[petsc-users] Understanding global and local rows in a distributed dense matrix
Roland Richter
roland.richter at ntnu.no
Wed Jan 13 06:39:56 CST 2021
Hei,
I am currently struggling a bit with my understanding of local and
global rows/columns in distributed dense matrices in PETSc.
The attached short program is creating a local matrix in every thread
with [matrix_size_rows, matrix_size_cols] as global size. Afterwards, I
flatten the matrix into a vector, and split this vector using the
boost-function split() when running using several MPI threads. In
addition I create a dense MPI-distributed matrix based on PETSc, using
the same input sizes, and set all values to zero (after I'm not
interested in the content itself, just the shape). Finally, I retrieve
the global and local values for the number of rows and columns using
MatGetLocalSize, and the number of the first and last row in each matrix
using MatGetOwnershipRange() and print them. According to the
documentation I would expect that the PETSc-based matrix is split up
Now, for an input size of [8, 8] and a single thread I get
/Rank 0 has a total size of 8, 8
Rank 0 has an initial size of 64
Rank 0 has a local matrix size of 8, 8
Rank 0 has a global matrix size of 8, 8
Rank 0 has a matrix spanning from row 0 to 8
Rank 0 has a vector size of 64///
which is what I expect. For two threads, though, I get
/Rank 0 has a total size of 8, 8//
//Rank 0 has an initial size of 64//
//Rank 0 has a local matrix size of 4, 4//
//Rank 0 has a global matrix size of 8, 8//
//Rank 0 has a matrix spanning from row 0 to 4//
//Rank 0 has a vector size of 32//
//Rank 1 has a total size of 8, 8//
//Rank 1 has an initial size of 64//
//Rank 1 has a local matrix size of 4, 4//
//Rank 1 has a global matrix size of 8, 8//
//Rank 1 has a matrix spanning from row 4 to 8//
Rank 1 has a vector size of 32/
Here, most entries make sense, except the size of the local matrices.
Why do I get a size of [4, 4], and not a size of [4, 8]? Each row should
be contiguous in the local process, and therefore each row should
contain all columns, not only a part of it.
Is there a misunderstanding about how to use MatGetLocalSize(), or
something else?
Thanks!
Roland Richter
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210113/2bb1de4d/attachment.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210113/2bb1de4d/attachment.bin>
