[petsc-users] DMPlex overlap
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Wed Mar 31 10:59:30 CDT 2021
On 31/03/2021 17:47, Matthew Knepley wrote:
> On Sat, Mar 27, 2021 at 9:27 AM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> Hi all,
> I promise to read this today. While I am doing that, I have a branch
> https://gitlab.com/petsc/petsc/-/commits/knepley/feature-plex-vertex-mapping
> which I think does the face labeling you want, but I have not tested it yet.
Thanks Matt, I'll have a look later today :) I also have working code
for what I need - maybe itś time to share my branch even if it's still
in progress.
Thanks
Nicolas
> Thanks,
> Matt
> First, I'm not sure I understand what the overlap parameter in
> DMPlexDistributeOverlap does. I tried the following: generate a small
> mesh on 1 rank with DMPlexCreateBoxMesh, then distribute it with
> DMPlexDistribute. At this point I have two nice partitions, with shared
> vertices and no overlapping cells. Then I call DMPlexDistributeOverlap
> with the overlap parameter set to 0 or 1, and get the same resulting
> plex in both cases. Why is that ?
> Second, I'm wondering what would be a good way to handle two overlaps
> and associated local vectors. In my adaptation code, the remeshing
> library requires a non-overlapping mesh, while the refinement criterion
> computation is based on hessian computations, which require a layer of
> overlap. What I can do is clone the dm before distributing the overlap,
> then manage two independent plex objects with their own local sections
> etc. and copy/trim local vectors manually. Is there a more automatic
> way
> to do this ?
> Thanks
> Nicolas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
