[petsc-users] Serial solution of system in MPI FEM application
    Ivano Barletta
    ivano.barletta at cmcc.it
    Mon Apr 19 08:04:18 CDT 2021
Thanks
I've tried the first option, I get this compilation error
undefined reference to `matcreatesubmatrices_'
My PETSc version is 3.7.5, is this a feature of newer versions?
Ivano
Il giorno ven 16 apr 2021 alle ore 16:06 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Fri, Apr 16, 2021 at 9:46 AM Ivano Barletta <ivano.barletta at cmcc.it>
> wrote:
>> Dear all,
>> I have an MPI FEM application with an elliptic problem that I
>> solve with PETSc. For debugging purposes I want to
>> let the master process to solve the global system.
>> Is there any simple way in PETSc to gather the distributed matrix
>> (the type is MATMPIAIJ) on a single MPI process?
> You could use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateSubMatrices.html
> to extract a single, serial matrix on process 0. However, you can do this
> with the solver automatically using
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCTELESCOPE.html
> If you have the memory, you can do this more simply with
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCREDUNDANT.html
>   Thanks,
>      Matt
>> Thanks,
>> Ivano
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/5420ca68/attachment.html>
