[petsc-users] Serial solution of system in MPI FEM application
Matthew Knepley
knepley at gmail.com
Fri Apr 16 09:06:45 CDT 2021
On Fri, Apr 16, 2021 at 9:46 AM Ivano Barletta <ivano.barletta at cmcc.it>
wrote:
> Dear all,
> I have an MPI FEM application with an elliptic problem that I
> solve with PETSc. For debugging purposes I want to
> let the master process to solve the global system.
> Is there any simple way in PETSc to gather the distributed matrix
> (the type is MATMPIAIJ) on a single MPI process?
You could use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateSubMatrices.html
to extract a single, serial matrix on process 0. However, you can do this
with the solver automatically using
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCTELESCOPE.html
If you have the memory, you can do this more simply with
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCREDUNDANT.html
Matt
> Thanks,
> Ivano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210416/b91b9794/attachment.html>
