[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
Thu Apr 15 10:12:51 CDT 2021
configure.log looks fine. What errors? resend the error log.
BTW: ILP64 is the wrong version to use. The build is for LP64.
/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
Satish
On Thu, 15 Apr 2021, TAY wee-beng wrote:
> Hi,
> Using main gave errors too. Attached configure.log.
> Is there any other solution?
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> Personal research webpage: _http://tayweebeng.wixsite.com/website_
> Youtube research showcase: _https://goo.gl/PtvdwQ_
> linkedin: _https://www.linkedin.com/in/tay-weebeng_
> >> On 15/4/2021 11:42 am, Satish Balay wrote:
> >>> The c examples ran fine. However fortran has issues.
> >>> ex5f.F90(83): error #6405: The same named entity from different modules
> >>> and/or program units cannot be referenced.   [PETSC_COMM_WORLD]
> >>>         call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
> >>> Is the fortran compiler defaulting to F2008/2018 mode?
> >>> You can try building 'release' branch of petsc git repo and see if this
> >>> problem persists.
> >> I tried and got this error below, configure.log attached.
> >> export PETSC_DIR=`pwd`
> >> export PETSC_ARCH=petsc-dev_win64_impi_vs2017
> >> ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> >> --with-cxx='win32fe cl' --with-mpi-include=/cygdrive/c/Program\ Files\
> >> \(x86\)/Intel/oneAPI/mpi/latest/include
> >> --with-mpi-lib='[/cygdrive/c/Program\
> >>  Files\
> >> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\
> >> Files\
> >> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\
> >> _ilp64.lib]' --download-fblaslapack=1 --with-debugging=1
> >> --with-fortran-interfaces=1
> >>              Configuring PETSc to compile on your system
> >> TESTING: alternateConfigureLibrary from
> >> config.packages.sprng(config/BuildSystem/config/package.py:959)
> >>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> >> details):
> >> Error! sowing on windows requires cygwin/g++. Please install it with cygwin
> >> setup.exe
> > yes - this is a requirement for using the git repo.
> > I guess alternatively  - you can try:
> > https://ftp.mcs.anl.gov/pub/petsc/petsc-main.tar.gz
> > Satish
> >>> Satish
> >>>> Hi Satish,
> >>>> I use option 1, but the errors I got from make check seems similar. I
> >>>> have
> >>>> attached the output.
> >>>> Yours sincerely,
> >>>> On 15/4/2021 9:54 am, Satish Balay wrote:
> >>>>> 1. You can avoid this complexity if you can use in-place install of
> >>>>> PETSc
> >>>>> [i.e do not use --prefix option to build PETSc]
> >>>>> 2. For a prefix install - the following patch should fix the issue [i.e
> >>>>> requires rerunning 'configure; make; make install']
> >>>>> diff --git a/config/BuildSystem/config/compilerOptions.py
> >>>>> b/config/BuildSystem/config/compilerOptions.py
> >>>>> index bdfd209203..b2e02783d9 100644
> >>>>> --- a/config/BuildSystem/config/compilerOptions.py
> >>>>> +++ b/config/BuildSystem/config/compilerOptions.py
> >>>>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
> >>>>>           if not status:
> >>>>>             if compiler.find('win32fe') > -1:
> >>>>>               version = '\\n'.join(output.split('\n')[0:2])
> >>>>> +          version = version.replace('\r','')
> >>>>>             else:
> >>>>>               #PGI/Windows writes an empty '\r\n' on the first line of
> >>>>>               output
> >>>>>               if output.count('\n') > 1 and output.split('\n')[0] ==
> >>>>>               '\r':
> >>>>> 3. For testing a prefix install - you would do:
> >>>>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>> PETSC_ARCH=""
> >>>>> [these instructions are printed to the screen when you run 'make
> >>>>> install'
> >>>>> Satish
> >>>>>> Hi Satish,
> >>>>>> I tried a few things, not sure if it's correct. But it doesn't seem to
> >>>>>> work
> >>>>>> I edit petscvariables in
> >>>>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>>>> and
> >>>>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>>>> from:
> >>>>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>>>> 27,
> >>>>>> 2017 11:10:38 AM
> >>>>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
> >>>>>> MPICC_SHOW = Unavailable
> >>>>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>>>> 27,
> >>>>>> 2017 11:10:38 AM
> >>>>>> MPICXX_SHOW = Unavailable
> >>>>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>>>> 27,
> >>>>>> 2017 11:10:38 AM
> >>>>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications
> >>>>>> running
> >>>>>> on
> >>>>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> >>>>>> to
> >>>>>> 27,
> >>>>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
> >>>>>> 19.16.27045 for x64
> >>>>>> 27,
> >>>>>> 19.16.27045 for x64
> >>>>>> 27,
> >>>>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
> >>>>>> applications running on Intel(R) 64, Version 2021.2.0 Build
> >>>>>> 20210228_000000
> >>>>>> Then in cygwin,
> >>>>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
> >>>>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>> make check
> >>>>>> make: *** No rule to make target 'check'.  Stop.
> >>>>>> Also:
> >>>>>> $ export PETSC_DIR=`pwd`
> >>>>>> make check
> >>>>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: ***
> >>>>>> target
> >>>>>> pattern contains no '%'.  Stop.
> >>>>>> Yours sincerely,
> >>>>>>>> Hi Satish,
> >>>>>>>> Sorry, what do you mean by "manually fix up this file"?
> >>>>>>>> Should I edit the petscvariables file?
> >>>>>>> yes
> >>>>>>>> Do I need to rebuild the lib?
> >>>>>>> no
> >>>>>>> After editing the file - run 'make check'
> >>>>>>> Satish
> >>>>>>>> I guess this problem is related to the new Intel oneAPI if I'm not
> >>>>>>>> wrong.
> >>>>>>>> No
> >>>>>>>> such problem previously.
> >>>>>>>> Yours sincerely,
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>> x64
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>> x64
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 2017 11:10:38 AM
> >>>>>>>>> running
> >>>>>>>>> on
> >>>>>>>>> I'm not sure what happened here. You might want to just manually fix
> >>>>>>>>> up
> >>>>>>>>> this
> >>>>>>>>> file
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 19.16.27045 for x64
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 19.16.27045 for x64
> >>>>>>>>> Feb
> >>>>>>>>> 27,
> >>>>>>>>> 20210228_000000
> >>>>>>>>> Satish
> >>>>>>>>>> Hi all,
> >>>>>>>>>> I have attached the req file
> >>>>>>>>>> Yours sincerely,
> >>>>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
> >>>>>>>>>>> Please send the file
> >>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> >>>>>>>>>>> Satish
> >>>>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
> >>>>>>>>>>>> Hi,
> >>>>>>>>>>>> I redo the installation:
> >>>>>>>>>>>> /*Now to install the libraries do:*//*
> >>>>>>>>>>>> *//*make
> >>>>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
> >>>>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
> >>>>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
> >>>>>>>>>>>> *//*$ make
> >>>>>>>>>>>> *//**** Using
> >>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>>>>>> *//**** Installing PETSc at prefix location:
> >>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
> >>>>>>>>>>>> *//*Install complete.*//*
> >>>>>>>>>>>> *//*Now to check if the libraries are working do (in current
> >>>>>>>>>>>> directory):*//*
> >>>>>>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>>>> PETSC_ARCH="" check*//*
> >>>>>>>>>>>> *//*/usr/bin/make  --no-print-directory -f makefile
> >>>>>>>>>>>> mpi4py-install
> >>>>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
> >>>>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
> >>>>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
> >>>>>>>>>>>> I ran the check:
> >>>>>>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
> >>>>>>>>>>>> *** missing separator.  Stop.*/
> >>>>>>>>>>>> Why is this happening?
> >>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
> >>>>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
> >>>>>>>>>>>>> When you do the install it will tell you exactly what to run to
> >>>>>>>>>>>>> run
> >>>>>>>>>>>>> "check".
> >>>>>>>>>>>>> You might double check that .
> >>>>>>>>>>>>> Mark
> >>>>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
> >>>>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
> >>>>>>>>>>>>>           Hi Barry,
> >>>>>>>>>>>>>           Ops, which dir should I run /*export
> >>>>>>>>>>>>>           PETSC_DIR=`pwd`*//*
> >>>>>>>>>>>>>           Maybe I ran it wrongly initially at where the lib is
> >>>>>>>>>>>>>           stored:
> >>>>>>>>>>>>>           /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
> >>>>>>>>>>>>>           My source is at
> >>>>>>>>>>>>>           /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
> >>>>>>>>>>>>>           Now I ran:
> >>>>>>>>>>>>>           /*export PETSC_DIR=`pwd`*//*
> >>>>>>>>>>>>>           *//*cd src/ksp/ksp/tutorials/*//*
> >>>>>>>>>>>>>           *//*make ex2f*/
> >>>>>>>>>>>>>           /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
> >>>>>>>>>>>>>           ifort -MD -Z7 -fpp  -MD -Z7 -fpp
> >>>>>>>>>>>>>           -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
> >>>>>>>>>>>>>           -I/cygdrive/d/wtay/Downloads/S*//*
> >>>>>>>>>>>>>           *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
> >>>>>>>>>>>>>           -I/cygdrive/c/Program\ Files\
> >>>>>>>>>>>>>           \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
> >>>>>>>>>>>>>           -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
> >>>>>>>>>>>>>           *//*15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>           -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>           -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>>>>           -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
> >>>>>>>>>>>>>           *//*_vs2017/lib -lpetsc -lflapack -lfblas
> >>>>>>>>>>>>>           Files\
> >>>>>>>>>>>>>           /cygdrive/c/*//*
> >>>>>>>>>>>>>           *//*Program\ Files\
> >>>>>>>>>>>>>           Gdi32.lib
> >>>>>>>>>>>>>           User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o
> >>>>>>>>>>>>>           ex2f*//*
> >>>>>>>>>>>>>           *//*ifort: command line warning #10006: ignoring
> >>>>>>>>>>>>>           unknown
> >>>>>>>>>>>>>           option
> >>>>>>>>>>>>>           '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>>>>           unknown
> >>>>>>>>>>>>>           option
> >>>>>>>>>>>>>           '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(80): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           different modules and/or program units cannot be
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(80): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           the name of a procedure. [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*ex2f.F90(81): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(81): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*ex2f.F90(93): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(93): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*ex2f.F90(159): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(159): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*ex2f.F90(171): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*         call
> >>>>>>>>>>>>>           PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(171): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*         call
> >>>>>>>>>>>>>           *//*ex2f.F90(193): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
> >>>>>>>>>>>>>           *//*ex2f.F90(193): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*ex2f.F90(319): error #6405: The same named entity
> >>>>>>>>>>>>>           from
> >>>>>>>>>>>>>           referenced.
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*ex2f.F90(319): error #7112: This actual argument
> >>>>>>>>>>>>>           must
> >>>>>>>>>>>>>           not
> >>>>>>>>>>>>>           be
> >>>>>>>>>>>>>           *//*      call
> >>>>>>>>>>>>>           *//*compilation aborted for ex2f.F90 (code 1)*//*
> >>>>>>>>>>>>>           *//*make: ***
> >>>>>>>>>>>>>           [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
> >>>>>>>>>>>>>           ex2f] Error 1*/
> >>>>>>>>>>>>>           I have also attached the "/*make check*/" output.
> >>>>>>>>>>>>>           Seems
> >>>>>>>>>>>>>           like
> >>>>>>>>>>>>>           there's problem with fortran compile.
> >>>>>>>>>>>>>           Yours sincerely,
> >>>>>>>>>>>>>           <http://tayweebeng.wixsite.com/website>_
> >>>>>>>>>>>>>           <https://goo.gl/PtvdwQ>_
> >>>>>>>>>>>>>           <https://www.linkedin.com/in/tay-weebeng>_
> >>>>>>>>>>>>>           On 14/4/2021 3:47 pm, Barry Smith wrote:
> >>>>>>>>>>>>>>            Please send configure.log and make.log and the
> >>>>>>>>>>>>>>           results
> >>>>>>>>>>>>>>           of
> >>>>>>>>>>>>>>           "make
> >>>>>>>>>>>>>>           check" so we have the details on the build process.
> >>>>>>>>>>>>>>>           /*No rule to make target
> >>>>>>>>>>>>>>>           '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
> >>>>>>>>>>>>>>>           Stop.*/
> >>>>>>>>>>>>>>            Looks funny; it does not seem to separate the PETSc
> >>>>>>>>>>>>>>           directory
> >>>>>>>>>>>>>>           from its configuration directory appropriately.
> >>>>>>>>>>>>>>             Are you sure
> >>>>>>>>>>>>>>>           *//*export
> >>>>>>>>>>>>>>>           PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
> >>>>>>>>>>>>>>           are run in the appropriate directory so that
> >>>>>>>>>>>>>>           PETSC_DIR
> >>>>>>>>>>>>>>           is
> >>>>>>>>>>>>>>           correct.
> >>>>>>>>>>>>>>           Barry
> >>>>>>>>>>>>>>>           On Apr 14, 2021, at 2:20 AM, TAY wee-beng
> >>>>>>>>>>>>>>>           Hi Mark,
> >>>>>>>>>>>>>>>           I'm not sure what's wrong.
> >>>>>>>>>>>>>>>           In VS2017 + Intel oneAPI,
> >>>>>>>>>>>>>>>           even after adding the full path:
> >>>>>>>>>>>>>>>           #include
> >>>>>>>>>>>>>>>           <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
> >>>>>>>>>>>>>>>           I got a new error:
> >>>>>>>>>>>>>>>           /*Compiling with Intel® Fortran Compiler Classic
> >>>>>>>>>>>>>>>           2021.2.0
> >>>>>>>>>>>>>>>           [Intel(R) 64]...*//*
> >>>>>>>>>>>>>>>           *//*ex2f.F90*//*
> >>>>>>>>>>>>>>>           *//*petscksp.h(8): #error: can't find include file:
> >>>>>>>>>>>>>>>           petsc/finclude/petscpc.h*//*
> >>>>>>>>>>>>>>>           *//*ex2f : error PRJ0019: A tool returned an error
> >>>>>>>>>>>>>>>           code*/
> >>>>>>>>>>>>>>>           Note that I have also specified the include dir in
> >>>>>>>>>>>>>>>           the
> >>>>>>>>>>>>>>>           properties:
> >>>>>>>>>>>>>>>           /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
> >>>>>>>>>>>>>>>           I also tried in cygwin:
> >>>>>>>>>>>>>>>           *//*export
> >>>>>>>>>>>>>>>           PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
> >>>>>>>>>>>>>>>           *//*make ex2f*/
> >>>>>>>>>>>>>>>           I got the error:
> >>>>>>>>>>>>>>>           /*$ make ex2f*//*
> >>>>>>>>>>>>>>>           *//*makefile:41:
> >>>>>>>>>>>>>>>           /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
> >>>>>>>>>>>>>>>           No such file or directory*//*
> >>>>>>>>>>>>>>>           *//*make: *** No rule to make target
> >>>>>>>>>>>>>>>           Stop.*/
> >>>>>>>>>>>>>>>           Somehow it just doesn't work. Building the library
> >>>>>>>>>>>>>>>           has
> >>>>>>>>>>>>>>>           no
> >>>>>>>>>>>>>>>           problem though.
> >>>>>>>>>>>>>>>           I wonder what's wrong.
> >>>>>>>>>>>>>>>           Yours sincerely,
> >>>>>>>>>>>>>>>           On 14/4/2021 9:31 am, Mark Adams wrote:
> >>>>>>>>>>>>>>>>           PETSc has changed Fortran syntax since v3.9. You
> >>>>>>>>>>>>>>>>           should
> >>>>>>>>>>>>>>>>           upgrade. Look at examples for how to use modules
> >>>>>>>>>>>>>>>>           etc.
> >>>>>>>>>>>>>>>>               Classic
> >>>>>>>>>>>>>>>>               2021.2.0
> >>>>>>>>>>>>>>>>               *//*global.F90*//*
> >>>>>>>>>>>>>>>>               *//*global.F90(3): #error: can't find include
> >>>>>>>>>>>>>>>>               file:
> >>>>>>>>>>>>>>>>               petsc/finclude/petsc.h*//*
> >>>>>>>>>>>>>>>>               *//*global.F90(937): #error: can't find include
> >>>>>>>>>>>>>>>>               file:
> >>>>>>>>>>>>>>>>           It looks like you might not have your PETSC_ARCH
> >>>>>>>>>>>>>>>>           variable set.
> >>>>>>>>>>>>>>>>           You should get a full path to /finclude/petsc.h.
> >>>>>>>>>>>>>>>>           Look
> >>>>>>>>>>>>>>>>           at
> >>>>>>>>>>>>>>>>           the
> >>>>>>>>>>>>>>>>           compile line.
> >>>>>>>>>>>>>>>>           There are PETSc examples that you you can make to
> >>>>>>>>>>>>>>>>           see
> >>>>>>>>>>>>>>>>           an
> >>>>>>>>>>>>>>>>           example of a correct make. For example,
> >>>>>>>>>>>>>>>>           > cd petsc/src/ksp/ksp/tutorials
> >>>>>>>>>>>>>>>>            >  >  >  >  >  >  >  >  >  >  >  >  >  >  >  > make
> >>>>>>>>>>>>>>>>            >  >  >  >  >  >  >  >  > ex2f
> >>>>>>>>>>>>>>>>           should make an executable and you can look at the
> >>>>>>>>>>>>>>>>           compile
> >>>>>>>>>>>>>>>>           and
> >>>>>>>>>>>>>>>>           link lines, and compare to what you are using.
> >>>>>>>>>>>>>>>>           Mark
> >>>>>>>>>>>>>>>>               Yours sincerely,
> >>>>>>>>>>>>>>>>               linkedin:
