[petsc-users] Finite difference approximation of Jacobian
Dave May
dave.mayhem23 at gmail.com
Mon Dec 13 13:17:32 CST 2021
On Mon, 13 Dec 2021 at 20:13, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 13, 2021 at 1:52 PM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Mon, 13 Dec 2021 at 19:29, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Mon, Dec 13, 2021 at 1:16 PM Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>>> On Sat 11. Dec 2021 at 22:28, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, Dec 11, 2021 at 1:58 PM Tang, Qi <tangqi at msu.edu> wrote:
>>>>>> Hi,
>>>>>> Does anyone have comment on finite difference coloring with DMStag?
>>>>>> We are using DMStag and TS to evolve some nonlinear equations implicitly.
>>>>>> It would be helpful to have the coloring Jacobian option with that.
>>>>> Since DMStag produces the Jacobian connectivity,
>>>> This is incorrect.
>>>> The DMCreateMatrix implementation for DMSTAG only sets the number of
>>>> nonzeros (very inaccurately). It does not insert any zero values and thus
>>>> the nonzero structure is actually not defined.
>>>> That is why coloring doesn’t work.
>>> Ah, thanks Dave.
>>> Okay, we should fix that.It is perfectly possible to compute the nonzero
>>> pattern from the DMStag information.
>> Agreed. The API for DMSTAG is complete enough to enable one to
>> loop over the cells, and for all quantities defined on the cell (centre,
>> face, vertex),
>> insert values into the appropriate slot in the matrix.
>> Combined with MATPREALLOCATOR, I believe a compact and readable
>> code should be possible to write for the preallocation (cf DMDA).
>> I think the only caveat with the approach of using all quantities defined
>> on the cell is
>> It may slightly over allocate depending on how the user wishes to impose
>> the boundary condition,
>> or slightly over allocate for says Stokes where there is no
>> pressure-pressure coupling term.
> Yes, and would not handle higher order stencils.I think the
> overallocating is livable for the first imeplementation.
Sure, but neither does DMDA.
The user always has to know what they are doing and set the stencil width
accordingly.
I actually had this point listed in my initial email (and the stencil
growth issue when using FD for nonlinear problems),
however I deleted it as all the same issue exist in DMDA and no one
complains (at least not loudly) :D
> Thanks,
> Matt
>> Thanks,
>> Dave
>>> Paging Patrick :)
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Dave
>>>> you can use -snes_fd_color_use_mat. It has many options. Here is an
>>>>> example of us using that:
>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex19.c#L898
>>>>> Thanks,
>>>>> Matt
>>>>>> Thanks,
>>>>>> Qi
>>>>>> On Oct 15, 2021, at 3:07 PM, Jorti, Zakariae via petsc-users <
>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> Hello,
>>>>>> Does the Jacobian approximation using coloring and finite
>>>>>> differencing of the function evaluation work in DMStag?
>>>>>> Thank you.
>>>>>> Best regards,
>>>>>> Zakariae
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211213/002f2e40/attachment.html>
