[petsc-users] PETSC installation on Cray
Enrico
degregori at dkrz.de
Tue Mar 2 07:33:23 CST 2021
attached is the configuration and make log files.
Enrico
On 02/03/2021 14:13, Matthew Knepley wrote:
> On Tue, Mar 2, 2021 at 7:49 AM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
> Hi,
> I'm having some problems installing PETSC with Cray compiler.
> I use this configuration:
> ./configure --with-cc=cc --with-cxx=CC --with-fc=0 --with-debugging=1
> --with-shared-libraries=1 COPTFLAGS=-O0 CXXOPTFLAGS=-O0
> and when I do
> make all
> I get the following error because of cmathcalls.h:
> CC-1043 craycc: ERROR File = /usr/include/bits/cmathcalls.h, Line = 55
> _Complex can only be used with floating-point types.
> __MATHCALL (cacos, (_Mdouble_complex_ __z));
> Am I doing something wrong?
> This was expended from somewhere. Can you show the entire err log?
> Thanks,
> Matt
> Regards,
> Enrico Degregori
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210302/8b664ae9/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210302/8b664ae9/attachment-0003.bin>
