[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
Satish Balay
balay at mcs.anl.gov
Sat Apr 17 09:08:34 CDT 2021
Can you try editing this example and changing PETSC_COMM_WORLD to MPI_COMM_WORLD - and
see if that works?
Satish
On Fri, 16 Apr 2021, TAY wee-beng wrote:
> Hi,
> There's no error.log.
> I have removed the LP64 lib but the error is still the same during Fortran
> test below. Any other solution?
> $ make PETSC_DIR=/cygdrive/e/wtay/Downloads/Source_codes/petsc-main
> PETSC_ARCH=petsc-dev_win64_impi_vs2017 check
> Running check examples to verify correct installation
> Using PETSC_DIR=/cygdrive/e/wtay/Downloads/Source_codes/petsc-main and
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
> make[3]:
> [/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/conf/rules:350:
> ex5f.PETSc] Error 2 (ignored)
> *******************Error detected during compile or link!*******************
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> /cygdrive/e/wtay/Downloads/Source_codes/petsc-main/src/snes/tutorials ex5f
> /cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/bin/win32fe/win32fe
> ifort -MD -Z7 -fpp -MD -Z7 -fpp
> -I/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/include
> e_codes/petsc-main/petsc-dev_win64_impi_vs2017/include -I/cygdrive/c/Program\
> Files\ \(x86\)/Intel/oneAPI/mpi/latest/include ex5f.F90
> -L/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/petsc-dev_win64_imp
> i_vs2017/lib
> -L/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/petsc-dev_win64_impi_vs2017/lib
> -lpetsc -lflapack -lfblas /c
> ygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
> /cygdrive/c/Program\ Files\
> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib Gdi32.lib User32.lib
> Advapi32.lib Kernel32.lib Ws2_3
> 2.lib -o ex5f
> ex5f.F90(83): error #6405: The same named entity from different modules and/or
> program units cannot be referenced. [PETSC_COMM_WORLD]
> call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
> ex5f.F90(83): error #7112: This actual argument must not be the name of a
> procedure. [PETSC_COMM_WORLD]
> ex5f.F90(84): error #6405: The same named entity from different modules and/or
> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
> ex5f.F90(84): error #7112: This actual argument must not be the name of a
> ex5f.F90(96): error #6405: The same named entity from different modules and/or
> ierr = PETSC_ERR_ARG_OUTOFRANGE; call
> PetscError(PETSC_COMM_WORLD,ierr,0,'Lambda'); call
> MPIU_Abort(PETSC_COMM_WORLD,ierr)
> ex5f.F90(96): error #7112: This actual argument must not be the name of a
> ex5f.F90(103): error #6405: The same named entity from different modules
> and/or program units cannot be referenced. [PETSC_COMM_WORLD]
> call SNESCreate(PETSC_COMM_WORLD,snes,ierr)
> ex5f.F90(103): error #7112: This actual argument must not be the name of a
> ex5f.F90(120): error #6405: The same named entity from different modules
> call DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE, &
> ex5f.F90(120): error #6285: There is no matching specific subroutine for this
> generic subroutine call. [DMDACREATE2D]
> compilation aborted for ex5f.F90 (code 1)
> make[4]: ***
> [/cygdrive/e/wtay/Downloads/Source_codes/petsc-main/lib/petsc/conf/test:23:
> ex5f] Error 1
> Completed test examples
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> Personal research webpage: _http://tayweebeng.wixsite.com/website_
> Youtube research showcase: _https://goo.gl/PtvdwQ_
> linkedin: _https://www.linkedin.com/in/tay-weebeng_
> On 15/4/2021 11:12 pm, Satish Balay wrote:
> > configure.log looks fine. What errors? resend the error log.
> > BTW: ILP64 is the wrong version to use. The build is for LP64.
> > \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
> > Satish
> > On Thu, 15 Apr 2021, TAY wee-beng wrote:
> >> Hi,
> >> Using main gave errors too. Attached configure.log.
> >> Is there any other solution?
> >> Yours sincerely,
> >>>> On 15/4/2021 11:42 am, Satish Balay wrote:
> >>>>> The c examples ran fine. However fortran has issues.
> >>>>> Is the fortran compiler defaulting to F2008/2018 mode?
> >>>>> You can try building 'release' branch of petsc git repo and see if this
> >>>>> problem persists.
> >>>> I tried and got this error below, configure.log attached.
> >>>> export PETSC_DIR=`pwd`
> >>>> export PETSC_ARCH=petsc-dev_win64_impi_vs2017
> >>>> ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> >>>> --with-cxx='win32fe cl' --with-mpi-include=/cygdrive/c/Program\ Files\
> >>>> --with-mpi-lib='[/cygdrive/c/Program\
> >>>> Files\
> >>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\
> >>>> Files\
> >>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\
> >>>> Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi
> >>>> _ilp64.lib]' --download-fblaslapack=1 --with-debugging=1
> >>>> --with-fortran-interfaces=1
> >>>> Configuring PETSc to compile on your system
> >>>> TESTING: alternateConfigureLibrary from
> >>>> config.packages.sprng(config/BuildSystem/config/package.py:959)
> >>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> >>>> details):
> >>>> Error! sowing on windows requires cygwin/g++. Please install it with
> >>>> cygwin
> >>>> setup.exe
> >>> yes - this is a requirement for using the git repo.
> >>> I guess alternatively - you can try:
> >>> https://ftp.mcs.anl.gov/pub/petsc/petsc-main.tar.gz
> >>> Satish
> >>>>> Satish
> >>>>>> Hi Satish,
> >>>>>> I use option 1, but the errors I got from make check seems similar. I
> >>>>>> have
> >>>>>> attached the output.
> >>>>>> Yours sincerely,
> >>>>>> On 15/4/2021 9:54 am, Satish Balay wrote:
> >>>>>>> 1. You can avoid this complexity if you can use in-place install of
> >>>>>>> PETSc
> >>>>>>> [i.e do not use --prefix option to build PETSc]
> >>>>>>> 2. For a prefix install - the following patch should fix the issue
> >>>>>>> [i.e
> >>>>>>> requires rerunning 'configure; make; make install']
> >>>>>>> diff --git a/config/BuildSystem/config/compilerOptions.py
> >>>>>>> b/config/BuildSystem/config/compilerOptions.py
> >>>>>>> index bdfd209203..b2e02783d9 100644
> >>>>>>> --- a/config/BuildSystem/config/compilerOptions.py
> >>>>>>> +++ b/config/BuildSystem/config/compilerOptions.py
> >>>>>>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
> >>>>>>> if not status:
> >>>>>>> if compiler.find('win32fe') > -1:
> >>>>>>> version = '\\n'.join(output.split('\n')[0:2])
> >>>>>>> + version = version.replace('\r','')
> >>>>>>> else:
> >>>>>>> #PGI/Windows writes an empty '\r\n' on the first line
> >>>>>>> of
> >>>>>>> output
> >>>>>>> if output.count('\n') > 1 and output.split('\n')[0] ==
> >>>>>>> '\r':
> >>>>>>> 3. For testing a prefix install - you would do:
> >>>>>>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>> PETSC_ARCH=""
> >>>>>>> [these instructions are printed to the screen when you run 'make
> >>>>>>> install'
> >>>>>>> Satish
> >>>>>>>> Hi Satish,
> >>>>>>>> I tried a few things, not sure if it's correct. But it doesn't seem
> >>>>>>>> to
> >>>>>>>> work
> >>>>>>>> I edit petscvariables in
> >>>>>>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>>>>>> and
> >>>>>>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>>>>>> from:
> >>>>>>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>>>>>> 27,
> >>>>>>>> 2017 11:10:38 AM
> >>>>>>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
> >>>>>>>> MPICC_SHOW = Unavailable
> >>>>>>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon,
> >>>>>>>> Feb
> >>>>>>>> 27,
> >>>>>>>> 2017 11:10:38 AM
> >>>>>>>> MPICXX_SHOW = Unavailable
> >>>>>>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon,
> >>>>>>>> Feb
> >>>>>>>> 27,
> >>>>>>>> 2017 11:10:38 AM
> >>>>>>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications
> >>>>>>>> running
> >>>>>>>> on
> >>>>>>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> >>>>>>>> to
> >>>>>>>> 27,
> >>>>>>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
> >>>>>>>> 19.16.27045 for x64
> >>>>>>>> Feb
> >>>>>>>> 27,
> >>>>>>>> 19.16.27045 for x64
> >>>>>>>> Feb
> >>>>>>>> 27,
> >>>>>>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
> >>>>>>>> applications running on Intel(R) 64, Version 2021.2.0 Build
> >>>>>>>> 20210228_000000
> >>>>>>>> Then in cygwin,
> >>>>>>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
> >>>>>>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>>> make check
> >>>>>>>> make: *** No rule to make target 'check'. Stop.
> >>>>>>>> Also:
> >>>>>>>> $ export PETSC_DIR=`pwd`
> >>>>>>>> make check
> >>>>>>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: ***
> >>>>>>>> target
> >>>>>>>> pattern contains no '%'. Stop.
> >>>>>>>> Yours sincerely,
> >>>>>>>>>> Hi Satish,
> >>>>>>>>>> Sorry, what do you mean by "manually fix up this file"?
> >>>>>>>>>> Should I edit the petscvariables file?
> >>>>>>>>> yes
> >>>>>>>>>> Do I need to rebuild the lib?
> >>>>>>>>> no
> >>>>>>>>> After editing the file - run 'make check'
> >>>>>>>>> Satish
> >>>>>>>>>> I guess this problem is related to the new Intel oneAPI if I'm not
> >>>>>>>>>> wrong.
> >>>>>>>>>> No
> >>>>>>>>>> such problem previously.
> >>>>>>>>>> Yours sincerely,
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>>>> x64
> >>>>>>>>>>> Mon,
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>>>> x64
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>>>> running
> >>>>>>>>>>> on
> >>>>>>>>>>> I'm not sure what happened here. You might want to just manually
> >>>>>>>>>>> fix
> >>>>>>>>>>> up
> >>>>>>>>>>> this
> >>>>>>>>>>> file
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> 19.16.27045 for x64
> >>>>>>>>>>> Mon,
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> 19.16.27045 for x64
> >>>>>>>>>>> Feb
> >>>>>>>>>>> 27,
> >>>>>>>>>>> for
> >>>>>>>>>>> 20210228_000000
> >>>>>>>>>>> Satish
> >>>>>>>>>>>> Hi all,
> >>>>>>>>>>>> I have attached the req file
> >>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
> >>>>>>>>>>>>> Please send the file
> >>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> >>>>>>>>>>>>> Satish
> >>>>>>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
> >>>>>>>>>>>>>> Hi,
> >>>>>>>>>>>>>> I redo the installation:
> >>>>>>>>>>>>>> /*Now to install the libraries do:*//*
> >>>>>>>>>>>>>> *//*make
> >>>>>>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
> >>>>>>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
> >>>>>>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
> >>>>>>>>>>>>>> *//*$ make
> >>>>>>>>>>>>>> *//**** Using
> >>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>>>>>>>> *//**** Installing PETSc at prefix location:
> >>>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>>>>>>>> *//*Install complete.*//*
> >>>>>>>>>>>>>> *//*Now to check if the libraries are working do (in current
> >>>>>>>>>>>>>> directory):*//*
> >>>>>>>>>>>>>> *//*make
> >>>>>>>>>>>>>> PETSC_ARCH="" check*//*
> >>>>>>>>>>>>>> *//*/usr/bin/make --no-print-directory -f makefile
> >>>>>>>>>>>>>> mpi4py-install
> >>>>>>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
> >>>>>>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install
> >>>>>>>>>>>>>> bamg-install*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
> >>>>>>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
> >>>>>>>>>>>>>> I ran the check:
> >>>>>>>>>>>>>> /*$ make
> >>>>>>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
> >>>>>>>>>>>>>> *** missing separator. Stop.*/
> >>>>>>>>>>>>>> Why is this happening?
> >>>>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
> >>>>>>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
> >>>>>>>>>>>>>>> When you do the install it will tell you exactly what to run
> >>>>>>>>>>>>>>> to
> >>>>>>>>>>>>>>> run
> >>>>>>>>>>>>>>> "check".
> >>>>>>>>>>>>>>> You might double check that .
> >>>>>>>>>>>>>>> Mark
> >>>>>>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
> >>>>>>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
> >>>>>>>>>>>>>>> Hi Barry,
> >>>>>>>>>>>>>>> Ops, which dir should I run /*export
> >>>>>>>>>>>>>>> PETSC_DIR=`pwd`*//*
> >>>>>>>>>>>>>>> Maybe I ran it wrongly initially at where the lib
> >>>>>>>>>>>>>>> is
> >>>>>>>>>>>>>>> stored:
> >>>>>>>>>>>>>>> /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
> >>>>>>>>>>>>>>> My source is at
> >>>>>>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
> >>>>>>>>>>>>>>> Now I ran:
> >>>>>>>>>>>>>>> /*export PETSC_DIR=`pwd`*//*
> >>>>>>>>>>>>>>> *//*cd src/ksp/ksp/tutorials/*//*
> >>>>>>>>>>>>>>> *//*make ex2f*/
> >>>>>>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
> >>>>>>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
> >>>>>>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/S*//*
> >>>>>>>>>>>>>>> *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
> >>>>>>>>>>>>>>> -I/cygdrive/c/Program\ Files\
> >>>>>>>>>>>>>>> ex2f.F90
> >>>>>>>>>>>>>>> -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
> >>>>>>>>>>>>>>> *//*15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>>> -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>>> -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>>> -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
> >>>>>>>>>>>>>>> *//*_vs2017/lib -lpetsc -lflapack -lfblas
> >>>>>>>>>>>>>>> Files\
> >>>>>>>>>>>>>>> /cygdrive/c/*//*
> >>>>>>>>>>>>>>> *//*Program\ Files\
> >>>>>>>>>>>>>>> Gdi32.lib
> >>>>>>>>>>>>>>> User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o
> >>>>>>>>>>>>>>> ex2f*//*
> >>>>>>>>>>>>>>> *//*ifort: command line warning #10006: ignoring
> >>>>>>>>>>>>>>> unknown
> >>>>>>>>>>>>>>> option
> >>>>>>>>>>>>>>> '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>>>>>> unknown
> >>>>>>>>>>>>>>> option
> >>>>>>>>>>>>>>> '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(80): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> different modules and/or program units cannot be
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(80): error #7112: This actual argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> the name of a procedure. [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(81): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(81): error #7112: This actual argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(93): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(93): error #7112: This actual argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(159): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(159): error #7112: This actual
> >>>>>>>>>>>>>>> argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(171): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(171): error #7112: This actual
> >>>>>>>>>>>>>>> argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(193): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
> >>>>>>>>>>>>>>> *//*ex2f.F90(193): error #7112: This actual
> >>>>>>>>>>>>>>> argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(319): error #6405: The same named
> >>>>>>>>>>>>>>> entity
> >>>>>>>>>>>>>>> from
> >>>>>>>>>>>>>>> referenced.
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*ex2f.F90(319): error #7112: This actual
> >>>>>>>>>>>>>>> argument
> >>>>>>>>>>>>>>> must
> >>>>>>>>>>>>>>> not
> >>>>>>>>>>>>>>> be
> >>>>>>>>>>>>>>> *//* call
> >>>>>>>>>>>>>>> *//*compilation aborted for ex2f.F90 (code 1)*//*
> >>>>>>>>>>>>>>> *//*make: ***
> >>>>>>>>>>>>>>> [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
> >>>>>>>>>>>>>>> ex2f] Error 1*/
> >>>>>>>>>>>>>>> I have also attached the "/*make check*/" output.
> >>>>>>>>>>>>>>> Seems
> >>>>>>>>>>>>>>> like
> >>>>>>>>>>>>>>> there's problem with fortran compile.
> >>>>>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>>>>> <http://tayweebeng.wixsite.com/website>_
> >>>>>>>>>>>>>>> <https://goo.gl/PtvdwQ>_
> >>>>>>>>>>>>>>> <https://www.linkedin.com/in/tay-weebeng>_
> >>>>>>>>>>>>>>> On 14/4/2021 3:47 pm, Barry Smith wrote:
> >>>>>>>>>>>>>>>> Please send configure.log and make.log and the
> >>>>>>>>>>>>>>>> results
> >>>>>>>>>>>>>>>> of
> >>>>>>>>>>>>>>>> "make
> >>>>>>>>>>>>>>>> check" so we have the details on the build
> >>>>>>>>>>>>>>>> process.
> >>>>>>>>>>>>>>>>> /*No rule to make target
> >>>>>>>>>>>>>>>>> '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
> >>>>>>>>>>>>>>>>> Stop.*/
> >>>>>>>>>>>>>>>> Looks funny; it does not seem to separate the
> >>>>>>>>>>>>>>>> PETSc
> >>>>>>>>>>>>>>>> directory
> >>>>>>>>>>>>>>>> from its configuration directory appropriately.
> >>>>>>>>>>>>>>>> Are you sure
> >>>>>>>>>>>>>>>>> *//*export
> >>>>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
> >>>>>>>>>>>>>>>> are run in the appropriate directory so that
> >>>>>>>>>>>>>>>> PETSC_DIR
> >>>>>>>>>>>>>>>> is
> >>>>>>>>>>>>>>>> correct.
> >>>>>>>>>>>>>>>> Barry
> >>>>>>>>>>>>>>>>> On Apr 14, 2021, at 2:20 AM, TAY wee-beng
> >>>>>>>>>>>>>>>>> Hi Mark,
> >>>>>>>>>>>>>>>>> I'm not sure what's wrong.
> >>>>>>>>>>>>>>>>> In VS2017 + Intel oneAPI,
> >>>>>>>>>>>>>>>>> even after adding the full path:
> >>>>>>>>>>>>>>>>> #include
> >>>>>>>>>>>>>>>>> <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
> >>>>>>>>>>>>>>>>> I got a new error:
> >>>>>>>>>>>>>>>>> /*Compiling with Intel® Fortran Compiler Classic
> >>>>>>>>>>>>>>>>> 2021.2.0
> >>>>>>>>>>>>>>>>> [Intel(R) 64]...*//*
> >>>>>>>>>>>>>>>>> *//*ex2f.F90*//*
> >>>>>>>>>>>>>>>>> *//*petscksp.h(8): #error: can't find include
> >>>>>>>>>>>>>>>>> file:
> >>>>>>>>>>>>>>>>> petsc/finclude/petscpc.h*//*
> >>>>>>>>>>>>>>>>> *//*ex2f : error PRJ0019: A tool returned an
> >>>>>>>>>>>>>>>>> error
> >>>>>>>>>>>>>>>>> code*/
> >>>>>>>>>>>>>>>>> Note that I have also specified the include dir
> >>>>>>>>>>>>>>>>> in
> >>>>>>>>>>>>>>>>> the
> >>>>>>>>>>>>>>>>> properties:
> >>>>>>>>>>>>>>>>> /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
> >>>>>>>>>>>>>>>>> I also tried in cygwin:
> >>>>>>>>>>>>>>>>> *//*export
> >>>>>>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
> >>>>>>>>>>>>>>>>> *//*make ex2f*/
> >>>>>>>>>>>>>>>>> I got the error:
> >>>>>>>>>>>>>>>>> /*$ make ex2f*//*
> >>>>>>>>>>>>>>>>> *//*makefile:41:
> >>>>>>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
> >>>>>>>>>>>>>>>>> No such file or directory*//*
> >>>>>>>>>>>>>>>>> *//*make: *** No rule to make target
> >>>>>>>>>>>>>>>>> Stop.*/
> >>>>>>>>>>>>>>>>> Somehow it just doesn't work. Building the
> >>>>>>>>>>>>>>>>> library
> >>>>>>>>>>>>>>>>> has
> >>>>>>>>>>>>>>>>> no
> >>>>>>>>>>>>>>>>> problem though.
> >>>>>>>>>>>>>>>>> I wonder what's wrong.
> >>>>>>>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>>>>>>> linkedin:
> >>>>>>>>>>>>>>>>> On 14/4/2021 9:31 am, Mark Adams wrote:
> >>>>>>>>>>>>>>>>>> PETSc has changed Fortran syntax since v3.9. You
> >>>>>>>>>>>>>>>>>> should
> >>>>>>>>>>>>>>>>>> upgrade. Look at examples for how to use modules
> >>>>>>>>>>>>>>>>>> etc.
> >>>>>>>>>>>>>>>>>> Classic
> >>>>>>>>>>>>>>>>>> 2021.2.0
> >>>>>>>>>>>>>>>>>> *//*global.F90*//*
> >>>>>>>>>>>>>>>>>> *//*global.F90(3): #error: can't find
> >>>>>>>>>>>>>>>>>> include
> >>>>>>>>>>>>>>>>>> file:
> >>>>>>>>>>>>>>>>>> petsc/finclude/petsc.h*//*
> >>>>>>>>>>>>>>>>>> *//*global.F90(937): #error: can't find
> >>>>>>>>>>>>>>>>>> include
> >>>>>>>>>>>>>>>>>> file:
> >>>>>>>>>>>>>>>>>> It looks like you might not have your PETSC_ARCH
> >>>>>>>>>>>>>>>>>> variable set.
> >>>>>>>>>>>>>>>>>> You should get a full path to /finclude/petsc.h.
> >>>>>>>>>>>>>>>>>> Look
> >>>>>>>>>>>>>>>>>> at
> >>>>>>>>>>>>>>>>>> the
> >>>>>>>>>>>>>>>>>> compile line.
> >>>>>>>>>>>>>>>>>> There are PETSc examples that you you can make
> >>>>>>>>>>>>>>>>>> to
> >>>>>>>>>>>>>>>>>> see
> >>>>>>>>>>>>>>>>>> an
> >>>>>>>>>>>>>>>>>> example of a correct make. For example,
> >>>>>>>>>>>>>>>>>> > cd petsc/src/ksp/ksp/tutorials
