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5
> type: plex
> 0-cells: 36 0
> 1-cells: 85 0
> 2-cells: 50 0
> Labels:
> celltype: 3 strata with value/size (0 (36), 3 (50), 1 (85))
> Then run it telling Plex to distribute after creating the mesh
> 2 ./test_overlap -initial_dm_view -dm_plex_box_faces 5,5 -dm_distribute
> type: plex
> 0-cells: 21 21
> 1-cells: 45 45
> 2-cells: 25 25
> Labels:
> The get the same thing back with overlap = 0
> type: plex
> 0-cells: 21 21
> 1-cells: 45 45
> 2-cells: 25 25
> Labels:
> and get larger local meshes with overlap = 1
> -dm_distribute -dm_distribute_overlap 1
> type: plex
> 0-cells: 29 29
> 1-cells: 65 65
> 2-cells: 37 37
> Labels:
> Thanks,
> Matt
> On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> Nicolas
> On 31/03/2021 17:51, Matthew Knepley wrote:
> > On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
> <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
> > Hi all,
> > First, I'm not sure I understand what the overlap
> parameter in
> > DMPlexDistributeOverlap does. I tried the following:
> generate a small
> > mesh on 1 rank with DMPlexCreateBoxMesh, then distribute
> it with
> > DMPlexDistribute. At this point I have two nice
> partitions, with shared
> > vertices and no overlapping cells. Then I call
> > with the overlap parameter set to 0 or 1, and get the
> same resulting
> > plex in both cases. Why is that ?
> > The overlap parameter says how many cell adjacencies to go
> out. You
> > should not get the same
> > mesh out. We have lots of examples that use this. If you send
> your small
> > example, I can probably
> > tell you what is happening.
> Ok so I do have a small example on that and the DMClone thing I
> set up
> to understand! I attach it to the email.
> For the overlap, you can change the overlap constant at the top
> of the
> file. With OVERLAP=0 or 1, the distributed overlapping mesh
> (shown using
> -over_dm_view, it's DMover) are the same, and different from the
> mesh
> before distributing the overlap (shown using -distrib_dm_view). For
> larger overlap values they're different.
> The process is:
> 1/ create a DM dm on 1 rank
> 2/ clone dm into dm2
> 3/ distribute dm
> 4/ clone dm into dm3
> 5/ distribute dm overlap
> I print all the DMs after each step. dm has a distributed
> overlap, dm2
> is not distributed, dm3 is distributed but without overlap. Since
> distribute and distributeOverlap create new DMs, I don't seem
> have a
> problem with the shallow copies.
> > Second, I'm wondering what would be a good way to handle
> two overlaps
> > and associated local vectors. In my adaptation code, the
> remeshing
> > library requires a non-overlapping mesh, while the
> refinement criterion
> > computation is based on hessian computations, which
> require a layer of
> > overlap. What I can do is clone the dm before
> distributing the overlap,
> > then manage two independent plex objects with their own
> local sections
> > etc. and copy/trim local vectors manually. Is there a
> more automatic
> > way
> > to do this ?
> > DMClone() is a shallow copy, so that will not work. You would
> maintain
> > two different Plexes, overlapping
> > and non-overlapping, with their own sections and vecs. Are
> you sure you
> > need to keep around the non-overlapping one?
> > Maybe if I understood what operations you want to work, I
> could say
> > something more definitive.
> I need to be able to pass the non-overlapping mesh to the
> remesher. I
> can either maintain 2 plexes, or trim the overlapping plex when
> I create
> the arrays I give to the remesher. I'm not sure which is the
> best/worst ?
> Thanks
> Nicolas
> > Thanks,
> > Matt
> > Thanks
> > Nicolas
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results
> to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
