[petsc-users] Understanding global and local rows in a distributed dense matrix
Stefano Zampini
stefano.zampini at gmail.com
Wed Jan 13 07:26:03 CST 2021
MATMPIDENSE does not implement any cyclic distribution. In parallel, a
dense matrix is split by rows. Each process owns localrows*globalcols
entries. Local sizes are to be intended as the size of the right and left
vectors used in matvec operations, and are not strictly related with
storage considerations.
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSize.html
Il Mer 13 Gen 2021, 15:40 Roland Richter <roland.richter at ntnu.no> ha
scritto:
> Hei,
> I am currently struggling a bit with my understanding of local and global
> rows/columns in distributed dense matrices in PETSc.
> The attached short program is creating a local matrix in every thread with
> [matrix_size_rows, matrix_size_cols] as global size. Afterwards, I flatten
> the matrix into a vector, and split this vector using the boost-function
> split() when running using several MPI threads. In addition I create a
> dense MPI-distributed matrix based on PETSc, using the same input sizes,
> and set all values to zero (after I'm not interested in the content itself,
> just the shape). Finally, I retrieve the global and local values for the
> number of rows and columns using MatGetLocalSize, and the number of the
> first and last row in each matrix using MatGetOwnershipRange() and print
> them. According to the documentation I would expect that the PETSc-based
> matrix is split up
> Now, for an input size of [8, 8] and a single thread I get
> *Rank 0 has a total size of 8, 8 Rank 0 has an initial size of 64 Rank 0
> has a local matrix size of 8, 8 Rank 0 has a global matrix size of 8, 8
> Rank 0 has a matrix spanning from row 0 to 8 Rank 0 has a vector size of 64*
> which is what I expect. For two threads, though, I get
> *Rank 0 has a total size of 8, 8*
> *Rank 0 has an initial size of 64*
> *Rank 0 has a local matrix size of 4, 4*
> *Rank 0 has a global matrix size of 8, 8*
> *Rank 0 has a matrix spanning from row 0 to 4*
> *Rank 0 has a vector size of 32*
> *Rank 1 has a total size of 8, 8*
> *Rank 1 has an initial size of 64*
> *Rank 1 has a local matrix size of 4, 4*
> *Rank 1 has a global matrix size of 8, 8*
> *Rank 1 has a matrix spanning from row 4 to 8*
> * Rank 1 has a vector size of 32*
> Here, most entries make sense, except the size of the local matrices. Why
> do I get a size of [4, 4], and not a size of [4, 8]? Each row should be
> contiguous in the local process, and therefore each row should contain all
> columns, not only a part of it.
> Is there a misunderstanding about how to use MatGetLocalSize(), or
> something else?
> Thanks!
> Regards,
> Roland Richter
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210113/33a73dcc/attachment.html>
