[petsc-users] Serial solution of system in MPI FEM application
Matthew Knepley
knepley at gmail.com
Mon Apr 19 08:06:46 CDT 2021
On Mon, Apr 19, 2021 at 9:04 AM Ivano Barletta <ivano.barletta at cmcc.it>
wrote:
> Thanks
> I've tried the first option, I get this compilation error
> undefined reference to `matcreatesubmatrices_'
> My PETSc version is 3.7.5, is this a feature of newer versions?
It was renamed from MatGetSubMatrix()
https://www.mcs.anl.gov/petsc/documentation/changes/38.html
Matt
> Ivano
> Il giorno ven 16 apr 2021 alle ore 16:06 Matthew Knepley <
> knepley at gmail.com> ha scritto:
>> On Fri, Apr 16, 2021 at 9:46 AM Ivano Barletta <ivano.barletta at cmcc.it>
>> wrote:
>>> Dear all,
>>> I have an MPI FEM application with an elliptic problem that I
>>> solve with PETSc. For debugging purposes I want to
>>> let the master process to solve the global system.
>>> Is there any simple way in PETSc to gather the distributed matrix
>>> (the type is MATMPIAIJ) on a single MPI process?
>> You could use
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateSubMatrices.html
>> to extract a single, serial matrix on process 0. However, you can do this
>> with the solver automatically using
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCTELESCOPE.html
>> If you have the memory, you can do this more simply with
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCREDUNDANT.html
>> Thanks,
>> Matt
>>> Thanks,
>>> Ivano
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/8696eb3f/attachment.html>
