[petsc-users] PETSC installation on Cray
Tue Mar 2 07:39:19 CST 2021
On Tue, Mar 2, 2021 at 8:33 AM Enrico <degregori at dkrz.de> wrote:
> Hi,
> attached is the configuration and make log files.
cmathcalls.h is a GNU c header. Is the Cray compiler supposed to be using
this header, or has something gone wrong with
the installation on this machine. This does not seem to be connected to
PETSc, but maybe it is in a way I cannot see.
    Matt
> Enrico
> On 02/03/2021 14:13, Matthew Knepley wrote:
> > On Tue, Mar 2, 2021 at 7:49 AM Enrico <degregori at dkrz.de
> > <mailto:degregori at dkrz.de>> wrote:
> >     Hi,
> >     I'm having some problems installing PETSC with Cray compiler.
> >     I use this configuration:
> >     ./configure --with-cc=cc --with-cxx=CC --with-fc=0 --with-debugging=1
> >     --with-shared-libraries=1 COPTFLAGS=-O0 CXXOPTFLAGS=-O0
> >     and when I do
> >     make all
> >     I get the following error because of cmathcalls.h:
> >     CC-1043 craycc: ERROR File = /usr/include/bits/cmathcalls.h, Line =
> 55
> >         _Complex can only be used with floating-point types.
> >         __MATHCALL (cacos, (_Mdouble_complex_ __z));
> >     Am I doing something wrong?
> > This was expended from somewhere. Can you show the entire err log?
> >    Thanks,
> >       Matt
> >     Regards,
> >     Enrico Degregori
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210302/619f07f1/attachment.html>
