[petsc-users] download zlib error
Barry Smith
bsmith at petsc.dev
Tue Jul 6 22:53:29 CDT 2021
$ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 593k 100 593k 0 0 835k 0 --:--:-- --:--:-- --:--:-- 834k
~/Src/petsc (barry/2021-07-03/demonstrate-network-parallel-build=) arch-demonstrate-network-parallel-build
$ tar -zxf zlib-1.2.11.tar.gz
$ ls zlib-1.2.11
CMakeLists.txt adler32.c deflate.c gzread.c inflate.h os400 watcom zlib.h
ChangeLog amiga deflate.h gzwrite.c inftrees.c qnx win32 zlib.map
FAQ compress.c doc infback.c inftrees.h test zconf.h zlib.pc.cmakein
INDEX configure examples inffast.c make_vms.com treebuild.xml zconf.h.cmakein zlib.pc.in
Makefile contrib gzclose.c inffast.h msdos trees.c zconf.h.in zlib2ansi
Makefile.in crc32.c gzguts.h inffixed.h nintendods trees.h zlib.3 zutil.c
README crc32.h gzlib.c inflate.c old uncompr.c zlib.3.pdf zutil.h
> On Jul 6, 2021, at 7:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> Mark,
> You can try what the configure error message should be suggesting (it is not clear if that is being printed to your screen or no).
> ERROR: Unable to download package ZLIB from: http://www.zlib.net/zlib-1.2.11.tar.gz <http://www.zlib.net/zlib-1.2.11.tar.gz>
> My browser can not open this and I could not see a download button on this site.
> Can you download this?
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
> * You can run with --with-packages-download-dir=/adirectory and ./configure will instruct you what packages to download manually
> * or you can download the above URL manually, to /yourselectedlocation/zlib-1.2.11.tar.gz
> and use the configure option:
> --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
> Barry
> > On Jul 6, 2021, at 4:29 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> > I am getting some sort of error in build zlib on Spock at ORNL.
> > Other libraries are downloaded and I am sure the network is fine.
> > Any ideas?
> > Thanks,
> > Mark
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210706/79dbe8ce/attachment-0001.html>
