[petsc-users] download zlib error
Wed Jul 7 08:17:59 CDT 2021
It is hard to see the error. I suspect it is something crazy with the
install. Can you run the build by hand?
cd
/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11
&& CC="cc" CFLAGS="-fPIC -fstack-protector -Qunused-arguments -g -O0
-I${ROCM_PATH}/include"
prefix="/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos"
./configure  && /usr/bin/gmake -j8 -l307.2 &&  /usr/bin/gmake install
and see what happens, and what the error code is?
     Matt
On Wed, Jul 7, 2021 at 8:48 AM Mark Adams <mfadams at lbl.gov> wrote:
> Also, this is in jczhang/fix-kokkos-includes
> On Wed, Jul 7, 2021 at 8:46 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Apparently the same error with
>> --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
>> On Tue, Jul 6, 2021 at 11:53 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> $ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz
>>>   % Total    % Received % Xferd  Average Speed   Time    Time     Time
>>> Current
>>>                                  Dload  Upload   Total   Spent    Left
>>> Speed
>>> 100  593k  100  593k    0     0   835k      0 --:--:-- --:--:--
>>> --:--:--  834k
>>> ~/Src/petsc* (barry/2021-07-03/demonstrate-network-parallel-build=)*
>>> arch-demonstrate-network-parallel-build
>>> $ tar -zxf zlib-1.2.11.tar.gz
>>> $ ls zlib-1.2.11
>>> CMakeLists.txt  adler32.c       deflate.c       gzread.c
>>> inflate.h       os400           watcom          zlib.h
>>> ChangeLog       amiga           deflate.h       gzwrite.c
>>> inftrees.c      qnx             win32           zlib.map
>>> FAQ             compress.c      doc             infback.c
>>> inftrees.h      test            zconf.h         zlib.pc.cmakein
>>> INDEX           configure       examples        inffast.c
>>> make_vms.com    treebuild.xml   zconf.h.cmakein zlib.pc.in
>>> Makefile        contrib         gzclose.c       inffast.h       msdos
>>>         trees.c         zconf.h.in      zlib2ansi
>>> Makefile.in     crc32.c         gzguts.h        inffixed.h
>>> nintendods      trees.h         zlib.3          zutil.c
>>> README          crc32.h         gzlib.c         inflate.c       old
>>>         uncompr.c       zlib.3.pdf      zutil.h
>>> On Jul 6, 2021, at 7:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Mark,
>>>>    You can try what the configure error message should be suggesting
>>>> (it is not clear if that is being printed to your screen or no).
>>>> ERROR: Unable to download package ZLIB from:
>>> My browser can not open this and I could not see a download button on
>>> this site.
>>> Can you download this?
>>>> * If URL specified manually - perhaps there is a typo?
>>>> * If your network is disconnected - please reconnect and rerun
>>>> ./configure
>>>> * Or perhaps you have a firewall blocking the download
>>>> * You can run with --with-packages-download-dir=/adirectory and
>>>> ./configure will instruct you what packages to download manually
>>>> * or you can download the above URL manually, to
>>>>   and use the configure option:
>>>>   Barry
>>>> > On Jul 6, 2021, at 4:29 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> > I am getting some sort of error in build zlib on Spock at ORNL.
>>>> > Other libraries are downloaded and I am sure the network is fine.
>>>> > Any ideas?
>>>> > Thanks,
>>>> > Mark
>>>> > <configure.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210707/d5c4f28a/attachment-0001.html>
