[petsc-users] DMPlex overlap
Matthew Knepley
knepley at gmail.com
Wed Mar 31 10:47:21 CDT 2021
On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> Hi all,
I promise to read this today. While I am doing that, I have a branch
https://gitlab.com/petsc/petsc/-/commits/knepley/feature-plex-vertex-mapping
which I think does the face labeling you want, but I have not tested it yet.
Matt
> First, I'm not sure I understand what the overlap parameter in
> DMPlexDistributeOverlap does. I tried the following: generate a small
> mesh on 1 rank with DMPlexCreateBoxMesh, then distribute it with
> DMPlexDistribute. At this point I have two nice partitions, with shared
> vertices and no overlapping cells. Then I call DMPlexDistributeOverlap
> with the overlap parameter set to 0 or 1, and get the same resulting
> plex in both cases. Why is that ?
> Second, I'm wondering what would be a good way to handle two overlaps
> and associated local vectors. In my adaptation code, the remeshing
> library requires a non-overlapping mesh, while the refinement criterion
> computation is based on hessian computations, which require a layer of
> overlap. What I can do is clone the dm before distributing the overlap,
> then manage two independent plex objects with their own local sections
> etc. and copy/trim local vectors manually. Is there a more automatic way
> to do this ?
> Thanks
> Nicolas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/81db157b/attachment.html>
