[petsc-users] Scaling of the Petsc Binary Viewer
Thu Jul 8 16:05:48 CDT 2021
On Thu, Jul 8, 2021 at 7:35 AM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> Hi Matthew,
> Thank you for your answer ! So I tried to add those steps, and I have the
> same behavior as the one described in this thread :
> https://lists.mcs.anl.gov/pipermail/petsc-dev/2015-July/017978.html
> *[0]PETSC ERROR: --------------------- Error Message
> --------------------------------------------------------------[0]PETSC
> ERROR: Object is in wrong state[0]PETSC ERROR: DM global to natural SF was
> not created.You must call DMSetUseNatural() before
> DMPlexDistribute().[0]PETSC ERROR: See
> https://www.mcs.anl.gov/petsc/documentation/faq.html
> <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.[0]PETSC ERROR: Petsc Development GIT revision:
> v3.14.4-671-g707297fd510  GIT Date: 2021-02-24 22:50:05 +0000[0]PETSC
> ERROR: /ccc/work/cont001/ocre/bridelbert/EULERIAN2D/bin/eulerian2D on a
>  named inti1401 by bridelbert Thu Jul  8 07:50:24 2021[0]PETSC ERROR:
> Configure options --with-clean=1
> --prefix=/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti
> --with-make-np=8 --with-windows-graphics=0 --with-debugging=1
> --download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
> --PETSC_ARCH=INTI_UNS3D
> --with-fc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpifort
> --with-cc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicc
> --with-cxx=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicxx
> --with-openmp=0
> --download-sowing=/ccc/work/cont001/ocre/bridelbert/v1.1.26-p1.tar.gz
> --download-metis=/ccc/work/cont001/ocre/bridelbert/git.metis.tar.gz
> --download-parmetis=/ccc/work/cont001/ocre/bridelbert/git.parmetis.tar.gz
> --download-fblaslapack=/ccc/work/cont001/ocre/bridelbert/git.fblaslapack.tar.gz
> --with-cmake-dir=/ccc/products/cmake-3.13.3/system/default[0]PETSC ERROR:
> #1 DMPlexGlobalToNaturalBegin() line 247 in
> /ccc/work/cont001/ocre/bridelbert/04-PETSC/src/dm/impls/plex/plexnatural.c[0]PETSC
> ERROR: #2 User provided function() line 0 in User file*
> The creation of my DM is as follow :
> *            ! Read mesh from file name 'meshname'            call
> DMPlexCreateFromFile(PETSC_COMM_WORLD, meshname, PETSC_TRUE, dm, ierr);
> CHKERRA(ierr)            ! Distribute on processors            call
> DMSetUseNatural(dm, PETSC_TRUE, ierr)                                  ;
> CHKERRA(ierr)            ! Start with connectivity            call
> DMSetBasicAdjacency(dm, PETSC_TRUE, PETSC_FALSE, ierr)                 ;
> DMPlexDistribute(dm, overlap, PETSC_NULL_SF, dmDist, ierr)             ;
> CHKERRA(ierr)            ! Security check            if (dmDist /=
> PETSC_NULL_DM) then                ! Destroy previous dm
> call DMDestroy(dm, ierr)                                                ;
> CHKERRA(ierr)                ! Replace with dmDist                dm =
> dmDist            end if            ! Finalize setup of the object
>   call DMSetFromOptions(dm, ierr)
>   ; CHKERRA(ierr)            ! Boundary condition with ghost cells
>   call DMPlexConstructGhostCells(dm, PETSC_NULL_CHARACTER,
> PETSC_NULL_INTEGER, dmGhost, ierr); CHKERRA(ierr)            ! Security
> check            if (dmGhost /= PETSC_NULL_DM) then                !
> Destroy previous dm                call DMDestroy(dm, ierr)
>                                ; CHKERRA(ierr)                ! Replace
> with dmGhost                dm = dmGhost            end if*
> And I write my vector as follow :
> *                call DMCreateGlobalVector(dm, Xnat, ierr); CHKERRA(ierr)
>               call PetscObjectSetName(Xnat, "NaturalSolution", ierr);
> CHKERRA(ierr)                call DMPlexGlobalToNaturalBegin(dm, X, Xnat,
> ierr); CHKERRA(ierr)                call DMPlexGlobalToNaturalEnd(dm, X,
> Xnat, ierr); CHKERRA(ierr)                call
> DMGetOutputSequenceNumber(dm, save_seqnum, save_seqval, ierr);
> CHKERRA(ierr)                call DMSetOutputSequenceNumber(dm, -1, 0.d0,
> ierr); CHKERRA(ierr)                write(filename,'(A,I8.8,A)')
> "restart_", stepnum, ".bin"                call
> PetscViewerCreate(PETSC_COMM_WORLD, binViewer, ierr); CHKERRA(ierr)
>         call PetscViewerSetType(binViewer, PETSCVIEWERBINARY, ierr);
> CHKERRA(ierr)                call PetscViewerFileSetMode(binViewer,
> FILE_MODE_WRITE, ierr); CHKERRA(ierr);                call
> PetscViewerBinarySetUseMPIIO(binViewer, PETSC_TRUE, ierr); CHKERRA(ierr);
>               call PetscViewerFileSetName(binViewer, trim(filename), ierr);
> CHKERRA(ierr)                ! call VecView(X, binViewer, ierr);
> CHKERRA(ierr)                call VecView(Xnat, binViewer, ierr);
> CHKERRA(ierr)                call PetscViewerDestroy(binViewer, ierr);
> save_seqnum, save_seqval, ierr); CHKERRA(ierr)*
> Did you find the time to fix the bug you are mentioning in the thread
> above regarding the passing of the natural property when calling
> DMPlexConstructGhostCells ?
No, thanks for reminding me. I coded up what I think is a fix, but I do not
have a test yet. Maybe you can help me make one. Here is the branch
  https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-natural-fvghost
Can you run and see if it fixes that error? Then we can figure out the best
way to do your output.
     Matt
> Thanks !!
> Thibault
> Le mer. 7 juil. 2021 à 23:46, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Wed, Jul 7, 2021 at 3:49 PM Thibault Bridel-Bertomeu <
>>> Hi Dave,
>>> Thank you for your fast answer.
>>> To postprocess the files in python, I use the PetscBinaryIO package that
>>> is provided with PETSc, yes.
>>> I load the file like this :
>>> *import numpy as npimport meshioimport PetscBinaryIO as pioimport
>>> matplotlib as mplimport matplotlib.pyplot as pltimport matplotlib.cm
>>> <http://matplotlib.cm> as cmmpl.use('Agg')*
>>> *restartname = "restart_00001001.bin"print("Reading {}
>>> ...".format(restartname))io = pio.PetscBinaryIO()fh =
>>> open(restartname)objecttype = io.readObjectType(fh)data = Noneif objecttype
>>> == 'Vec':    data = io.readVec(fh)print("Size of data = ",
>>> data.size)print("Size of a single variable (4 variables) = ", data.size /
>>> 4)assert(np.isclose(data.size / 4.0, np.floor(data.size / 4.0)))*
>>> Then I load the mesh (it's from Gmsh so I use the meshio package) :
>>> *meshname = "ForwardFacing.msh"print("Reading {}
>>> ...".format(meshname))mesh = meshio.read(meshname)print("Number of vertices
>>> = ", mesh.points.shape[0])print("Number of cells = ",
>>> mesh.cells_dict['quad'].shape[0])*
>>> From the 'data' and the 'mesh' I use tricontourf from matplotlib to plot
>>> the figure.
>>> I removed the call to ...SetUseMPIIO... and it gives the same kind of
>>> data yes (I attached a figure of the data obtained with the binary viewer
>>> without MPI I/O).
>>> Maybe it's just a connectivity issue ? Maybe the way the Vec is written
>>> by the PETSc viewer somehow does not match the connectivity from the ori
>>> Gmsh file but some other connectivity of the partitionned DMPlex ?
>> Yes, when you distribute the mesh, it gets permuted so that each piece is
>> contiguous. This happens on all meshes (DMDA, DMStag, DMPlex, DMForest).
>> When it is written out, it just concatenates that ordering, or what we
>> usually call the "global order" since it is the order of a global vector.
>>> If so, is there a way to get the latter ?
>> If you call
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMSetUseNatural.html
>> before distribution, then a mapping back to the original ordering will be
>> saved. You can use
>> that mapping with a global vector and an original vector
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>> to get a vector in the original ordering. However, you would also need to
>> understand how you want that output.
>> The ExodusII viewer uses this by default since people how use it (Blaise)
>> generally want that. Most people using
>> HDF5 (me) want the new order since it is faster. Plex ex15 and ex26 show
>> some manipulations using this mapping.
>>> I know the binary viewer does not work on DMPlex,
>> You can output the Vec in native format, which will use the
>> GlobalToNatural reordering. It will not output the Plex,
>> but you will have the values in the order you expect.
>>> the VTK viewer yields a corrupted dataset
>> VTK is not supported. We support Paraview through the Xdmf extension to
>> HDF5.
>>> and I have issues with HDF5 viewer with MPI (see another recent thread
>>> of mine) ...
>> I have not been able to reproduce this yet.
>>   Thanks,
>>       Matt
>>> Thanks again for your help !!
>>> Thibault
>>> Le mer. 7 juil. 2021 à 20:54, Dave May <dave.mayhem23 at gmail.com> a
>>> écrit :
>>>> On Wed 7. Jul 2021 at 20:41, Thibault Bridel-Bertomeu <
>>>>> Dear all,
>>>>> I have been having issues with large Vec (based on DMPLex) and massive
>>>>> MPI I/O  ... it looks like the data that is written by the Petsc Binary
>>>>> Viewer is gibberish for large meshes split on a high number of processes.
>>>>> For instance, I am using a mesh that has around 50 million cells, split on
>>>>> 1024 processors.
>>>>> The computation seems to run fine, the timestep computed from the data
>>>>> makes sense so I think internally everything is fine. But when I look at
>>>>> the solution (one example attached) it's noise - at this point it should
>>>>> show a bow shock developing on the left near the step.
>>>>> The piece of code I use is below for the output :
>>>>>                 call DMGetOutputSequenceNumber(dm, save_seqnum,
>>>>>                 call DMSetOutputSequenceNumber(dm, -1, 0.d0, ierr);
>>>>> CHKERRA(ierr)
>>>>>                 write(filename,'(A,I8.8,A)') "restart_", stepnum,
>>>>> ".bin"
>>>>>                 call PetscViewerCreate(PETSC_COMM_WORLD, binViewer,
>>>>>                 call PetscViewerBinarySetUseMPIIO(binViewer,
>>>> Do you get the correct output if you don’t call the function above (or
>>>> equivalently use PETSC_FALSE)
>>>>> CHKERRA(ierr)
>>>>>                 call VecView(X, binViewer, ierr); CHKERRA(ierr)
>>>>>                 call PetscViewerDestroy(binViewer, ierr); CHKERRA(ierr)
>>>>>                 call DMSetOutputSequenceNumber(dm, save_seqnum,
>>>>> I do not think there is anything wrong with it but of course I would
>>>>> be happy to hear your feedback.
>>>>> Nonetheless my question was : how far have you tested the binary mpi
>>>>> i/o of a Vec ? Does it make some sense that for a 50 million cell mesh
>>>>> split on 1024 processes, it could somehow fail ?
>>>>> Or is it my python drawing method that is completely incapable of
>>>>> handling this dataset ? (paraview displays the same thing though so I'm not
>>>>> sure ...)
>>>> Are you using the python provided tools within petsc to load the Vec
>>>> from file?
>>>> Thanks,
>>>> Dave
>>>>> Thank you very much for your advice and help !!!
>>>>> Thibault
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210708/d6593147/attachment.html>
