[petsc-users] Preconditioner for stokes flow with mixed boundary conditions.
Matthew Knepley
knepley at gmail.com
Mon Apr 19 14:13:34 CDT 2021
On Mon, Apr 19, 2021 at 2:55 PM Abhinav Singh <abhinavrajendra at gmail.com>
wrote:
> The only reference that I know of which solves these equations is :
> https://www.pks.mpg.de/fileadmin/user_upload/MPIPKS/group_pages/BiologicalPhysics/juelicher/publications/2015/AHp-MMfIAPVG2015.pdf
These people are using a direct method.
> There is coordinate free form in the appendix. They have been solved using
> the UMFPACK Solver on staggered grids. I am trying a new approach (pressure
> correction with auxiliary potential). In 2 dimensions, the approach worked
> well with GMRES. In 3d, GMRES again works but with Dirichlet
GMRES with what preconditioner? It helps when you discuss solvers if you
send the output of -ksp_view.
Matt
> On Mon, 19 Apr 2021 at 20:45, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Apr 19, 2021 at 2:38 PM Abhinav Singh <abhinavrajendra at gmail.com>
>> wrote:
>>> Hello,
>>> The Stokes flow equations are a 3d version of the equations attached
>>> (Stokes-Leslie Flow). Only variables/unknowns are v and
>>> u_xy=0.5(Dx(vy)+Dy(vx).
>> This is not what I have referred to as Stokes flow (Google gave me no
>> results for Stokes-Leslie flow). The Stokes operator is elliptic, but I
>> have no idea if
>> what you have written is. It has fourth order derivatives in it, with
>> mixed nonlinear terms, so nothing is clear to me. Is there a
>> coordinate-independent form?
>> From what I see in the image, I have no idea what solvers might work. Do
>> you have any reference where people have solved this before?
>> Thanks,
>> Matt
>>> I am trying to solve them iteratively by correcting the pressure to
>>> reach a steady state. I start with 0 pressure. Currently, I am unable to
>>> solve the first iteration (periodic in X and Z. V=0 at Y=0 and
>>> Dx(vy)+Dy(vx)=g(x) at Y=10).
>>> I think the equations might be singular but I am not sure as in my
>>> experience, the problem is well posed if the solution is known at certain
>>> boundaries.
>>> [image: by default 2021-04-19 at 20.28.28.png]
>>> On Mon, 19 Apr 2021 at 15:59, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Mon, Apr 19, 2021 at 9:37 AM Abhinav Singh <
>>>> abhinavrajendra at gmail.com> wrote:
>>>>> What does this mean? Stokes means using an incompressibility
>>>>>> constraint, for which we often introduce a pressure.
>>>>> Yes, what I mean is solving the momentum block, say with known
>>>>> pressure. viscosity is constant however, the momentum equation has both
>>>>> Laplacian and Gradient terms.
>>>> That does not make any sense to me. Can you write the equation?
>>>> Thanks,
>>>> Matt
>>>>> You should use a good Laplacian preconditioner, like -pc_type gamg or
>>>>>> -pc_type ml.
>>>>> I tried gamg and it seems to diverge as the solution is NaN. The KSP
>>>>> residual message is " 0 KSP Residual norm 1.131782747169e+01 ".
>>>>> When using -pc_type ml, I get Aggregate Warning and then some faulty
>>>>> address which stops the code.
>>>>> On Mon, 19 Apr 2021 at 12:31, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Apr 19, 2021 at 6:18 AM Abhinav Singh <
>>>>>>> Hello all,
>>>>>>> I am trying to solve for incompressible stokes flow on a particle
>>>>>>> based discretization. I use a pressure correction technique along with
>>>>>>> Particle strength exchange like operators.
>>>>>>> I call Petsc to solve the Stokes Equation without the pressure term.
>>>>>> Do you mean you are solving only the momentum block? If so, do you
>>>>>> have a constant viscosity? If so, then this is just the Laplace equation.
>>>>>> -pc_type ml.
>>>>>> Thanks
>>>>>> Matt
>>>>>>> GMRES usually works great but with dirichlet boundary conditions.
>>>>>>> When I use a mixed boundary condition in Y, (dirichlet on bottom and
>>>>>>> Neumann on the top) with periodicity in X,Z. GMRES fails converge when the
>>>>>>> size of matrix increases. For smaller size (upto 27*27*5), only GMRES works
>>>>>>> and that too only with the option 'pc_type none'. I was unable to find any
>>>>>>> preconditioner which worked. Eventually, it also fails for bigger size.
>>>>>>> UMFPACK works but LU decomposition fails after a certain size and is very
>>>>>>> slow.
>>>>>>> It would be great if you could suggest a way or a preconditioner
>>>>>>> which suits this problem.
>>>>>>> Kind regards,
>>>>>>> Abhinav
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/c8e4c9bc/attachment-0001.html>
Name: by default 2021-04-19 at 20.28.28.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/c8e4c9bc/attachment-0001.png>
