[petsc-users] MUMPS failure
    Pierre Jolivet
    pierre at joliv.et
    Mon Mar 22 13:16:15 CDT 2021
Also, maybe run with -info dump and grep for MUMPS errors in dump.%p, because some failures are silent otherwise.
Pierre
> On 22 Mar 2021, at 7:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 22, 2021 at 2:07 PM Chris Hewson <chris at resfrac.com <mailto:chris at resfrac.com>> wrote:
> Hi Matt,
> No, we are running it without debugging in prod and then running debug I can't reproduce the error, from stderr we get:
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [1]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors
> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [1]PETSC ERROR: to get more information on the crash.
> [1]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
> application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 1
> If you can afford it, running an instance with -on_error_attach_debugger so that if it fails we can get a stack trace, would be
> very valuable, since right now we do not know exactly what is failing.
>   Thanks,
>      Matt
> Chris Hewson
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
> On Mon, Mar 22, 2021 at 12:04 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Mon, Mar 22, 2021 at 1:56 PM Chris Hewson <chris at resfrac.com <mailto:chris at resfrac.com>> wrote:
> Hi All,
> I have been having a problem with MUMPS randomly crashing in our program and causing the entire program to crash. I am compiling in -O2 optimization mode and using --download-mumps etc. to compile PETSc. If I rerun the program, 95%+ of the time I can't reproduce the error. It seems to be a similar issue to this thread:
> https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html <https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html>
> Similar to the resolution there I am going to try and increase icntl_14 and see if that resolves the issue. Any other thoughts on this?
> When it fails, do you get a stack trace?
>  Thanks,
>     Matt
> Thanks,
> Chris Hewson
> ResFrac
> +1.587.575.9792
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/d6d7003a/attachment.html>
