[petsc-users] download zlib error
Mark Adams
mfadams at lbl.gov
Wed Jul 7 07:46:31 CDT 2021
Apparently the same error with
--download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
On Tue, Jul 6, 2021 at 11:53 PM Barry Smith <bsmith at petsc.dev> wrote:
> $ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz
> % Total % Received % Xferd Average Speed Time Time Time
> Current
> Dload Upload Total Spent Left
> Speed
> 100 593k 100 593k 0 0 835k 0 --:--:-- --:--:-- --:--:--
> 834k
> ~/Src/petsc* (barry/2021-07-03/demonstrate-network-parallel-build=)*
> arch-demonstrate-network-parallel-build
> $ tar -zxf zlib-1.2.11.tar.gz
> $ ls zlib-1.2.11
> CMakeLists.txt adler32.c deflate.c gzread.c inflate.h
> os400 watcom zlib.h
> ChangeLog amiga deflate.h gzwrite.c
> inftrees.c qnx win32 zlib.map
> FAQ compress.c doc infback.c
> inftrees.h test zconf.h zlib.pc.cmakein
> INDEX configure examples inffast.c
> make_vms.com treebuild.xml zconf.h.cmakein zlib.pc.in
> Makefile contrib gzclose.c inffast.h msdos
> trees.c zconf.h.in zlib2ansi
> Makefile.in crc32.c gzguts.h inffixed.h nintendods
> trees.h zlib.3 zutil.c
> README crc32.h gzlib.c inflate.c old
> uncompr.c zlib.3.pdf zutil.h
> On Jul 6, 2021, at 7:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Mark,
>> You can try what the configure error message should be suggesting (it
>> is not clear if that is being printed to your screen or no).
>> ERROR: Unable to download package ZLIB from:
> My browser can not open this and I could not see a download button on this
> site.
> Can you download this?
>> * If URL specified manually - perhaps there is a typo?
>> * If your network is disconnected - please reconnect and rerun ./configure
>> * Or perhaps you have a firewall blocking the download
>> * You can run with --with-packages-download-dir=/adirectory and
>> ./configure will instruct you what packages to download manually
>> * or you can download the above URL manually, to
>> and use the configure option:
>> Barry
>> > On Jul 6, 2021, at 4:29 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > I am getting some sort of error in build zlib on Spock at ORNL.
>> > Other libraries are downloaded and I am sure the network is fine.
>> > Any ideas?
>> > Thanks,
>> > Mark
>> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210707/bb58a5d7/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210707/bb58a5d7/attachment-0001.obj>
