[petsc-users] PETSC installation on Cray
Matthew Knepley
knepley at gmail.com
Tue Mar 2 07:13:43 CST 2021
On Tue, Mar 2, 2021 at 7:49 AM Enrico <degregori at dkrz.de> wrote:
> Hi,
> I'm having some problems installing PETSC with Cray compiler.
> I use this configuration:
> ./configure --with-cc=cc --with-cxx=CC --with-fc=0 --with-debugging=1
> --with-shared-libraries=1 COPTFLAGS=-O0 CXXOPTFLAGS=-O0
> and when I do
> make all
> I get the following error because of cmathcalls.h:
> CC-1043 craycc: ERROR File = /usr/include/bits/cmathcalls.h, Line = 55
> _Complex can only be used with floating-point types.
> __MATHCALL (cacos, (_Mdouble_complex_ __z));
> Am I doing something wrong?
This was expended from somewhere. Can you show the entire err log?
Matt
> Regards,
> Enrico Degregori
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210302/3778e3db/attachment.html>
