[petsc-users] MUMPS failure
Matthew Knepley
knepley at gmail.com
Mon Mar 22 13:09:33 CDT 2021
On Mon, Mar 22, 2021 at 2:07 PM Chris Hewson <chris at resfrac.com> wrote:
> Hi Matt,
> No, we are running it without debugging in prod and then running debug I
> can't reproduce the error, from stderr we get:
> [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [1]PETSC ERROR: to get more information on the crash.
> [1]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
> causing the crash.
> application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 1
If you can afford it, running an instance with -on_error_attach_debugger so
that if it fails we can get a stack trace, would be
very valuable, since right now we do not know exactly what is failing.
Matt
> *Chris Hewson*
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
> On Mon, Mar 22, 2021 at 12:04 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Mar 22, 2021 at 1:56 PM Chris Hewson <chris at resfrac.com> wrote:
>>> Hi All,
>>> I have been having a problem with MUMPS randomly crashing in our program
>>> and causing the entire program to crash. I am compiling in -O2 optimization
>>> mode and using --download-mumps etc. to compile PETSc. If I rerun the
>>> program, 95%+ of the time I can't reproduce the error. It seems to be a
>>> similar issue to this thread:
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html
>>> Similar to the resolution there I am going to try and increase icntl_14
>>> and see if that resolves the issue. Any other thoughts on this?
>> When it fails, do you get a stack trace?
>> Thanks,
>> Matt
>>> Thanks,
>>> *Chris Hewson*
>>> ResFrac
>>> +1.587.575.9792
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/314017a2/attachment.html>
