[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
TAY wee-beng
zonexo at gmail.com
Thu Apr 15 20:16:56 CDT 2021
There's no error.log.
I have removed the LP64 lib but the error is still the same during
Fortran test below. Any other solution?
$ make PETSC_DIR=/cygdrive/e/wtay/Downloads/Source_codes/petsc-main
PETSC_ARCH=petsc-dev_win64_impi_vs2017 check
Running check examples to verify correct installation
Using PETSC_DIR=/cygdrive/e/wtay/Downloads/Source_codes/petsc-main and
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
make[3]:
[/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/conf/rules:350:
ex5f.PETSc] Error 2 (ignored)
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/src/snes/tutorials ex5f
/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/bin/win32fe/win32fe
ifort -MD -Z7 -fpp -MD -Z7 -fpp
-I/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/include
e_codes/petsc-main/petsc-dev_win64_impi_vs2017/include
-I/cygdrive/c/Program\ Files\
\(x86\)/Intel/oneAPI/mpi/latest/include ex5f.F90
-L/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/petsc-dev_win64_imp
i_vs2017/lib
-L/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/petsc-dev_win64_impi_vs2017/lib
-lpetsc -lflapack -lfblas /c
\(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\
Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib Gdi32.lib
User32.lib Advapi32.lib Kernel32.lib Ws2_3
2.lib -o ex5f
ex5f.F90(83): error #6405: The same named entity from different modules
and/or program units cannot be referenced. [PETSC_COMM_WORLD]
call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
ex5f.F90(83): error #7112: This actual argument must not be the name of
a procedure. [PETSC_COMM_WORLD]
ex5f.F90(84): error #6405: The same named entity from different modules
call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
ex5f.F90(84): error #7112: This actual argument must not be the name of
ex5f.F90(96): error #6405: The same named entity from different modules
ierr = PETSC_ERR_ARG_OUTOFRANGE; call
PetscError(PETSC_COMM_WORLD,ierr,0,'Lambda'); call
MPIU_Abort(PETSC_COMM_WORLD,ierr)
ex5f.F90(96): error #7112: This actual argument must not be the name of
ex5f.F90(103): error #6405: The same named entity from different modules
call SNESCreate(PETSC_COMM_WORLD,snes,ierr)
ex5f.F90(103): error #7112: This actual argument must not be the name of
ex5f.F90(120): error #6405: The same named entity from different modules
call
DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE, &
ex5f.F90(120): error #6285: There is no matching specific subroutine for
this generic subroutine call. [DMDACREATE2D]
call
compilation aborted for ex5f.F90 (code 1)
make[4]: ***
[/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/conf/test:23:
ex5f] Error 1
Completed test examples
Thank you very much.
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: _http://tayweebeng.wixsite.com/website_
Youtube research showcase: _https://goo.gl/PtvdwQ_
linkedin: _https://www.linkedin.com/in/tay-weebeng_
On 15/4/2021 11:12 pm, Satish Balay wrote:
> configure.log looks fine. What errors? resend the error log.
> BTW: ILP64 is the wrong version to use. The build is for LP64.
> /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
> Satish
> On Thu, 15 Apr 2021, TAY wee-beng wrote:
>> Hi,
>> Using main gave errors too. Attached configure.log.
>> Is there any other solution?
>> Yours sincerely,
>>>> On 15/4/2021 11:42 am, Satish Balay wrote:
>>>>> The c examples ran fine. However fortran has issues.
>>>>> Is the fortran compiler defaulting to F2008/2018 mode?
>>>>> You can try building 'release' branch of petsc git repo and see if this
>>>>> problem persists.
>>>> I tried and got this error below, configure.log attached.
>>>> export PETSC_DIR=`pwd`
>>>> export PETSC_ARCH=petsc-dev_win64_impi_vs2017
>>>> ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
>>>> --with-cxx='win32fe cl' --with-mpi-include=/cygdrive/c/Program\ Files\
>>>> --with-mpi-lib='[/cygdrive/c/Program\
>>>> Files\
>>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\
>>>> Files\
>>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\
>>>> _ilp64.lib]' --download-fblaslapack=1 --with-debugging=1
>>>> --with-fortran-interfaces=1
>>>> Configuring PETSc to compile on your system
>>>> TESTING: alternateConfigureLibrary from
>>>> config.packages.sprng(config/BuildSystem/config/package.py:959)
>>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>>>> details):
>>>> Error! sowing on windows requires cygwin/g++. Please install it with cygwin
>>>> setup.exe
>>> yes - this is a requirement for using the git repo.
>>> I guess alternatively - you can try:
>>> https://ftp.mcs.anl.gov/pub/petsc/petsc-main.tar.gz
>>> Satish
>>>>> Satish
>>>>>> Hi Satish,
>>>>>> I use option 1, but the errors I got from make check seems similar. I
>>>>>> have
>>>>>> attached the output.
>>>>>> Yours sincerely,
>>>>>> On 15/4/2021 9:54 am, Satish Balay wrote:
>>>>>>> 1. You can avoid this complexity if you can use in-place install of
>>>>>>> PETSc
>>>>>>> [i.e do not use --prefix option to build PETSc]
>>>>>>> 2. For a prefix install - the following patch should fix the issue [i.e
>>>>>>> requires rerunning 'configure; make; make install']
>>>>>>> diff --git a/config/BuildSystem/config/compilerOptions.py
>>>>>>> b/config/BuildSystem/config/compilerOptions.py
>>>>>>> index bdfd209203..b2e02783d9 100644
>>>>>>> --- a/config/BuildSystem/config/compilerOptions.py
>>>>>>> +++ b/config/BuildSystem/config/compilerOptions.py
>>>>>>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
>>>>>>> if not status:
>>>>>>> if compiler.find('win32fe') > -1:
>>>>>>> version = '\\n'.join(output.split('\n')[0:2])
>>>>>>> + version = version.replace('\r','')
>>>>>>> else:
>>>>>>> #PGI/Windows writes an empty '\r\n' on the first line of
>>>>>>> output
>>>>>>> if output.count('\n') > 1 and output.split('\n')[0] ==
>>>>>>> '\r':
>>>>>>> 3. For testing a prefix install - you would do:
>>>>>>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>> PETSC_ARCH=""
>>>>>>> [these instructions are printed to the screen when you run 'make
>>>>>>> install'
>>>>>>> Satish
>>>>>>>> Hi Satish,
>>>>>>>> I tried a few things, not sure if it's correct. But it doesn't seem to
>>>>>>>> work
>>>>>>>> I edit petscvariables in
>>>>>>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>>>>>> and
>>>>>>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>>>>>> from:
>>>>>>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
>>>>>>>> 27,
>>>>>>>> 2017 11:10:38 AM
>>>>>>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
>>>>>>>> MPICC_SHOW = Unavailable
>>>>>>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
>>>>>>>> 27,
>>>>>>>> 2017 11:10:38 AM
>>>>>>>> MPICXX_SHOW = Unavailable
>>>>>>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
>>>>>>>> 27,
>>>>>>>> 2017 11:10:38 AM
>>>>>>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications
>>>>>>>> running
>>>>>>>> on
>>>>>>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
>>>>>>>> to
>>>>>>>> 27,
>>>>>>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
>>>>>>>> 19.16.27045 for x64
>>>>>>>> 27,
>>>>>>>> 19.16.27045 for x64
>>>>>>>> 27,
>>>>>>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
>>>>>>>> applications running on Intel(R) 64, Version 2021.2.0 Build
>>>>>>>> 20210228_000000
>>>>>>>> Then in cygwin,
>>>>>>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
>>>>>>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>>>>>> make check
>>>>>>>> make: *** No rule to make target 'check'. Stop.
>>>>>>>> Also:
>>>>>>>> $ export PETSC_DIR=`pwd`
>>>>>>>> make check
>>>>>>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: ***
>>>>>>>> target
>>>>>>>> pattern contains no '%'. Stop.
>>>>>>>> Yours sincerely,
>>>>>>>>>> Hi Satish,
>>>>>>>>>> Sorry, what do you mean by "manually fix up this file"?
>>>>>>>>>> Should I edit the petscvariables file?
>>>>>>>>> yes
>>>>>>>>>> Do I need to rebuild the lib?
>>>>>>>>> no
>>>>>>>>> After editing the file - run 'make check'
>>>>>>>>> Satish
>>>>>>>>>> I guess this problem is related to the new Intel oneAPI if I'm not
>>>>>>>>>> wrong.
>>>>>>>>>> No
>>>>>>>>>> such problem previously.
>>>>>>>>>> Yours sincerely,
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 2017 11:10:38 AM
>>>>>>>>>>> x64
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 2017 11:10:38 AM
>>>>>>>>>>> x64
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 2017 11:10:38 AM
>>>>>>>>>>> running
>>>>>>>>>>> on
>>>>>>>>>>> I'm not sure what happened here. You might want to just manually fix
>>>>>>>>>>> up
>>>>>>>>>>> this
>>>>>>>>>>> file
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 19.16.27045 for x64
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 19.16.27045 for x64
>>>>>>>>>>> Feb
>>>>>>>>>>> 27,
>>>>>>>>>>> 20210228_000000
>>>>>>>>>>> Satish
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> I have attached the req file
>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
>>>>>>>>>>>>> Please send the file
>>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
>>>>>>>>>>>>> Satish
>>>>>>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> I redo the installation:
>>>>>>>>>>>>>> /*Now to install the libraries do:*//*
>>>>>>>>>>>>>> *//*make
>>>>>>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
>>>>>>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
>>>>>>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
>>>>>>>>>>>>>> *//*$ make
>>>>>>>>>>>>>> *//**** Using
>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
>>>>>>>>>>>>>> *//**** Installing PETSc at prefix location:
>>>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 ****//*
>>>>>>>>>>>>>> *//*Install complete.*//*
>>>>>>>>>>>>>> *//*Now to check if the libraries are working do (in current
>>>>>>>>>>>>>> directory):*//*
>>>>>>>>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>>>>>> PETSC_ARCH="" check*//*
>>>>>>>>>>>>>> *//*/usr/bin/make --no-print-directory -f makefile
>>>>>>>>>>>>>> mpi4py-install
>>>>>>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
>>>>>>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
>>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
>>>>>>>>>>>>>> I ran the check:
>>>>>>>>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
>>>>>>>>>>>>>> *** missing separator. Stop.*/
>>>>>>>>>>>>>> Why is this happening?
>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
>>>>>>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
>>>>>>>>>>>>>>> When you do the install it will tell you exactly what to run to
>>>>>>>>>>>>>>> run
>>>>>>>>>>>>>>> "check".
>>>>>>>>>>>>>>> You might double check that .
>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
>>>>>>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
>>>>>>>>>>>>>>> Hi Barry,
>>>>>>>>>>>>>>> Ops, which dir should I run /*export
>>>>>>>>>>>>>>> PETSC_DIR=`pwd`*//*
>>>>>>>>>>>>>>> Maybe I ran it wrongly initially at where the lib is
>>>>>>>>>>>>>>> stored:
>>>>>>>>>>>>>>> /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
>>>>>>>>>>>>>>> My source is at
>>>>>>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
>>>>>>>>>>>>>>> Now I ran:
>>>>>>>>>>>>>>> /*export PETSC_DIR=`pwd`*//*
>>>>>>>>>>>>>>> *//*cd src/ksp/ksp/tutorials/*//*
>>>>>>>>>>>>>>> *//*make ex2f*/
>>>>>>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
>>>>>>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
>>>>>>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/S*//*
>>>>>>>>>>>>>>> *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
>>>>>>>>>>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/include ex2f.F90
>>>>>>>>>>>>>>> -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
>>>>>>>>>>>>>>> *//*15.0_win64_impi_vs2017/lib
>>>>>>>>>>>>>>> -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>>>>> -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>>>>> -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
>>>>>>>>>>>>>>> *//*_vs2017/lib -lpetsc -lflapack -lfblas
>>>>>>>>>>>>>>> Files\
>>>>>>>>>>>>>>> /cygdrive/c/*//*
>>>>>>>>>>>>>>> *//*Program\ Files\
>>>>>>>>>>>>>>> Gdi32.lib
>>>>>>>>>>>>>>> User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o
>>>>>>>>>>>>>>> ex2f*//*
>>>>>>>>>>>>>>> *//*ifort: command line warning #10006: ignoring
>>>>>>>>>>>>>>> unknown
>>>>>>>>>>>>>>> option
>>>>>>>>>>>>>>> '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>>>>> unknown
>>>>>>>>>>>>>>> option
>>>>>>>>>>>>>>> '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(80): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> different modules and/or program units cannot be
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(80): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> the name of a procedure. [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(81): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(81): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(93): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(93): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//*ex2f.F90(159): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(159): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(171): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(171): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(193): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
>>>>>>>>>>>>>>> *//*ex2f.F90(193): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(319): error #6405: The same named entity
>>>>>>>>>>>>>>> from
>>>>>>>>>>>>>>> referenced.
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*ex2f.F90(319): error #7112: This actual argument
>>>>>>>>>>>>>>> must
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> *//* call
>>>>>>>>>>>>>>> *//*compilation aborted for ex2f.F90 (code 1)*//*
>>>>>>>>>>>>>>> *//*make: ***
>>>>>>>>>>>>>>> [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
>>>>>>>>>>>>>>> ex2f] Error 1*/
>>>>>>>>>>>>>>> I have also attached the "/*make check*/" output.
>>>>>>>>>>>>>>> Seems
>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>> there's problem with fortran compile.
>>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>>> <http://tayweebeng.wixsite.com/website>_
>>>>>>>>>>>>>>> <https://goo.gl/PtvdwQ>_
>>>>>>>>>>>>>>> <https://www.linkedin.com/in/tay-weebeng>_
>>>>>>>>>>>>>>> On 14/4/2021 3:47 pm, Barry Smith wrote:
>>>>>>>>>>>>>>>> Please send configure.log and make.log and the
>>>>>>>>>>>>>>>> results
>>>>>>>>>>>>>>>> of
>>>>>>>>>>>>>>>> "make
>>>>>>>>>>>>>>>> check" so we have the details on the build process.
>>>>>>>>>>>>>>>>> /*No rule to make target
>>>>>>>>>>>>>>>>> '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
>>>>>>>>>>>>>>>>> Stop.*/
>>>>>>>>>>>>>>>> Looks funny; it does not seem to separate the PETSc
>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>> from its configuration directory appropriately.
>>>>>>>>>>>>>>>> Are you sure
>>>>>>>>>>>>>>>>> *//*export
>>>>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
>>>>>>>>>>>>>>>> are run in the appropriate directory so that
>>>>>>>>>>>>>>>> PETSC_DIR
>>>>>>>>>>>>>>>> is
>>>>>>>>>>>>>>>> correct.
>>>>>>>>>>>>>>>> Barry
>>>>>>>>>>>>>>>>> On Apr 14, 2021, at 2:20 AM, TAY wee-beng
>>>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>>>> I'm not sure what's wrong.
>>>>>>>>>>>>>>>>> In VS2017 + Intel oneAPI,
>>>>>>>>>>>>>>>>> even after adding the full path:
>>>>>>>>>>>>>>>>> #include
>>>>>>>>>>>>>>>>> <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
>>>>>>>>>>>>>>>>> I got a new error:
>>>>>>>>>>>>>>>>> /*Compiling with Intel® Fortran Compiler Classic
>>>>>>>>>>>>>>>>> 2021.2.0
>>>>>>>>>>>>>>>>> [Intel(R) 64]...*//*
>>>>>>>>>>>>>>>>> *//*ex2f.F90*//*
>>>>>>>>>>>>>>>>> *//*petscksp.h(8): #error: can't find include file:
>>>>>>>>>>>>>>>>> petsc/finclude/petscpc.h*//*
>>>>>>>>>>>>>>>>> *//*ex2f : error PRJ0019: A tool returned an error
>>>>>>>>>>>>>>>>> code*/
>>>>>>>>>>>>>>>>> Note that I have also specified the include dir in
>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>> properties:
>>>>>>>>>>>>>>>>> /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
>>>>>>>>>>>>>>>>> I also tried in cygwin:
>>>>>>>>>>>>>>>>> *//*export
>>>>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
>>>>>>>>>>>>>>>>> *//*make ex2f*/
>>>>>>>>>>>>>>>>> I got the error:
>>>>>>>>>>>>>>>>> /*$ make ex2f*//*
>>>>>>>>>>>>>>>>> *//*makefile:41:
>>>>>>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
>>>>>>>>>>>>>>>>> No such file or directory*//*
>>>>>>>>>>>>>>>>> *//*make: *** No rule to make target
>>>>>>>>>>>>>>>>> Stop.*/
>>>>>>>>>>>>>>>>> Somehow it just doesn't work. Building the library
>>>>>>>>>>>>>>>>> has
>>>>>>>>>>>>>>>>> no
>>>>>>>>>>>>>>>>> problem though.
>>>>>>>>>>>>>>>>> I wonder what's wrong.
>>>>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>>>>> On 14/4/2021 9:31 am, Mark Adams wrote:
>>>>>>>>>>>>>>>>>> PETSc has changed Fortran syntax since v3.9. You
>>>>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>>>>> upgrade. Look at examples for how to use modules
>>>>>>>>>>>>>>>>>> etc.
>>>>>>>>>>>>>>>>>> Classic
>>>>>>>>>>>>>>>>>> 2021.2.0
>>>>>>>>>>>>>>>>>> *//*global.F90*//*
>>>>>>>>>>>>>>>>>> *//*global.F90(3): #error: can't find include
>>>>>>>>>>>>>>>>>> file:
>>>>>>>>>>>>>>>>>> petsc/finclude/petsc.h*//*
>>>>>>>>>>>>>>>>>> *//*global.F90(937): #error: can't find include
>>>>>>>>>>>>>>>>>> file:
>>>>>>>>>>>>>>>>>> It looks like you might not have your PETSC_ARCH
>>>>>>>>>>>>>>>>>> variable set.
>>>>>>>>>>>>>>>>>> You should get a full path to /finclude/petsc.h.
>>>>>>>>>>>>>>>>>> Look
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>> compile line.
>>>>>>>>>>>>>>>>>> There are PETSc examples that you you can make to
>>>>>>>>>>>>>>>>>> see
>>>>>>>>>>>>>>>>>> an
>>>>>>>>>>>>>>>>>> example of a correct make. For example,
>>>>>>>>>>>>>>>>>> > cd petsc/src/ksp/ksp/tutorials
>>>>>>>>>>>>>>>>>> > > > > > > > > > > > > > > > > make
>>>>>>>>>>>>>>>>>> > > > > > > > > > ex2f
>>>>>>>>>>>>>>>>>> should make an executable and you can look at the
>>>>>>>>>>>>>>>>>> compile
>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>> link lines, and compare to what you are using.
>>>>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>>>>>> linkedin:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210416/d8469733/attachment-0001.html>
