[petsc-users] Scaling of the Petsc Binary Viewer
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Fri Jul 9 06:25:52 CDT 2021
Hi Matt,
Thank you for working that fast !
I pulled your branch and tested your solution but unfortunately it crashed
(I did not change the piece of code I sent you before for the creation of
the DM). I am sending you the full error listing in a private e-mail so
you can see what happened exactly.
Thanks !!
Thibault
Le jeu. 8 juil. 2021 à 23:06, Matthew Knepley <knepley at gmail.com> a écrit :
> On Thu, Jul 8, 2021 at 7:35 AM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Hi Matthew,
>> Thank you for your answer ! So I tried to add those steps, and I have the
>> same behavior as the one described in this thread :
>> https://lists.mcs.anl.gov/pipermail/petsc-dev/2015-July/017978.html
>> *[0]PETSC ERROR: --------------------- Error Message
>> --------------------------------------------------------------[0]PETSC
>> ERROR: Object is in wrong state[0]PETSC ERROR: DM global to natural SF was
>> not created.You must call DMSetUseNatural() before
>> DMPlexDistribute().[0]PETSC ERROR: See
>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>> <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
>> shooting.[0]PETSC ERROR: Petsc Development GIT revision:
>> v3.14.4-671-g707297fd510 GIT Date: 2021-02-24 22:50:05 +0000[0]PETSC
>> ERROR: /ccc/work/cont001/ocre/bridelbert/EULERIAN2D/bin/eulerian2D on a
>> named inti1401 by bridelbert Thu Jul 8 07:50:24 2021[0]PETSC ERROR:
>> Configure options --with-clean=1
>> --prefix=/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti
>> --with-make-np=8 --with-windows-graphics=0 --with-debugging=1
>> --download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
>> --PETSC_ARCH=INTI_UNS3D
>> --with-fc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpifort
>> --with-cc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicc
>> --with-cxx=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicxx
>> --with-openmp=0
>> --download-sowing=/ccc/work/cont001/ocre/bridelbert/v1.1.26-p1.tar.gz
>> --download-metis=/ccc/work/cont001/ocre/bridelbert/git.metis.tar.gz
>> --download-parmetis=/ccc/work/cont001/ocre/bridelbert/git.parmetis.tar.gz
>> --download-fblaslapack=/ccc/work/cont001/ocre/bridelbert/git.fblaslapack.tar.gz
>> --with-cmake-dir=/ccc/products/cmake-3.13.3/system/default[0]PETSC ERROR:
>> #1 DMPlexGlobalToNaturalBegin() line 247 in
>> /ccc/work/cont001/ocre/bridelbert/04-PETSC/src/dm/impls/plex/plexnatural.c[0]PETSC
>> ERROR: #2 User provided function() line 0 in User file*
>> The creation of my DM is as follow :
>> * ! Read mesh from file name 'meshname' call
>> DMPlexCreateFromFile(PETSC_COMM_WORLD, meshname, PETSC_TRUE, dm, ierr);
>> CHKERRA(ierr) ! Distribute on processors call
>> DMSetUseNatural(dm, PETSC_TRUE, ierr) ;
>> CHKERRA(ierr) ! Start with connectivity call
>> DMSetBasicAdjacency(dm, PETSC_TRUE, PETSC_FALSE, ierr) ;
>> DMPlexDistribute(dm, overlap, PETSC_NULL_SF, dmDist, ierr) ;
>> CHKERRA(ierr) ! Security check if (dmDist /=
>> PETSC_NULL_DM) then ! Destroy previous dm
>> call DMDestroy(dm, ierr) ;
>> CHKERRA(ierr) ! Replace with dmDist dm =
>> dmDist end if ! Finalize setup of the object
>> call DMSetFromOptions(dm, ierr)
>> ; CHKERRA(ierr) ! Boundary condition with ghost cells
>> call DMPlexConstructGhostCells(dm, PETSC_NULL_CHARACTER,
>> PETSC_NULL_INTEGER, dmGhost, ierr); CHKERRA(ierr) ! Security
>> check if (dmGhost /= PETSC_NULL_DM) then !
>> Destroy previous dm call DMDestroy(dm, ierr)
>> ; CHKERRA(ierr) ! Replace
>> with dmGhost dm = dmGhost end if*
>> And I write my vector as follow :
>> * call DMCreateGlobalVector(dm, Xnat, ierr);
>> CHKERRA(ierr) call PetscObjectSetName(Xnat,
>> "NaturalSolution", ierr); CHKERRA(ierr) call
>> DMPlexGlobalToNaturalBegin(dm, X, Xnat, ierr); CHKERRA(ierr)
>> call DMPlexGlobalToNaturalEnd(dm, X, Xnat, ierr); CHKERRA(ierr)
>> call DMGetOutputSequenceNumber(dm, save_seqnum, save_seqval, ierr);
>> CHKERRA(ierr) call DMSetOutputSequenceNumber(dm, -1, 0.d0,
>> ierr); CHKERRA(ierr) write(filename,'(A,I8.8,A)')
>> "restart_", stepnum, ".bin" call
>> PetscViewerCreate(PETSC_COMM_WORLD, binViewer, ierr); CHKERRA(ierr)
>> call PetscViewerSetType(binViewer, PETSCVIEWERBINARY, ierr);
>> CHKERRA(ierr) call PetscViewerFileSetMode(binViewer,
>> FILE_MODE_WRITE, ierr); CHKERRA(ierr); call
>> PetscViewerBinarySetUseMPIIO(binViewer, PETSC_TRUE, ierr); CHKERRA(ierr);
>> call PetscViewerFileSetName(binViewer, trim(filename), ierr);
>> CHKERRA(ierr) ! call VecView(X, binViewer, ierr);
>> CHKERRA(ierr) call VecView(Xnat, binViewer, ierr);
>> CHKERRA(ierr) call PetscViewerDestroy(binViewer, ierr);
>> save_seqnum, save_seqval, ierr); CHKERRA(ierr)*
>> Did you find the time to fix the bug you are mentioning in the thread
>> above regarding the passing of the natural property when calling
>> DMPlexConstructGhostCells ?
> No, thanks for reminding me. I coded up what I think is a fix, but I do
> not have a test yet. Maybe you can help me make one. Here is the branch
> https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-natural-fvghost
> Can you run and see if it fixes that error? Then we can figure out the
> best way to do your output.
> Thanks,
> Matt
>> Thanks !!
>> Thibault
>> Le mer. 7 juil. 2021 à 23:46, Matthew Knepley <knepley at gmail.com> a
>> écrit :
>>> On Wed, Jul 7, 2021 at 3:49 PM Thibault Bridel-Bertomeu <
>>>> Hi Dave,
>>>> Thank you for your fast answer.
>>>> To postprocess the files in python, I use the PetscBinaryIO package
>>>> that is provided with PETSc, yes.
>>>> I load the file like this :
>>>> *import numpy as npimport meshioimport PetscBinaryIO as pioimport
>>>> matplotlib as mplimport matplotlib.pyplot as pltimport matplotlib.cm
>>>> <http://matplotlib.cm> as cmmpl.use('Agg')*
>>>> *restartname = "restart_00001001.bin"print("Reading {}
>>>> ...".format(restartname))io = pio.PetscBinaryIO()fh =
>>>> open(restartname)objecttype = io.readObjectType(fh)data = Noneif objecttype
>>>> == 'Vec': data = io.readVec(fh)print("Size of data = ",
>>>> data.size)print("Size of a single variable (4 variables) = ", data.size /
>>>> 4)assert(np.isclose(data.size / 4.0, np.floor(data.size / 4.0)))*
>>>> Then I load the mesh (it's from Gmsh so I use the meshio package) :
>>>> *meshname = "ForwardFacing.msh"print("Reading {}
>>>> ...".format(meshname))mesh = meshio.read(meshname)print("Number of vertices
>>>> = ", mesh.points.shape[0])print("Number of cells = ",
>>>> mesh.cells_dict['quad'].shape[0])*
>>>> From the 'data' and the 'mesh' I use tricontourf from matplotlib to
>>>> plot the figure.
>>>> I removed the call to ...SetUseMPIIO... and it gives the same kind of
>>>> data yes (I attached a figure of the data obtained with the binary viewer
>>>> without MPI I/O).
>>>> Maybe it's just a connectivity issue ? Maybe the way the Vec is written
>>>> by the PETSc viewer somehow does not match the connectivity from the ori
>>>> Gmsh file but some other connectivity of the partitionned DMPlex ?
>>> Yes, when you distribute the mesh, it gets permuted so that each piece
>>> is contiguous. This happens on all meshes (DMDA, DMStag, DMPlex, DMForest).
>>> When it is written out, it just concatenates that ordering, or what we
>>> usually call the "global order" since it is the order of a global vector.
>>>> If so, is there a way to get the latter ?
>>> If you call
>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMSetUseNatural.html
>>> before distribution, then a mapping back to the original ordering will
>>> be saved. You can use
>>> that mapping with a global vector and an original vector
>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>> to get a vector in the original ordering. However, you would also need
>>> to understand how you want that output.
>>> The ExodusII viewer uses this by default since people how use it
>>> (Blaise) generally want that. Most people using
>>> HDF5 (me) want the new order since it is faster. Plex ex15 and ex26 show
>>> some manipulations using this mapping.
>>>> I know the binary viewer does not work on DMPlex,
>>> You can output the Vec in native format, which will use the
>>> GlobalToNatural reordering. It will not output the Plex,
>>> but you will have the values in the order you expect.
>>>> the VTK viewer yields a corrupted dataset
>>> VTK is not supported. We support Paraview through the Xdmf extension to
>>> HDF5.
>>>> and I have issues with HDF5 viewer with MPI (see another recent thread
>>>> of mine) ...
>>> I have not been able to reproduce this yet.
>>> Thanks,
>>> Matt
>>>> Thanks again for your help !!
>>>> Thibault
>>>> Le mer. 7 juil. 2021 à 20:54, Dave May <dave.mayhem23 at gmail.com> a
>>>> écrit :
>>>>> On Wed 7. Jul 2021 at 20:41, Thibault Bridel-Bertomeu <
>>>>>> Dear all,
>>>>>> I have been having issues with large Vec (based on DMPLex) and
>>>>>> massive MPI I/O ... it looks like the data that is written by the Petsc
>>>>>> Binary Viewer is gibberish for large meshes split on a high number of
>>>>>> processes. For instance, I am using a mesh that has around 50 million
>>>>>> cells, split on 1024 processors.
>>>>>> The computation seems to run fine, the timestep computed from the
>>>>>> data makes sense so I think internally everything is fine. But when I look
>>>>>> at the solution (one example attached) it's noise - at this point it should
>>>>>> show a bow shock developing on the left near the step.
>>>>>> The piece of code I use is below for the output :
>>>>>> call DMSetOutputSequenceNumber(dm, -1, 0.d0, ierr);
>>>>>> CHKERRA(ierr)
>>>>>> write(filename,'(A,I8.8,A)') "restart_", stepnum,
>>>>>> ".bin"
>>>>>> call PetscViewerCreate(PETSC_COMM_WORLD, binViewer,
>>>>>> call PetscViewerBinarySetUseMPIIO(binViewer,
>>>>> Do you get the correct output if you don’t call the function above (or
>>>>> equivalently use PETSC_FALSE)
>>>>>> CHKERRA(ierr)
>>>>>> call VecView(X, binViewer, ierr); CHKERRA(ierr)
>>>>>> CHKERRA(ierr)
>>>>>> call DMSetOutputSequenceNumber(dm, save_seqnum,
>>>>>> I do not think there is anything wrong with it but of course I would
>>>>>> be happy to hear your feedback.
>>>>>> Nonetheless my question was : how far have you tested the binary mpi
>>>>>> i/o of a Vec ? Does it make some sense that for a 50 million cell mesh
>>>>>> split on 1024 processes, it could somehow fail ?
>>>>>> Or is it my python drawing method that is completely incapable of
>>>>>> handling this dataset ? (paraview displays the same thing though so I'm not
>>>>>> sure ...)
>>>>> Are you using the python provided tools within petsc to load the Vec
>>>>> from file?
>>>>> Thanks,
>>>>> Dave
>>>>>> Thank you very much for your advice and help !!!
>>>>>> Thibault
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210709/fa3975cd/attachment-0001.html>
