[petsc-users] Preconditioner for stokes flow with mixed boundary conditions.
Abhinav Singh
abhinavrajendra at gmail.com
Mon Apr 19 13:55:19 CDT 2021
The only reference that I know of which solves these equations is :
https://www.pks.mpg.de/fileadmin/user_upload/MPIPKS/group_pages/BiologicalPhysics/juelicher/publications/2015/AHp-MMfIAPVG2015.pdf
There is coordinate free form in the appendix. They have been solved using
the UMFPACK Solver on staggered grids. I am trying a new approach (pressure
correction with auxiliary potential). In 2 dimensions, the approach worked
well with GMRES. In 3d, GMRES again works but with Dirichlet
On Mon, 19 Apr 2021 at 20:45, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 19, 2021 at 2:38 PM Abhinav Singh <abhinavrajendra at gmail.com>
> wrote:
>> Hello,
>> The Stokes flow equations are a 3d version of the equations attached
>> (Stokes-Leslie Flow). Only variables/unknowns are v and
>> u_xy=0.5(Dx(vy)+Dy(vx).
> This is not what I have referred to as Stokes flow (Google gave me no
> results for Stokes-Leslie flow). The Stokes operator is elliptic, but I
> have no idea if
> what you have written is. It has fourth order derivatives in it, with
> mixed nonlinear terms, so nothing is clear to me. Is there a
> coordinate-independent form?
> From what I see in the image, I have no idea what solvers might work. Do
> you have any reference where people have solved this before?
> Thanks,
> Matt
>> I am trying to solve them iteratively by correcting the pressure to reach
>> a steady state. I start with 0 pressure. Currently, I am unable to solve
>> the first iteration (periodic in X and Z. V=0 at Y=0 and Dx(vy)+Dy(vx)=g(x)
>> at Y=10).
>> I think the equations might be singular but I am not sure as in my
>> experience, the problem is well posed if the solution is known at certain
>> boundaries.
>> [image: by default 2021-04-19 at 20.28.28.png]
>> On Mon, 19 Apr 2021 at 15:59, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Mon, Apr 19, 2021 at 9:37 AM Abhinav Singh <abhinavrajendra at gmail.com>
>>> wrote:
>>>> What does this mean? Stokes means using an incompressibility
>>>>> constraint, for which we often introduce a pressure.
>>>> Yes, what I mean is solving the momentum block, say with known
>>>> pressure. viscosity is constant however, the momentum equation has both
>>>> Laplacian and Gradient terms.
>>> That does not make any sense to me. Can you write the equation?
>>> Thanks,
>>> Matt
>>>> You should use a good Laplacian preconditioner, like -pc_type gamg or
>>>>> -pc_type ml.
>>>> I tried gamg and it seems to diverge as the solution is NaN. The KSP
>>>> residual message is " 0 KSP Residual norm 1.131782747169e+01 ".
>>>> When using -pc_type ml, I get Aggregate Warning and then some faulty
>>>> address which stops the code.
>>>> On Mon, 19 Apr 2021 at 12:31, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Apr 19, 2021 at 6:18 AM Abhinav Singh <
>>>>> abhinavrajendra at gmail.com> wrote:
>>>>>> Hello all,
>>>>>> I am trying to solve for incompressible stokes flow on a particle
>>>>>> based discretization. I use a pressure correction technique along with
>>>>>> Particle strength exchange like operators.
>>>>>> I call Petsc to solve the Stokes Equation without the pressure term.
>>>>> Do you mean you are solving only the momentum block? If so, do you
>>>>> have a constant viscosity? If so, then this is just the Laplace equation.
>>>>> -pc_type ml.
>>>>> Thanks
>>>>> Matt
>>>>>> GMRES usually works great but with dirichlet boundary conditions.
>>>>>> When I use a mixed boundary condition in Y, (dirichlet on bottom and
>>>>>> Neumann on the top) with periodicity in X,Z. GMRES fails converge when the
>>>>>> size of matrix increases. For smaller size (upto 27*27*5), only GMRES works
>>>>>> and that too only with the option 'pc_type none'. I was unable to find any
>>>>>> preconditioner which worked. Eventually, it also fails for bigger size.
>>>>>> UMFPACK works but LU decomposition fails after a certain size and is very
>>>>>> slow.
>>>>>> It would be great if you could suggest a way or a preconditioner
>>>>>> which suits this problem.
>>>>>> Kind regards,
>>>>>> Abhinav
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/e22abe2c/attachment-0001.html>
Name: by default 2021-04-19 at 20.28.28.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/e22abe2c/attachment-0001.png>
