[petsc-users] --with-mpi=0
Barry Smith
bsmith at petsc.dev
Sat Dec 18 15:46:27 CST 2021
It seems like this might be a good strategy, presumably the directory is already made to hold mpi.h for MPI uni
Perhaps its possible to change our installer to have mpiuni's mod file at prefix/include/petsc/mpiuni/mpi.mod - [to enable reusing mpi.mod name ]
> On Dec 18, 2021, at 4:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Sure - that's the trade-off.
> At some point I think we decided not to map mpiuni.mod to mpi.mod [to avoid potential clash with other mpi/mpiuni type impls].
> If I remember correctly - we could limit on the C side - by not installing mpi.h in std location [its at include/petsc/mpiuni/mpi.h]
> And since mpiuni's mpi.mod is to be installed in prefix/include - I think this different name was chosen.
> And now that we are supporting 'use mpi or mpi_f08' - its 'use mpiuni or mpi or mpi_f08' or use --with-mpi-f90module-visibility=1
> For now petscmpi maps to mpi or mpiuni.
> [at some point we had an option to skip fortran mpi_comm_rank() etc - as they would clash with similar uni impls. But I see that option no longer exists?]
> Satish
> On Sat, 18 Dec 2021, Barry Smith wrote:
>> Urg, this is pretty horrible. petscmpi? Why can't MPIUNI provide this as "standard" MPI modules?
>>> On Dec 18, 2021, at 11:04 AM, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> Ah - you need 'use petscmpi'
>>> For example: ksp/ksp/tutorials/ex44f.F90
>>> Satish
>>> On Sat, 18 Dec 2021, Matthew Knepley wrote:
>>>> On Sat, Dec 18, 2021 at 9:26 AM Tabrez Ali <tabrezali at gmail.com> wrote:
>>>>> Hi,
>>>>> I am trying to compile Fortran code with PETSc 3.16 built without MPI,
>>>>> i.e., --with-mpi=0, and am getting the following error:
>>>>> call MPI_Comm_rank(MPI_COMM_WORLD,rank,ierr)
>>>>> 1
>>>>> Error: Symbol ‘mpi_comm_world’ at (1) has no IMPLICIT type
>>>> Hi Tabrez,
>>>> The definition of MPI_COMM_WORLD is in mpif.h. Are you #including that?
>>>> Thanks,
>>>> Matt
>>>>> There are no issues with PETSc 3.14 or prior versions. Any ideas as to
>>>>> what could be wrong?
>>>>> I do see the following note (below) in
>>>>> https://petsc.org/main/docs/changes/315/ but I am not sure if it's
>>>>> related:
>>>>> *Add configure option --with-mpi-f90module-visibility [default=``1``].
>>>>> With 0, mpi.mod will not be visible in use code (via petscsys.mod) -
>>>>> so mpi_f08 can now be used*
>>>>> Regards,
>>>>> Tabrez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211218/d7897ba4/attachment.html>
