[petsc-users] --with-mpi=0
Barry Smith
bsmith at petsc.dev
Sat Dec 18 14:49:15 CST 2021
Urg, this is pretty horrible. petscmpi? Why can't MPIUNI provide this as "standard" MPI modules?
> On Dec 18, 2021, at 11:04 AM, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Ah - you need 'use petscmpi'
> For example: ksp/ksp/tutorials/ex44f.F90
> Satish
> On Sat, 18 Dec 2021, Matthew Knepley wrote:
>> On Sat, Dec 18, 2021 at 9:26 AM Tabrez Ali <tabrezali at gmail.com> wrote:
>>> Hi,
>>> I am trying to compile Fortran code with PETSc 3.16 built without MPI,
>>> i.e., --with-mpi=0, and am getting the following error:
>>> call MPI_Comm_rank(MPI_COMM_WORLD,rank,ierr)
>>> 1
>>> Error: Symbol ‘mpi_comm_world’ at (1) has no IMPLICIT type
>> Hi Tabrez,
>> The definition of MPI_COMM_WORLD is in mpif.h. Are you #including that?
>> Thanks,
>> Matt
>>> There are no issues with PETSc 3.14 or prior versions. Any ideas as to
>>> what could be wrong?
>>> I do see the following note (below) in
>>> https://petsc.org/main/docs/changes/315/ but I am not sure if it's
>>> related:
>>> *Add configure option --with-mpi-f90module-visibility [default=``1``].
>>> With 0, mpi.mod will not be visible in use code (via petscsys.mod) -
>>> so mpi_f08 can now be used*
>>> Regards,
>>> Tabrez
