[petsc-users] --with-mpi=0
Sat Dec 18 15:36:31 CST 2021
Sure - that's the trade-off.
At some point I think we decided not to map mpiuni.mod to mpi.mod [to avoid potential clash with other mpi/mpiuni type impls].
If I remember correctly - we could limit on the C side - by not installing mpi.h in std location [its at include/petsc/mpiuni/mpi.h]
And since mpiuni's mpi.mod is to be installed in prefix/include - I think this different name was chosen.
And now that we are supporting 'use mpi or mpi_f08' - its 'use mpiuni or mpi or mpi_f08' or use --with-mpi-f90module-visibility=1
For now petscmpi maps to mpi or mpiuni.
Perhaps its possible to change our installer to have mpiuni's mod file at  prefix/include/petsc/mpiuni/mpi.mod - [to enable reusing mpi.mod name ]
[at some point we had an option to skip fortran mpi_comm_rank() etc - as they would clash with similar uni impls. But I see that option no longer exists?]
Satish
On Sat, 18 Dec 2021, Barry Smith wrote:
>   Urg, this is pretty horrible. petscmpi?  Why can't MPIUNI provide this as "standard" MPI modules?
> > On Dec 18, 2021, at 11:04 AM, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > Ah - you need 'use petscmpi'
> > For example: ksp/ksp/tutorials/ex44f.F90
> > Satish
> > On Sat, 18 Dec 2021, Matthew Knepley wrote:
> >> On Sat, Dec 18, 2021 at 9:26 AM Tabrez Ali <tabrezali at gmail.com> wrote:
> >>> Hi,
> >>> I am trying to compile Fortran code with PETSc 3.16 built without MPI,
> >>> i.e., --with-mpi=0, and am getting the following error:
> >>>   call MPI_Comm_rank(MPI_COMM_WORLD,rank,ierr)
> >>>                                         1
> >>> Error: Symbol ‘mpi_comm_world’ at (1) has no IMPLICIT type
> >> Hi Tabrez,
> >> The definition of MPI_COMM_WORLD is in mpif.h. Are you #including that?
> >>  Thanks,
> >>    Matt
> >>> There are no issues with PETSc 3.14 or prior versions. Any ideas as to
> >>> what could be wrong?
> >>> I do see the following note (below) in
> >>> https://petsc.org/main/docs/changes/315/ but I am not sure if it's
> >>> related:
> >>> *Add configure option --with-mpi-f90module-visibility [default=``1``].
> >>> With 0, mpi.mod will not be visible in use code (via petscsys.mod) -
> >>> so mpi_f08 can now be used*
> >>> Regards,
> >>> Tabrez
