[petsc-users] DMPlex overlap
Matthew Knepley
knepley at gmail.com
Wed Mar 31 12:02:31 CDT 2021
Alright, I think the problem had to do with keeping track of what DM you
were looking at. This code increases the overlap of an initial DM:
static char help[] = "Tests plex distribution and overlaps.\n";
#include <petsc/private/dmpleximpl.h>
int main (int argc, char * argv[]) {
DM dm, dm2;
PetscInt overlap;
MPI_Comm comm;
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr) return ierr;
comm = PETSC_COMM_WORLD;
ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL, NULL,
PETSC_TRUE, &dm);CHKERRQ(ierr);
ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
ierr = PetscObjectSetName((PetscObject) dm, "Initial DM");CHKERRQ(ierr);
ierr = DMViewFromOptions(dm, NULL, "-initial_dm_view");CHKERRQ(ierr);
ierr = DMPlexGetOverlap(dm, &overlap);CHKERRQ(ierr);
ierr = DMPlexDistributeOverlap(dm, overlap+1, NULL, &dm2);CHKERRQ(ierr);
ierr = PetscObjectSetName((PetscObject) dm2, "More Overlap
DM");CHKERRQ(ierr);
ierr = DMViewFromOptions(dm2, NULL, "-over_dm_view");CHKERRQ(ierr);
ierr = DMDestroy(&dm2);CHKERRQ(ierr);
ierr = DMDestroy(&dm);CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
and when we run it we get the expected result
master *:~/Downloads/tmp/Nicolas$ /PETSc3/petsc/apple/bin/mpiexec -n 2
./test_overlap -initial_dm_view -dm_plex_box_faces 5,5 -dm_distribute
-dm_distribute_overlap 1 -over_dm_view
DM Object: Initial DM 2 MPI processes
type: plex
Initial DM in 2 dimensions:
0-cells: 29 29
1-cells: 65 65
2-cells: 37 37
Labels:
depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
marker: 1 strata with value/size (1 (27))
Face Sets: 1 strata with value/size (1 (13))
DM Object: More Overlap DM 2 MPI processes
type: plex
More Overlap DM in 2 dimensions:
0-cells: 36 36
1-cells: 85 85
2-cells: 50 50
Labels:
depth: 3 strata with value/size (0 (36), 1 (85), 2 (50))
celltype: 3 strata with value/size (0 (36), 1 (85), 3 (50))
marker: 1 strata with value/size (1 (40))
Face Sets: 1 strata with value/size (1 (20))
Matt
On Wed, Mar 31, 2021 at 12:57 PM Matthew Knepley <knepley at gmail.com> wrote:
> Okay, let me show a really simple example that gives the expected result
> before I figure out what is going wrong for you. This code
> DM dm;
> MPI_Comm comm;
> return ierr;
> can do all the overlap tests. For example, you can run it naively and get
> a serial mesh
> type: plex
> 0-cells: 36 0
> 1-cells: 85 0
> 2-cells: 50 0
> Labels:
> celltype: 3 strata with value/size (0 (36), 3 (50), 1 (85))
> Then run it telling Plex to distribute after creating the mesh
> type: plex
> 0-cells: 21 21
> 1-cells: 45 45
> 2-cells: 25 25
> Labels:
> depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
> celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
> marker: 1 strata with value/size (1 (21))
> Face Sets: 1 strata with value/size (1 (10))
> The get the same thing back with overlap = 0
> -dm_distribute_overlap 0
> type: plex
> 0-cells: 21 21
> 1-cells: 45 45
> 2-cells: 25 25
> Labels:
> and get larger local meshes with overlap = 1
> type: plex
> 0-cells: 29 29
> 1-cells: 65 65
> 2-cells: 37 37
> Labels:
> Thanks,
> Matt
> On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral <
> nicolas.barral at math.u-bordeaux.fr> wrote:
>> Nicolas
>> On 31/03/2021 17:51, Matthew Knepley wrote:
>> > On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
>> > <nicolas.barral at math.u-bordeaux.fr
>> > <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>> > Hi all,
>> > First, I'm not sure I understand what the overlap parameter in
>> > DMPlexDistributeOverlap does. I tried the following: generate a
>> small
>> > mesh on 1 rank with DMPlexCreateBoxMesh, then distribute it with
>> > DMPlexDistribute. At this point I have two nice partitions, with
>> shared
>> > vertices and no overlapping cells. Then I call
>> > with the overlap parameter set to 0 or 1, and get the same resulting
>> > plex in both cases. Why is that ?
>> > The overlap parameter says how many cell adjacencies to go out. You
>> > should not get the same
>> > mesh out. We have lots of examples that use this. If you send your
>> small
>> > example, I can probably
>> > tell you what is happening.
>> Ok so I do have a small example on that and the DMClone thing I set up
>> to understand! I attach it to the email.
>> For the overlap, you can change the overlap constant at the top of the
>> file. With OVERLAP=0 or 1, the distributed overlapping mesh (shown using
>> -over_dm_view, it's DMover) are the same, and different from the mesh
>> before distributing the overlap (shown using -distrib_dm_view). For
>> larger overlap values they're different.
>> The process is:
>> 1/ create a DM dm on 1 rank
>> 2/ clone dm into dm2
>> 3/ distribute dm
>> 4/ clone dm into dm3
>> 5/ distribute dm overlap
>> I print all the DMs after each step. dm has a distributed overlap, dm2
>> is not distributed, dm3 is distributed but without overlap. Since
>> distribute and distributeOverlap create new DMs, I don't seem have a
>> problem with the shallow copies.
>> > Second, I'm wondering what would be a good way to handle two
>> overlaps
>> > and associated local vectors. In my adaptation code, the remeshing
>> > library requires a non-overlapping mesh, while the refinement
>> criterion
>> > computation is based on hessian computations, which require a layer
>> of
>> > overlap. What I can do is clone the dm before distributing the
>> overlap,
>> > then manage two independent plex objects with their own local
>> sections
>> > etc. and copy/trim local vectors manually. Is there a more automatic
>> > way
>> > to do this ?
>> > DMClone() is a shallow copy, so that will not work. You would maintain
>> > two different Plexes, overlapping
>> > and non-overlapping, with their own sections and vecs. Are you sure you
>> > need to keep around the non-overlapping one?
>> > Maybe if I understood what operations you want to work, I could say
>> > something more definitive.
>> I need to be able to pass the non-overlapping mesh to the remesher. I
>> can either maintain 2 plexes, or trim the overlapping plex when I create
>> the arrays I give to the remesher. I'm not sure which is the best/worst ?
>> Thanks
>> Nicolas
>> > Thanks,
>> > Matt
>> > Thanks
>> > Nicolas
>> > What most experimenters take for granted before they begin their
>> > experiments is infinitely more interesting than any results to which
>> > their experiments lead.
>> > -- Norbert Wiener
>> > https://www.cse.buffalo.edu/~knepley/ <
>> http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/970948be/attachment.html>
