[petsc-users] download zlib error
Mark Adams mfadams at lbl.gov
Wed Jul 7 07:47:46 CDT 2021
Also, this is in jczhang/fix-kokkos-includes
On Wed, Jul 7, 2021 at 8:46 AM Mark Adams <mfadams at lbl.gov> wrote:
> Apparently the same error with
> --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
> On Tue, Jul 6, 2021 at 11:53 PM Barry Smith <bsmith at petsc.dev> wrote:
>> $ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz
>>   % Total    % Received % Xferd  Average Speed   Time    Time     Time
>> Current
>>                                  Dload  Upload   Total   Spent    Left
>> Speed
>> 100  593k  100  593k    0     0   835k      0 --:--:-- --:--:-- --:--:--
>> 834k
>> ~/Src/petsc* (barry/2021-07-03/demonstrate-network-parallel-build=)*
>> arch-demonstrate-network-parallel-build
>> $ tar -zxf zlib-1.2.11.tar.gz
>> $ ls zlib-1.2.11
>> CMakeLists.txt  adler32.c       deflate.c       gzread.c        inflate.h
>>       os400           watcom          zlib.h
>> ChangeLog       amiga           deflate.h       gzwrite.c
>> inftrees.c      qnx             win32           zlib.map
>> FAQ             compress.c      doc             infback.c
>> inftrees.h      test            zconf.h         zlib.pc.cmakein
>> INDEX           configure       examples        inffast.c
>> make_vms.com    treebuild.xml   zconf.h.cmakein zlib.pc.in
>> Makefile        contrib         gzclose.c       inffast.h       msdos
>>         trees.c         zconf.h.in      zlib2ansi
>> Makefile.in     crc32.c         gzguts.h        inffixed.h
>> nintendods      trees.h         zlib.3          zutil.c
>> README          crc32.h         gzlib.c         inflate.c       old
>>         uncompr.c       zlib.3.pdf      zutil.h
>> On Jul 6, 2021, at 7:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>   Mark,
>>>    You can try what the configure error message should be suggesting (it
>>> is not clear if that is being printed to your screen or no).
>>> ERROR: Unable to download package ZLIB from:
>> My browser can not open this and I could not see a download button on
>> this site.
>> Can you download this?
>>> * If URL specified manually - perhaps there is a typo?
>>> * If your network is disconnected - please reconnect and rerun
>>> ./configure
>>> * Or perhaps you have a firewall blocking the download
>>> * You can run with --with-packages-download-dir=/adirectory and
>>> ./configure will instruct you what packages to download manually
>>> * or you can download the above URL manually, to
>>>   and use the configure option:
>>>   Barry
>>> > On Jul 6, 2021, at 4:29 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > I am getting some sort of error in build zlib on Spock at ORNL.
>>> > Other libraries are downloaded and I am sure the network is fine.
>>> > Any ideas?
>>> > Thanks,
>>> > Mark
>>> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210707/842f3dc1/attachment.html>
