[petsc-users] DMPlex overlap
Matthew Knepley
knepley at gmail.com
Wed Mar 31 11:57:02 CDT 2021
Okay, let me show a really simple example that gives the expected result
before I figure out what is going wrong for you. This code
static char help[] = "Tests plex distribution and overlaps.\n";
#include <petsc/private/dmpleximpl.h>
int main (int argc, char * argv[]) {
DM dm;
MPI_Comm comm;
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, NULL, help);if (ierr) return ierr;
comm = PETSC_COMM_WORLD;
ierr = DMPlexCreateBoxMesh(comm, 2, PETSC_TRUE, NULL, NULL, NULL, NULL,
PETSC_TRUE, &dm);CHKERRQ(ierr);
ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
ierr = PetscObjectSetName((PetscObject) dm, "Initial DM");CHKERRQ(ierr);
ierr = DMViewFromOptions(dm, NULL, "-initial_dm_view");CHKERRQ(ierr);
ierr = DMDestroy(&dm);CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
can do all the overlap tests. For example, you can run it naively and get a
serial mesh
master *:~/Downloads/tmp/Nicolas$ /PETSc3/petsc/apple/bin/mpiexec -n 2
./test_overlap -initial_dm_view -dm_plex_box_faces 5,5
DM Object: Initial DM 2 MPI processes
type: plex
Initial DM in 2 dimensions:
0-cells: 36 0
1-cells: 85 0
2-cells: 50 0
Labels:
celltype: 3 strata with value/size (0 (36), 3 (50), 1 (85))
depth: 3 strata with value/size (0 (36), 1 (85), 2 (50))
marker: 1 strata with value/size (1 (40))
Face Sets: 1 strata with value/size (1 (20))
Then run it telling Plex to distribute after creating the mesh
./test_overlap -initial_dm_view -dm_plex_box_faces 5,5 -dm_distribute
type: plex
0-cells: 21 21
1-cells: 45 45
2-cells: 25 25
Labels:
depth: 3 strata with value/size (0 (21), 1 (45), 2 (25))
celltype: 3 strata with value/size (0 (21), 1 (45), 3 (25))
marker: 1 strata with value/size (1 (21))
Face Sets: 1 strata with value/size (1 (10))
The get the same thing back with overlap = 0
-dm_distribute_overlap 0
type: plex
0-cells: 21 21
1-cells: 45 45
2-cells: 25 25
Labels:
and get larger local meshes with overlap = 1
-dm_distribute_overlap 1
type: plex
0-cells: 29 29
1-cells: 65 65
2-cells: 37 37
Labels:
depth: 3 strata with value/size (0 (29), 1 (65), 2 (37))
celltype: 3 strata with value/size (0 (29), 1 (65), 3 (37))
marker: 1 strata with value/size (1 (27))
Face Sets: 1 strata with value/size (1 (13))
Matt
On Wed, Mar 31, 2021 at 12:22 PM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> Nicolas
> On 31/03/2021 17:51, Matthew Knepley wrote:
> > On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
> > <nicolas.barral at math.u-bordeaux.fr
> > <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> > Hi all,
> > First, I'm not sure I understand what the overlap parameter in
> > DMPlexDistributeOverlap does. I tried the following: generate a small
> > mesh on 1 rank with DMPlexCreateBoxMesh, then distribute it with
> > DMPlexDistribute. At this point I have two nice partitions, with
> shared
> > vertices and no overlapping cells. Then I call
> > with the overlap parameter set to 0 or 1, and get the same resulting
> > plex in both cases. Why is that ?
> > The overlap parameter says how many cell adjacencies to go out. You
> > should not get the same
> > mesh out. We have lots of examples that use this. If you send your small
> > example, I can probably
> > tell you what is happening.
> Ok so I do have a small example on that and the DMClone thing I set up
> to understand! I attach it to the email.
> For the overlap, you can change the overlap constant at the top of the
> file. With OVERLAP=0 or 1, the distributed overlapping mesh (shown using
> -over_dm_view, it's DMover) are the same, and different from the mesh
> before distributing the overlap (shown using -distrib_dm_view). For
> larger overlap values they're different.
> The process is:
> 1/ create a DM dm on 1 rank
> 2/ clone dm into dm2
> 3/ distribute dm
> 4/ clone dm into dm3
> 5/ distribute dm overlap
> I print all the DMs after each step. dm has a distributed overlap, dm2
> is not distributed, dm3 is distributed but without overlap. Since
> distribute and distributeOverlap create new DMs, I don't seem have a
> problem with the shallow copies.
> > Second, I'm wondering what would be a good way to handle two overlaps
> > and associated local vectors. In my adaptation code, the remeshing
> > library requires a non-overlapping mesh, while the refinement
> criterion
> > computation is based on hessian computations, which require a layer
> of
> > overlap. What I can do is clone the dm before distributing the
> overlap,
> > then manage two independent plex objects with their own local
> sections
> > etc. and copy/trim local vectors manually. Is there a more automatic
> > way
> > to do this ?
> > DMClone() is a shallow copy, so that will not work. You would maintain
> > two different Plexes, overlapping
> > and non-overlapping, with their own sections and vecs. Are you sure you
> > need to keep around the non-overlapping one?
> > Maybe if I understood what operations you want to work, I could say
> > something more definitive.
> I need to be able to pass the non-overlapping mesh to the remesher. I
> can either maintain 2 plexes, or trim the overlapping plex when I create
> the arrays I give to the remesher. I'm not sure which is the best/worst ?
> Thanks
> Nicolas
> > Thanks,
> > Matt
> > Thanks
> > Nicolas
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/10d77898/attachment.html>
