[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
    TAY wee-beng
    zonexo at gmail.com
    Wed Apr 14 23:23:13 CDT 2021
On 15/4/2021 11:42 am, Satish Balay wrote:
> The c examples ran fine. However fortran has issues.
> ex5f.F90(83): error #6405: The same named entity from different modules and/or program units cannot be referenced.   [PETSC_COMM_WORLD]
>        call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
> Is the fortran compiler defaulting to F2008/2018 mode?
> You can try building 'release' branch of petsc git repo and see if this problem persists.
I tried and got this error below, configure.log attached.
export PETSC_DIR=`pwd`
export PETSC_ARCH=petsc-dev_win64_impi_vs2017
./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
--with-cxx='win32fe cl' --with-mpi-include=/cygdrive/c/Program\ Files\
\(x86\)/Intel/oneAPI/mpi/latest/include
--with-mpi-lib='[/cygdrive/c/Program\
  Files\
\(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\
Files\
\(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\
Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi
_ilp64.lib]' --download-fblaslapack=1 --with-debugging=1
--with-fortran-interfaces=1
              Configuring PETSc to compile on your system
TESTING: alternateConfigureLibrary from
config.packages.sprng(config/BuildSystem/config/package.py:959)
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Error! sowing on windows requires cygwin/g++. Please install it with
cygwin setup.exe
> Satish
> On Thu, 15 Apr 2021, TAY wee-beng wrote:
>> Hi Satish,
>> I use option 1, but the errors I got from make check seems similar. I have
>> attached the output.
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>> Personal research webpage: _http://tayweebeng.wixsite.com/website_
>> Youtube research showcase: _https://goo.gl/PtvdwQ_
>> linkedin: _https://www.linkedin.com/in/tay-weebeng_
>> On 15/4/2021 9:54 am, Satish Balay wrote:
>>> 1. You can avoid this complexity if you can use in-place install of PETSc
>>> [i.e do not use --prefix option to build PETSc]
>>> 2. For a prefix install - the following patch should fix the issue [i.e
>>> requires rerunning 'configure; make; make install']
>>> diff --git a/config/BuildSystem/config/compilerOptions.py
>>> b/config/BuildSystem/config/compilerOptions.py
>>> index bdfd209203..b2e02783d9 100644
>>> --- a/config/BuildSystem/config/compilerOptions.py
>>> +++ b/config/BuildSystem/config/compilerOptions.py
>>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
>>>          if not status:
>>>            if compiler.find('win32fe') > -1:
>>>              version = '\\n'.join(output.split('\n')[0:2])
>>> +          version = version.replace('\r','')
>>>            else:
>>>              #PGI/Windows writes an empty '\r\n' on the first line of output
>>>              if output.count('\n') > 1 and output.split('\n')[0] == '\r':
>>> 3. For testing a prefix install - you would do:
>>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>> PETSC_ARCH=""
>>> [these instructions are printed to the screen when you run 'make install'
>>> Satish
>>>> Hi Satish,
>>>> I tried a few things, not sure if it's correct. But it doesn't seem to work
>>>> I edit petscvariables in
>>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>> and
>>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>> from:
>>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
>>>> MPICC_SHOW = Unavailable
>>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> MPICXX_SHOW = Unavailable
>>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
>>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
>>>> to
>>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
>>>> 19.16.27045 for x64
>>>> 19.16.27045 for x64
>>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
>>>> applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
>>>> Then in cygwin,
>>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
>>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>> make check
>>>> make: *** No rule to make target 'check'.  Stop.
>>>> Also:
>>>> $ export PETSC_DIR=`pwd`
>>>> make check
>>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: *** target
>>>> pattern contains no '%'.  Stop.
>>>> Yours sincerely,
>>>>>> Hi Satish,
>>>>>> Sorry, what do you mean by "manually fix up this file"?
>>>>>> Should I edit the petscvariables file?
>>>>> yes
>>>>>> Do I need to rebuild the lib?
>>>>> no
>>>>> After editing the file - run 'make check'
>>>>> Satish
>>>>>> I guess this problem is related to the new Intel oneAPI if I'm not wrong.
>>>>>> No
>>>>>> such problem previously.
>>>>>> Yours sincerely,
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> on
>>>>>>> I'm not sure what happened here. You might want to just manually fix up
>>>>>>> this
>>>>>>> file
>>>>>>> 27,
>>>>>>> 19.16.27045 for x64
>>>>>>> 27,
>>>>>>> 19.16.27045 for x64
>>>>>>> 27,
>>>>>>> 20210228_000000
>>>>>>> Satish
>>>>>>>> Hi all,
>>>>>>>> I have attached the req file
>>>>>>>> Yours sincerely,
>>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
>>>>>>>>> Please send the file
>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
>>>>>>>>> Satish
>>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I redo the installation:
>>>>>>>>>> /*Now to install the libraries do:*//*
>>>>>>>>>> *//*make
>>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
>>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
>>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
>>>>>>>>>> *//*$ make
>>>>>>>>>> *//**** Using
>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
>>>>>>>>>> *//**** Installing PETSc at prefix location:
>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
>>>>>>>>>> *//*Install complete.*//*
>>>>>>>>>> *//*Now to check if the libraries are working do (in current
>>>>>>>>>> directory):*//*
>>>>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>> PETSC_ARCH="" check*//*
>>>>>>>>>> *//*/usr/bin/make  --no-print-directory -f makefile
>>>>>>>>>> mpi4py-install
>>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
>>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
>>>>>>>>>> I ran the check:
>>>>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
>>>>>>>>>> *** missing separator.  Stop.*/
>>>>>>>>>> Why is this happening?
>>>>>>>>>> Yours sincerely,
>>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
>>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
>>>>>>>>>>> When you do the install it will tell you exactly what to run to run
>>>>>>>>>>> "check".
>>>>>>>>>>> You might double check that .
>>>>>>>>>>> Mark
>>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
>>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
>>>>>>>>>>>          Hi Barry,
>>>>>>>>>>>          Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
>>>>>>>>>>>          Maybe I ran it wrongly initially at where the lib is stored:
>>>>>>>>>>>          /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
>>>>>>>>>>>          My source is at
>>>>>>>>>>>          /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
>>>>>>>>>>>          Now I ran:
>>>>>>>>>>>          *//*cd src/ksp/ksp/tutorials/*//*
>>>>>>>>>>>          *//*make ex2f*/
>>>>>>>>>>>          /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
>>>>>>>>>>>          ifort -MD -Z7 -fpp  -MD -Z7 -fpp
>>>>>>>>>>>          -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
>>>>>>>>>>>          -I/cygdrive/d/wtay/Downloads/S*//*
>>>>>>>>>>>          *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
>>>>>>>>>>>          -I/cygdrive/c/Program\ Files\
>>>>>>>>>>>          \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
>>>>>>>>>>>          -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
>>>>>>>>>>>          *//*15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
>>>>>>>>>>>          *//*_vs2017/lib -lpetsc -lflapack -lfblas
>>>>>>>>>>>          Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
>>>>>>>>>>>          /cygdrive/c/*//*
>>>>>>>>>>>          *//*Program\ Files\
>>>>>>>>>>>          \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
>>>>>>>>>>>          Gdi32.lib
>>>>>>>>>>>          User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
>>>>>>>>>>>          *//*ifort: command line warning #10006: ignoring unknown
>>>>>>>>>>>          option
>>>>>>>>>>>          '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>          option
>>>>>>>>>>>          '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>          *//*ex2f.F90(80): error #6405: The same named entity from
>>>>>>>>>>>          [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>          *//*      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(80): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          the name of a procedure. [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>          *//*ex2f.F90(81): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(81): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(93): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(93): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(159): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call
>>>>>>>>>>>          VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(159): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*      call
>>>>>>>>>>>          *//*ex2f.F90(171): error #6405: The same named entity from
>>>>>>>>>>>          *//*         call
>>>>>>>>>>>          PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(171): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*         call
>>>>>>>>>>>          *//*ex2f.F90(193): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(193): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(319): error #6405: The same named entity from
>>>>>>>>>>>          *//*ex2f.F90(319): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*compilation aborted for ex2f.F90 (code 1)*//*
>>>>>>>>>>>          *//*make: ***
>>>>>>>>>>>          [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
>>>>>>>>>>>          ex2f] Error 1*/
>>>>>>>>>>>          I have also attached the "/*make check*/" output. Seems like
>>>>>>>>>>>          there's problem with fortran compile.
>>>>>>>>>>>          Yours sincerely,
>>>>>>>>>>>          <http://tayweebeng.wixsite.com/website>_
>>>>>>>>>>>          <https://goo.gl/PtvdwQ>_
>>>>>>>>>>>          <https://www.linkedin.com/in/tay-weebeng>_
>>>>>>>>>>>          On 14/4/2021 3:47 pm, Barry Smith wrote:
>>>>>>>>>>>>           Please send configure.log and make.log and the results of
>>>>>>>>>>>>          "make
>>>>>>>>>>>>          check" so we have the details on the build process.
>>>>>>>>>>>>>          /*No rule to make target
>>>>>>>>>>>>>          '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
>>>>>>>>>>>>>          Stop.*/
>>>>>>>>>>>>           Looks funny; it does not seem to separate the PETSc
>>>>>>>>>>>>          directory
>>>>>>>>>>>>          from its configuration directory appropriately.
>>>>>>>>>>>>            Are you sure
>>>>>>>>>>>>>          *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
>>>>>>>>>>>>          are run in the appropriate directory so that PETSC_DIR is
>>>>>>>>>>>>          correct.
>>>>>>>>>>>>          Barry
>>>>>>>>>>>>>          On Apr 14, 2021, at 2:20 AM, TAY wee-beng
>>>>>>>>>>>>>          Hi Mark,
>>>>>>>>>>>>>          I'm not sure what's wrong.
>>>>>>>>>>>>>          In VS2017 + Intel oneAPI,
>>>>>>>>>>>>>          even after adding the full path:
>>>>>>>>>>>>>          #include
>>>>>>>>>>>>>          <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
>>>>>>>>>>>>>          I got a new error:
>>>>>>>>>>>>>          /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
>>>>>>>>>>>>>          [Intel(R) 64]...*//*
>>>>>>>>>>>>>          *//*ex2f.F90*//*
>>>>>>>>>>>>>          *//*petscksp.h(8): #error: can't find include file:
>>>>>>>>>>>>>          petsc/finclude/petscpc.h*//*
>>>>>>>>>>>>>          *//*ex2f : error PRJ0019: A tool returned an error code*/
>>>>>>>>>>>>>          Note that I have also specified the include dir in the
>>>>>>>>>>>>>          properties:
>>>>>>>>>>>>>          /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
>>>>>>>>>>>>>          I also tried in cygwin:
>>>>>>>>>>>>>          *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
>>>>>>>>>>>>>          *//*make ex2f*/
>>>>>>>>>>>>>          I got the error:
>>>>>>>>>>>>>          /*$ make ex2f*//*
>>>>>>>>>>>>>          *//*makefile:41:
>>>>>>>>>>>>>          /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
>>>>>>>>>>>>>          No such file or directory*//*
>>>>>>>>>>>>>          *//*make: *** No rule to make target
>>>>>>>>>>>>>          Stop.*/
>>>>>>>>>>>>>          Somehow it just doesn't work. Building the library has no
>>>>>>>>>>>>>          problem though.
>>>>>>>>>>>>>          I wonder what's wrong.
>>>>>>>>>>>>>          Yours sincerely,
>>>>>>>>>>>>>          On 14/4/2021 9:31 am, Mark Adams wrote:
>>>>>>>>>>>>>>          PETSc has changed Fortran syntax since v3.9. You should
>>>>>>>>>>>>>>          upgrade. Look at examples for how to use modules etc.
>>>>>>>>>>>>>>              2021.2.0
>>>>>>>>>>>>>>              *//*global.F90*//*
>>>>>>>>>>>>>>              *//*global.F90(3): #error: can't find include file:
>>>>>>>>>>>>>>              petsc/finclude/petsc.h*//*
>>>>>>>>>>>>>>              *//*global.F90(937): #error: can't find include file:
>>>>>>>>>>>>>>          It looks like you might not have your PETSC_ARCH
>>>>>>>>>>>>>>          variable set.
>>>>>>>>>>>>>>          You should get a full path to /finclude/petsc.h. Look at
>>>>>>>>>>>>>>          the
>>>>>>>>>>>>>>          compile line.
>>>>>>>>>>>>>>          There are PETSc examples that you you can make to see an
>>>>>>>>>>>>>>          example of a correct make. For example,
>>>>>>>>>>>>>>          > cd petsc/src/ksp/ksp/tutorials
>>>>>>>>>>>>>>           >  >  >  >  >  >  >  >  >  >  >  >  >  >  >  > make
>>>>>>>>>>>>>>           >  >  >  >  >  >  >  > ex2f
>>>>>>>>>>>>>>          should make an executable and you can look at the compile
>>>>>>>>>>>>>>          and
>>>>>>>>>>>>>>          link lines, and compare to what you are using.
>>>>>>>>>>>>>>          Mark
>>>>>>>>>>>>>>              Yours sincerely,
Executing: uname -s
stdout: CYGWIN_NT-10.0
Starting configure run at Thu, 15 Apr 2021 12:04:40 +0800
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-cxx="win32fe cl" --with-mpi-include="/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include" --with-mpi-lib="[/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib]" --download-fblaslapack=1 --with-debugging=1 --with-fortran-interfaces=1
Working directory: /cygdrive/d/wtay/Downloads/Source_codes/petsc
Machine platform:
uname_result(system='CYGWIN_NT-10.0-17763', node='DELL-T7610', release='3.2.0-340.x86_64', version='2021-03-29 08:42 UTC', machine='x86_64', processor='')
Python version:
3.8.8 (default, Mar  4 2021, 21:24:42)
[GCC 10.2.0]
  Environmental variables
VSCMD_ARG_TGT_ARCH=x64
DevEnvDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\
USERDOMAIN=DELL-T7610
OS=Windows_NT
__DOTNET_PREFERRED_BITNESS=64
COMMONPROGRAMFILES=C:\Program Files\Common Files
VCToolsVersion=14.16.27023
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
PROCESSOR_LEVEL=6
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files\Intel\Wired Networking\
CommonProgramW6432=C:\Program Files\Common Files
INCLUDE=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dev-utilities\latest\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\ucrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\shared;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\winrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\cppwinrt
!ExitCode=00000000
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
OCL_ICD_FILENAMES=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\emu\intelocl64_emu.dll;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\x64\intelocl64.dll
VSCMD_ARG_app_plat=Desktop
LANG=en_US.UTF-8
TZ=Asia/Singapore
VS150COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\Tools\
HOSTNAME=DELL-T7610
CUDA_PATH_V11_2=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2
PUBLIC=C:\Users\Public
TEC_360_2020R2=C:\Program Files\Tecplot\Tecplot 360 EX 2020 R2\
OLDPWD=/cygdrive/d/wtay/Downloads/Source_codes
TARGET_VS=vs2017
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
I_MPI_ONEAPI_ROOT=C:\Program Files (x86)\Intel\oneAPI\mpi\2021.2.0
VSCMD_START_DIR=C:\Program Files (x86)\Intel\oneAPI
WindowsSdkBinPath=C:\Program Files (x86)\Windows Kits\10\bin\
ANSYS_SYSDIR32=win32
VS2017INSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional
CUDA_PATH=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2
VCToolsInstallDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\
UATDATA=C:\Windows\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
FrameworkVersion64=v4.0.30319
USERNAME=wtay
MOZ_PLUGIN_PATH=C:\PROGRAM FILES (X86)\FOXIT SOFTWARE\FOXIT READER\plugins\
LOGONSERVER=\\DELL-T7610
PROCESSOR_ARCHITECTURE=AMD64
VCIDEInstallDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\
ERRORSTATE=0
LOCALAPPDATA=C:\Users\wtay\AppData\Local
TBB_TARGET_ARCH=intel64
ANS_OLD_ATTACH=1
COMPUTERNAME=DELL-T7610
__MS_VC_INSTALL_PATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\
ANSYS_SYSDIR=winx64
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
WindowsLibPath=C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17763.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17763.0
USER=DELL-T7610+wtay
CMPLR_ROOT=C:\Program Files (x86)\Intel\oneAPI\compiler\latest
IFORT_COMPILER21=C:\Program Files (x86)\Intel\oneAPI\compiler\2021.2.0\windows\
FrameworkDIR64=C:\Windows\Microsoft.NET\Framework64
SYSTEMDRIVE=C:
USERPROFILE=C:\Users\wtay
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
SYSTEMROOT=C:\Windows
USERDOMAIN_ROAMINGPROFILE=DELL-T7610
OneDriveCommercial=D:\wtay\OneDrive
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
MSMPI_BENCHMARKS=C:\Program Files\Microsoft MPI\Benchmarks\
MIC_LIBRARY_PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\mic;
TBB_BIN_DIR=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\
PWD=/cygdrive/d/wtay/Downloads/Source_codes/petsc
MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
HOME=/home/wtay
__DOTNET_ADD_64BIT=1
TMP=/tmp
ExtensionSdkDir=C:\Program Files (x86)\Microsoft SDKs\Windows Kits\10\ExtensionSDKs
CMAKE_PREFIX_PATH=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..;
TBB_TARGET_VS=vc14
INTEL_TARGET_ARCH=intel64
VSINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\
INTELGTDEBUGGERROOT=C:\Program Files (x86)\Intel\oneAPI\debugger\latest\env\\..
Platform=x64
CommandPromptType=Native
CPATH=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dpl\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dev-utilities\latest\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64;
INTELFPGAOCLSDKROOT=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\oclfpga
NVTOOLSEXT_PATH=C:\Program Files\NVIDIA Corporation\NvToolsExt\
FrameworkDir=C:\Windows\Microsoft.NET\Framework64\
VSCMD_ARG_HOST_ARCH=x64
OneDrive=D:\wtay\OneDrive
VARSDIR=C:\Program Files (x86)\Intel\oneAPI\dpl\latest\env\
SW_SIM_MPIT=INTELMPI
DPL_ROOT=C:\Program Files (x86)\Intel\oneAPI\dpl\latest
!C:=C:\cygwin64\bin
VisualStudioVersion=15.0
PROCESSOR_REVISION=3e04
FPS_BROWSER_USER_PROFILE_STRING=Default
CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
PROFILEREAD=true
ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
NVCUDASAMPLES_ROOT=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v11.2
AWP_LOCALE202=en-us
WindowsSDKLibVersion=10.0.17763.0\
VCINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\
LIB=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\lib\intel64\vc14;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib\release;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\intel64_win;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17763.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17763.0\um\x64;
LIBPATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x86\store\references;C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17763.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17763.0;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;
SETVARS_COMPLETED=1
VSCMD_VER=15.9.35
PROMPT=$P$G
NUMBER_OF_PROCESSORS=48
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses
MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\mic;
WindowsSdkDir=C:\Program Files (x86)\Windows Kits\10\
COMSPEC=C:\Windows\system32\cmd.exe
APPDATA=C:\Users\wtay\AppData\Roaming
TERM=xterm-256color
SHELL=/bin/bash
INTEL_TARGET_PLATFORM=windows
WindowsSdkVerBinPath=C:\Program Files (x86)\Windows Kits\10\bin\10.0.17763.0\
WindowsSDKVersion=10.0.17763.0\
AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
PETSC_DIR_OLD=D:\wtay\Lib\petsc-3.9.3_win64_impi_vs2017
UCRTVersion=10.0.17763.0
WINDIR=C:\Windows
TARGET_VS_ARCH=amd64
ProgramData=C:\ProgramData
SHLVL=1
PRINTER=\\http://172.18.66.189:631\tsl_ljlvl2
FrameworkVersion=v4.0.30319
ALLUSERSPROFILE=C:\ProgramData
TEMP=/tmp
__VSCMD_PREINIT_PATH=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2\libnvvp;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Tecplot\Tecplot 360 EX 2020 R2\bin;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\bin;C:\ProgramData\Miniconda3;C:\ProgramData\Miniconda3\Library\mingw-w64\bin;C:\ProgramData\Miniconda3\Library\usr\bin;C:\ProgramData\Miniconda3\Library\bin;C:\ProgramData\Miniconda3\Scripts;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\NVIDIA Corporation\Nsight Compute 2020.3.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Users\wtay\AppData\Local\Microsoft\WindowsApps;C:\Users\wtay\AppData\Local\GitHubDesktop\bin;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\lib;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\libfabric;
DPCPP_ROOT=C:\Program Files (x86)\Intel\oneAPI
DriverData=C:\Windows\System32\Drivers\DriverData
UniversalCRTSdkDir=C:\Program Files (x86)\Windows Kits\10\
SESSIONNAME=Console
PATH=/usr/local/bin:/usr/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Miniconda3:/cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin:/cygdrive/c/ProgramData/Miniconda3/Library/usr/bin:/cygdrive/c/ProgramData/Miniconda3/Library/bin:/cygdrive/c/ProgramData/Miniconda3/Scripts:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0:/cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn:/cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc
TBBROOT=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..
HOMEDRIVE=C:
HCPAW=D:\wtay\nBox
INFOPATH=/usr/local/info:/usr/share/info:/usr/info
NVCUDASAMPLES11_2_ROOT=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v11.2
I_MPI_ROOT=C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..
Framework40Version=v4.0
HOMEPATH=\Users\wtay
ORIGINAL_PATH=/cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Miniconda3:/cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin:/cygdrive/c/ProgramData/Miniconda3/Library/usr/bin:/cygdrive/c/ProgramData/Miniconda3/Library/bin:/cygdrive/c/ProgramData/Miniconda3/Scripts:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0:/cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn:/cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc
LSTC_LICENSE=ANSYS
VCToolsRedistDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Redist\MSVC\14.16.27012\
EXECIGNORE=*.dll
library_kind=release
VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\
    Files in path provided by default path
      /usr/local/bin:
      /usr/bin: addftinfo.exe addr2line.exe apropos ar.exe arch.exe as.exe ash.exe awk b2sum.exe base32.exe base64.exe basename.exe bash.exe bashbug bunzip2.exe bzcat.exe bzcmp bzdiff bzegrep bzfgrep bzgrep bzip2.exe bzip2recover.exe bzless bzmore c++filt.exe ca-legacy cal.exe captoinfo cat.exe catman.exe chattr.exe chcon.exe chgrp.exe chmod.exe chown.exe chroot.exe chrt.exe cksum.exe clear.exe cmp.exe col.exe colcrt.exe colrm.exe column.exe comm.exe corelist cp.exe cpan csplit.exe cut.exe cygargp-0.dll cygattr-1.dll cygblkid-1.dll cygbrotlicommon-1.dll cygbrotlidec-1.dll cygbz2-1.dll cygcbor-0.dll cygcheck.exe cygcom_err-2.dll cygcrypt-2.dll cygcrypto-1.0.0.dll cygcrypto-1.1.dll cygcurl-4.dll cygdb-5.3.dll cygdb_cxx-5.3.dll cygdb_sql-5.3.dll cygedit-0.dll cygexpat-1.dll cygfdisk-1.dll cygffi-6.dll cygfido2-1.dll cygformw-10.dll cyggc-1.dll cyggcc_s-seh-1.dll cyggdbm-6.dll cyggdbm_compat-4.dll cyggmp-10.dll cyggssapi_krb5-2.dll cygguile-2.2-1.dll cyghistory7.dll cygiconv-2.dll cygidn2-0.dll cygintl-8.dll cygk5crypto-3.dll cygkrb5-3.dll cygkrb5support-0.dll cyglber-2-4-2.dll cygldap-2-4-2.dll cygldap_r-2-4-2.dll cygltdl-7.dll cyglz4-1.dll cyglzma-5.dll cygmagic-1.dll cygman-2-9-4.dll cygmandb-2-9-4.dll cygmenuw-10.dll cygmpfr-6.dll cygncursesw-10.dll cygnghttp2-14.dll cygp11-kit-0.dll cygpanelw-10.dll cygpath.exe cygpcre-1.dll cygperl5_32.dll cygpipeline-1.dll cygpkgconf-3.dll cygpopt-0.dll cygpsl-5.dll cygreadline7.dll cygrunsrv.exe cygsasl2-3.dll cygserver-config cygsigsegv-2.dll cygsmartcols-1.dll cygsqlite3-0.dll cygssh2-1.dll cygssl-1.0.0.dll cygssl-1.1.dll cygstart.exe cygstdc++-6.dll cygtasn1-6.dll cygticw-10.dll cygunistring-2.dll cyguuid-1.dll cygwin-console-helper.exe cygwin1.dll cygxxhash-0.dll cygz.dll cygzstd-1.dll dash.exe date.exe dd.exe df.exe diff.exe diff3.exe diffstat.exe dir.exe dircolors.exe dirname.exe dlltool.exe dllwrap.exe dnsdomainname domainname du.exe dumper.exe easy_install-2.7 easy_install-3.8 echo.exe editrights.exe egrep elfedit.exe enc2xs encguess env.exe eqn.exe eqn2graph ex expand.exe expr.exe factor.exe false.exe fgrep fido2-assert.exe fido2-cred.exe fido2-token.exe file.exe find.exe flock.exe fmt.exe fold.exe gawk-5.1.0.exe gawk.exe gdiffmk gencat.exe getconf.exe getent.exe getfacl.exe getopt.exe git-receive-pack.exe git-shell.exe git-upload-archive.exe git-upload-pack.exe git.exe gkill.exe gprof.exe grap2graph grep.exe grn.exe grodvi.exe groff.exe grolbp.exe grolj4.exe grops.exe grotty.exe groups.exe gunzip gzexe gzip.exe h2ph h2xs head.exe hexdump.exe hostid.exe hostname.exe hpftodit.exe i686-w64-mingw32-pkg-config id.exe indxbib.exe info.exe infocmp.exe infotocap install-info.exe install.exe instmodsh ipcmk.exe ipcrm.exe ipcs.exe isosize.exe join.exe json_pp kill.exe lastlog.exe ld.bfd.exe ld.exe ldd.exe ldh.exe less.exe lessecho.exe lesskey.exe lexgrog.exe libnetcfg libpython2.7.dll libpython3.8.dll link-cygwin.exe lkbib.exe ln.exe locale.exe locate.exe logger.exe login.exe logname.exe look.exe lookbib.exe ls.exe lsattr.exe lzcat lzcmp lzdiff lzegrep lzfgrep lzgrep lzless lzma lzmadec.exe lzmainfo.exe lzmore make-dummy-cert make.exe man-recode.exe man.exe mandb.exe manpath.exe mcookie.exe md5sum.exe minidumper.exe mintheme mintty.exe mkdir.exe mkfifo.exe mkgroup.exe mknod.exe mkpasswd.exe mkshortcut.exe mktemp.exe more.exe mount.exe mv.exe namei.exe neqn nice.exe nl.exe nm.exe nohup.exe nproc.exe nroff numfmt.exe objcopy.exe objdump.exe od.exe openssl.exe p11-kit.exe passwd.exe paste.exe pathchk.exe pdfroff peflags.exe peflagsall perl.exe perl5.32.1.exe perlbug perldoc perlivp perlthanks pfbtops.exe pg.exe pic.exe pic2graph piconv pinky.exe pip2 pip2.7 pip3 pip3.8 pkg-config pkgconf.exe pl2pm pldd.exe pod2html pod2man pod2text pod2usage podchecker post-grohtml.exe pr.exe pre-grohtml.exe preconv.exe printenv.exe printf.exe prove ps.exe ptar ptardiff ptargrep ptx.exe pwd.exe pydoc2.7 pydoc3 pydoc3.8 python python2.7.exe python3 python3.8.exe pzstd.exe ranlib.exe readelf.exe readlink.exe readshortcut.exe realpath.exe rebase-trigger rebase.exe rebaseall rebaselst refer.exe regtool.exe rename.exe renew-dummy-cert renice.exe reset rev.exe rm.exe rmdir.exe rsync-ssl rsync.exe run.exe runcon.exe rvi rview rvim scp.exe script.exe scriptreplay.exe sdiff.exe sed.exe seq.exe setfacl.exe setmetamode.exe setsid.exe sftp.exe sh.exe sha1sum.exe sha224sum.exe sha256sum.exe sha384sum.exe sha512sum.exe shasum shred.exe shuf.exe size.exe sleep.exe slogin soelim.exe sort.exe splain split.exe ssh-add.exe ssh-agent.exe ssh-copy-id ssh-host-config ssh-keygen.exe ssh-keyscan.exe ssh-user-config ssh.exe ssp.exe stat.exe stdbuf.exe strace.exe streamzip strings.exe strip.exe stty.exe sum.exe sync.exe tabs.exe tac.exe tail.exe tar.exe taskset.exe tbl.exe tee.exe test.exe tfmtodit.exe tic.exe timeout.exe toe.exe touch.exe tput.exe tr.exe troff.exe true.exe truncate.exe trust.exe tset.exe tsort.exe tty.exe tzselect tzset.exe ul.exe umount.exe uname.exe unexpand.exe uniq.exe unlink.exe unlzma unxz unzstd update-ca-trust update-crypto-policies updatedb users.exe uuidgen.exe uuidparse.exe vdir.exe vi.exe view vim.exe vimdiff vimtutor wc.exe whatis.exe whereis.exe which.exe who.exe whoami.exe windmc.exe windres.exe x86_64-pc-cygwin-pkg-config x86_64-w64-mingw32-pkg-config xargs.exe xsubpp xxd.exe xz.exe xzcat xzcmp xzdec.exe xzdiff xzegrep xzfgrep xzgrep xzless xzmore yes.exe zcat zcmp zdiff zdump.exe zegrep zfgrep zforce zgrep zipdetails zless zmore znew zstd.exe zstdcat zstdgrep zstdless zstdmt [.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14: tbb.def tbb12.dll tbb12.pdb tbb12_debug.dll tbb12_debug.pdb tbbbind.dll tbbbind.pdb tbbbind_2_0.dll tbbbind_2_0.pdb tbbbind_2_0_debug.dll tbbbind_2_0_debug.pdb tbbbind_2_4.dll tbbbind_2_4.pdb tbbbind_2_4_debug.dll tbbbind_2_4_debug.pdb tbbbind_debug.dll tbbbind_debug.pdb tbbmalloc.def tbbmalloc.dll tbbmalloc.pdb tbbmalloc_debug.dll tbbmalloc_debug.pdb tbbmalloc_proxy.dll tbbmalloc_proxy.pdb tbbmalloc_proxy_debug.dll tbbmalloc_proxy_debug.pdb
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils: fi_info.exe fi_pingpong.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin: libfabric.dll utils
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release: impi.dll impi.pdb
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin: cpuinfo.exe debug hydra_bstrap_proxy.exe hydra_pmi_proxy.exe hydra_service.exe IMB-MPI1.exe IMB-NBC.exe IMB-RMA.exe impi_info.exe libmpi_ilp64.dll mpicc.bat mpicl.bat mpicxx.bat mpiexec.exe mpif77.bat mpif90.bat mpifc.bat mpiicc.bat mpiicpc.bat mpiifort.bat mpitune.bat release tune
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin: dpct.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin: oneapi-cli.exe OneAPI.vsix version.txt
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin: gdb-add-index-oneapi gdb-oneapi.exe gdbserver-gt.exe iga64.dll igfxdbg.dll igfxdbgxchg64.dll
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin: aocl-ioc64.exe clang++.exe clang-cl.exe clang-offload-bundler.exe clang-offload-deps.exe clang-offload-wrapper.exe clang.exe dpcpp.exe file-table-tform.exe fpp.exe icx.exe ifx.exe intel64 intel64_ia32 ioc64.exe ld.lld.exe ld64.lld.darwinnew.exe ld64.lld.exe libomp-fallback-cassert.spv libomp-fallback-cmath-fp64.spv libomp-fallback-cmath.spv libomp-fallback-complex-fp64.spv libomp-fallback-complex.spv libsycl-fallback-cassert.spv libsycl-fallback-cmath-fp64.spv libsycl-fallback-cmath.spv libsycl-fallback-complex-fp64.spv libsycl-fallback-complex.spv llc.exe lld-link.exe lld.exe llvm-ar.exe llvm-cov.exe llvm-foreach.exe llvm-lib.exe llvm-link.exe llvm-no-spir-kernel.exe llvm-objcopy.exe llvm-profdata.exe llvm-spirv.exe omptarget.dll omptarget.rtl.level0.dll omptarget.rtl.opencl.dll opencl-aot.exe pi_level_zero.dll pi_opencl.dll sycl-ls.exe sycl-post-link.exe sycl.conf sycl.dll sycld.dll wasm-ld.exe xfortcom.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib: clang clbltfnshared.rtl emu libfortran-target.obj libomp-cmath-fp64.obj libomp-cmath.obj libomp-complex-fp64.obj libomp-complex.obj libomp-fallback-cassert.obj libomp-fallback-cmath-fp64.obj libomp-fallback-cmath.obj libomp-fallback-complex-fp64.obj libomp-fallback-complex.obj libomp-msvc.obj libomptarget-opencl.bc libomptarget-spirvdevicertl.obj libsycl-cmath-fp64.obj libsycl-cmath.obj libsycl-complex-fp64.obj libsycl-complex.obj libsycl-crt.obj libsycl-fallback-cassert.obj libsycl-fallback-cmath-fp64.obj libsycl-fallback-cmath.obj libsycl-fallback-complex-fp64.obj libsycl-fallback-complex.obj oclfpga ocloc omptarget.lib OpenCL.lib sycl.lib sycld.lib x64 x86
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64: 1033 cilkrts20.dll codecov.exe deftofd.exe fortcom.exe fpp.exe fqwin.hlp icl.cfg icl.exe ifort.cfg ifort.exe map_opts.exe mcpcom.exe profdcg.exe profmerge.exe profmergesampling.exe proforder.exe tselect.exe xilib.exe xilink.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler: 1033 cilkrts20.dll cilkrts20.pdb ifdlg100.dll libchkp.dll libicaf.dll libifcoremd.dll libifcoremdd.dll libifcorert.dll libifcorertd.dll libifportmd.dll libiomp5md.dll libiomp5md.pdb libiompstubs5md.dll libirngmd.dll libmmd.dll libmmd.pdb libmmdd.dll libmmdd.pdb svml_dispmd.dll svml_dispmd.pdb
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin: acl_emulator_kernel_rt.dll acl_hostxml.dll alteracl_icd.dll aocl-binedit.exe aocl-boardspec.exe aocl-extract-aocx.exe aocl-get-platform-diagnose.exe aocl-hash.exe aocl-libedit.exe aocl-profile-gpp.exe aocl-rtl-hash.exe aoc_cosim_mmd.dll aoc_cosim_msim.dll aoc_cosim_msim32.dll hls_cosim_msim.dll hls_cosim_msim32.dll hls_emul.dll hls_fixed_point_math_x86.dll hls_vpfp_library.dll libelf.dll perl psg_mpfr.dll psg_mpir.dll
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin: aocl-clang.exe aocl-link.exe aocl-llc.exe aocl-llvm-spirv.exe aocl-opt.exe
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin: acl_emulator_kernel_rt.dll acl_hostxml.dll alteracl_icd.dll aoc_cosim_mmd.dll aoc_cosim_msim.dll aoc_cosim_msim32.dll coffcopy.exe devinfo.exe hls_cosim_msim.dll hls_cosim_msim32.dll hls_emul.dll hls_fixed_point_math_x86.dll hls_vpfp_library.dll libelf.dll profile-report.bat system_integrator.exe zlib1.dll
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin: aoc.exe aocl.exe fpga_crossgen.exe fpga_libtool.exe vswhere.exe
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64: 1033 atlprov.dll bscmake.exe c1.dll c1xx.dll c2.dll cl.exe cl.exe.config CppCoreCheck.dll cvtres.exe d3dcompiler_47.dll dpcmi.dll dumpbin.exe editbin.exe EspXEngine.dll lib.exe link.exe link.exe.config LocalESPC.dll Microsoft.Diagnostics.Tracing.EventSource.dll Microsoft.VisualStudio.RemoteControl.dll Microsoft.VisualStudio.Telemetry.dll Microsoft.VisualStudio.Utilities.Internal.dll ml64.exe msobj140.dll mspdb140.dll mspdbcmf.exe mspdbcore.dll mspdbsrv.exe mspdbst.dll mspft140.dll msvcdis140.dll msvcp140.dll msvcp140_1.dll msvcp140_2.dll Newtonsoft.Json.dll nmake.exe pgocvt.exe pgodb140.dll pgomgr.exe pgort140.dll pgosweep.exe undname.exe vcmeta.dll vcruntime140.dll vctip.exe xdcmake.exe xdcmake.exe.config
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages: 1033 autolayt.dll bined.dll clang-format.exe concrt140.dll cpfe.dll cpfecl.Android.arm.dll cpfecl.Android.arm64.dll cpfecl.Android.x64.dll cpfecl.Android.x86.dll cpfecl.arm.dll cpfecl.arm64.dll cpfecl.Clang.Windows.arm.dll cpfecl.Clang.Windows.x64.dll cpfecl.Clang.Windows.x86.dll cpfecl.iOS.arm.dll cpfecl.iOS.arm64.dll cpfecl.iOS.x64.dll cpfecl.iOS.x86.dll cpfecl.Linux.arm.dll cpfecl.Linux.x64.dll cpfecl.Linux.x86.dll cpfecl.Win32.dll cpfecl.x64.dll cpp.hint dbsvc.dll DirControl.dll dxcompiler.dll en MacroPicker.dll mfc140u.dll Microsoft.VisualC.ProjectControls.dll Microsoft.VisualC.ProjectStore.Implementation.dll msgblder.dll msvcp140.dll platform.winmd rcxdti.dll resedit.dll vcbuild.dll VCInterfaces.tlb vcmeta.dll vcpb2.tlb vcpkg.dll vcpkgsrv.exe vcpkgsrv.exe.config VCProject.dll vcruntime140.dll
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow: ActivateApplication.exe catalog.json CertificateInformation.dat ComComponents cs de EntityFramework.dll es extension.vsixmanifest Extensions fr it ja ko manifest.json Microsoft.TeamFoundation.TestPlatform.Client.dll Microsoft.TestTools.Cpp.targets Microsoft.VisualStudio.Diagnostics.Measurement.dll Microsoft.VisualStudio.MSTest.TestWindow.dll Microsoft.VisualStudio.QualityTools.Common.dll Microsoft.VisualStudio.QualityTools.ExecutionCommon.dll Microsoft.VisualStudio.QualityTools.Resource.dll Microsoft.VisualStudio.QualityTools.UnitTestFramework.dll Microsoft.VisualStudio.TestPlatform.BuildTasks.dll Microsoft.VisualStudio.TestPlatform.Client.dll Microsoft.VisualStudio.TestPlatform.Common.dll Microsoft.VisualStudio.TestPlatform.Core.dll Microsoft.VisualStudio.TestPlatform.ObjectModel.dll Microsoft.VisualStudio.TestPlatform.TestExecutor.Core.dll Microsoft.VisualStudio.TestPlatform.Utilities.AppContainer.dll Microsoft.VisualStudio.TestPlatform.Utilities.dll Microsoft.VisualStudio.TestWindow.Core.dll Microsoft.VisualStudio.TestWindow.CppUnitTestExtension.dll Microsoft.VisualStudio.TestWindow.dll Microsoft.VisualStudio.TestWindow.Interfaces.dll Microsoft.VisualStudio.TestWindow.pkgdef Microsoft.VisualStudio.TestWindow.VSTest.dll msdia140typelib_clr0200.dll pl pt-BR ru TestPlatform.ObjectModel.manifest TestPlatform.ObjectModel.x86.manifest TestWindowProvideCodeBase.pkgdef tr vstest.console.exe vstest.console.exe.config vstest.discoveryengine.exe vstest.discoveryengine.exe.config vstest.discoveryengine.x86.exe vstest.discoveryengine.x86.exe.config vstest.executionengine.clr20.exe vstest.executionengine.clr20.exe.config vstest.executionengine.exe vstest.executionengine.exe.config vstest.executionengine.x86.clr20.exe vstest.executionengine.x86.clr20.exe.config vstest.executionengine.x86.exe vstest.executionengine.x86.exe.config x64 zh-Hans zh-Hant
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer: 1028 1029 1031 1033 1036 1040 1041 1042 1045 1046 1049 1055 2052 3082 BuildNotificationApp.exe BuildNotificationApp.exe.config catalog.json CertificateInformation.dat cs de en EndTask.exe es extension.vsixmanifest fr Git git2-msvstfs.dll it ja ko libgit2-src.zip LibGit2Sharp.dll manifest.json Microsoft.IdentityModel.Clients.ActiveDirectory.dll Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll Microsoft.IdentityModel.Logging.dll Microsoft.IdentityModel.Tokens.dll Microsoft.ServiceBus.dll Microsoft.TeamFoundation.Build.Activities.dll Microsoft.TeamFoundation.Build.Client.dll Microsoft.TeamFoundation.Build.Common.dll Microsoft.TeamFoundation.Build.Config.dll Microsoft.TeamFoundation.Build.Controls.Common.dll Microsoft.TeamFoundation.Build.Controls.dll Microsoft.TeamFoundation.Build.ProcessComponents.dll Microsoft.TeamFoundation.Build.WebApi.dll Microsoft.TeamFoundation.Build.Workflow.dll Microsoft.TeamFoundation.Build2.WebApi.dll Microsoft.TeamFoundation.Client.dll Microsoft.TeamFoundation.CodeReview.Components.dll Microsoft.TeamFoundation.CodeReview.Controls.dll Microsoft.TeamFoundation.Common.dll Microsoft.TeamFoundation.Controls.dll Microsoft.TeamFoundation.Core.WebApi.dll Microsoft.TeamFoundation.DeleteTeamProject.dll Microsoft.TeamFoundation.Deployment.Workflow.dll Microsoft.TeamFoundation.Diff.dll Microsoft.TeamFoundation.Discussion.Client.dll Microsoft.TeamFoundation.DistributedTask.Common.Contracts.dll Microsoft.TeamFoundation.Git.Client.dll Microsoft.TeamFoundation.Git.Controls.dll Microsoft.TeamFoundation.Git.CoreServices.dll Microsoft.TeamFoundation.Git.dll Microsoft.TeamFoundation.Git.Graph.dll Microsoft.TeamFoundation.Git.Provider.dll Microsoft.TeamFoundation.Lab.Client.dll Microsoft.TeamFoundation.Lab.Common.dll Microsoft.TeamFoundation.Lab.TestIntegration.Client.dll Microsoft.TeamFoundation.Lab.Workflow.Activities.dll Microsoft.TeamFoundation.Lab.WorkflowIntegration.Client.dll Microsoft.TeamFoundation.OfficeIntegration.Common.dll Microsoft.TeamFoundation.ProjectManagement.dll Microsoft.TeamFoundation.SharePointReporting.Integration.dll Microsoft.TeamFoundation.SourceControl.WebApi.dll Microsoft.TeamFoundation.Sync.Mapping.dll Microsoft.TeamFoundation.Sync.Project.Server.Library.dll Microsoft.TeamFoundation.Sync.ProjectServerApi.dll Microsoft.TeamFoundation.Sync.Shared.dll Microsoft.TeamFoundation.TeamExplorer.Navigation.dll Microsoft.TeamFoundation.Test.WebApi.dll Microsoft.TeamFoundation.TestImpact.BuildIntegration.dll Microsoft.TeamFoundation.TestImpact.Client.dll Microsoft.TeamFoundation.TestManagement.Client.dll Microsoft.TeamFoundation.TestManagement.ClientPackage.dll Microsoft.TeamFoundation.TestManagement.Common.dll Microsoft.TeamFoundation.TestManagement.Controller.dll Microsoft.TeamFoundation.TestManagement.Controls.dll Microsoft.TeamFoundation.TestManagement.PcwPlugin.dll Microsoft.TeamFoundation.TestManagement.WebApi.dll Microsoft.TeamFoundation.VersionControl.Client.dll Microsoft.TeamFoundation.VersionControl.Common.dll Microsoft.TeamFoundation.VersionControl.Common.Integration.dll Microsoft.TeamFoundation.VersionControl.ControlAdapter.dll Microsoft.TeamFoundation.VersionControl.Controls.Common.dll Microsoft.TeamFoundation.VersionControl.Controls.dll Microsoft.TeamFoundation.VersionControl.UIFeatures.dll Microsoft.TeamFoundation.Work.WebApi.dll Microsoft.TeamFoundation.WorkItemTracking.Client.DataStoreLoader.dll Microsoft.TeamFoundation.WorkItemTracking.Client.dll Microsoft.TeamFoundation.WorkItemTracking.Client.QueryLanguage.dll Microsoft.TeamFoundation.WorkItemTracking.Common.dll Microsoft.TeamFoundation.WorkItemTracking.Controls.dll Microsoft.TeamFoundation.WorkItemTracking.ControlsCore.dll Microsoft.TeamFoundation.WorkItemTracking.Proxy.dll Microsoft.TeamFoundation.WorkItemTracking.WebApi.dll Microsoft.VisualStudio.ContextManagement.Package.dll Microsoft.VisualStudio.ContextManagement.Public.dll Microsoft.VisualStudio.Services.Client.Interactive.dll Microsoft.VisualStudio.Services.Common.dll Microsoft.VisualStudio.Services.Integration.dll Microsoft.VisualStudio.Services.WebApi.dll Microsoft.VisualStudio.TeamFoundation.Build.dll Microsoft.VisualStudio.TeamFoundation.Client.dll Microsoft.VisualStudio.TeamFoundation.dll Microsoft.VisualStudio.TeamFoundation.InitializationPackage.dll Microsoft.VisualStudio.TeamFoundation.Lab.dll Microsoft.VisualStudio.TeamFoundation.NuGetCredentialProvider.dll Microsoft.VisualStudio.TeamFoundation.PCW.dll Microsoft.VisualStudio.TeamFoundation.SharePointReporting.dll Microsoft.VisualStudio.TeamFoundation.VersionControl.dll Microsoft.VisualStudio.TeamFoundation.WorkItemTracking.dll Microsoft.VisualStudio.Zip.9.0.dll Microsoft.WITDataStore32.dll Microsoft.WITDataStore64.dll Newtonsoft.Json.dll pl pt-BR ru System.IdentityModel.Tokens.Jwt.dll System.Net.Http.Formatting.dll System.Web.Http.dll TeamExplorer.CodeBase.pkgdef TeamExplorer.pkgdef TeamExplorerThemes.pkgdef TF.exe TF.exe.config TFSBuild.exe TFSBuild.exe.config TfsDeleteProject.exe TfsDeleteProject.exe.config TfsProvider.dll TfsProviderStub.dll TFSSecurity.exe TFSSecurity.exe.config tr vsDiffMerge.exe witadmin.exe witadmin.exe.config zh-Hans zh-Hant
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn: csc.exe csc.exe.config csc.rsp csi.exe csi.exe.config csi.rsp Microsoft.Build.Tasks.CodeAnalysis.dll Microsoft.CodeAnalysis.CSharp.dll Microsoft.CodeAnalysis.CSharp.Scripting.dll Microsoft.CodeAnalysis.dll Microsoft.CodeAnalysis.Scripting.dll Microsoft.CodeAnalysis.VisualBasic.dll Microsoft.CSharp.Core.targets Microsoft.DiaSymReader.Native.amd64.dll Microsoft.DiaSymReader.Native.x86.dll Microsoft.Managed.Core.targets Microsoft.VisualBasic.Core.targets Microsoft.Win32.Primitives.dll System.AppContext.dll System.Collections.Immutable.dll System.Console.dll System.Diagnostics.DiagnosticSource.dll System.Diagnostics.FileVersionInfo.dll System.Diagnostics.StackTrace.dll System.Globalization.Calendars.dll System.IO.Compression.dll System.IO.Compression.ZipFile.dll System.IO.FileSystem.dll System.IO.FileSystem.Primitives.dll System.Net.Http.dll System.Net.Sockets.dll System.Reflection.Metadata.dll System.Runtime.InteropServices.RuntimeInformation.dll System.Security.Cryptography.Algorithms.dll System.Security.Cryptography.Encoding.dll System.Security.Cryptography.Primitives.dll System.Security.Cryptography.X509Certificates.dll System.Text.Encoding.CodePages.dll System.Threading.Tasks.Extensions.dll System.ValueTuple.dll System.Xml.ReaderWriter.dll System.Xml.XmlDocument.dll System.Xml.XPath.dll System.Xml.XPath.XDocument.dll vbc.exe vbc.exe.config vbc.rsp VBCSCompiler.exe VBCSCompiler.exe.config
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64: 1033 KernelTraceControl.dll msdia140.dll msdia140.dll.manifest PerfSDK vsinstr.exe vsinstr.legacy.exe vsperfrelogger.dll vspmsg.dll
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools: 1033 CoverageDSPriv.xsd dbgcore.dll dbghelp.dll KernelTraceControl.dll Microsoft.DbgHelp.manifest Microsoft.VisualStudio.PerformanceTools.CounterInfo.dll Microsoft.VisualStudio.PerformanceTools.EtwMon.dll Microsoft.VisualStudio.PerformanceTools.RulesEngine.dll Microsoft.VisualStudio.PerformanceTools.Visualization.dll msdia140.dll msdia140.dll.manifest PerfItems PerfPkg.dll PerfSDK Plugins ProfilingTasks.xml ProfilingTasks.xsd ReportMetadata.xsd Setups symsrv.dll symsrv.yes vsinstr.exe vsinstr.legacy.exe VSPerf.exe VSPerf.exe.config VSPerfAnalysis.dll VSPerfControl.Interop.dll VSPerfData.dll VSPerfPresentation.dll VsPerfReader.dll vsperfrelogger.dll VSPerfReport.exe VSPerfReport.exe.manifest VSPerf_Rule_Definitions.xml vspmsg.dll x64
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64: 1033 dbgcore.dll dbghelp.dll Microsoft.DbgHelp.manifest Microsoft.VisualStudio.Profiler.dll SamplingRuntime.dll VSPerfCmd.exe VSPerfControl.dll VSPerfControl.Interop.dll VSPerfCorProf.dll VSPerfCpuCounters.xsd VSPerfDrv150.sys VSPerfMon.exe VSPerfSrv.exe VSPerfSys150.cat vspmsg.dll
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools: 1033 dbgcore.dll dbghelp.dll Microsoft.DbgHelp.manifest Microsoft.VisualStudio.Enterprise.AspNetHelper.dll Microsoft.VisualStudio.PerformanceTools.CmdHelper.dll Microsoft.VisualStudio.Profiler.dll ReportMetadata.xsd SamplingRuntime.dll VSPerfASPNetCmd.exe VSPerfCLREnv.cmd VSPerfCmd.exe VSPerfCollectionPlan.xml VSPerfControl.dll VSPerfControl.Interop.dll VSPerfCorProf.dll VSPerfCpuCounters.xsd VSPerfDrv150.sys VSPerfMon.exe VSPerfSrv.exe VSPerfSys150.cat VSPerf_Platform_K7.xml VSPerf_Platform_K8.xml VSPerf_Platform_P4.xml VSPerf_Platform_P6.xml VSPerf_Platform_P6_arch.xml VSPerf_Portable.xml VSPerf_Rule_Definitions.xml vspmsg.dll VsWebSite.Interop.dll x64
      /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64: 1033 AccChecker accevent.exe adpcmencode3.exe AppAnalysis appxpackaging.dll appxsip.dll betest.exe betest.xml BetestSample.xml bulkmetadatapackagingwizard.exe cert2spc.exe certmgr.exe ComparePackage.exe computerhardwareids.exe config.mftx convert-moftoprovider.exe cppwinrt.exe ctrpp.exe d3dcompiler_47.dll d3dcsxd_47.dll d3dcsx_47.dll default.tmf DeployUtil.exe devicemetadatacommon.dll DeviceMetadataWizard.exe dxc.exe dxcapsviewer.exe dxcompiler.dll dxil.dll en-US esp32.tsp espexe.exe espui.dll event.dll extidgen.exe filetypeverifier.exe filtdump.exe filtreg.exe ftquery.exe fxc.exe gamesaveutil.exe genmanifest.exe genxbf.dll graphedt.exe ifilttst.exe IFiltTst.Ini inspect.exe install-sampleprovider.cmd interop.searchapi.dll interop.taskscheduler.dll ISVTier5AppSigningPrivKey.dat ISVTier5AppSigningPubKey.dat ISVTier5AppSignSDK.cc ISVTier5AppSignSDK.xml ISVTier5AppSignSDK_Client.xml isxps.exe isxpshlp.dll iviewers.dll jsconstraintdebug.exe makeappx.exe makecat.exe makecat.exe.manifest makecert.exe makepri.exe mbidgenerator.exe mc.exe mdmerge.exe mergemod.dll mfdetours.dll mftrace.exe Microsoft.Azure.KeyVault.Core.dll Microsoft.ComparePackage.Lib.dll Microsoft.Data.Edm.dll Microsoft.Data.OData.dll Microsoft.Data.Services.Client.dll Microsoft.Diagnostics.Tracing.EventSource.dll Microsoft.IdentityModel.Clients.ActiveDirectory.dll Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll Microsoft.Ingestion.Shared.Metrics.dll Microsoft.Ingestion.Shared.WebApi.Client.dll Microsoft.PackageEditor.Lib.dll Microsoft.Packaging.SDKUtils.dll Microsoft.StoreUploader.Lib.dll Microsoft.UniversalStore.Ingestion.Upload.Client.dll Microsoft.UniversalStore.Ingestion.Upload.UploadApiContracts.dll microsoft.win32.search.query.dll Microsoft.Windows.Build.Appx.AppxPackaging.dll.manifest Microsoft.Windows.Build.Appx.AppxSip.dll.manifest Microsoft.Windows.Build.Appx.OpcServices.dll.manifest Microsoft.Windows.Build.Signing.mssign32.dll.manifest Microsoft.Windows.Build.Signing.wintrust.dll.manifest Microsoft.WindowsAzure.Configuration.dll Microsoft.WindowsAzure.Storage.DataMovement.dll Microsoft.WindowsAzure.Storage.dll midl.exe midlc.exe midlrt.exe midlrtmd.dll mlgen.exe mlgenlib.dll mrmsupport.dll msisip.dll mssign32.dll mt.exe mt.exe.config muirct.exe Newtonsoft.Json.dll NLog.dll oleview.exe opcservices.dll PackageEditor.exe patchwiz.dll pktextract.exe proppage.dll provisioningtesthelper.dll ProvisioningTestHelper.psd1 ptconform.dll pvk2pfx.exe rc.exe rcdll.dll register_app.vbs regwinmd.exe signtool.exe signtool.exe.manifest StoreUploader.exe StoreUploader.exe.config swriter.xml System.Net.Http.Formatting.dll System.Spatial.dll TB3x.exe tedutil.dll topoedit.exe tracefmt.exe tracelog.exe tracepdb.exe traceview.exe tracewpp.exe ucrt UIAVerify uninstall-sampleprovider.cmd uuidgen.exe virtualstoragevss.cat virtualstoragevss.inf virtualstoragevss.sys vmsavedstatedumpprovider.dll vsdiagview.exe vshadow.exe vssagent.exe vsssampleprovider.dll vsstrace.exe vstorcontrol.exe vstorinterface.dll vswriter.exe VswriterSample.xml vswriter_config.xml WiCompon.vbs widialog.vbs widiffdb.vbs wiexport.vbs wifeatur.vbs wifilver.vbs wigenxfm.vbs wiimport.vbs wilangid.vbs wilstprd.vbs wilstscr.vbs wilstxfm.vbs wimakcab.vbs wimerge.vbs winmdidl.exe wintrust.dll wintrust.dll.ini wipolicy.vbs wireadme.txt wirunsql.vbs wistream.vbs wisubstg.vbs wisuminf.vbs witextin.vbs witoansi.vbs wiusexfm.vbs wmicodegen.dll wsdcodegen.exe wsddebug_client.exe wsddebug_host.exe wstracedump.exe wstraceutil.exe wsutil.exe wsutilhelper.dll xpsanalyzer.exe xpsconverter.exe
      /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64: GenXBF.dll XamlDiagnostics
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin: 1028 1031 1033 1036 1040 1041 1042 1049 2052 3082 amd64 AssemblyFolders.config cs de de-DE en en-US es es-ES FileTracker32.dll FileTracker64.dll fr fr-FR it it-IT ja ja-JP ko ko-KR Microsoft.Build.Conversion.Core.dll Microsoft.Build.dll Microsoft.Build.Engine.dll Microsoft.Build.Framework.dll Microsoft.Build.Tasks.Core.dll Microsoft.Build.Utilities.Core.dll Microsoft.Common.CrossTargeting.targets Microsoft.Common.CurrentVersion.targets Microsoft.Common.overridetasks Microsoft.Common.targets Microsoft.Common.tasks Microsoft.CSharp.CrossTargeting.targets Microsoft.CSharp.CurrentVersion.targets Microsoft.CSharp.targets Microsoft.Data.Entity.targets Microsoft.NetFramework.CurrentVersion.props Microsoft.NetFramework.CurrentVersion.targets Microsoft.NetFramework.props Microsoft.NetFramework.targets Microsoft.ServiceModel.targets Microsoft.VisualBasic.CrossTargeting.targets Microsoft.VisualBasic.CurrentVersion.targets Microsoft.VisualBasic.targets Microsoft.WinFx.targets Microsoft.WorkflowBuildExtensions.targets Microsoft.Xaml.targets MSBuild MSBuild.exe MSBuild.exe.config MSBuild.rsp MSBuildTaskHost.exe MSBuildTaskHost.exe.config pl pt-BR ref Roslyn ru ru-RU SdkResolvers System.Collections.Immutable.dll System.IO.Compression.dll System.Runtime.InteropServices.RuntimeInformation.dll System.Threading.Tasks.Dataflow.dll tr Tracker.exe Workflow.targets Workflow.VisualBasic.targets zh-CN zh-Hans zh-Hant zh-TW
      /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319: 1033 Accessibility.dll AddInProcess.exe AddInProcess.exe.config AddInProcess32.exe AddInProcess32.exe.config AddInUtil.exe AddInUtil.exe.config AdoNetDiag.dll adonetdiag.mof adonetdiag.mof.uninstall alink.dll AppLaunch.exe applaunch.exe.config ASP.NETWebAdminFiles Aspnet.config aspnet.mof aspnet.mof.uninstall aspnet_compiler.exe aspnet_filter.dll aspnet_isapi.dll Aspnet_perf.dll aspnet_perf.h aspnet_perf.ini aspnet_perf2.ini aspnet_rc.dll aspnet_regbrowsers.exe aspnet_regiis.exe aspnet_regsql.exe aspnet_state.exe aspnet_state_perf.h aspnet_state_perf.ini aspnet_wp.exe CasPol.exe caspol.exe.config clientexclusionlist.xml CLR-ETW.man clr.dll clrcompression.dll clretwrc.dll clrjit.dll compatjit.dll ComSvcConfig.exe Config CORPerfMonExt.dll csc.exe csc.exe.config csc.rsp Culture.dll CustomMarshalers.dll cvtres.exe cvtres.exe.config DataSvcUtil.exe DataSvcUtil.exe.config default.win32manifest dfdll.dll dfsvc.exe dfsvc.exe.config diasymreader.dll dv_aspnetmmc.chm EdmGen.exe en-US EventLogMessages.dll FileTracker.dll fusion.dll ilasm.exe ilasm.exe.config InstallCommon.sql InstallMembership.sql InstallPersistSqlState.sql InstallPersonalization.sql InstallProfile.SQL InstallRoles.sql InstallSqlState.sql InstallSqlStateTemplate.sql InstallUtil.exe InstallUtil.exe.config InstallUtilLib.dll InstallWebEventSqlProvider.sql ISymWrapper.dll jsc.exe jsc.exe.config locale.nlp Microsoft.Activities.Build.dll Microsoft.Build.Conversion.v4.0.dll Microsoft.Build.dll Microsoft.Build.Engine.dll Microsoft.Build.Framework.dll Microsoft.Build.Tasks.v4.0.dll Microsoft.Build.Utilities.v4.0.dll Microsoft.Build.xsd Microsoft.Common.OverrideTasks Microsoft.Common.targets Microsoft.Common.Tasks Microsoft.CSharp.dll Microsoft.CSharp.targets Microsoft.Data.Entity.Build.Tasks.dll Microsoft.Data.Entity.targets Microsoft.Internal.Tasks.Dataflow.dll Microsoft.JScript.dll Microsoft.JScript.tlb Microsoft.NETFramework.props Microsoft.NETFramework.targets Microsoft.ServiceModel.targets Microsoft.Transactions.Bridge.dll Microsoft.Transactions.Bridge.Dtc.dll Microsoft.VisualBasic.Activities.Compiler.dll Microsoft.VisualBasic.Compatibility.Data.dll Microsoft.VisualBasic.Compatibility.dll Microsoft.VisualBasic.dll Microsoft.VisualBasic.targets Microsoft.VisualC.Dll Microsoft.VisualC.STLCLR.dll Microsoft.Win32.Primitives.dll Microsoft.Windows.ApplicationServer.Applications.45.man Microsoft.Windows.ApplicationServer.Applications.dll Microsoft.WinFx.targets Microsoft.Workflow.Compiler.exe Microsoft.Workflow.Compiler.exe.config Microsoft.WorkflowBuildExtensions.targets Microsoft.Xaml.targets MmcAspExt.dll MSBuild MSBuild.exe msbuild.exe.config MSBuild.rsp mscordacwks.dll mscordbi.dll mscoree.tlb mscoreei.dll mscoreeis.dll mscorlib.dll mscorlib.tlb mscorpe.dll mscorpehost.dll mscorrc.dll mscorsecimpl.dll mscorsn.dll mscorsvc.dll mscorsvw.exe MUI NativeImages netstandard.dll ngen.exe ngen.log ngen.old.log ngentask.exe ngentasklauncher.dll normidna.nlp normnfc.nlp normnfd.nlp normnfkc.nlp normnfkd.nlp PerfCounter.dll peverify.dll RegAsm.exe regasm.exe.config RegSvcs.exe regsvcs.exe.config SbsNclPerf.dll ServiceModelEvents.dll ServiceModelInstallRC.dll ServiceModelPerformanceCounters.dll ServiceModelPerformanceCounters.man ServiceModelReg.exe ServiceModelRegUI.dll ServiceMonikerSupport.dll SMDiagnostics.dll SMSvcHost.exe SMSvcHost.exe.config SOS.dll SQL sysglobl.dll System.Activities.Core.Presentation.dll System.Activities.dll System.Activities.DurableInstancing.dll System.Activities.Presentation.dll System.AddIn.Contract.dll System.AddIn.dll System.AppContext.dll System.Collections.Concurrent.dll System.Collections.dll System.Collections.NonGeneric.dll System.Collections.Specialized.dll System.ComponentModel.Annotations.dll System.ComponentModel.Composition.dll system.componentmodel.composition.registration.dll System.ComponentModel.DataAnnotations.dll System.ComponentModel.dll System.ComponentModel.EventBasedAsync.dll System.ComponentModel.Primitives.dll System.ComponentModel.TypeConverter.dll System.Configuration.dll System.Configuration.Install.dll System.Console.dll System.Core.dll System.Data.Common.dll System.Data.DataSetExtensions.dll System.Data.dll System.Data.Entity.Design.dll System.Data.Entity.dll System.Data.Linq.dll System.Data.OracleClient.dll System.Data.Services.Client.dll System.Data.Services.Design.dll System.Data.Services.dll System.Data.SqlXml.dll System.Deployment.dll System.Design.dll System.Device.dll System.Diagnostics.Contracts.dll System.Diagnostics.Debug.dll System.Diagnostics.FileVersionInfo.dll System.Diagnostics.Process.dll System.Diagnostics.StackTrace.dll System.Diagnostics.TextWriterTraceListener.dll System.Diagnostics.Tools.dll System.Diagnostics.TraceSource.dll System.Diagnostics.Tracing.dll System.DirectoryServices.AccountManagement.dll System.DirectoryServices.dll System.DirectoryServices.Protocols.dll System.dll System.Drawing.Design.dll System.Drawing.dll System.Drawing.Primitives.dll System.Drawing.tlb System.Dynamic.dll System.Dynamic.Runtime.dll System.EnterpriseServices.dll System.EnterpriseServices.Thunk.dll System.EnterpriseServices.tlb System.EnterpriseServices.Wrapper.dll System.Globalization.Calendars.dll System.Globalization.dll System.Globalization.Extensions.dll System.IdentityModel.dll System.IdentityModel.Selectors.dll System.IdentityModel.Services.dll System.IO.Compression.dll System.IO.Compression.FileSystem.dll System.IO.Compression.ZipFile.dll System.IO.dll System.IO.FileSystem.dll System.IO.FileSystem.DriveInfo.dll System.IO.FileSystem.Primitives.dll System.IO.FileSystem.Watcher.dll System.IO.IsolatedStorage.dll System.IO.Log.dll System.IO.MemoryMappedFiles.dll System.IO.Pipes.dll System.IO.UnmanagedMemoryStream.dll System.Linq.dll System.Linq.Expressions.dll System.Linq.Parallel.dll System.Linq.Queryable.dll System.Management.dll System.Management.Instrumentation.dll System.Messaging.dll System.Net.dll System.Net.Http.dll System.Net.Http.Rtc.dll System.Net.Http.WebRequest.dll System.Net.NameResolution.dll System.Net.NetworkInformation.dll System.Net.Ping.dll System.Net.Primitives.dll System.Net.Requests.dll System.Net.Security.dll System.Net.Sockets.dll System.Net.WebHeaderCollection.dll System.Net.WebSockets.Client.dll System.Net.WebSockets.dll System.Numerics.dll System.Numerics.Vectors.dll System.ObjectModel.dll System.Reflection.context.dll System.Reflection.dll System.Reflection.Emit.dll System.Reflection.Emit.ILGeneration.dll System.Reflection.Emit.Lightweight.dll System.Reflection.Extensions.dll System.Reflection.Primitives.dll System.Resources.Reader.dll System.Resources.ResourceManager.dll System.Resources.Writer.dll System.Runtime.Caching.dll System.Runtime.CompilerServices.VisualC.dll System.Runtime.dll System.Runtime.DurableInstancing.dll System.Runtime.Extensions.dll System.Runtime.Handles.dll System.Runtime.InteropServices.dll System.Runtime.InteropServices.RuntimeInformation.dll System.Runtime.InteropServices.WindowsRuntime.dll System.Runtime.Numerics.dll System.Runtime.Remoting.dll System.Runtime.Serialization.dll System.Runtime.Serialization.Formatters.dll System.Runtime.Serialization.Formatters.Soap.dll System.Runtime.Serialization.Json.dll System.Runtime.Serialization.Primitives.dll System.Runtime.Serialization.Xml.dll System.Runtime.WindowsRuntime.dll System.Runtime.WindowsRuntime.UI.Xaml.dll System.Security.Claims.dll System.Security.Cryptography.Algorithms.dll System.Security.Cryptography.Csp.dll System.Security.Cryptography.Encoding.dll System.Security.Cryptography.Primitives.dll System.Security.Cryptography.X509Certificates.dll System.Security.dll System.Security.Principal.dll System.Security.SecureString.dll System.ServiceModel.Activation.dll System.ServiceModel.Activities.dll System.ServiceModel.Channels.dll System.ServiceModel.Discovery.dll System.ServiceModel.dll System.ServiceModel.Duplex.dll System.ServiceModel.Http.dll System.ServiceModel.Internals.dll System.ServiceModel.NetTcp.dll System.ServiceModel.Primitives.dll System.ServiceModel.Routing.dll System.ServiceModel.Security.dll System.ServiceModel.ServiceMoniker40.dll System.ServiceModel.WasHosting.dll System.ServiceModel.Web.dll System.ServiceProcess.dll System.Text.Encoding.dll System.Text.Encoding.Extensions.dll System.Text.RegularExpressions.dll System.Threading.dll System.Threading.Overlapped.dll System.Threading.Tasks.dll System.Threading.Tasks.Parallel.dll System.Threading.Thread.dll System.Threading.ThreadPool.dll System.Threading.Timer.dll System.tlb System.Transactions.dll System.ValueTuple.dll System.Web.Abstractions.dll System.Web.ApplicationServices.dll System.Web.DataVisualization.Design.dll System.Web.DataVisualization.dll System.Web.dll System.Web.DynamicData.Design.dll System.Web.DynamicData.dll System.Web.Entity.Design.dll System.Web.Entity.dll System.Web.Extensions.Design.dll System.Web.Extensions.dll System.Web.Mobile.dll System.Web.RegularExpressions.dll System.Web.Routing.dll System.Web.Services.dll System.Web.tlb System.Windows.dll System.Windows.Forms.DataVisualization.Design.dll System.Windows.Forms.DataVisualization.dll System.Windows.Forms.dll System.Windows.Forms.tlb System.Workflow.Activities.dll System.Workflow.ComponentModel.dll System.Workflow.Runtime.dll System.WorkflowServices.dll System.Xaml.dll System.Xaml.Hosting.dll System.XML.dll System.Xml.Linq.dll System.Xml.ReaderWriter.dll System.Xml.Serialization.dll System.Xml.XDocument.dll System.Xml.XmlDocument.dll System.Xml.XmlSerializer.dll System.Xml.XPath.dll System.Xml.XPath.XDocument.dll Temporary ASP.NET Files ThirdPartyNotices.txt TLBREF.DLL UninstallCommon.sql UninstallMembership.sql UninstallPersistSqlState.sql UninstallPersonalization.sql UnInstallProfile.SQL UninstallRoles.sql UninstallSqlState.sql UninstallSqlStateTemplate.sql UninstallWebEventSqlProvider.sql vbc.exe vbc.exe.config vbc.rsp webengine.dll webengine4.dll WMINet_Utils.dll Workflow.Targets Workflow.VisualBasic.Targets WorkflowServiceHostPerformanceCounters.dll WorkflowServiceHostPerformanceCounters.man WPF WsatConfig.exe XamlBuildTask.dll XPThemes.manifest XsdBuildTask.dll
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE: 1033 adodb.manifest api-ms-win-core-file-l1-2-0.dll api-ms-win-core-file-l2-1-0.dll api-ms-win-core-localization-l1-2-0.dll api-ms-win-core-processthreads-l1-1-1.dll api-ms-win-core-synch-l1-2-0.dll api-ms-win-core-timezone-l1-1-0.dll api-ms-win-crt-convert-l1-1-0.dll api-ms-win-crt-environment-l1-1-0.dll api-ms-win-crt-filesystem-l1-1-0.dll api-ms-win-crt-heap-l1-1-0.dll api-ms-win-crt-locale-l1-1-0.dll api-ms-win-crt-math-l1-1-0.dll api-ms-win-crt-multibyte-l1-1-0.dll api-ms-win-crt-runtime-l1-1-0.dll api-ms-win-crt-stdio-l1-1-0.dll api-ms-win-crt-string-l1-1-0.dll api-ms-win-crt-time-l1-1-0.dll api-ms-win-crt-utility-l1-1-0.dll Assets Automation Automation.manifest blend.isolation.ini CodeMarkersEtw.man CodeMarkersEtwRc.dll CommonExtensions compluslm.dll concrt140.dll convert.dir DDConfigCA.exe devenv.com devenv.exe devenv.exe.config devenv.isolation.ini devenv.prf devenv.visualelementsmanifest.xml devenv.winprf devenvdesc.dll en en-US Extensions FeedbackCollector.exe FeedbackCollector.exe.config iisresolver.dll ItemTemplates master.pkgdef Microsoft.Data.ConnectionUI.Dialog.dll Microsoft.Data.ConnectionUI.dll Microsoft.JavaScript.Services.dll Microsoft.VisualStudio.CallHierarchy.Package.Definitions.dll Microsoft.VisualStudio.CallHierarchy.Package.Implementation.dll Microsoft.VisualStudio.CodeMarkers.dll Microsoft.VisualStudio.Configuration.dll Microsoft.VisualStudio.ConfigurationUI.dll Microsoft.VisualStudio.Converters.Interop.dll Microsoft.VisualStudio.Data.Compatibility.dll Microsoft.VisualStudio.Data.dll Microsoft.VisualStudio.Data.Host.dll Microsoft.VisualStudio.Data.Interop.dll Microsoft.VisualStudio.Data.Package.dll Microsoft.VisualStudio.Data.Providers.Common.dll Microsoft.VisualStudio.Data.Providers.Oracle.dll Microsoft.VisualStudio.Data.Providers.SqlServer.dll Microsoft.VisualStudio.DataDesign.Common.dll Microsoft.VisualStudio.DataDesign.DataSetDesigner.dll Microsoft.VisualStudio.DataDesign.Interfaces.dll Microsoft.VisualStudio.DataDesign.WpfDataTool.dll Microsoft.VisualStudio.DataTools.dll Microsoft.VisualStudio.DataTools.Interop.dll Microsoft.VisualStudio.Debugger.dll Microsoft.VisualStudio.Debugger.Engine.dll Microsoft.VisualStudio.Debugger.Parallel.dll Microsoft.VisualStudio.Debugger.Parallel.Gpu.dll Microsoft.VisualStudio.Design.dll Microsoft.VisualStudio.Designer.Interfaces.dll Microsoft.VisualStudio.Diagnostics.Measurement.Native.dll Microsoft.VisualStudio.dll Microsoft.VisualStudio.Editors.WCF.dll Microsoft.VisualStudio.ExportTemplate.dll Microsoft.VisualStudio.ExtensionEngine.dll Microsoft.VisualStudio.HostingProcess.Utilities.dll Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll Microsoft.VisualStudio.ImageCatalog.dll Microsoft.VisualStudio.Imaging.dll Microsoft.VisualStudio.Licensing.dll Microsoft.VisualStudio.ManagedInterfaces.manifest Microsoft.VisualStudio.OnlineLicensing.dll Microsoft.VisualStudio.Package.LanguageService.10.0.dll Microsoft.VisualStudio.Package.LanguageService.11.0.dll Microsoft.VisualStudio.Package.LanguageService.12.0.dll Microsoft.VisualStudio.Package.LanguageService.14.0.dll Microsoft.VisualStudio.Package.LanguageService.15.0.dll Microsoft.VisualStudio.PerfWatson.dll Microsoft.VisualStudio.Platform.WindowManagement.dll Microsoft.VisualStudio.ProductKeyDialog.dll Microsoft.VisualStudio.ProductKeyDialog.tlb Microsoft.VisualStudio.ProjectConverters.DLL Microsoft.VisualStudio.QualityTools.Wizard.TestProjectWizards.manifest Microsoft.VisualStudio.RegDetour.dll Microsoft.VisualStudio.ServerExplorer.dll Microsoft.VisualStudio.Settings.15.0.dll Microsoft.VisualStudio.Shell.UI.Internal.dll Microsoft.VisualStudio.Shell.ViewManager.dll Microsoft.VisualStudio.TemplateWizard.dll Microsoft.VisualStudio.TestTools.UITest.Extension.IE.Communication.sxs.manifest Microsoft.VisualStudio.TestTools.UITest.Playback.Engine.sxs.manifest Microsoft.VisualStudio.Utilities.dll Microsoft.VisualStudio.VC.dll Microsoft.VisualStudio.vspGridControl.dll Microsoft.VisualStudio.Web.Application.dll Microsoft.VisualStudio.Web.dll Microsoft.VisualStudio.Web.Host.exe Microsoft.VisualStudio.Web.Host.exe.config Microsoft.VisualStudio.Web.Host.Shared.dll Microsoft.VisualStudio.Web.HTML.dll Microsoft.VisualStudio.Web.PublishContract.dll Microsoft.VisualStudio.Windows.Forms.dll Microsoft.VisualStudio.WizardFramework.Dll Microsoft.VisualStudio.WPFFlavor.dll Microsoft.VSDesigner.dll Microsoft.VSDesigner.WCF.dll Microsoft.Web.Design.Client.dll Microsoft.WebPublisher.dll Microsoft.WizardFramework.dll Microsoft.WizardFrameworkVS.dll MinimalResponsivenessTrackingManifest.xml msdia120.dll msdia140.dll msenv.dll msenvico.dll msenvmnu.dll msobj120.dll msobj140.dll mspdb140.dll mspdbcore.dll mspdbsrv.exe mspdbst.dll MSTest.exe MSTest.exe.config msvcdis120.dll msvcdis140.dll msvcp140.dll msvcr120_clr0400.dll NewFileItems NewScriptItems offreg.dll PerfWatson2.exe PerfWatson2.exe.config pidgenx.dll pkconfig.xrm-ms PkgdefMgmt.dll PrivateAssemblies Profiles ProjectAggregator.dll ProjectTemplates PublicAssemblies Publicize.exe QTAgent.exe QTAgent.exe.config QTAgent32.exe QTAgent32.exe.config QTAgent32_35.exe QTAgent32_35.exe.config QTAgent32_40.exe QTAgent32_40.exe.config QTAgent_35.exe QTAgent_35.exe.config QTAgent_40.exe QTAgent_40.exe.config QTDCAgent.exe QTDCAgent.exe.config QTDCAgent32.exe QTDCAgent32.exe.config Rebex.Net.Ftp.dll Rebex.Net.ProxySocket.dll Rebex.Net.SecureSocket.dll Rebex.Net.Sftp.dll Rebex.Net.Ssh.dll Rebex.Security.dll ReferenceAssemblies Remote Debugger ReSharper (Visual Studio).vsk Resources.pri Resources.scale-140.pri Resources.scale-180.pri ResponsivenessTrackingManifest.xml Script Diagnostics ShellExtensions SolutionTemplates srcsrv.dll srcsrv.ini StanPackage.manifest StartPages StorePID.exe symsrv.dll symsrv.yes System.Drawing.VisualStudio.15.0.dll System.Threading.Tasks.Dataflow.dll System.VisualStudio.15.0.dll System.Windows.Forms.VisualStudio.15.0.dll T4VSHostProcess.exe T4VSHostProcess.exe.config TCM.exe TCM.exe.config TestTools TextTemplate.ico TextTransform.exe TextTransform.exe.config TfsLabConfig.exe TfsLabConfig.exe.config ToolboxCaches ucrtbase.dll UserControlTestContainer.exe usertype.dat vb7to8.exe vb7to8DL.dll vbdebug.dll VC VCGraphicsWizard.dll vcruntime140.dll VcxprojReader.exe VcxprojReader.exe.config Visual Basic 6.vsk Visual C# 2005.vsk Visual C++ 2.vsk Visual C++ 6.vsk Visual Studio 6.vsk Visual Studio Code.vsk VS SCC VSConvertersPackage.dll VSConvertersPackage.dll.manifest vsdebugeng.dll VsDebugWERHelper.exe VSFinalizer.exe VsGa.Application.pkgdef VsGa.exe VsGa.exe.config vsga.isolation.ini VsGa.pkgdef VsGa.pkgundef VsGa.winprf VsGraphics VsGraphicsDesc.dll VSGraphicsExtensions VsGraphicsMnu.dll VSHiveStub.exe vshost-clr2.exe vshost.exe vshost32-clr2.exe vshost32.exe VSInitializer.exe VSIXInstaller.exe VSIXInstaller.exe.config VSLaunchBrowser.exe vslog.dll vsn.exe vsn.exe.config VsRegEdit.exe VsRegistryDetour.dll vssln.dll vstlbinf.dll VSWebHandler.exe VSWebLauncher.exe VsWerHandler.dll VsWizard.dll VsWizards.manifest WindowsFormsIntegration.Design.dll WindowsFormsIntegration.Package.dll WinFxBrowserApplicationTemplateWizard.dll WinFxCustomControlTemplateWizard.dll x64 Xml
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools: 1033 api-ms-win-crt-convert-l1-1-0.dll api-ms-win-crt-filesystem-l1-1-0.dll api-ms-win-crt-heap-l1-1-0.dll api-ms-win-crt-locale-l1-1-0.dll api-ms-win-crt-math-l1-1-0.dll api-ms-win-crt-multibyte-l1-1-0.dll api-ms-win-crt-runtime-l1-1-0.dll api-ms-win-crt-stdio-l1-1-0.dll api-ms-win-crt-string-l1-1-0.dll api-ms-win-crt-time-l1-1-0.dll api-ms-win-crt-utility-l1-1-0.dll errlook.exe errlook.hlp guidgen.exe LaunchDevCmd.bat makehm.exe mfc140chs.dll mfc140cht.dll mfc140deu.dll mfc140enu.dll mfc140esn.dll mfc140fra.dll mfc140ita.dll mfc140jpn.dll mfc140kor.dll mfc140rus.dll mfc140u.dll Rules2BuildRules.xslt Rules2Props.xslt Rules2Targets.xslt spyxx.chm spyxx.exe spyxxhk.dll spyxxhk_amd64.dll spyxx_amd64.chm spyxx_amd64.exe ucrtbase.dll vcconvertengine.dll VCProjectConversion.dll vcruntime140.dll VDT vsdevcmd VsDevCmd.bat VsMSBuildCmd.bat
      /cygdrive/c/Program Files/Microsoft MPI/Bin: mpiexec.exe mpitrace.man msmpilaunchsvc.exe smpd.exe
      /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin: bin2c.exe compute-sanitizer.bat crt cu++filt.exe cublas64_11.dll cublasLt64_11.dll cuda-memcheck.exe cudafe++.exe cudart32_110.dll cudart64_110.dll cudnn64_8.dll cudnn_adv_infer64_8.dll cudnn_adv_train64_8.dll cudnn_cnn_infer64_8.dll cudnn_cnn_train64_8.dll cudnn_ops_infer64_8.dll cudnn_ops_train64_8.dll cufft64_10.dll cufftw64_10.dll cuinj64_112.dll cuobjdump.exe curand64_10.dll cusolver64_11.dll cusolverMg64_11.dll cusparse64_11.dll fatbinary.exe nppc64_11.dll nppial64_11.dll nppicc64_11.dll nppidei64_11.dll nppif64_11.dll nppig64_11.dll nppim64_11.dll nppist64_11.dll nppisu64_11.dll nppitc64_11.dll npps64_11.dll nvblas64_11.dll nvcc.exe nvcc.profile nvdisasm.exe nvjpeg64_11.dll nvlink.exe nvprof.exe nvprune.exe nvrtc-builtins64_112.dll nvrtc-prev nvrtc64_112_0.dll nvvp.bat ptxas.exe
      /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp: .eclipseproduct artifacts.xml configuration eclipsec.exe epl-v10.html features notice.html nvvp.exe nvvp.ini p2 plugins readme
      /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common: cudart32_65.dll cudart64_30_9.dll cudart64_65.dll PhysXDevice.dll PhysXDevice64.dll PhysXLoader.dll PhysXLoader64.dll PhysXUpdateLoader.dll PhysXUpdateLoader64.dll
      /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin: ABQDMP_Core.dll ABQSMAAbuBasicUtils.dll ABQSMAAbuGeom.dll ABQSMAAspCommunications.dll ABQSMAAspDiagExtractor.dll ABQSMAAspSchemaSupport.dll ABQSMAAspSupport.dll ABQSMABasAlloc.dll ABQSMABasCoreUtils.dll ABQSMABasGenericsLib.dll ABQSMABasPrfTrkLib.dll ABQSMABasShared.dll ABQSMABasXmlDocument.dll ABQSMABasXmlParser.dll ABQSMABlaModule.dll ABQSMAEliLicenseModule.dll ABQSMAElkCore.dll ABQSMAFeoModules.dll ABQSMAFsmShared.dll ABQSMAMsgCommModules.dll ABQSMAMsgModules.dll ABQSMAMtxCoreModule.dll ABQSMAObjSimObjectsMod.dll ABQSMAOdbApi.dll ABQSMAOdbAttrEO.dll ABQSMAOdbCore.dll ABQSMAOdbCoreGeom.dll ABQSMAOdbDdbOdb.dll ABQSMARfmInterface.dll ABQSMARomDiagEx.dll ABQSMASglSharedLib.dll ABQSMASglSimXmlFndLib.dll ABQSMAShpCore.dll ABQSMASimBCompress.dll ABQSMASimBulkAPI.dll ABQSMASimContainers.dll ABQSMASimInterface.dll ABQSMASimManifestSubcomp.dll ABQSMASimPoolManager.dll ABQSMASrvBasic.dll ABQSMAUzlZlib.dll boost_date_time-vc141-mt-x64-1_69.dll boost_filesystem-vc141-mt-x64-1_69.dll boost_iostreams-vc141-mt-x64-1_69.dll boost_log-vc141-mt-x64-1_69.dll boost_regex-vc141-mt-x64-1_69.dll boost_thread-vc141-mt-x64-1_69.dll CATSysAllocator.dll CATSysCommunication.dll CATSysMultiThreading.dll CATSysTS.dll CATSysTSObjectModeler.dll common_analytics.dll common_helpabout.dll common_helplauncher.dll common_settings.dll common_socketutil.dll common_strutil.dll common_ui.dll common_ui_qt.dll common_welcomescreen.dll ctkwidgets.dll dataio_metadata.dll dataio_utils.dll DSYSysDlg.dll DSYSysWMIDriver.dll exception.dll ffmpeg.exe ftgl.dll gethostids.bat gethostids.vbs icudt63.dll icuuc63.dll JS0BASEILB.dll JS0GROUP.dll libfftw.dll libifcoremd.dll libifportmd.dll libmmd.dll lpkview.exe mesa mfc140u.dll MSMpiSetup.exe pltview.exe plugins preplot.exe property.dll pthreadVC2.dll qt.conf Qt5Core.dll Qt5Gui.dll Qt5Network.dll Qt5OpenGL.dll Qt5Positioning.dll Qt5PrintSupport.dll Qt5Qml.dll Qt5Quick.dll Qt5QuickWidgets.dll Qt5Svg.dll Qt5WebChannel.dll Qt5WebEngineCore.dll Qt5WebEngineWidgets.dll Qt5Widgets.dll QtWebEngineProcess.exe qxtgui.dll resources rlmutil.exe signals.dll SMAFeaBackbone.dll styleproperties.dll szcombine.exe szpltview.exe tec360.exe tecgui.dll tecio.dll teciompi.dll tecquery.dll tecutilbatch.dll tecutilchecked.dll tecutilcurvefit_crvakima.dll tecutilcurvefit_crvgen.dll tecutilcurvefit_stineinterp.dll tecutildataio_convergehdf5.dll tecutildataio_convergeout.dll tecutildataio_excsv.dll tecutildataio_exodus.dll tecutildataio_fluent.dll tecutildataio_fvcom.dll tecutildataio_h5load.dll tecutildataio_loadcgns.dll tecutildataio_loaddem.dll tecutildataio_loaddxf.dll tecutildataio_loadensight.dll tecutildataio_loadexcel.dll tecutildataio_loadfea.dll tecutildataio_loadflow3d.dll tecutildataio_loadgen.dll tecutildataio_loadhdf.dll tecutildataio_loadkiva.dll tecutildataio_loadply.dll tecutildataio_loadss.dll tecutildataio_plot3d.dll tecutildataio_roms.dll tecutildataio_szlclient.dll tecutildataio_szlfile.dll tecutildataio_telemac.dll tecutildataio_utils.dll tecutildataio_vtkfile.dll tecutildataio_wrf.dll tecutilinternal_connectLOD_exer.dll tecutilinternal_convertzone.dll tecutilinternal_createpolydata.dll tecutilinternal_dialoglaunch.dll tecutilinternal_dockwidget.dll tecutilinternal_getstyle.dll tecutilinternal_handletest.dll tecutilinternal_JournalValidator.dll tecutilinternal_loadrel.dll tecutilinternal_multithread_exer.dll tecutilinternal_tecio_exer.dll tecutilinternal_TecUtilAPIExerciser.dll tecutilinternal_testdata.dll tecutilinternal_testgeom.dll tecutilinternal_transientdatainspector.dll tecutilmisc_guibld.dll tecutilscript_extendmcr.dll tecutilscript_extendtimemcr.dll tecutilscript_tecutilserver.dll tecutiltools_advqet.dll tecutiltools_cfd.dll tecutiltools_combinezones.dll tecutiltools_editauxdata.dll tecutiltools_extractblankedzones.dll tecutiltools_extractovertime.dll tecutiltools_extractpreciseline.dll tecutiltools_keyframe.dll tecutiltools_maxincolumn.dll tecutiltools_measuredistance.dll tecutiltools_mulframe.dll tecutiltools_multiframe3d.dll tecutiltools_nodemapcompressor.dll tecutiltools_performancemonitor.dll tecutiltools_pickalter.dll tecutiltools_statechg.dll tecutiltools_statistics.dll tecutiltools_strandeditor.dll tecutiltools_tensoregn.dll tecutiltools_timelink.dll tecutiltools_timeseries.dll tecutilutil_utils.dll tp360addonuiaction.dll tp360event.dll tpdataload.dll tpsdkbase.dll tpsdkcommon.dll tpsdkdialogsx_qt.dll tpsdkdialogs_common_qt.dll tpsdkdialogs_data_qt.dll tpsdkdialogs_fieldplot_qt.dll tpsdkdialogs_io_qt.dll tpsdkdialogs_lineplot_qt.dll tpsdkdialogs_misc_qt.dll tpsdkdialogs_prompt_qt.dll tpsdkdialogs_scripting_qt.dll tpsdkdialogs_view_qt.dll tpsdkdialogs_zonestyle_qt.dll tpsdkintegrationmanager.dll tpsdkintegrationmanager_qt.dll tpsdkolddialogs_qt.dll tpsdkproperty.dll tpsdkpropertybindings_qt.dll tpsdkpropertymanager.dll tpsdkrendering_gl.dll tpsdkrendering_opengl.dll tpsdkuicommon.dll tpsdkuicommon_qt.dll tptoolbox.dll translations VCRUNTIME140.dll VCRUNTIME140_1.dll vs2008_vcredist_x64.exe vs2015-2019_vcredist_x64.exe
      /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin: cpuinfo.exe debug hydra_bstrap_proxy.exe hydra_pmi_proxy.exe hydra_service.exe IMB-MPI1.exe IMB-NBC.exe IMB-RMA.exe impi_info.exe legacy libmpi_ilp64.dll mpicc.bat mpicl.bat mpicxx.bat mpiexec.exe mpif77.bat mpif90.bat mpifc.bat mpiicc.bat mpiicpc.bat mpiifort.bat mpitune.bat mpivars.bat release tune
      /cygdrive/c/ProgramData/Miniconda3: api-ms-win-core-console-l1-1-0.dll api-ms-win-core-datetime-l1-1-0.dll api-ms-win-core-debug-l1-1-0.dll api-ms-win-core-errorhandling-l1-1-0.dll api-ms-win-core-file-l1-1-0.dll api-ms-win-core-file-l1-2-0.dll api-ms-win-core-file-l2-1-0.dll api-ms-win-core-handle-l1-1-0.dll api-ms-win-core-heap-l1-1-0.dll api-ms-win-core-interlocked-l1-1-0.dll api-ms-win-core-libraryloader-l1-1-0.dll api-ms-win-core-localization-l1-2-0.dll api-ms-win-core-memory-l1-1-0.dll api-ms-win-core-namedpipe-l1-1-0.dll api-ms-win-core-processenvironment-l1-1-0.dll api-ms-win-core-processthreads-l1-1-0.dll api-ms-win-core-processthreads-l1-1-1.dll api-ms-win-core-profile-l1-1-0.dll api-ms-win-core-rtlsupport-l1-1-0.dll api-ms-win-core-string-l1-1-0.dll api-ms-win-core-synch-l1-1-0.dll api-ms-win-core-synch-l1-2-0.dll api-ms-win-core-sysinfo-l1-1-0.dll api-ms-win-core-timezone-l1-1-0.dll api-ms-win-core-util-l1-1-0.dll api-ms-win-crt-conio-l1-1-0.dll api-ms-win-crt-convert-l1-1-0.dll api-ms-win-crt-environment-l1-1-0.dll api-ms-win-crt-filesystem-l1-1-0.dll api-ms-win-crt-heap-l1-1-0.dll api-ms-win-crt-locale-l1-1-0.dll api-ms-win-crt-math-l1-1-0.dll api-ms-win-crt-multibyte-l1-1-0.dll api-ms-win-crt-private-l1-1-0.dll api-ms-win-crt-process-l1-1-0.dll api-ms-win-crt-runtime-l1-1-0.dll api-ms-win-crt-stdio-l1-1-0.dll api-ms-win-crt-string-l1-1-0.dll api-ms-win-crt-time-l1-1-0.dll api-ms-win-crt-utility-l1-1-0.dll concrt140.dll conda-meta condabin cwp.py DLLs envs etc include Lib Library libs LICENSE_PYTHON.txt Menu msvcp140.dll msvcp140_1.dll msvcp140_2.dll msvcp140_codecvt_ids.dll pkgs python.exe python.pdb python3.dll python38.dll python38.pdb pythonw.exe pythonw.pdb Scripts shell tcl Tools ucrtbase.dll Uninstall-Miniconda3.exe vccorlib140.dll vcomp140.dll vcruntime140.dll vcruntime140_1.dll venvlauncher.exe venvwlauncher.exe _conda.exe
      Warning accessing /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin gives errors: [Errno 2] No such file or directory: '/cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin'
      Warning accessing /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin gives errors: [Errno 2] No such file or directory: '/cygdrive/c/ProgramData/Miniconda3/Library/usr/bin'
      /cygdrive/c/ProgramData/Miniconda3/Library/bin: api-ms-win-core-console-l1-1-0.dll api-ms-win-core-datetime-l1-1-0.dll api-ms-win-core-debug-l1-1-0.dll api-ms-win-core-errorhandling-l1-1-0.dll api-ms-win-core-file-l1-1-0.dll api-ms-win-core-file-l1-2-0.dll api-ms-win-core-file-l2-1-0.dll api-ms-win-core-handle-l1-1-0.dll api-ms-win-core-heap-l1-1-0.dll api-ms-win-core-interlocked-l1-1-0.dll api-ms-win-core-libraryloader-l1-1-0.dll api-ms-win-core-localization-l1-2-0.dll api-ms-win-core-memory-l1-1-0.dll api-ms-win-core-namedpipe-l1-1-0.dll api-ms-win-core-processenvironment-l1-1-0.dll api-ms-win-core-processthreads-l1-1-0.dll api-ms-win-core-processthreads-l1-1-1.dll api-ms-win-core-profile-l1-1-0.dll api-ms-win-core-rtlsupport-l1-1-0.dll api-ms-win-core-string-l1-1-0.dll api-ms-win-core-synch-l1-1-0.dll api-ms-win-core-synch-l1-2-0.dll api-ms-win-core-sysinfo-l1-1-0.dll api-ms-win-core-timezone-l1-1-0.dll api-ms-win-core-util-l1-1-0.dll api-ms-win-crt-conio-l1-1-0.dll api-ms-win-crt-convert-l1-1-0.dll api-ms-win-crt-environment-l1-1-0.dll api-ms-win-crt-filesystem-l1-1-0.dll api-ms-win-crt-heap-l1-1-0.dll api-ms-win-crt-locale-l1-1-0.dll api-ms-win-crt-math-l1-1-0.dll api-ms-win-crt-multibyte-l1-1-0.dll api-ms-win-crt-private-l1-1-0.dll api-ms-win-crt-process-l1-1-0.dll api-ms-win-crt-runtime-l1-1-0.dll api-ms-win-crt-stdio-l1-1-0.dll api-ms-win-crt-string-l1-1-0.dll api-ms-win-crt-time-l1-1-0.dll api-ms-win-crt-utility-l1-1-0.dll concrt140.dll conda.bat c_rehash.pl libcrypto-1_1-x64.dll libcrypto-1_1-x64.pdb libssl-1_1-x64.dll libssl-1_1-x64.pdb mfc140u.dll mfcm140u.dll msvcp140.dll msvcp140_1.dll msvcp140_2.dll msvcp140_codecvt_ids.dll openssl.exe openssl.pdb pythoncom38.dll pywintypes38.dll sqlite3.dll sqlite3.dll.c~.conda_trash sqlite3.exe ucrtbase.dll vccorlib140.dll vcomp140.dll vcruntime140.dll vcruntime140_1.dll yaml.dll
      /cygdrive/c/ProgramData/Miniconda3/Scripts: 2to3-script.py 2to3.exe activate activate.bat chardetect-script.py chardetect.exe conda-env-script.py conda-env.exe conda-script.py conda.exe cph-script.py cph.exe deactivate idle-script.py idle.exe menuinst-script.py menuinst.exe pip-script.py pip.exe pip3-script.py pip3.exe pydoc-script.py pydoc.exe pywin32_postinstall.py pywin32_testall.py tqdm-script.py tqdm.exe wheel-script.py wheel.exe
      /cygdrive/c/Windows/system32: 0409 1028 1029 1031 1033 1036 1040 1041 1042 1045 1046 1049 1055 2052 3082 @AppHelpToast.png @AudioToastIcon.png @BackgroundAccessToastIcon.png @bitlockertoastimage.png @edptoastimage.png @EnrollmentToastIcon.png @language_notification_icon.png @optionalfeatures.png @VpnToastIcon.png @WiFiNotificationIcon.png @windows-hello-V4.1.gif @WindowsHelloFaceToastIcon.png @WindowsUpdateToastIcon.contrast-black.png @WindowsUpdateToastIcon.contrast-white.png @WindowsUpdateToastIcon.png @WirelessDisplayToast.png @WwanNotificationIcon.png @WwanSimLockIcon.png aadauthhelper.dll aadcloudap.dll aadjcsp.dll aadtb.dll aadWamExtension.dll AboutSettingsHandlers.dll AboveLockAppHost.dll accessibilitycpl.dll accountaccessor.dll AccountsRt.dll AcGenral.dll AcLayers.dll acledit.dll aclui.dll acmigration.dll ACPBackgroundManagerPolicy.dll acppage.dll acproxy.dll AcSpecfc.dll ActionCenter.dll ActionCenterCPL.dll ActionMgr.dll ActionQueue.dll ActivationClient.dll ActivationManager.dll activeds.dll activeds.tlb ActiveSyncCsp.dll ActiveSyncProvider.dll actxprxy.dll AcWinRT.dll AcXtrnal.dll AdaptiveCards.dll AddressParser.dll adhapi.dll adhsvc.dll AdmTmpl.dll adprovider.dll adrclient.dll adsldp.dll adsldpc.dll adsmsext.dll adsnt.dll adtschema.dll AdvancedEmojiDS.dll AdvancedInstallers advapi32.dll advapi32res.dll advpack.dll aeevts.dll aeinv.dll aepic.dll AgentService.exe aitstatic.exe AJRouter.dll alg.exe altspace.dll am-et amsi.dll amsiproxy.dll amstream.dll AnalogCommonProxyStub.dll apds.dll APHostClient.dll APHostRes.dll APHostService.dll ApiSetHost.AppExecutionAlias.dll apisetschema.dll APMon.dll AppContracts.dll AppExtension.dll apphelp.dll Apphlpdm.dll AppHostRegistrationVerifier.exe appidapi.dll appidcertstorecheck.exe appidpolicyconverter.exe AppIdPolicyEngineApi.dll appidsvc.dll appidtel.exe appinfo.dll appinfoext.dll ApplicationFrame.dll ApplicationFrameHost.exe AppLocker AppLockerCSP.dll ApplySettingsTemplateCatalog.exe ApplyTrustOffline.exe AppManagementConfiguration.dll appmgmts.dll appmgr.dll AppMon.dll AppointmentActivation.dll AppointmentApis.dll appraiser appraiser.dll AppReadiness.dll apprepapi.dll AppResolver.dll ApproveChildRequest.exe appsruprov.dll AppV AppVCatalog.dll AppVClient.exe AppvClientEventLog.dll AppVClientPS.dll AppVDllSurrogate.exe AppVEntStreamingManager.dll AppVEntSubsystemController.dll AppVEntSubsystems64.dll AppVEntVirtualization.dll appverif.chm appverif.exe appverifUI.dll appvetwclientres.dll appvetwsharedperformance.dll appvetwstreamingux.dll AppVFileSystemMetadata.dll AppVIntegration.dll AppVManifest.dll AppVNice.exe AppVOrchestration.dll AppVPolicy.dll AppVPublishing.dll AppVReporting.dll AppVScripting.dll AppVSentinel.dll AppVShNotify.exe AppVStreamingUX.dll AppVStreamMap.dll AppVTerminator.dll appwiz.cpl AppxAllUserStore.dll AppXApplicabilityBlob.dll AppxApplicabilityEngine.dll AppXDeploymentClient.dll AppXDeploymentExtensions.desktop.dll AppXDeploymentExtensions.onecore.dll AppXDeploymentServer.dll AppxPackaging.dll AppxProvisioning.xml AppxSip.dll AppxStreamingDataSourcePS.dll AppxSysprep.dll ar-SA archiveint.dll ARP.EXE AsIO2.dll aspnet_counters.dll AssignedAccessCsp.dll AssignedAccessManager.dll assignedaccessmanagersvc.dll assignedaccessproviderevents.dll AssignedAccessRuntime.dll AssignedAccessShellProxy.dll asycfilt.dll at.exe AtBroker.exe atl.dll atl100.dll atl110.dll atlthunk.dll atmlib.dll attrib.exe audiodg.exe AudioEndpointBuilder.dll AudioEng.dll AudioHandlers.dll AUDIOKSE.dll audioresourceregistrar.dll AudioSes.dll audiosrv.dll AudioSrvPolicyManager.dll auditcse.dll AuditNativeSnapIn.dll auditpol.exe auditpolcore.dll AuditPolicyGPInterop.dll auditpolmsg.dll AuthBroker.dll AuthBrokerUI.dll authentication.dll AuthExt.dll authfwcfg.dll AuthFWGP.dll AuthFWSnapin.dll AuthFWWizFwk.dll AuthHost.exe AuthHostProxy.dll authui.dll authz.dll autochk.exe autoconv.exe autofmt.exe autopilot.dll autoplay.dll AverageRoom.bin avicap32.dll avifil32.dll avrt.dll AxInstSv.dll AxInstUI.exe azman.msc azroles.dll azroleui.dll AzSqlExt.dll AzureSettingSyncProvider.dll baaupdate.exe BackgroundMediaPolicy.dll backgroundTaskHost.exe BackgroundTransferHost.exe BamSettingsClient.dll BarcodeProvisioningPlugin.dll basecsp.dll basesrv.dll bash.exe batmeter.dll bcastdvr.proxy.dll BcastDVRBroker.dll BcastDVRClient.dll BcastDVRCommon.dll bcastdvruserservice.dll bcd.dll bcdboot.exe bcdedit.exe bcdprov.dll bcdsrv.dll BCP47Langs.dll BCP47mrm.dll bcrypt.dll bcryptprimitives.dll bdaplgin.ax bdechangepin.exe BdeHdCfg.exe BdeHdCfgLib.dll bderepair.dll bdesvc.dll BdeSysprep.dll bdeui.dll BdeUISrv.exe bdeunlock.exe BFE.DLL bg-BG bi.dll bidispl.dll BingASDS.dll BingFilterDS.dll BingMaps.dll BingOnlineServices.dll BioCredProv.dll BioIso.exe bisrv.dll BitLockerCsp.dll BitLockerDeviceEncryption.exe BitLockerWizard.exe BitLockerWizardElev.exe bitsadmin.exe bitsigd.dll bitsperf.dll BitsProxy.dll biwinrt.dll BlbEvents.dll blbres.dll blb_ps.dll BluetoothApis.dll BluetoothDesktopHandlers.dll BluetoothPairingSystemToastIcon.contrast-black.png BluetoothPairingSystemToastIcon.contrast-high.png BluetoothPairingSystemToastIcon.contrast-white.png BluetoothPairingSystemToastIcon.png BluetoothSystemToastIcon.contrast-white.png BluetoothSystemToastIcon.png bnmanager.dll Boot boot.sdi bootcfg.exe bootim.exe BootMenuUX.dll bootsect.exe bootstr.dll bootux.dll BOOTVID.DLL bopomofo.uce bridgeres.dll bridgeunattend.exe BrokerLib.dll browcli.dll browserbroker.dll browserexport.exe BrowserSettingSync.dll browser_broker.exe browseui.dll BTAGService.dll BthAvctpSvc.dll BthAvrcp.dll BthAvrcpAppSvc.dll bthci.dll BthMtpContextHandler.dll bthpanapi.dll BthpanContextHandler.dll Bthprops bthprops.cpl BthRadioMedia.dll bthserv.dll BthTelemetry.dll bthudtask.exe btpanui.dll Bubbles.scr BWContextHandler.dll ByteCodeGenerator.exe cabapi.dll cabinet.dll cabview.dll cacls.exe calc.exe CallButtons.dll CallButtons.ProxyStub.dll CallHistoryClient.dll CameraCaptureUI.dll canonurl.dll CapabilityAccessHandlers.dll CapabilityAccessManager.dll CapabilityAccessManagerClient.dll capauthz.dll capiprovider.dll capisp.dll CaptureService.dll CastingShellExt.dll CastLaunch.dll CastSrv.exe CatRoot catroot2 catsrv.dll catsrvps.dll catsrvut.dll CBDHSvc.dll cca.dll ccmcore.dll CcmFramework.h CcmFramework.ini ccmperf.dll CcmUsrCse.dll cdd.dll cdosys.dll cdp.dll cdprt.dll cdpsvc.dll cdpusersvc.dll CellularAPI.dll cellulardatacapabilityhandler.dll cemapi.dll cero.rs certca.dll certcli.dll certCredProvider.dll certenc.dll CertEnroll.dll CertEnrollCtrl.exe CertEnrollUI.dll certlm.msc certmgr.dll certmgr.msc CertPKICmdlet.dll CertPolEng.dll certprop.dll certreq.exe certutil.exe cfgbkend.dll cfgmgr32.dll CfgSPCellular.dll CfgSPPolicy.dll cflapi.dll cfmifs.dll cfmifsproxy.dll Chakra.dll Chakradiag.dll Chakrathunk.dll change.exe changepk.exe charmap.exe chartv.dll ChatApis.dll chcp.com CheckNetIsolation.exe chglogon.exe chgport.exe chgusr.exe chkdsk.exe chkntfs.exe chkwudrv.dll choice.exe CHookExt.dll ChsStrokeDS.dll chs_singlechar_pinyin.dat ChtAdvancedDS.dll ChtBopomofoDS.dll ChtCangjieDS.dll ChtHkStrokeDS.dll ChtQuickDS.dll ChxAPDS.dll ChxDecoder.dll ChxHAPDS.dll chxinputrouter.dll chxranker.dll CHxReadingStringIME.dll ci.dll cic.dll CIDiag.exe cipher.exe CIRCoInst.dll CIWmi.dll clb.dll clbcatq.dll cldapi.dll cleanmgr.exe CleanPCCSP.dll clfsw32.dll cliconfg.dll cliconfg.exe cliconfg.rll clip.exe ClipboardServer.dll Clipc.dll ClipRenew.exe ClipSVC.dll ClipUp.exe cloudAP.dll CloudDomainJoinAUG.dll CloudDomainJoinDataModelServer.dll CloudExperienceHost.dll CloudExperienceHostBroker.dll CloudExperienceHostBroker.exe CloudExperienceHostCommon.dll CloudExperienceHostUser.dll CloudNotifications.exe CloudStorageWizard.exe clrhost.dll clusapi.dll cmcfg32.dll cmd.exe cmdext.dll cmdial32.dll cmdkey.exe cmdl32.exe cmgrcspps.dll cmifw.dll cmintegrator.dll cmlua.dll cmmon32.exe cmpbk32.dll cmstp.exe cmstplua.dll cmutil.dll cngcredui.dll cngprovider.dll cnvfat.dll cob-au.rs CodeIntegrity cofire.exe cofiredm.dll colbact.dll coloradapterclient.dll colorcpl.exe colorui.dll com combase.dll comcat.dll comctl32.dll comdlg32.dll comexp.msc coml2.dll comp.exe compact.exe CompatTelRunner.exe compmgmt.msc CompMgmtLauncher.exe ComposableShellProxyStub.dll ComposerFramework.dll CompPkgSrv.exe CompPkgSup.dll compstui.dll computecore.dll computelibeventlog.dll computenetwork.dll ComputerDefaults.exe ComputerToastIcon.contrast-white.png ComputerToastIcon.png computestorage.dll comrepl.dll comres.dll comsnap.dll comsvcs.dll comuid.dll concrt140.dll concrt140d.dll config configmanager2.dll Configuration ConfigureExpandedStorage.dll conhost.exe ConhostV1.dll connect.dll ConnectedAccountState.dll consent.exe ConsentExperienceCommon.dll ConsentUX.dll ConsentUxClient.dll console.dll ConsoleLogon.dll ConstraintIndex.Search.dll ContactActivation.dll ContactApis.dll ContactHarvesterDS.dll container.dll ContentDeliveryManager.Utilities.dll control.exe convert.exe convertvhd.exe coreaudiopolicymanagerext.dll coredpus.dll coredpussvr.exe CoreMessaging.dll CoreShell.dll CoreShellAPI.dll CoreShellExtFramework.dll CoreUIComponents.dll correngine.dll Cortana.Persona.dll CortanaMapiHelper.dll CortanaMapiHelper.ProxyStub.dll CourtesyEngine.dll CPFilters.dll CredDialogBroker.dll CredentialMigrationHandler.dll CredentialUIBroker.exe CredProv2faHelper.dll CredProvDataModel.dll CredProvHelper.dll credprovhost.dll credprovs.dll credprovslegacy.dll credssp.dll credui.dll credwiz.exe crypt32.dll cryptbase.dll cryptcatsvc.dll cryptdlg.dll cryptdll.dll cryptext.dll cryptnet.dll cryptngc.dll CryptoWinRT.dll cryptsp.dll cryptsvc.dll crypttpmeksvc.dll cryptui.dll cryptuiwizard.dll cryptxml.dll cs-CZ cscapi.dll cscdll.dll CscMig.dll cscobj.dll cscript.exe cscsvc.dll cscui.dll CspCellularSettings.dll csplte.dll CspProxy.dll csrr.rs csrsrv.dll csrss.exe CSystemEventsBrokerClient.dll ctfmon.exe cttune.exe cttunesvr.exe curl.exe cuzzapi.dll cwsqlite3odbc.dll cxcredprov.dll CXHProvisioningServer.dll C_037.NLS C_10000.NLS C_10001.NLS C_10002.NLS C_10003.NLS C_10004.NLS C_10005.NLS C_10006.NLS C_10007.NLS C_10008.NLS C_10010.NLS C_10017.NLS C_10021.NLS C_10029.NLS C_10079.NLS C_10081.NLS C_10082.NLS C_1026.NLS C_1047.NLS C_1140.NLS C_1141.NLS C_1142.NLS C_1143.NLS C_1144.NLS C_1145.NLS C_1146.NLS C_1147.NLS C_1148.NLS C_1149.NLS C_1250.NLS C_1251.NLS C_1252.NLS C_1253.NLS C_1254.NLS C_1255.NLS C_1256.NLS C_1257.NLS C_1258.NLS C_1361.NLS C_20000.NLS C_20001.NLS C_20002.NLS C_20003.NLS C_20004.NLS C_20005.NLS C_20105.NLS C_20106.NLS C_20107.NLS C_20108.NLS C_20127.NLS C_20261.NLS C_20269.NLS C_20273.NLS C_20277.NLS C_20278.NLS C_20280.NLS C_20284.NLS C_20285.NLS C_20290.NLS C_20297.NLS C_20420.NLS C_20423.NLS C_20424.NLS C_20833.NLS C_20838.NLS C_20866.NLS C_20871.NLS C_20880.NLS C_20905.NLS C_20924.NLS C_20932.NLS C_20936.NLS C_20949.NLS C_21025.NLS C_21027.NLS C_21866.NLS C_28591.NLS C_28592.NLS C_28593.NLS C_28594.NLS C_28595.NLS C_28596.NLS C_28597.NLS C_28598.NLS C_28599.NLS c_28603.nls C_28605.NLS C_437.NLS C_500.NLS C_708.NLS C_720.NLS C_737.NLS C_775.NLS C_850.NLS C_852.NLS C_855.NLS C_857.NLS C_858.NLS C_860.NLS C_861.NLS C_862.NLS C_863.NLS C_864.NLS C_865.NLS C_866.NLS C_869.NLS C_870.NLS C_874.NLS C_875.NLS C_932.NLS C_936.NLS C_949.NLS C_950.NLS C_G18030.DLL c_GSM7.DLL C_IS2022.DLL C_ISCII.DLL d2d1.dll d2d1debug1.dll d3d10.dll d3d10core.dll d3d10level9.dll d3d10ref.dll d3d10sdklayers.dll d3d10warp.dll d3d10_1.dll d3d10_1core.dll d3d11.dll d3d11on12.dll d3d11ref.dll d3d11sdklayers.dll d3d11_1sdklayers.dll D3D12.dll d3d8thk.dll d3d9.dll d3d9on12.dll D3DCompiler_33.dll D3DCompiler_34.dll D3DCompiler_35.dll D3DCompiler_36.dll D3DCompiler_37.dll D3DCompiler_38.dll D3DCompiler_39.dll D3DCompiler_40.dll D3DCompiler_41.dll D3DCompiler_42.dll D3DCompiler_43.dll D3DCompiler_47.dll d3dcsx_42.dll d3dcsx_43.dll d3dref9.dll D3DSCache.dll d3dx10.dll d3dx10_33.dll d3dx10_34.dll d3dx10_35.dll d3dx10_36.dll d3dx10_37.dll d3dx10_38.dll d3dx10_39.dll d3dx10_40.dll d3dx10_41.dll d3dx10_42.dll d3dx10_43.dll d3dx11_42.dll d3dx11_43.dll d3dx9_24.dll d3dx9_25.dll d3dx9_26.dll d3dx9_27.dll d3dx9_28.dll d3dx9_29.dll d3dx9_30.dll d3dx9_31.dll d3dx9_32.dll d3dx9_33.dll d3dx9_34.dll d3dx9_35.dll d3dx9_36.dll D3DX9_37.dll D3DX9_38.dll D3DX9_39.dll D3DX9_40.dll D3DX9_41.dll D3DX9_42.dll D3DX9_43.dll da-DK dab.dll dabapi.dll DAConn.dll dafAspInfraProvider.dll dafBth.dll DafDnsSd.dll dafDockingProvider.dll DafGip.dll DAFIoT.dll DAFIPP.dll dafpos.dll DafPrintProvider.dll dafupnp.dll dafWCN.dll dafWfdProvider.dll DAFWiProv.dll DAFWSD.dll DAMediaManager.dll DAMM.dll DaOtpCredentialProvider.dll das.dll dasHost.exe dataclen.dll DataExchange.dll DataExchangeHost.exe datamarketsvc.dll DataStoreCacheDumpTool.exe DataUsageHandlers.dll DataUsageLiveTileTask.exe datusage.dll davclnt.dll davhlpr.dll DavSyncProvider.dll daxexec.dll dbgcore.dll dbgeng.dll dbghelp.dll DbgModel.dll dbnetlib.dll dbnmpntw.dll dccw.exe dciman32.dll dcntel.dll dcomcnfg.exe dcomp.dll DDACLSys.dll DdcAntiTheftApi.dll DdcClaimsApi.dll DdcComImplementationsDesktop.dll DDDS.dll DDFs ddisplay.dll ddodiag.exe DDOIProxy.dll DDORes.dll ddpchunk.dll ddptrace.dll ddputils.dll ddp_ps.dll ddraw.dll ddrawex.dll de-DE DefaultAccountTile.png DefaultDeviceManager.dll DefaultHrtfs.bin DefaultPrinterProvider.dll DefaultQuestions.json Defrag.exe defragproxy.dll defragres.dll defragsvc.dll delegatorprovider.dll desk.cpl deskadp.dll deskmon.dll desktopimgdownldr.exe DesktopKeepOnToastImg.gif DesktopShellAppStateContract.dll DesktopShellExt.dll DesktopSwitcherDataModel.dll DetailedReading-Default.xml DevDispItemProvider.dll DeveloperOptionsSettingsHandlers.dll devenum.dll deviceaccess.dll deviceassociation.dll DeviceCensus.exe DeviceCenter.dll DeviceCredential.dll DeviceCredentialDeployment.exe DeviceDirectoryClient.dll DeviceDisplayStatusManager.dll DeviceDriverRetrievalClient.dll DeviceEject.exe DeviceElementSource.dll DeviceEnroller.exe DeviceFlows.DataModel.dll DeviceMetadataRetrievalClient.dll devicengccredprov.dll DevicePairing.dll DevicePairingExperienceMEM.dll DevicePairingFolder.dll DevicePairingProxy.dll DevicePairingWizard.exe DeviceProperties.exe DeviceReactivation.dll deviceregistration.dll DeviceSetupManager.dll DeviceSetupManagerAPI.dll DeviceSetupStatusProvider.dll DevicesFlowBroker.dll DeviceSoftwareInstallationClient.dll DeviceUpdateAgent.dll DeviceUxRes.dll devinv.dll devmgmt.msc devmgr.dll DevModeRunAsUserConfig.msc devobj.dll DevPropMgr.dll DevQueryBroker.dll devrtl.dll dfdts.dll DFDWiz.exe dfrgui.exe dfscli.dll dfshim.dll DfsShlEx.dll dggpext.dll dhcpcmonitor.dll dhcpcore.dll dhcpcore6.dll dhcpcsvc.dll dhcpcsvc6.dll dhcpsapi.dll DiagCpl.dll DiagnosticInvoker.dll DiagnosticLogCSP.dll diagperf.dll DiagSvc.dll DiagSvcs diagtrack.dll dialclient.dll dialer.exe dialserver.dll DictationManager.dll difxapi.dll dimsjob.dll dimsroam.dll dinput.dll dinput8.dll Direct2DDesktop.dll directmanipulation.dll directml.dll discan.dll diskmgmt.msc diskpart.exe diskperf.exe diskraid.exe DiskSnapshot.conf DiskSnapshot.exe Dism Dism.exe DismApi.dll DispBroker.dll dispdiag.exe dispex.dll Display.dll DisplayManager.dll DisplaySwitch.exe DisplaySystemToastIcon.contrast-white.png DisplaySystemToastIcon.png djctq.rs djoin.exe dllhost.exe dllhst3g.exe DMAlertListener.ProxyStub.dll DmApiSetExtImplDesktop.dll DMAppsRes.dll dmcertinst.exe dmcfghost.exe dmcfgutils.dll dmclient.exe dmcmnutils.dll dmcommandlineutils.dll dmcsps.dll dmdlgs.dll dmdskmgr.dll dmdskres.dll dmdskres2.dll dmenrollengine.dll dmenterprisediagnostics.dll dmintf.dll dmiso8601utils.dll dmloader.dll DmNotificationBroker.exe dmocx.dll dmoleaututils.dll DmOmaCpMo.exe dmprocessxmlfiltered.dll dmpushproxy.dll DMPushRouterCore.dll DMRCDecoder.dll dmsynth.dll dmusic.dll dmutil.dll dmvdsitf.dll dmview.ocx dmwappushsvc.dll dmwmicsp.dll dmxmlhelputils.dll dns-sd.exe dnsapi.dll dnscacheugc.exe dnscmmc.dll dnsext.dll dnshc.dll dnsrslvr.dll dnssd.dll dnssdX.dll Docking.VirtualInput.dll DockInterface.ProxyStub.dll docprop.dll DocumentPerformanceEvents.dll DolbyHrtfEnc.dll DolbyMATEnc.dll domgmt.dll dosettings.dll doskey.exe dosvc.dll dot3api.dll dot3cfg.dll Dot3Conn.dll dot3dlg.dll dot3gpclnt.dll dot3gpui.dll dot3hc.dll dot3mm.dll dot3msm.dll dot3svc.dll dot3ui.dll downlevel dpapi.dll dpapimig.exe dpapiprovider.dll dpapisrv.dll DpiScaling.exe dpnaddr.dll dpnathlp.dll dpnet.dll dpnhpast.dll dpnhupnp.dll dpnlobby.dll dpnsvr.exe dps.dll dpx.dll DragDropExperienceDataExchangeDelegated.dll driverquery.exe drivers DriverState DriverStore drprov.dll drt.dll DrtmAuth1.bin DrtmAuth10.bin DrtmAuth11.bin DrtmAuth2.bin DrtmAuth3.bin DrtmAuth4.bin DrtmAuth5.bin DrtmAuth6.bin DrtmAuth7.bin DrtmAuth8.bin DrtmAuth9.bin drtprov.dll drttransport.dll drvcfg.exe drvinst.exe drvsetup.dll DRVSTORE drvstore.dll dsauth.dll dsc DscCore.dll DscCoreConfProv.dll dsclient.dll dscproxy.dll DscTimer.dll dsdmo.dll dskquota.dll dskquoui.dll DsmUserTask.exe dsound.dll dsparse.dll dsprop.dll dsquery.dll dsreg.dll dsregcmd.exe dsrole.dll dssec.dat dssec.dll dssenh.dll dssvc.dll dstokenclean.exe Dsui.dll dsuiext.dll dswave.dll dtsh.dll DTUHandler.exe DTUHandlerPS.dll DuCsps.dll dui70.dll duser.dll dusmapi.dll dusmsvc.dll dusmtask.exe dvdplay.exe dwm.exe dwmapi.dll dwmcore.dll dwmghost.dll dwminit.dll dwmredir.dll DWrite.dll DWWIN.EXE dxcpl.exe dxdiag.exe dxdiagn.dll dxgi.dll dxgiadaptercache.exe dxgidebug.dll dxgwdi.dll dxilconv.dll DXP.dll dxpps.dll Dxpserver.exe DxpTaskSync.dll dxtmsft.dll dxtrans.dll dxva2.dll DynamicLong.bin DynamicMedium.bin DynamicShort.bin dynamoapi.dll e1c65x64.din e1cmsg.dll e1r68x64.din e1rmsg.dll EAMProgressHandler.dll Eap3Host.exe eapp3hst.dll eappcfg.dll eappcfgui.dll eappgnui.dll eapphost.dll eappprxy.dll eapprovp.dll eapsimextdesktop.dll eapsvc.dll easconsent.dll EaseOfAccessDialog.exe easinvoker.exe easinvoker.proxystub.dll EASPolicyManagerBrokerHost.exe EasPolicyManagerBrokerPS.dll easwrt.dll edgeangle.dll EdgeContent.dll edgehtml.dll edgehtmlpluginpolicy.bin edgeIso.dll EdgeManager.dll EditBufferTestHook.dll EditionUpgradeHelper.dll EditionUpgradeManagerObj.dll edpauditapi.dll EDPCleanup.exe edpcsp.dll edpnotify.exe edptask.dll edputil.dll EduPrintProv.exe eeprov.dll eeutil.dll efsadu.dll efscore.dll efsext.dll efslsaext.dll efssvc.dll efsui.exe efsutil.dll efswrt.dll EhStorAPI.dll EhStorAuthn.exe EhStorPwdMgr.dll EhStorShell.dll el-GR els.dll ELSCore.dll elshyph.dll elslad.dll elsTrans.dll EmailApis.dll embeddedmodesvc.dll embeddedmodesvcapi.dll EmojiDS.dll en en-GB en-US encapi.dll EncDump.dll energy.dll energyprov.dll energytask.dll enrollmentapi.dll EnterpriseAPNCsp.dll EnterpriseAppMgmtClient.dll EnterpriseAppMgmtSvc.dll EnterpriseAppVMgmtCSP.dll enterprisecsps.dll EnterpriseDesktopAppMgmtCSP.dll enterpriseetw.dll EnterpriseModernAppMgmtCSP.dll enterpriseresourcemanager.dll eqossnap.dll ErrorDetails.dll ErrorDetailsCore.dll es-ES es-MX es.dll EsdSip.dll esent.dll esentprf.dll esentutl.exe esevss.dll eShims.dll esrb.rs et-EE EthernetMediaManager.dll ETWCoreUIComponentsResources.dll ETWESEProviderResources.dll EtwRundown.dll eudcedit.exe eUICCsCSP.dll EventAggregation.dll eventcls.dll eventcreate.exe EventViewer_EventDetails.xsl eventvwr.exe eventvwr.msc ExecModelClient.dll execmodelproxy.dll expand.exe ExplorerFrame.dll ExSMime.dll extrac32.exe ExtrasXmlParser.dll E_2D4B0DE.DLL E_2LM0DE.DLL F12 f3ahvoas.dll facecredentialprovider.dll Family.Authentication.dll Family.Cache.dll Family.Client.dll Family.SyncEngine.dll FamilySafetyExt.dll Faultrep.dll FaxPrinterInstaller.dll fc.exe fcon.dll fdBth.dll fdBthProxy.dll FdDevQuery.dll fde.dll fdeploy.dll fdPHost.dll fdPnp.dll fdprint.dll fdProxy.dll FDResPub.dll fdSSDP.dll fdWCN.dll fdWNet.dll fdWSD.dll FeatureToastBulldogImg.png FeatureToastDlpImg.png feclient.dll ffbroker.dll fhcat.dll fhcfg.dll fhcleanup.dll fhcpl.dll fhengine.dll fhevents.dll fhlisten.dll fhmanagew.exe fhsettingsprovider.dll fhshl.dll fhsrchapi.dll fhsrchph.dll fhsvc.dll fhsvcctl.dll fhtask.dll fhuxadapter.dll fhuxapi.dll fhuxcommon.dll fhuxgraphics.dll fhuxpresentation.dll fi-FI fidocredprov.dll FileAppxStreamingDataSource.dll FileHistory.exe filemgmt.dll FilterDS.dll find.exe findnetprinters.dll findstr.exe finger.exe fingerprintcredential.dll Firewall.cpl FirewallAPI.dll FirewallControlPanel.dll fixmapi.exe FlightSettings.dll fltLib.dll fltMC.exe FluencyDS.dll FM20.DLL FM20enu.DLL fmapi.dll fmifs.dll fms.dll FNTCACHE.DAT FntCache.dll fodhelper.exe Fondue.exe fontdrvhost.exe fontext.dll FontGlyphAnimator.dll fontgroupsoverride.dll FontProvider.dll fontsub.dll fontview.exe forfiles.exe format.com fpb.rs fphc.dll fr-CA fr-FR framedyn.dll framedynos.dll FrameServer.dll FrameworkPerf.dll frprov.dll fsavailux.exe FSClient.dll FsIso.exe fsmgmt.msc fsquirt.exe fsutil.exe fsutilext.dll fthsvc.dll ftp.exe fundisc.dll fveapi.dll fveapibase.dll fvecerts.dll fvecpl.dll fvenotify.exe fveprompt.exe fveskybackup.dll fveui.dll fvewiz.dll FvSDK_x64.dll fwbase.dll fwcfg.dll fwmdmcsp.dll fwpolicyiomgr.dll FWPUCLNT.DLL FwRemoteSvr.dll FXSAPI.dll FXSCOM.dll FXSCOMEX.dll FXSCOMPOSE.dll FXSCOMPOSERES.dll FXSCOVER.exe FXSEVENT.dll FXSMON.dll FXSRESM.dll FXSROUTE.dll FXSST.dll FXSSVC.exe FXST30.dll FXSTIFF.dll FxsTmp FXSUNATD.exe FXSUTILITY.dll g711codc.ax GameBarPresenceWriter.exe GameBarPresenceWriter.proxy.dll GameChatOverlayExt.dll GameChatTranscription.dll gamemode.dll GamePanel.exe GamePanelExternalHook.dll GameSystemToastIcon.contrast-white.png GameSystemToastIcon.png gameux.dll gamingtcui.dll gatherNetworkInfo.vbs gb2312.uce gcdef.dll gdi32.dll gdi32full.dll GdiPlus.dll generaltel.dll GenValObj.exe Geocommon.dll Geolocation.dll getmac.exe getuname.dll glmf32.dll GlobCollationHost.dll globinputhost.dll glu32.dll gmsaclient.dll gpapi.dll gpedit.dll gpedit.msc gpprefcl.dll gpprnext.dll gpresult.exe gpscript.dll gpscript.exe gpsvc.dll gptext.dll gpupdate.exe GraphicsCapture.dll GraphicsPerfSvc.dll grb.rs Groupinghc.dll GroupPolicy GroupPolicyUsers grpconv.exe hal.dll HalExtIntcLpioDMA.dll HalExtPL080.dll HandwritingSystemToastIcon.contrast-white.png HandwritingSystemToastIcon.png hascsp.dll HashtagDS.dll hbaapi.dll hcproviders.dll HdcpHandler.dll hdwwiz.cpl hdwwiz.exe he-IL HeadphoneSystemToastIcon.contrast-white.png HeadphoneSystemToastIcon.png HeadsetSystemToastIcon.contrast-white.png HeadsetSystemToastIcon.png HealthSystemToastIcon.contrast-white.png HealthSystemToastIcon.png HeatCore.dll help.exe HelpPaneProxy.dll hgcpl.dll hgprint.dll hhctrl.ocx hhsetup.dll hid.dll hidphone.tsp hidserv.dll hlink.dll hmkd.dll hnetcfg.dll HNetCfgClient.dll hnetmon.dll HOSTNAME.EXE hotplug.dll hr-HR HrtfApo.dll html.iec httpapi.dll httpprxc.dll httpprxm.dll httpprxp.dll HttpsDataSource.dll htui.dll hu-HU hvax64.exe hvhostsvc.dll hvix64.exe hvloader.dll hvsievaluator.exe hvsigpext.dll HvSocket.dll ias ias.dll iasacct.dll iasads.dll iasdatastore.dll iashlpr.dll IasMigPlugin.dll iasnap.dll iaspolcy.dll iasrad.dll iasrecst.dll iassam.dll iassdo.dll iassvcs.dll icacls.exe icfupgd.dll icm32.dll icmp.dll icmui.dll IconCodecService.dll IcsEntitlementHost.exe icsigd.dll icsunattend.exe icsvc.dll icsvcext.dll icsxml icuin.dll icuuc.dll IdCtrls.dll ideograf.uce IdListen.dll idndl.dll IDStore.dll ie4uinit.exe ie4ushowIE.exe IEAdvpack.dll ieapfltr.dll iedkcs32.dll ieframe.dll iemigplugin.dll iepeers.dll ieproxy.dll iernonce.dll iertutil.dll iesetup.dll iesysprep.dll ieui.dll ieuinit.inf ieUnatt.exe iexpress.exe ifmon.dll ifsutil.dll ifsutilx.dll igdDiag.dll IHDS.dll ihvrilproxy.dll IKEEXT.DLL imaadp32.acm imagehlp.dll imageres.dll imagesp1.dll imapi.dll imapi2.dll imapi2fs.dll IME imgutil.dll imm32.dll immersivetpmvscmgrsvr.exe ImplatSetup.dll IndexedDbLegacy.dll inetcomm.dll inetcpl.cpl inetmib1.dll inetpp.dll inetppui.dll INETRES.dll inetsrv InfDefaultInstall.exe InkEd.dll InkObjCore.dll InprocLogger.dll input.dll InputController.dll InputHost.dll InputInjectionBroker.dll InputLocaleManager.dll InputMethod InputService.dll InputSwitch.dll InputSystemToastIcon.contrast-white.png InputSystemToastIcon.png inseng.dll InstallService.dll InstallServiceTasks.dll InstallUtil.InstallLog internetmail.dll InternetMailCsp.dll intl.cpl invagent.dll iologmsg.dll IoTAssignedAccessLockFramework.dll iotstartup.exe ipconfig.exe IPELoggingDictationHelper.dll IPHLPAPI.DLL iphlpsvc.dll Ipmi ipnathlp.dll IpNatHlpClient.dll IPROSetMonitor.exe iprtprio.dll iprtrmgr.dll ipsecsnp.dll IPSECSVC.DLL ipsmsnap.dll ipxlatcfg.dll irclass.dll irftp.exe iri.dll irmon.dll irprops.cpl iscsicli.exe iscsicpl.dll iscsicpl.exe iscsidsc.dll iscsied.dll iscsiexe.dll iscsilog.dll iscsium.dll iscsiwmi.dll iscsiwmiv2.dll ISM.dll ISMIF32.dll isoburn.exe it-IT itircl.dll itss.dll iuilp.dll iumbase.dll iumcrypt.dll iumdll.dll IumSdk.dll iyuv_32.dll ja-jp JavaScriptCollectionAgent.dll jdns_sd.dll joinproviderol.dll joinutil.dll joy.cpl JpMapControl.dll jpndecoder.dll jpninputrouter.dll jpnranker.dll JpnServiceDS.dll jscript.dll jscript9.dll jscript9diag.dll jsproxy.dll kanji_1.uce kanji_2.uce kbd101.dll kbd101a.dll kbd101b.dll kbd101c.dll kbd103.dll kbd106.dll kbd106n.dll KBDA1.DLL KBDA2.DLL KBDA3.DLL KBDAL.DLL KBDARME.DLL kbdarmph.dll kbdarmty.dll KBDARMW.DLL kbdax2.dll KBDAZE.DLL KBDAZEL.DLL KBDAZST.DLL KBDBASH.DLL KBDBE.DLL KBDBENE.DLL KBDBGPH.DLL KBDBGPH1.DLL KBDBHC.DLL KBDBLR.DLL KBDBR.DLL KBDBU.DLL KBDBUG.DLL KBDBULG.DLL KBDCA.DLL KBDCAN.DLL KBDCHER.DLL KBDCHERP.DLL KBDCR.DLL KBDCZ.DLL KBDCZ1.DLL KBDCZ2.DLL KBDDA.DLL KBDDIV1.DLL KBDDIV2.DLL KBDDV.DLL KBDDZO.DLL KBDES.DLL KBDEST.DLL KBDFA.DLL kbdfar.dll KBDFC.DLL KBDFI.DLL KBDFI1.DLL KBDFO.DLL KBDFR.DLL KBDFTHRK.DLL KBDGAE.DLL KBDGEO.DLL kbdgeoer.dll kbdgeome.dll kbdgeooa.dll kbdgeoqw.dll KBDGKL.DLL KBDGN.DLL KBDGR.DLL KBDGR1.DLL KBDGRLND.DLL KBDGTHC.DLL KBDHAU.DLL KBDHAW.DLL KBDHE.DLL KBDHE220.DLL KBDHE319.DLL KBDHEB.DLL kbdhebl3.dll KBDHELA2.DLL KBDHELA3.DLL KBDHEPT.DLL KBDHU.DLL KBDHU1.DLL kbdibm02.dll KBDIBO.DLL KBDIC.DLL KBDINASA.DLL KBDINBE1.DLL KBDINBE2.DLL KBDINBEN.DLL KBDINDEV.DLL KBDINEN.DLL KBDINGUJ.DLL KBDINHIN.DLL KBDINKAN.DLL KBDINMAL.DLL KBDINMAR.DLL KBDINORI.DLL KBDINPUN.DLL KBDINTAM.DLL KBDINTEL.DLL KBDINUK2.DLL KBDIR.DLL KBDIT.DLL KBDIT142.DLL KBDIULAT.DLL KBDJAV.DLL KBDJPN.DLL KBDKAZ.DLL KBDKHMR.DLL KBDKNI.DLL KBDKOR.DLL KBDKURD.DLL KBDKYR.DLL KBDLA.DLL KBDLAO.DLL kbdlisub.dll kbdlisus.dll kbdlk41a.dll KBDLT.DLL KBDLT1.DLL KBDLT2.DLL KBDLV.DLL KBDLV1.DLL KBDLVST.DLL KBDMAC.DLL KBDMACST.DLL KBDMAORI.DLL KBDMLT47.DLL KBDMLT48.DLL KBDMON.DLL KBDMONMO.DLL KBDMONST.DLL KBDMYAN.DLL KBDNE.DLL kbdnec.dll kbdnec95.dll kbdnecat.dll kbdnecnt.dll KBDNEPR.DLL kbdnko.dll KBDNO.DLL KBDNO1.DLL KBDNSO.DLL KBDNTL.DLL KBDOGHAM.DLL KBDOLCH.DLL KBDOLDIT.DLL KBDOSM.DLL KBDPASH.DLL kbdphags.dll KBDPL.DLL KBDPL1.DLL KBDPO.DLL KBDRO.DLL KBDROPR.DLL KBDROST.DLL KBDRU.DLL KBDRU1.DLL KBDRUM.DLL KBDSF.DLL KBDSG.DLL KBDSL.DLL KBDSL1.DLL KBDSMSFI.DLL KBDSMSNO.DLL KBDSN1.DLL KBDSORA.DLL KBDSOREX.DLL KBDSORS1.DLL KBDSORST.DLL KBDSP.DLL KBDSW.DLL KBDSW09.DLL KBDSYR1.DLL KBDSYR2.DLL KBDTAILE.DLL KBDTAJIK.DLL KBDTAM99.DLL KBDTAT.DLL KBDTH0.DLL KBDTH1.DLL KBDTH2.DLL KBDTH3.DLL KBDTIFI.DLL KBDTIFI2.DLL KBDTIPRC.DLL KBDTIPRD.DLL KBDTT102.DLL KBDTUF.DLL KBDTUQ.DLL KBDTURME.DLL KBDTZM.DLL KBDUGHR.DLL KBDUGHR1.DLL KBDUK.DLL KBDUKX.DLL KBDUR.DLL KBDUR1.DLL KBDURDU.DLL KBDUS.DLL KBDUSA.DLL KBDUSL.DLL KBDUSR.DLL KBDUSX.DLL KBDUZB.DLL KBDVNTC.DLL KBDWOL.DLL KBDYAK.DLL KBDYBA.DLL KBDYCC.DLL KBDYCL.DLL kd.dll kdcom.dll kdcpw.dll kdhvcom.dll kdnet.dll kdnet_uart16550.dll KdsCli.dll kdstub.dll kdusb.dll kd_02_10df.dll kd_02_10ec.dll kd_02_1137.dll kd_02_14e4.dll kd_02_15b3.dll kd_02_1969.dll kd_02_19a2.dll kd_02_1af4.dll kd_02_8086.dll kd_07_1415.dll kd_0C_8086.dll keepaliveprovider.dll KerbClientShared.dll kerberos.dll kernel.appcore.dll kernel32.dll KernelBase.dll KeyboardSystemToastIcon.contrast-white.png KeyboardSystemToastIcon.png KeyCredMgr.dll keyiso.dll keymgr.dll KeywordDetectorMsftSidAdapter.dll klist.exe kmddsp.tsp KnobsCore.dll KnobsCsp.dll ko-KR korean.uce ksetup.exe ksproxy.ax kstvtune.ax ksuser.dll Kswdmcap.ax ksxbar.ax ktmutil.exe ktmw32.dll l2gpstore.dll l2nacp.dll L2SecHC.dll label.exe LangCleanupSysprepAction.dll LanguageComponentsInstaller.dll LanguageComponentsInstallerComHandler.exe LanguageOverlayServer.dll LanguageOverlayUtil.dll LanguagePackDiskCleanup.dll LaptopPlugInToastImg.gif LargeRoom.bin LaunchTM.exe LaunchWinApp.exe lcphrase.tbl lcptr.tbl LegacyNetUX.dll LegacyNetUXHost.exe LESDebug.log lfsvc.dll libcrypto.dll license.rtf LicenseManager.dll LicenseManagerApi.dll LicenseManagerShellext.exe LicenseManagerSvc.dll Licenses LicensingCSP.dll licensingdiag.exe LicensingDiagSpp.dll LicensingUI.exe LicensingWinRT.dll licmgr10.dll linkinfo.dll ListSvc.dll lltdapi.dll lltdres.dll lltdsvc.dll lmhsvc.dll loadperf.dll locale.nls localsec.dll localspl.dll localui.dll LocationApi.dll LocationFramework.dll LocationFrameworkInternalPS.dll LocationFrameworkPS.dll LocationNotificationWindows.exe LocationWinPalMisc.dll Locator.exe LockAppBroker.dll LockAppHost.exe LockController.dll LockHostingFramework.dll LockScreenContent.dll LockScreenContentHost.dll LockScreenContentServer.exe LockScreenData.dll lodctr.exe log LogFiles loghours.dll logman.exe logoff.exe logoncli.dll LogonController.dll LogonUI.exe Logs lpasvc.dll lpk.dll lpkinstall.exe lpksetup.exe lpksetupproxyserv.dll lpremove.exe LsaIso.exe lsasrv.dll lsass.exe LSCSHostPolicy.dll lsm.dll lsmproxy.dll lstelemetry.dll lt-LT luainstall.dll luiapi.dll lusrmgr.msc lv-LV lxss lz32.dll l_intl.nls Macromed Magnification.dll Magnify.exe MailContactsCalendarSync main.cpl MaintenanceUI.dll makecab.exe manage-bde.exe manage-bde.wsf MapConfiguration.dll MapControlCore.dll MapControlStringsRes.dll MapGeocoder.dll mapi32.dll mapistub.dll MapRouter.dll MapsBtSvc.dll MapsBtSvcProxy.dll MapsCSP.dll MapsStore.dll MapsTelemetry.dll mapstoasttask.dll mapsupdatetask.dll mavinject.exe MbaeApi.dll MbaeApiPublic.dll MbaeParserTask.exe MbaeXmlParser.dll mblctr.exe MBMediaManager.dll MBR2GPT.EXE mbsmsapi.dll mbussdapi.dll mcbuilder.exe MCCSEngineShared.dll MCCSPal.dll mciavi32.dll mcicda.dll mciqtz32.dll mciseq.dll mciwave.dll MCRecvSrc.dll MCU.exe mcupdate_AuthenticAMD.dll mcupdate_GenuineIntel.dll MDMAgent.exe MDMAppInstaller.exe MdmCommon.dll MdmDiagnostics.dll MdmDiagnosticsTool.exe mdminst.dll mdmlocalmanagement.dll mdmmigrator.dll mdmpostprocessevaluator.dll mdmregistration.dll MdRes.exe MdSched.exe MediaFoundation.DefaultPerceptionProvider.dll MediaSystemToastIcon.contrast-white.png MediaSystemToastIcon.png MediumRoom.bin MemoryDiagnostic.dll MessagingDataModel2.dll MessagingService.dll mf3216.dll mfc100.dll mfc100chs.dll mfc100cht.dll mfc100deu.dll mfc100enu.dll mfc100esn.dll mfc100fra.dll mfc100ita.dll mfc100jpn.dll mfc100kor.dll mfc100rus.dll mfc100u.dll mfc110.dll mfc110chs.dll mfc110cht.dll mfc110d.dll mfc110deu.dll mfc110enu.dll mfc110esn.dll mfc110fra.dll mfc110ita.dll mfc110jpn.dll mfc110kor.dll mfc110rus.dll mfc110u.dll mfc110ud.dll mfc120.dll mfc120chs.dll mfc120cht.dll mfc120deu.dll mfc120enu.dll mfc120esn.dll mfc120fra.dll mfc120ita.dll mfc120jpn.dll mfc120kor.dll mfc120rus.dll mfc120u.dll mfc140.dll mfc140chs.dll mfc140cht.dll mfc140d.dll mfc140deu.dll mfc140enu.dll mfc140esn.dll mfc140fra.dll mfc140ita.dll mfc140jpn.dll mfc140kor.dll mfc140rus.dll mfc140u.dll mfc140ud.dll mfc42.dll mfc42u.dll mfcm100.dll mfcm100u.dll mfcm110.dll mfcm110d.dll mfcm110u.dll mfcm110ud.dll mfcm120.dll mfcm120u.dll mfcm140.dll mfcm140d.dll mfcm140u.dll mfcm140ud.dll mfcsubs.dll mfksproxy.dll mfsensorgroup.dll mgmtapi.dll mgmtrefreshcredprov.dll mi.dll mibincodec.dll Microsoft Microsoft-ConfigMgr-Events.dll Microsoft-Windows-AppModelExecEvents.dll microsoft-windows-battery-events.dll microsoft-windows-hal-events.dll Microsoft-Windows-Internal-Shell-NearShareExperience.dll microsoft-windows-kernel-pnp-events.dll microsoft-windows-kernel-power-events.dll microsoft-windows-kernel-processor-power-events.dll Microsoft-Windows-MapControls.dll Microsoft-Windows-MosHost.dll microsoft-windows-pdc.dll microsoft-windows-power-cad-events.dll microsoft-windows-processor-aggregator-events.dll microsoft-windows-sleepstudy-events.dll microsoft-windows-storage-tiering-events.dll microsoft-windows-system-events.dll Microsoft-WindowsPhone-SEManagementProvider.dll Microsoft.Bluetooth.Proxy.dll Microsoft.Bluetooth.Service.dll Microsoft.Bluetooth.UserService.dll Microsoft.Graphics.Display.DisplayEnhancementService.dll Microsoft.Management.Infrastructure.Native.Unmanaged.dll Microsoft.Uev.AgentDriverEvents.dll Microsoft.Uev.AppAgent.dll Microsoft.Uev.CabUtil.dll Microsoft.Uev.CmUtil.dll Microsoft.Uev.Common.dll Microsoft.Uev.Common.WinRT.dll Microsoft.Uev.CommonBridge.dll Microsoft.Uev.ConfigWrapper.dll Microsoft.Uev.CscUnpinTool.exe Microsoft.Uev.EventLogMessages.dll Microsoft.Uev.LocalSyncProvider.dll Microsoft.Uev.ManagedEventLogging.dll Microsoft.Uev.Management.dll Microsoft.Uev.Management.WmiAccess.dll Microsoft.Uev.ModernAppAgent.dll Microsoft.Uev.ModernAppCore.dll Microsoft.Uev.ModernAppData.WinRT.dll Microsoft.Uev.ModernSync.dll Microsoft.Uev.MonitorSyncProvider.dll Microsoft.Uev.Office2010CustomActions.dll Microsoft.Uev.Office2013CustomActions.dll Microsoft.Uev.PrinterCustomActions.dll Microsoft.Uev.SmbSyncProvider.dll Microsoft.Uev.SyncCommon.dll Microsoft.Uev.SyncConditions.dll Microsoft.Uev.SyncController.exe microsoft.windows.softwarelogo.showdesktop.exe MicrosoftAccountCloudAP.dll MicrosoftAccountExtension.dll MicrosoftAccountTokenProvider.dll MicrosoftAccountWAMExtension.dll MicrosoftEdgeBCHost.exe MicrosoftEdgeCP.exe MicrosoftEdgeDevTools.exe MicrosoftEdgeSH.exe midimap.dll migisol.dll migration miguiresource.dll migwiz mimefilt.dll mimofcodec.dll MinstoreEvents.dll mintdh.dll MiracastInputMgr.dll MiracastReceiver.dll MirrorDrvCompat.dll mispace.dll MitigationConfiguration.dll miutils.dll mlang.dat mlang.dll mmc.exe mmc.exe.config mmcbase.dll mmci.dll mmcico.dll mmcndmgr.dll mmcshext.dll MMDevAPI.dll mmgaclient.dll mmgaproxystub.dll mmgaserver.exe mmres.dll mmsys.cpl mobilenetworking.dll mobsync.exe mode.com modemui.dll modernexecserver.dll more.com moricons.dll moshost.dll MosHostClient.dll moshostcore.dll MosStorage.dll mountvol.exe MouseSystemToastIcon.contrast-white.png MouseSystemToastIcon.png Mpeg2Data.ax mpeval.dll mpg2splt.ax mpnotify.exe mpr.dll mprapi.dll mprddm.dll mprdim.dll mprext.dll mprmsg.dll MpSigStub.exe MPSSVC.dll mpunits.dll MRINFO.EXE MrmCoreR.dll MrmDeploy.dll MrmIndexer.dll MRT MRT.exe mrt100.dll mrt_map.dll ms3dthumbnailprovider.dll msaatext.dll msacm32.dll msacm32.drv msadp32.acm msafd.dll MSAJApi.dll MsApoFxProxy.dll MSAProfileNotificationHandler.dll msasn1.dll msaudite.dll msauserext.dll mscandui.dll mscat32.dll MSchedExe.exe msclmd.dll mscms.dll msconfig.exe mscoree.dll mscorier.dll mscories.dll msctf.dll msctfime.ime MsCtfMonitor.dll msctfp.dll msctfui.dll msctfuimanager.dll msdadiag.dll msdart.dll msdatsrc.tlb msdelta.dll msdmo.dll MSDRM msdrm.dll msdt.exe MsDtc msdtc.exe msdtckrm.dll msdtclog.dll msdtcprx.dll msdtcspoffln.dll msdtctm.dll msdtcuiu.dll msdtcVSp1res.dll MSDvbNP.ax msfeeds.dll msfeedsbs.dll msfeedssync.exe msftedit.dll MsftOemDllIgneous.dll msg.exe msg711.acm msgsm32.acm mshta.exe mshtml.dll mshtml.tlb MshtmlDac.dll mshtmled.dll mshtmler.dll msi.dll MsiCofire.dll msidcrl40.dll msident.dll msidle.dll msidntld.dll msieftp.dll msiexec.exe msihnd.dll msiltcfg.dll msimg32.dll msimsg.dll msimtf.dll msinfo32.exe msisip.dll msIso.dll msiwer.dll mskeyprotcli.dll mskeyprotect.dll msls31.dll msmpi.dll msmpires.dll MSNP.ax msobjs.dll msoert2.dll mspaint.exe mspatcha.dll mspatchc.dll msports.dll msprivs.dll msra.exe msrahc.dll MsraLegacy.tlb msrating.dll msrdc.dll MsRdpWebAccess.dll msrle32.dll msscntrs.dll mssecuser.dll mssign32.dll mssip32.dll mssitlb.dll MsSpellCheckingFacility.dll MsSpellCheckingHost.exe mssph.dll mssprxy.dll mssrch.dll mssvp.dll mstask.dll msTextPrediction.dll mstsc.exe mstscax.dll msutb.dll msv1_0.dll msvcirt.dll msvcp100.dll msvcp110.dll msvcp110d.dll msvcp110_win.dll msvcp120.dll msvcp120_clr0400.dll msvcp140.dll msvcp140d.dll msvcp140_1.dll msvcp140_1d.dll msvcp140_2.dll msvcp140_2d.dll msvcp140_clr0400.dll msvcp140_codecvt_ids.dll msvcp60.dll msvcp_win.dll msvcr100.dll msvcr100_clr0400.dll msvcr110.dll msvcr110d.dll msvcr120.dll msvcr120_clr0400.dll msvcrt.dll msvfw32.dll msvidc32.dll MSVidCtl.dll MSWB7.dll mswsock.dll msxml3.dll msxml3r.dll msxml6.dll msxml6r.dll msyuv.dll MtcModel.dll MTF.dll MTFAppServiceDS.dll MtfDecoder.dll MTFFuzzyDS.dll MTFServer.dll MTFSpellcheckDS.dll mtstocom.exe mtxclu.dll mtxdm.dll mtxex.dll mtxoci.dll MUI muifontsetup.dll MUILanguageCleanup.dll MuiUnattend.exe MultiDigiMon.exe musdialoghandlers.dll MusNotification.exe MusNotificationUx.exe MusNotifyIcon.exe MusUpdateHandlers.dll my-mm mycomput.dll mydocs.dll Mystify.scr NAPCRYPT.DLL NapiNSP.dll Narrator.exe NaturalAuth.dll NaturalAuthClient.dll NaturalLanguage6.dll navshutdown.dll nb-NO nbtstat.exe NcaApi.dll NcaSvc.dll ncbservice.dll NcdAutoSetup.dll NcdProp.dll nci.dll ncobjapi.dll ncpa.cpl ncrypt.dll ncryptprov.dll ncryptsslp.dll ncs2dmix.dll ncs2instutility.dll Ncs2Setp.dll ncscolib.dll ncsi.dll ncuprov.dll ndadmin.exe nddeapi.dll NDF ndfapi.dll ndfetw.dll NdfEventView.xml ndfhcdiscovery.dll ndishc.dll ndproxystub.dll nduprov.dll negoexts.dll net.exe net1.exe netapi32.dll netbios.dll netbtugc.exe NetCellcoreCellManagerProviderResources.dll netcenter.dll netcfg.exe NetCfgNotifyObjectHost.exe netcfgx.dll netcorehc.dll netdiagfx.dll NetDriverInstall.dll netevent.dll NetEvtFwdr.exe netfxperf.dll neth.dll NetHost.exe netid.dll netiohlp.dll netiougc.exe netjoin.dll netlogon.dll netman.dll NetMgmtIF.dll netmsg.dll netplwiz.dll Netplwiz.exe netprofm.dll netprofmsvc.dll netprovfw.dll netprovisionsp.dll NetSetupApi.dll NetSetupEngine.dll NetSetupShim.dll NetSetupSvc.dll netsh.exe netshell.dll NETSTAT.EXE nettrace.dll NetTrace.PLA.Diagnostics.xml netutils.dll NetworkBindingEngineMigPlugin.dll NetworkCollectionAgent.dll NetworkDesktopSettings.dll networkexplorer.dll networkhelper.dll networkitemfactory.dll networklist NetworkMobileSettings.dll NetworkProxyCsp.dll NetworkStatus.dll NetworkUXBroker.dll netwphelper.dll newdev.dll newdev.exe NFCProvisioningPlugin.dll NfcRadioMedia.dll ngccredprov.dll NgcCtnr.dll NgcCtnrGidsHandler.dll NgcCtnrSvc.dll NgcIso.exe NgcIsoCtnr.dll ngckeyenum.dll ngcksp.dll ngclocal.dll ngcpopkeysrv.dll NgcProCsp.dll ngcrecovery.dll ngcsvc.dll ngctasks.dll NicCo4.dll NicInstC.dll ninput.dll nl-NL nlaapi.dll nlahc.dll nlasvc.dll nlhtml.dll nlmgp.dll nlmproxy.dll nlmsprep.dll nlsbres.dll NlsData0000.dll NlsData0009.dll Nlsdl.dll NlsLexicons0009.dll nltest.exe NmaDirect.dll nmbind.exe nmscrub.exe NOISE.DAT normaliz.dll normidna.nls normnfc.nls normnfd.nls normnfkc.nls normnfkd.nls notepad.exe NotificationController.dll NotificationControllerPS.dll notificationplatformcomponent.dll npmproxy.dll NPSM.dll NPSMDesktopProvider.dll nrpsrv.dll nshhttp.dll nshipsec.dll nshwfp.dll nsi.dll nsisvc.dll nslookup.exe ntasn1.dll ntdll.dll ntdsapi.dll ntlanman.dll ntlanui2.dll NtlmShared.dll ntmarta.dll ntoskrnl.exe ntprint.dll ntprint.exe ntshrui.dll ntvdm64.dll Nui nvapi64.dll nvaudcap64v.dll nvcompiler.dll nvcpl.dll nvcuda.dll nvcuvid.dll nvdebugdump.exe nvEncodeAPI64.dll nvfatbinaryLoader.dll NvFBC64.dll nvidia-smi.1.pdf nvidia-smi.exe NvIFR64.dll NvIFROpenGL.dll nvinfo.pb nvmcumd.dll nvml.dll nvofapi64.dll nvptxJitCompiler.dll NvRtmpStreamer64.dll nvspcap64.dll nvspinfo.exe objsel.dll occache.dll ocsetapi.dll odbc32.dll odbcad32.exe odbcbcp.dll odbcconf.dll odbcconf.exe odbcconf.rsp odbccp32.dll odbccr32.dll odbccu32.dll odbcint.dll odbctrac.dll OEMDefaultAssociations.dll OEMDefaultAssociations.xml oemlicense.dll ofdeploy.exe offfilt.dll officecsp.dll offlinelsa.dll offlinesam.dll offreg.dll oflc-nz.rs OkDone_80.contrast-black.png OkDone_80.contrast-white.png OkDone_80.png olch2x8.ocx olch2xu8.ocx olch3x8.ocx olch3xu8.ocx ole32.dll oleacc.dll oleacchooks.dll oleaccrc.dll oleaut32.dll oledlg.dll oleprn.dll OmaDmAgent.dll omadmapi.dll omadmclient.exe omadmprc.exe OnDemandBrokerClient.dll OnDemandConnRouteHelper.dll OneBackupHandler.dll OneCoreCommonProxyStub.dll OneCoreUAPCommonProxyStub.dll OneDriveSettingSyncProvider.dll onex.dll onexui.dll oobe OpcServices.dll OpenCL.dll openfiles.exe opengl32.dll OpenSSH OpenWith.exe OptionalFeatures.exe ortcengine.dll osbaseln.dll osk.exe OskSupport.dll osuninst.dll OutdoorAudioEnvironment.bin P2P.dll P2PGraph.dll p2pnetsh.dll p2psvc.dll pacjsworker.exe PackagedCWALauncher.exe PackageInspector.exe packager.dll PackageStateRoaming.dll panmap.dll PasswordOnWakeSettingFlyout.exe PATHPING.EXE pautoenr.dll PayloadRestrictions.dll PaymentMediatorServiceProxy.dll pcacli.dll pcadm.dll pcaevts.dll pcalua.exe pcasvc.dll pcaui.dll pcaui.exe pcbp.rs pcl.sep PCPKsp.dll PCShellCommonProxyStub.dll pcsvDevice.dll pcwrun.exe pcwum.dll pcwutl.dll pdh.dll pdhui.dll PeerDist.dll PeerDistAD.dll PeerDistCacheProvider.dll PeerDistCleaner.dll PeerDistHttpTrans.dll PeerDistSh.dll PeerDistSvc.dll PeerDistWSDDiscoProv.dll pegi-pt.rs pegi.rs PeopleAPIs.dll PeopleBand.dll PerceptionDriverClient.dll PerceptionSimulation PerceptionSimulation.ProxyStubs.dll PerceptionSimulationDevice.exe PerceptionSimulationExtensions.dll PerceptionSimulationManager.dll perfc009.dat perfctrs.dll perfd009.dat perfdisk.dll perfh009.dat perfi009.dat perfmon.exe perfmon.msc perfnet.dll perfos.dll perfproc.dll PerfStringBackup.INI perftrack.dll perfts.dll PersonalizationCSP.dll PersonaX.dll phoneactivate.exe PhoneCallHistoryApis.dll PhoneDataSync.dll PhoneOm.dll PhonePlatformAbstraction.dll PhoneProviders.dll PhoneService.dll PhoneServiceRes.dll PhoneSystemToastIcon.contrast-white.png PhoneSystemToastIcon.png Phoneutil.dll PhoneutilRes.dll PhotoMetadataHandler.dll PhotoScreensaver.scr photowiz.dll PickerHost.exe PickerPlatform.dll pid.dll pidgenx.dll pifmgr.dll PimIndexMaintenance.dll PimIndexMaintenanceClient.dll Pimstore.dll PinEnrollmentBroker.exe PinEnrollmentHelper.dll PING.EXE pkeyhelper.dll PkgMgr.exe PktMon.exe PktMonApi.dll pku2u.dll pl-PL pla.dll plasrv.exe playlistfolder.dll PlaySndSrv.dll PlayToDevice.dll PlayToManager.dll playtomenu.dll PlayToStatusProvider.dll ploptin.dll pmcsnap.dll pngfilt.dll pnidui.dll pnpclean.dll pnppolicy.dll pnpts.dll pnpui.dll PnPUnattend.exe pnputil.exe PNPXAssoc.dll PNPXAssocPrx.dll pnrpauto.dll Pnrphc.dll pnrpnsp.dll pnrpsvc.dll PointOfService policymanager.dll policymanagerprecheck.dll polstore.dll poqexec.exe PortableDeviceSyncProvider.dll POSyncServices.dll pots.dll powercfg.cpl powercfg.exe powercpl.dll powrprof.dll ppcsnap.dll prauthproviders.dll PresentationCFFRasterizerNative_v0300.dll PresentationHost.exe PresentationHostProxy.dll PresentationNative_v0300.dll PresentationSettings.exe prevhost.exe prflbmsg.dll print.exe Print.Workflow.Source.dll PrintBrmUi.exe printfilterpipelineprxy.dll printfilterpipelinesvc.exe Printing_Admin_Scripts PrintIsolationHost.exe PrintIsolationProxy.dll printmanagement.msc PrintPlatformConfig.dll PrintRenderAPIHost.DLL printui.dll printui.exe PrintWorkflowProxy.dll PrintWorkflowService.dll PrintWSDAHost.dll prm0009.dll prncache.dll prnfldr.dll prnntfy.dll prntvpt.dll ProductEnumerator.dll profapi.dll profext.dll profprov.dll profsvc.dll profsvcext.dll PRONtObj.dll propsys.dll proquota.exe PROUnstl.exe provcore.dll provdatastore.dll provdiagnostics.dll provengine.dll provhandlers.dll provisioningcommandscsp.dll provisioningcsp.dll ProvisioningHandlers.dll provlaunch.exe provmigrate.dll provops.dll provpackageapidll.dll provplatformdesktop.dll ProvPluginEng.dll provsvc.dll ProvSysprep.dll provthrd.dll provtool.exe ProximityCommon.dll ProximityCommonPal.dll ProximityRtapiPal.dll ProximityService.dll ProximityServicePal.dll ProximityToast ProximityUxHost.exe prproc.exe prvdmofcomp.dll psapi.dll pscript.sep PSHED.DLL psisdecd.dll psisrndr.ax PSModuleDiscoveryProvider.dll psmodulediscoveryprovider.mof PsmServiceExtHost.dll psmsrv.dll psr.exe pstask.dll pstorec.dll pt-BR pt-PT ptpprov.dll puiapi.dll puiobj.dll PushToInstall.dll pwcreator.exe pwdrvio.sys pwdspio.sys pwlauncher.dll pwlauncher.exe pwNative.exe pwrshplugin.dll pwsso.dll qappsrv.exe qasf.dll qcap.dll qdv.dll qdvd.dll qedit.dll qedwipes.dll qmgr.dll qprocess.exe quartz.dll Query.dll query.exe QuickActionsDataModel.dll quickassist.exe QuietHours.dll quser.exe qwave.dll qwinsta.exe RacEngn.dll racpldlg.dll radardt.dll radarrs.dll RADCUI.dll ras rasadhlp.dll rasapi32.dll rasauto.dll rasautou.exe raschap.dll raschapext.dll rasctrnm.h rasctrs.dll rascustom.dll rasdiag.dll rasdial.exe rasdlg.dll raserver.exe rasgcw.dll rasman.dll rasmans.dll rasmbmgr.dll RasMediaManager.dll RASMM.dll rasmontr.dll rasphone.exe rasplap.dll rasppp.dll rastapi.dll rastls.dll rastlsext.dll RasToast RCoInstII64.dll RCoRes64.dat rdbui.dll rdpbase.dll rdpcfgex.dll rdpclip.exe rdpcore.dll rdpcorets.dll rdpencom.dll rdpendp.dll rdpinit.exe rdpinput.exe rdpnano.dll RdpRelayTransport.dll RdpSa.exe RdpSaProxy.exe RdpSaPs.dll RdpSaUacHelper.exe rdpserverbase.dll rdpshell.exe rdpsign.exe rdpudd.dll rdrleakdiag.exe RDSAppXHelper.dll rdsdwmdr.dll RDSPnf.exe rdvvmtransport.dll RDXService.dll RDXTaskFactory.dll ReAgent.dll ReAgentc.exe ReAgentTask.dll recdisc.exe recover.exe Recovery recovery.dll RecoveryDrive.exe refsutil.exe reg.exe regapi.dll RegCtrl.dll regedt32.exe regidle.dll regini.exe Register-CimProvider.exe regsvc.dll regsvr32.exe reguwpapi.dll ReInfo.dll rekeywiz.exe relog.exe RelPost.exe RemoteAppLifetimeManager.exe RemoteAppLifetimeManagerProxyStub.dll remoteaudioendpoint.dll remotepg.dll RemotePosWorker.exe remotesp.tsp RemoteSystemToastIcon.contrast-white.png RemoteSystemToastIcon.png RemoteWipeCSP.dll RemovableMediaProvisioningPlugin.dll RemoveDeviceContextHandler.dll RemoveDeviceElevated.dll rendezvousSession.tlb repair-bde.exe replace.exe ReportingCSP.dll reset.exe reseteng.dll ResetEngine.dll ResetEngine.exe ResetEngOnline.dll resmon.exe ResourceMapper.dll ResourcePolicyClient.dll ResourcePolicyServer.dll ResPriHMImageList ResPriHMImageListLowCost ResPriImageList ResPriImageListLowCost RestartManager.mof RestartManagerUninstall.mof RestartNowPower_80.contrast-black.png RestartNowPower_80.contrast-white.png RestartNowPower_80.png RestartTonight_80.png RestartTonight_80_contrast-black.png RestartTonight_80_contrast-white.png restore resutils.dll rgb9rast.dll Ribbons.scr riched20.dll riched32.dll rilproxy.dll RjvMDMConfig.dll RMActivate.exe RMActivate_isv.exe RMActivate_ssp.exe RMActivate_ssp_isv.exe RMapi.dll rmclient.dll RmClient.exe RMSRoamingSecurity.dll rmttpmvscmgrsvr.exe rnr20.dll ro-RO RoamingSecurity.dll Robocopy.exe rometadata.dll RotMgr.dll ROUTE.EXE RP3DAA64.dll RP3DHT64.dll RpcEpMap.dll rpchttp.dll RpcNs4.dll rpcnsh.dll RpcPing.exe rpcrt4.dll RpcRtRemote.dll rpcss.dll rsaenh.dll rshx32.dll rsop.msc RstrtMgr.dll rstrui.exe RTCOM64.dll RTDSnM64.cpl rtffilt.dll RtkApi64.dll RtkAPO64.dll RtkCfg64.dll RtkCoLDR64.dll RtlCPAPI64.dll rtm.dll rtmcodecs.dll RTMediaFrame.dll rtmmvrortc.dll rtmpal.dll rtmpltfm.dll RtPgEx64.dll rtutils.dll RTWorkQ.dll ru-RU RuleBasedDS.dll runas.exe rundll32.exe runexehelper.exe RunLegacyCPLElevated.exe runonce.exe RuntimeBroker.exe rwinsta.exe samcli.dll samlib.dll samsrv.dll sas.dll sbe.dll sbeio.dll sberes.dll sbservicetrigger.dll sc.exe scansetting.dll SCardBi.dll SCardDlg.dll SCardSvr.dll ScavengeSpace.xml scavengeui.dll ScDeviceEnum.dll scecli.dll scesrv.dll schannel.dll schedcli.dll schedsvc.dll ScheduleTime_80.contrast-black.png ScheduleTime_80.contrast-white.png ScheduleTime_80.png schtasks.exe scksp.dll scripto.dll ScriptRunner.exe scrnsave.scr scrobj.dll scrptadm.dll scrrun.dll sdbinst.exe sdchange.exe sdclt.exe sdcpl.dll SDDS.dll sdengin2.dll SDFHost.dll sdhcinst.dll sdiageng.dll sdiagnhost.exe sdiagprv.dll sdiagschd.dll sdohlp.dll sdrsvc.dll sdshext.dll Search.ProtocolHandler.MAPI2.dll SearchFilterHost.exe SearchFolder.dll SearchIndexer.exe SearchProtocolHost.exe SebBackgroundManagerPolicy.dll SecConfig.efi SecEdit.exe sechost.dll secinit.exe seclogon.dll secpol.msc secproc.dll secproc_isv.dll secproc_ssp.dll secproc_ssp_isv.dll secur32.dll SecureAssessmentHandlers.dll SecureBioSysprep.dll SecureBootUpdates securekernel.exe SecureTimeAggregator.dll security.dll SecurityAndMaintenance.png SecurityAndMaintenance_Alert.png SecurityAndMaintenance_Error.png SecurityCenterBroker.dll SecurityCenterBrokerPS.dll SecurityHealthAgent.dll SecurityHealthProxyStub.dll SecurityHealthService.exe SecurityHealthSSO.dll SecurityHealthSystray.exe SEMgrPS.dll SEMgrSvc.dll SEMgrSvcPAL.dll sendmail.dll Sens.dll SensApi.dll SensorDataService.exe SensorPerformanceEvents.dll SensorsApi.dll SensorsClassExtension.dll SensorsCpl.dll SensorService.dll SensorsNativeApi.dll SensorsNativeApi.V2.dll SensorsUtilsV2.dll sensrsvc.dll serialui.dll services.exe services.msc serwvdrv.dll SessEnv.dll sessionmsg.exe setbcdlocale.dll sethc.exe SetNetworkLocation.dll SetNetworkLocationFlyout.dll SetProxyCredential.dll setspn.exe SettingMonitor.dll settings.dat SettingsEnvironment.Desktop.dll SettingsExtensibilityHandlers.dll SettingsHandlers_Accessibility.dll SettingsHandlers_AppControl.dll SettingsHandlers_AppExecutionAlias.dll SettingsHandlers_AssignedAccess.dll SettingsHandlers_BackgroundApps.dll SettingsHandlers_BatteryUsage.dll SettingsHandlers_CapabilityAccess.dll SettingsHandlers_ClosedCaptioning.dll SettingsHandlers_ContentDeliveryManager.dll SettingsHandlers_Cortana.dll SettingsHandlers_Devices.dll SettingsHandlers_Display.dll SettingsHandlers_Flights.dll SettingsHandlers_Fonts.dll SettingsHandlers_Gaming.dll SettingsHandlers_Geolocation.dll SettingsHandlers_Gpu.dll SettingsHandlers_InkingTypingPrivacy.dll SettingsHandlers_InputPersonalization.dll SettingsHandlers_Language.dll SettingsHandlers_ManagePhone.dll SettingsHandlers_Maps.dll SettingsHandlers_Notifications.dll SettingsHandlers_nt.dll SettingsHandlers_OneCore_BatterySaver.dll SettingsHandlers_PCDisplay.dll SettingsHandlers_Pen.dll SettingsHandlers_Privacy.dll SettingsHandlers_QuickActions.dll SettingsHandlers_Region.dll SettingsHandlers_SharedExperiences_Rome.dll SettingsHandlers_SignInOptions.dll SettingsHandlers_SIUF.dll SettingsHandlers_SpeechPrivacy.dll SettingsHandlers_Startup.dll SettingsHandlers_StorageSense.dll SettingsHandlers_Troubleshoot.dll SettingsHandlers_User.dll SettingsHandlers_UserAccount.dll SettingsHandlers_WorkAccess.dll SettingSync.dll SettingSyncCore.dll SettingSyncHost.exe SettingSyncPolicy.dll setup setupapi.dll SetupBD.din setupcl.exe setupcln.dll setupetw.dll setupugc.exe setx.exe sfc.dll sfc.exe sfc_os.dll Sgrm SgrmBroker.exe SgrmClientApi.dll SgrmEnclave.dll SgrmEnclave_secure.dll SgrmLpac.exe shacct.dll shacctprofile.dll SharedPCCSP.dll SharedRealitySvc.dll SharedStartModel.dll SharedStartModelShim.dll ShareHost.dll sharemediacpl.dll SHCore.dll shdocvw.dll shell32.dll ShellCommonCommonProxyStub.dll ShellExperiences shellstyle.dll shfolder.dll shgina.dll ShiftJIS.uce shimeng.dll shimgvw.dll shlwapi.dll shpafact.dll shrpubw.exe shsetup.dll shsvcs.dll shunimpl.dll shutdown.exe shutdownext.dll shutdownux.dll shwebsvc.dll si-lk signdrv.dll sigverif.exe SIHClient.exe sihost.exe SimAuth.dll SimCfg.dll simpdata.tlb sk-SK skci.dll sl-SI slc.dll slcext.dll SleepStudy SlideToShutDown.exe slmgr slmgr.vbs slui.exe slwga.dll SmallRoom.bin SmartCardBackgroundPolicy.dll SmartcardCredentialProvider.dll SmartCardSimulator.dll smartscreen.exe smartscreenps.dll SMBHelperClass.dll smbwmiv2.dll SMI SmiEngine.dll smphost.dll SMSRouter.dll SmsRouterSvc.dll smss.exe SndVol.exe SndVolSSO.dll SnippingTool.exe snmpapi.dll snmptrap.exe Snooze_80.contrast-black.png Snooze_80.contrast-white.png Snooze_80.png socialapis.dll softkbd.dll softpub.dll sort.exe SortServer2003Compat.dll SortWindows61.dll SortWindows6Compat.dll SpaceAgent.exe spacebridge.dll SpaceControl.dll spaceman.exe SpatialAudioLicenseSrv.exe SpatializerApo.dll spbcd.dll SpeakersSystemToastIcon.contrast-white.png SpeakersSystemToastIcon.png Spectrum.exe SpectrumSyncClient.dll Speech SpeechPal.dll Speech_OneCore spfileq.dll spinf.dll spmpm.dll spnet.dll spool spoolss.dll spoolsv.exe spopk.dll spp spp.dll sppc.dll sppcext.dll sppcomapi.dll sppcommdlg.dll SppExtComObj.Exe sppinst.dll sppnp.dll sppobjs.dll sppsvc.exe sppui sppwinob.dll sppwmi.dll spwinsat.dll spwizeng.dll spwizimg.dll spwizres.dll SqlServerSpatial.dll SqlServerSpatial110.dll SqlServerSpatial150.dll sqlsrv32.dll sqlsrv32.rll sqmapi.dll sr-Latn-RS SRACAVIControl.ocx srchadmin.dll srclient.dll srcore.dll srdelayed.exe SrEvents.dll SRH.dll srhelper.dll srm.dll srmclient.dll srmlib.dll srms-apr.dat srms.dat srmscan.dll srmshell.dll srmstormod.dll srmtrace.dll srm_ps.dll srpapi.dll SrpUxNativeSnapIn.dll srrstr.dll SrTasks.exe sru srumapi.dll srumsvc.dll srvcli.dll srvsvc.dll srwmi.dll sscore.dll sscoreext.dll ssdm.dll ssdpapi.dll ssdpsrv.dll sspicli.dll sspisrv.dll SSShim.dll ssText3d.scr sstpsvc.dll StartMenuHelper64.dll StartTileData.dll Startupscan.dll StateRepository.Core.dll StaticDictDS.dll stclient.dll stdole2.tlb stdole32.tlb sti.dll sti_ci.dll stobject.dll StorageContextHandler.dll StorageUsage.dll storagewmi.dll storagewmi_passthru.dll stordiag.exe storewuauth.dll Storprop.dll StorSvc.dll streamci.dll StructuredQuery.dll SubRange.uce subst.exe sud.dll sv-SE svchost.exe svsvc.dll SwitcherDataModel.dll swprv.dll sxproxy.dll sxs.dll sxshared.dll sxssrv.dll sxsstore.dll sxstrace.exe SyncAppvPublishingServer.exe SyncAppvPublishingServer.vbs SyncCenter.dll SyncController.dll SyncHost.exe SyncHostps.dll SyncInfrastructure.dll SyncInfrastructureps.dll SyncProxy.dll Syncreg.dll SyncRes.dll SyncSettings.dll syncutil.dll sysclass.dll sysdm.cpl SysFxUI.dll sysmain.dll sysmon.ocx sysntfy.dll Sysprep sysprint.sep sysprtj.sep SysResetErr.exe syssetup.dll systemcpl.dll SystemEventsBrokerClient.dll SystemEventsBrokerServer.dll systeminfo.exe SystemPropertiesAdvanced.exe SystemPropertiesComputerName.exe SystemPropertiesDataExecutionPrevention.exe SystemPropertiesHardware.exe SystemPropertiesPerformance.exe SystemPropertiesProtection.exe SystemPropertiesRemote.exe systemreset.exe SystemResetPlatform SystemSettings.DataModel.dll SystemSettings.DeviceEncryptionHandlers.dll SystemSettings.Handlers.dll SystemSettings.SettingsExtensibility.dll SystemSettings.UserAccountsHandlers.dll SystemSettingsAdminFlows.exe SystemSettingsBroker.exe SystemSettingsRemoveDevice.exe SystemSettingsThresholdAdminFlowUI.dll SystemSupportInfo.dll SystemUWPLauncher.exe systray.exe t2embed.dll ta-in ta-lk Tabbtn.dll TabbtnEx.dll tabcal.exe TabletPC.cpl TabSvc.dll takeown.exe tapi3.dll tapi32.dll tapilua.dll TapiMigPlugin.dll tapiperf.dll tapisrv.dll TapiSysprep.dll tapiui.dll TapiUnattend.exe tar.exe TaskApis.dll taskbarcpl.dll taskcomp.dll TaskFlowDataEngine.dll taskhostw.exe taskkill.exe tasklist.exe Taskmgr.exe Tasks taskschd.dll taskschd.msc TaskSchdPS.dll tbauth.dll tbs.dll tcblaunch.exe tcbloader.dll tcmsetup.exe tcpbidi.xml tcpipcfg.dll tcpmib.dll tcpmon.dll tcpmon.ini tcpmonui.dll TCPSVCS.EXE tdc.ocx tdh.dll TDLMigration.dll telephon.cpl TelephonyInteractiveUser.dll TelephonyInteractiveUserRes.dll tellib.dll telnet.exe TempSignedLicenseExchangeTask.dll termmgr.dll termsrv.dll tetheringclient.dll tetheringconfigsp.dll TetheringIeProvider.dll TetheringMgr.dll tetheringservice.dll TetheringStation.dll TextInputFramework.dll th-TH themecpl.dll themeservice.dll themeui.dll ThirdPartyNoticesBySHS.txt threadpoolwinrt.dll thumbcache.dll ThumbnailExtractionHost.exe ti-et tier2punctuations.dll TieringEngineProxy.dll TieringEngineService.exe TileDataRepository.dll TimeBrokerClient.dll TimeBrokerServer.dll timedate.cpl TimeDateMUICallback.dll timeout.exe TimeSyncTask.dll tlscsp.dll TmInstall.log TmSysEvtEventTrackSM.log tmumh tokenbinding.dll TokenBroker.dll TokenBrokerCookies.exe TokenBrokerUI.dll tpm.msc TpmCertResources.dll tpmcompc.dll TpmCoreProvisioning.dll TpmInit.exe TpmTasks.dll tpmvsc.dll tpmvscmgr.exe tpmvscmgrsvr.exe tquery.dll tr-TR tracerpt.exe TRACERT.EXE traffic.dll TransformPPSToWlan.xslt TransformPPSToWlanCredentials.xslt TransliterationRanker.dll TransportDSA.dll tree.com trie.dll trkwks.dll TrustedSignalCredProv.dll tsbyuv.dll tscfgwmi.dll tscon.exe tsdiscon.exe TSErrRedir.dll tsgqec.dll tskill.exe tsmf.dll TSpkg.dll tspubwmi.dll TSSessionUX.dll tssrvlic.dll TSTheme.exe TsUsbGDCoInstaller.dll TsUsbRedirectionGroupPolicyExtension.dll TSWbPrxy.exe TSWorkspace.dll TsWpfWrp.exe ttdinject.exe ttdloader.dll ttdplm.dll ttdrecord.dll ttdrecordcpu.dll ttdwriter.dll TtlsAuth.dll TtlsCfg.dll TtlsExt.dll tttracer.exe tvratings.dll twext.dll twinapi.appcore.dll twinapi.dll twinui.appcore.dll twinui.dll twinui.pcshell.dll txflog.dll txfw32.dll typeperf.exe tzautoupdate.dll tzres.dll tzsync.exe tzsyncres.dll tzutil.exe ubpm.dll ucmhc.dll ucrtbase.dll ucrtbased.dll ucrtbase_clr0400.dll ucrtbase_enclave.dll ucsvc.exe udhisapi.dll uDWM.dll UefiCsp.dll UevAgentPolicyGenerator.exe UevAppMonitor.exe UevAppMonitor.exe.config UevCustomActionTypes.tlb UevTemplateBaselineGenerator.exe UevTemplateConfigItemGenerator.exe uexfat.dll ufat.dll UiaManager.dll UIAnimation.dll UIAutomationCore.dll uicom.dll UIManagerBrokerps.dll UIMgrBroker.exe uireng.dll UIRibbon.dll UIRibbonRes.dll uk-UA ulib.dll umb.dll umdmxfrm.dll umpnpmgr.dll umpo-overrides.dll umpo.dll umpoext.dll umpowmi.dll umrdp.dll unattend.dll unenrollhook.dll unimdm.tsp unimdmat.dll uniplat.dll Unistore.dll unlodctr.exe UNP untfs.dll UpdateAgent.dll updatecsp.dll updatehandlers.dll updatepolicy.dll upfc.exe UpgradeResultsUI.exe upnp.dll upnpcont.exe upnphost.dll upshared.dll uReFS.dll uReFSv1.dll ureg.dll url.dll urlmon.dll UsbCApi.dll usbceip.dll usbmon.dll usbperf.dll UsbPmApi.dll UsbSettingsHandlers.dll UsbTask.dll usbui.dll user32.dll UserAccountBroker.exe UserAccountControlSettings.dll UserAccountControlSettings.exe useractivitybroker.dll usercpl.dll UserDataAccessRes.dll UserDataAccountApis.dll UserDataLanguageUtil.dll UserDataPlatformHelperUtil.dll UserDataService.dll UserDataTimeUtil.dll UserDataTypeHelperUtil.dll UserDeviceRegistration.dll UserDeviceRegistration.Ngc.dll userenv.dll userinit.exe userinitext.dll UserLanguageProfileCallback.dll usermgr.dll usermgrcli.dll UserMgrProxy.dll usk.rs usoapi.dll UsoClient.exe usocore.dll usp10.dll ustprov.dll utcutil.dll utildll.dll Utilman.exe uudf.dll UvcModel.dll uwfcfgmgmt.dll uwfcsp.dll uwfservicingapi.dll UXInit.dll uxlib.dll uxlibres.dll uxtheme.dll vac.dll VAN.dll Vault.dll VaultCDS.dll vaultcli.dll VaultCmd.exe VaultRoaming.dll vaultsvc.dll VBICodec.ax vbisurf.ax vbsapi.dll vbscript.dll vcamp110.dll vcamp110d.dll vcamp120.dll vcamp140.dll vcamp140d.dll VCardParser.dll vccorlib110.dll vccorlib110d.dll vccorlib120.dll vccorlib140.dll vccorlib140d.dll vcomp100.dll vcomp110.dll vcomp110d.dll vcomp120.dll vcomp140.dll vcomp140d.dll vcruntime140.dll vcruntime140d.dll vcruntime140_1.dll vcruntime140_clr0400.dll vds.exe vdsbas.dll vdsdyn.dll vdsldr.exe vdsutil.dll vdsvd.dll vds_ps.dll verclsid.exe verifier.dll verifier.exe verifiergui.exe version.dll vertdll.dll vfbasics.dll vfcompat.dll vfcuzz.dll vfluapriv.dll vfnet.dll vfntlmless.dll vfnws.dll vfprint.dll vfprintpthelper.dll vfrdvcompat.dll vfuprov.dll vfwwdm32.dll vid.dll vidcap.ax VideoHandlers.dll virtdisk.dll VmApplicationHealthMonitorProxy.dll vmbuspipe.dll vmdevicehost.dll vmictimeprovider.dll vmnetbridge.dll vmrdvcore.dll vmsif.dll vmsifproxystub.dll vnetinst.dll vnetlib64.dll VocabRoamingHandler.dll VoiceActivationManager.dll VoipRT.dll vpnike.dll vpnikeapi.dll VpnSohDesktop.dll VPNv2CSP.dll vrfcore.dll VscMgrPS.dll VSCover110.dll vscover150.dll VSD3DRefDebug.dll vsflex8n.ocx VsGraphicsHelper.dll vsjitdebugger.exe vsocklib.dll VSPerf110.dll VSPerf150.dll vssadmin.exe vssapi.dll vsstrace.dll VSSVC.exe vss_ps.dll vulkan-1-999-0-0-0.dll vulkan-1.dll vulkaninfo-1-999-0-0-0.exe vulkaninfo.exe w32time.dll w32tm.exe w32topl.dll WaaSAssessment.dll WaaSMedicAgent.exe WaaSMedicCapsule.dll WaaSMedicPS.dll WaaSMedicSvc.dll WABSyncProvider.dll waitfor.exe WalletBackgroundServiceProxy.dll WalletProxy.dll WalletService.dll WallpaperHost.exe wavemsp.dll wbadmin.exe wbem wbemcomn.dll wbengine.exe wbiosrvc.dll wcimage.dll wcmapi.dll wcmcsp.dll wcmsvc.dll WCN WcnApi.dll wcncsvc.dll WcnEapAuthProxy.dll WcnEapPeerProxy.dll WcnNetsh.dll wcnwiz.dll wc_storage.dll wdc.dll WdfCoInstaller01009.dll WdfCoInstaller01011.dll WDI wdi.dll wdigest.dll wdmaud.drv wdscore.dll WdsUnattendTemplate.xml WEB.rs webauthn.dll WebCache.exe webcheck.dll WebClnt.dll webio.dll webplatstorageserver.dll WebRuntimeManager.dll webservices.dll Websocket.dll wecapi.dll wecsvc.dll wecutil.exe wephostsvc.dll wer.dll werconcpl.dll wercplsupport.dll werdiagcontroller.dll weretw.dll WerFault.exe WerFaultSecure.exe wermgr.exe wersvc.dll werui.dll wevtapi.dll wevtfwd.dll wevtsvc.dll wevtutil.exe wextract.exe WF.msc wfapigp.dll wfdprov.dll WFDSConMgr.dll WFDSConMgrSvc.dll WfHC.dll WFS.exe WFSR.dll whealogr.dll where.exe whhelper.dll whoami.exe wiaacmgr.exe wiaaut.dll wiadefui.dll wiadss.dll WiaExtensionHost64.dll wiarpc.dll wiascanprofiles.dll wiaservc.dll wiashext.dll wiatrace.dll wiawow64.exe WiFiCloudStore.dll WiFiConfigSP.dll wificonnapi.dll WiFiDisplay.dll wifinetworkmanager.dll wifitask.exe WimBootCompress.ini wimgapi.dll wimserv.exe win32appinventorycsp.dll Win32CompatibilityAppraiserCSP.dll win32k.sys win32kbase.sys win32kfull.sys win32kns.sys win32spl.dll win32u.dll Win32_DeviceGuard.dll winbio.dll WinBioDatabase WinBioDataModel.dll WinBioDataModelOOBE.exe winbioext.dll WinBioPlugIns winbrand.dll wincorlib.dll wincredprovider.dll wincredui.dll WindowManagement.dll Windows.AccountsControl.dll Windows.AI.MachineLearning.dll Windows.AI.MachineLearning.Preview.dll Windows.ApplicationModel.Background.SystemEventsBroker.dll Windows.ApplicationModel.Background.TimeBroker.dll Windows.ApplicationModel.Core.dll windows.applicationmodel.datatransfer.dll Windows.ApplicationModel.dll Windows.ApplicationModel.LockScreen.dll Windows.ApplicationModel.Store.dll Windows.ApplicationModel.Store.Preview.DOSettings.dll Windows.ApplicationModel.Store.TestingFramework.dll Windows.ApplicationModel.Wallet.dll Windows.CloudStore.dll Windows.CloudStore.Schema.DesktopShell.dll Windows.CloudStore.Schema.Shell.dll Windows.Cortana.Desktop.dll Windows.Cortana.OneCore.dll Windows.Cortana.PAL.Desktop.dll Windows.Cortana.ProxyStub.dll Windows.Data.Activities.dll Windows.Data.Pdf.dll Windows.Devices.AllJoyn.dll Windows.Devices.Background.dll Windows.Devices.Background.ps.dll Windows.Devices.Bluetooth.dll Windows.Devices.Custom.dll Windows.Devices.Custom.ps.dll Windows.Devices.Enumeration.dll Windows.Devices.Haptics.dll Windows.Devices.HumanInterfaceDevice.dll Windows.Devices.Lights.dll Windows.Devices.LowLevel.dll Windows.Devices.Midi.dll Windows.Devices.Perception.dll Windows.Devices.Picker.dll Windows.Devices.PointOfService.dll Windows.Devices.Portable.dll Windows.Devices.Printers.dll Windows.Devices.Printers.Extensions.dll Windows.Devices.Radios.dll Windows.Devices.Scanners.dll Windows.Devices.Sensors.dll Windows.Devices.SerialCommunication.dll Windows.Devices.SmartCards.dll Windows.Devices.SmartCards.Phone.dll Windows.Devices.Usb.dll Windows.Devices.WiFi.dll Windows.Devices.WiFiDirect.dll Windows.Energy.dll Windows.Gaming.Input.dll Windows.Gaming.Preview.dll Windows.Gaming.UI.GameBar.dll Windows.Gaming.XboxLive.Storage.dll Windows.Globalization.dll Windows.Globalization.Fontgroups.dll Windows.Globalization.PhoneNumberFormatting.dll Windows.Graphics.Display.BrightnessOverride.dll Windows.Graphics.Display.DisplayEnhancementOverride.dll Windows.Graphics.dll Windows.Graphics.Printing.3D.dll Windows.Graphics.Printing.dll Windows.Graphics.Printing.Workflow.dll Windows.Graphics.Printing.Workflow.Native.dll Windows.Help.Runtime.dll windows.immersiveshell.serviceprovider.dll Windows.Internal.AdaptiveCards.XamlCardRenderer.dll Windows.Internal.Bluetooth.dll Windows.Internal.CapturePicker.Desktop.dll Windows.Internal.CapturePicker.dll Windows.Internal.Devices.Sensors.dll Windows.Internal.Graphics.Display.DisplayEnhancementManagement.dll Windows.Internal.Management.dll Windows.Internal.Management.SecureAssessment.dll Windows.Internal.PlatformExtension.DevicePickerExperience.dll Windows.Internal.PlatformExtension.MiracastBannerExperience.dll Windows.Internal.PredictionUnit.dll Windows.Internal.Security.Attestation.DeviceAttestation.dll Windows.Internal.SecurityMitigationsBroker.dll Windows.Internal.Shell.Broker.dll windows.internal.shellcommon.AccountsControlExperience.dll windows.internal.shellcommon.AppResolverModal.dll Windows.Internal.ShellCommon.Broker.dll windows.internal.shellcommon.FilePickerExperienceMEM.dll Windows.Internal.ShellCommon.PrintExperience.dll windows.internal.shellcommon.shareexperience.dll windows.internal.shellcommon.ShellPosition.dll windows.internal.shellcommon.TokenBrokerModal.dll Windows.Internal.Signals.dll Windows.Internal.UI.BioEnrollment.ProxyStub.dll Windows.Internal.UI.Logon.ProxyStub.dll Windows.Management.Provisioning.ProxyStub.dll Windows.Management.SecureAssessment.CfgProvider.dll Windows.Management.SecureAssessment.Diagnostics.dll Windows.Management.Service.dll Windows.Management.Workplace.dll Windows.Management.Workplace.WorkplaceSettings.dll Windows.Media.BackgroundMediaPlayback.dll Windows.Media.BackgroundPlayback.exe Windows.Media.Devices.dll Windows.Media.FaceAnalysis.dll Windows.Media.Import.dll Windows.Media.MediaControl.dll Windows.Media.Ocr.dll Windows.Media.Playback.BackgroundMediaPlayer.dll Windows.Media.Playback.MediaPlayer.dll Windows.Media.Playback.ProxyStub.dll Windows.Media.Protection.PlayReady.dll Windows.Media.Speech.dll Windows.Media.Speech.UXRes.dll Windows.Mirage.dll Windows.Mirage.Internal.dll Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll Windows.Networking.BackgroundTransfer.ContentPrefetchTask.dll Windows.Networking.BackgroundTransfer.dll Windows.Networking.Connectivity.dll Windows.Networking.dll Windows.Networking.HostName.dll Windows.Networking.NetworkOperators.ESim.dll Windows.Networking.NetworkOperators.HotspotAuthentication.dll Windows.Networking.Proximity.dll Windows.Networking.ServiceDiscovery.Dnssd.dll Windows.Networking.Sockets.PushEnabledApplication.dll Windows.Networking.UX.EapRequestHandler.dll Windows.Networking.Vpn.dll Windows.Networking.XboxLive.ProxyStub.dll Windows.Payments.dll Windows.Perception.Stub.dll Windows.Security.Authentication.Identity.Provider.dll Windows.Security.Authentication.OnlineId.dll Windows.Security.Authentication.Web.Core.dll Windows.Security.Credentials.UI.CredentialPicker.dll Windows.Security.Credentials.UI.UserConsentVerifier.dll Windows.Security.Integrity.dll Windows.Services.TargetedContent.dll Windows.SharedPC.AccountManager.dll Windows.SharedPC.CredentialProvider.dll Windows.Shell.BlueLightReduction.dll Windows.Shell.Search.UriHandler.dll Windows.Shell.ServiceHostBuilder.dll Windows.Shell.StartLayoutPopulationEvents.dll Windows.StateRepository.dll Windows.StateRepositoryBroker.dll Windows.StateRepositoryClient.dll Windows.StateRepositoryCore.dll Windows.StateRepositoryPS.dll Windows.StateRepositoryUpgrade.dll Windows.Storage.ApplicationData.dll Windows.Storage.Compression.dll windows.storage.dll Windows.Storage.OneCore.dll Windows.Storage.Search.dll Windows.System.Diagnostics.dll Windows.System.Diagnostics.Telemetry.PlatformTelemetryClient.dll Windows.System.Diagnostics.TraceReporting.PlatformDiagnosticActions.dll Windows.System.Launcher.dll Windows.System.Profile.HardwareId.dll Windows.System.Profile.PlatformDiagnosticsAndUsageDataSettings.dll Windows.System.Profile.RetailInfo.dll Windows.System.Profile.SystemId.dll Windows.System.Profile.SystemManufacturers.dll Windows.System.RemoteDesktop.dll Windows.System.SystemManagement.dll Windows.System.UserDeviceAssociation.dll Windows.System.UserProfile.DiagnosticsSettings.dll Windows.UI.Accessibility.dll Windows.UI.AppDefaults.dll Windows.UI.BioFeedback.dll Windows.UI.BlockedShutdown.dll Windows.UI.Core.TextInput.dll Windows.UI.Cred.dll Windows.UI.CredDialogController.dll Windows.UI.dll Windows.UI.Immersive.dll Windows.UI.Input.Inking.Analysis.dll Windows.UI.Input.Inking.dll Windows.UI.Internal.Input.ExpressiveInput.dll Windows.UI.Internal.Input.ExpressiveInput.Resource.dll Windows.UI.Logon.dll Windows.UI.NetworkUXController.dll Windows.UI.PicturePassword.dll Windows.UI.Search.dll Windows.UI.Shell.dll Windows.UI.Storage.dll Windows.UI.Xaml.Controls.dll Windows.UI.Xaml.dll Windows.UI.Xaml.InkControls.dll Windows.UI.Xaml.Maps.dll Windows.UI.Xaml.Phone.dll Windows.UI.Xaml.Resources.Common.dll Windows.UI.Xaml.Resources.rs1.dll Windows.UI.Xaml.Resources.rs2.dll Windows.UI.Xaml.Resources.rs3.dll Windows.UI.Xaml.Resources.rs4.dll Windows.UI.Xaml.Resources.rs5.dll Windows.UI.Xaml.Resources.th.dll Windows.UI.Xaml.Resources.win81.dll Windows.UI.Xaml.Resources.win8rtm.dll Windows.UI.XamlHost.dll Windows.WARP.JITService.dll Windows.WARP.JITService.exe Windows.Web.Diagnostics.dll Windows.Web.dll Windows.Web.Http.dll WindowsActionDialog.exe WindowsCodecs.dll WindowsCodecsExt.dll WindowsCodecsRaw.dll WindowsCodecsRaw.txt WindowsDefaultHeatProcessor.dll windowsdefenderapplicationguardcsp.dll WindowsInternal.ComposableShell.ComposerFramework.dll WindowsInternal.ComposableShell.DesktopHosting.dll windowslivelogin.dll windowsperformancerecordercontrol.dll WindowsPowerShell WindowsSecurityIcon.png WindowsUpdateElevatedInstaller.exe winethc.dll winevt WinFax.dll winhttp.dll winhttpcom.dll WinHvEmulation.dll WinHvPlatform.dll wininet.dll wininetlui.dll wininit.exe wininitext.dll winipcfile.dll winipcsecproc.dll winipsec.dll winjson.dll Winlangdb.dll winload.efi winload.exe winlogon.exe winlogonext.dll WinMetadata winml.dll winmm.dll winmmbase.dll winmsipc.dll WinMsoIrmProtector.dll winnlsres.dll winnsi.dll WinOpcIrmProtector.dll winquic.dll winresume.efi winresume.exe winrm winrm.cmd winrm.vbs winrnr.dll winrs.exe winrscmd.dll winrshost.exe winrsmgr.dll winrssrv.dll WinRtTracing.dll WinSAT.exe WinSATAPI.dll WinSCard.dll WinSetupUI.dll winshfhc.dll winsku.dll winsockhc.dll winspool.drv winsqlite3.dll WINSRPC.DLL winsrv.dll winsrvext.dll winsta.dll WinSync.dll WinSyncMetastore.dll WinSyncProviders.dll wintrust.dll WinTypes.dll winusb.dll winver.exe WiredNetworkCSP.dll wisp.dll witnesswmiv2provider.dll wkscli.dll wkspbroker.exe wkspbrokerAx.dll wksprt.exe wksprtPS.dll wkssvc.dll wlanapi.dll wlancfg.dll WLanConn.dll wlandlg.dll wlanext.exe wlangpui.dll WLanHC.dll wlanhlp.dll WlanMediaManager.dll WlanMM.dll wlanmsm.dll wlanpref.dll WlanRadioManager.dll wlansec.dll wlansvc.dll wlansvcpal.dll wlanui.dll wlanutil.dll Wldap32.dll wldp.dll wlgpclnt.dll wlidcli.dll wlidcredprov.dll wlidfdp.dll wlidnsp.dll wlidprov.dll wlidres.dll wlidsvc.dll wlrmdr.exe WMALFXGFXDSP.dll wmdrmsdk.dll wmi.dll wmiclnt.dll wmicmiplugin.dll wmidcom.dll WmiMgmt.msc wmiprop.dll wmitomi.dll WMPhoto.dll wmsgapi.dll WMSPDMOD.DLL wnvapi.dll WofTasks.dll WofUtil.dll WordBreakers.dll WorkFolders.exe WorkfoldersControl.dll WorkFoldersGPExt.dll WorkFoldersRes.dll WorkFoldersShell.dll workfolderssvc.dll wosc.dll wow64.dll wow64cpu.dll wow64win.dll wowreg32.exe WpAXHolder.dll wpbcreds.dll Wpc.dll WpcApi.dll WpcDesktopMonSvc.dll WpcMon.exe wpcmon.png WpcRefreshTask.dll WpcTok.exe WpcWebFilter.dll wpnapps.dll wpnclient.dll wpncore.dll wpninprc.dll wpnpinst.exe wpnprv.dll wpnservice.dll wpnsruprov.dll WpnUserService.dll WpPortingLibrary.dll WppRecorderUM.dll wpr.config.xml wpr.exe WPTaskScheduler.dll wpx.dll write.exe ws2help.dll ws2_32.dll wscadminui.exe wscapi.dll wscinterop.dll wscisvif.dll WSClient.dll WSCollect.exe wscproxystub.dll wscript.exe wscsvc.dll wscui.cpl WSDApi.dll wsdchngr.dll WSDPrintProxy.DLL WSDScanProxy.dll wsecedit.dll wsepno.dll wshbth.dll wshcon.dll wshelper.dll wshext.dll wshhyperv.dll wship6.dll wshirda.dll wshom.ocx wshqos.dll wshrm.dll WSHTCPIP.DLL wshunix.dll wsl.exe wslapi.dll wslconfig.exe WsmAgent.dll wsmanconfig_schema.xml WSManHTTPConfig.exe WSManMigrationPlugin.dll WsmAuto.dll wsmplpxy.dll wsmprovhost.exe WsmPty.xsl WsmRes.dll WsmSvc.dll WsmTxt.xsl WsmWmiPl.dll wsnmp32.dll wsock32.dll wsplib.dll wsp_fs.dll wsp_health.dll wsp_sr.dll wsqmcons.exe WSReset.exe WSTPager.ax wtsapi32.dll wuapi.dll wuapihost.exe wuauclt.exe wuaueng.dll wuceffects.dll WUDFCoinstaller.dll WUDFCompanionHost.exe WUDFHost.exe WUDFPlatform.dll WudfSMCClassExt.dll WUDFx.dll WUDFx02000.dll wudriver.dll wups.dll wups2.dll wusa.exe wuuhext.dll wuuhosdeployment.dll wvc.dll WwaApi.dll WwaExt.dll WWAHost.exe WWanAPI.dll wwancfg.dll wwanconn.dll WWanHC.dll wwanmm.dll Wwanpref.dll wwanprotdim.dll WwanRadioManager.dll wwansvc.dll wwapi.dll x3daudio1_0.dll x3daudio1_1.dll X3DAudio1_2.dll X3DAudio1_3.dll X3DAudio1_4.dll X3DAudio1_5.dll X3DAudio1_6.dll X3DAudio1_7.dll xactengine2_0.dll xactengine2_1.dll xactengine2_10.dll xactengine2_2.dll xactengine2_3.dll xactengine2_4.dll xactengine2_5.dll xactengine2_6.dll xactengine2_7.dll xactengine2_8.dll xactengine2_9.dll xactengine3_0.dll xactengine3_1.dll xactengine3_2.dll xactengine3_3.dll xactengine3_4.dll xactengine3_5.dll xactengine3_6.dll xactengine3_7.dll XamlTileRender.dll XAPOFX1_0.dll XAPOFX1_1.dll XAPOFX1_2.dll XAPOFX1_3.dll XAPOFX1_4.dll XAPOFX1_5.dll XAudio2_0.dll XAudio2_1.dll XAudio2_2.dll XAudio2_3.dll XAudio2_4.dll XAudio2_5.dll XAudio2_6.dll XAudio2_7.dll XAudio2_8.dll XAudio2_9.dll XblAuthManager.dll XblAuthManagerProxy.dll XblAuthTokenBrokerExt.dll XblGameSave.dll XblGameSaveExt.dll XblGameSaveProxy.dll XblGameSaveTask.exe XboxGipRadioManager.dll xboxgipsvc.dll xboxgipsynthetic.dll XboxNetApiSvc.dll xcopy.exe xinput1_1.dll xinput1_2.dll xinput1_3.dll XInput1_4.dll XInput9_1_0.dll XInputUap.dll xmlfilter.dll xmllite.dll xmlprovi.dll xolehlp.dll XpsDocumentTargetPrint.dll XpsGdiConverter.dll XpsPrint.dll XpsRasterService.dll xpsservices.dll xwizard.dtd xwizard.exe xwizards.dll xwreg.dll xwtpdui.dll xwtpw32.dll zh-CN zh-TW zipcontainer.dll zipfldr.dll ztrace_maps.dll {3DA228BE-34DA-49f4-A081-66465B077429}
      /cygdrive/c/Windows: addins appcompat apppatch AppReadiness assembly bcastdvr bfsvc.exe BitLockerDiscoveryVolumeContents Boot bootstat.dat Branding CbsTemp CCM ccmcache ccmsetup cfgall.ini cfgwtp.ini Containers CSC Cursors debug diagnostics DigitalLocker DirectX.log dot3svc Downloaded Installations Downloaded Program Files DtcInstall.log eDrawingOfficeAutomator.INI EducationN.xml ELAMBKUP en-US EnterpriseN.xml explorer.exe FireEye Fonts GameBarPresenceWriter Globalization Help HelpPane.exe hh.exe IdentityCRL IME ImmersiveControlPanel INF InputMethod Installer L2Schemas LanguageOverlayCache LiveKernelReports Logs lsasetup.log media mib.bin Microsoft.NET Migration Minidump ModemLogs ms notepad.exe NvContainerRecovery.bat OCR OfcInstReg.log Offline Web Pages Panther Performance PFRO.log PLA PolicyDefinitions Prefetch PrintDialog ProfessionalEducationN.xml ProfessionalN.xml ProfessionalWorkstationN.xml Provisioning regedit.exe Registration RemotePackages rescache Resources SchCache schemas security ServiceProfiles ServiceState servicing Setup setupact.log setuperr.log ShellComponents ShellExperiences SKB SMSCFG.INI SoftwareDistribution SolidWorks Speech Speech_OneCore splwow64.exe symbols System system.ini System32 SystemApps SystemResources SysWOW64 TAPI Tasks Temp TextInput TmComm.log TMFilter.log tracing twain_32 twain_32.dll Vss WaaS Web win.ini WindowsShell.Manifest WindowsUpdate.log winhlp32.exe WinSxS write.exe
      /cygdrive/c/Windows/System32/Wbem: aeinv.mof AgentWmi.mof AgentWmiUninstall.mof appbackgroundtask.dll appbackgroundtask.mof appbackgroundtask_uninstall.mof AuditRsop.mof authfwcfg.mof AutoRecover bcd.mof cimdmtf.mof cimwin32.dll cimwin32.mof CIWmi.mof classlog.mof cli.mof cliegaliases.mof ddp.mof dimsjob.mof dimsroam.mof DMWmiBridgeProv.dll DMWmiBridgeProv.mof DMWmiBridgeProv1.dll DMWmiBridgeProv1.mof DMWmiBridgeProv1_Uninstall.mof DMWmiBridgeProv_Uninstall.mof dnsclientcim.dll dnsclientcim.mof dnsclientpsprovider.dll dnsclientpsprovider.mof dnsclientpsprovider_Uninstall.mof drvinst.mof DscCore.mof DscCoreConfProv.mof dscproxy.mof Dscpspluginwkr.dll DscTimer.mof dsprov.dll dsprov.mof eaimeapi.mof EmbeddedLockdownWmi.dll embeddedlockdownwmi.mof embeddedlockdownwmi_Uninstall.mof en en-US esscli.dll EventTracingManagement.dll EventTracingManagement.mof fastprox.dll fdPHost.mof fdrespub.mof fdSSDP.mof fdWNet.mof fdWSD.mof filetrace.mof firewallapi.mof FolderRedirectionWMIProvider.mof FunDisc.mof fwcfg.mof hbaapi.mof hnetcfg.mof IMAPIv2-Base.mof IMAPIv2-FileSystemSupport.mof IMAPIv2-LegacyShim.mof interop.mof IpmiDTrc.mof ipmiprr.dll ipmiprv.dll ipmiprv.mof IpmiPTrc.mof ipsecsvc.mof irda.mof irmon.mof iscsidsc.mof iscsihba.mof iscsiprf.mof iscsirem.mof iscsiwmiv2.mof iscsiwmiv2_uninstall.mof kerberos.mof KrnlProv.dll krnlprov.mof L2SecHC.mof lltdio.mof lltdsvc.mof Logs lsasrv.mof mblctr.mof MDMAppProv.dll MDMAppProv.mof MDMAppProv_Uninstall.mof MDMSettingsProv.dll MDMSettingsProv.mof MDMSettingsProv_Uninstall.mof Microsoft-Windows-OfflineFiles.mof Microsoft-Windows-Remote-FileSystem.mof Microsoft.AppV.AppVClientWmi.dll Microsoft.AppV.AppVClientWmi.mof Microsoft.ConfigurationManager.AssetProvider_v2.0.50727.mof Microsoft.ConfigurationManager.DefaultAppsProvider_v2.0.50727.mof Microsoft.ConfigurationManager.WinRTProvider_v4.0.30319.mof Microsoft.Uev.AgentWmi.dll Microsoft.Uev.ManagedAgentWmi.mof Microsoft.Uev.ManagedAgentWmiUninstall.mof mispace.mof mispace_uninstall.mof mmc.mof MMFUtil.dll MOF mofcomp.exe mofd.dll mofinstall.dll mountmgr.mof mpeval.mof mpsdrv.mof mpssvc.mof msdtcwmi.dll MsDtcWmi.mof msfeeds.mof msfeedsbs.mof msi.mof msiprov.dll msiscsi.mof MsNetImPlatform.mof mstsc.mof mstscax.mof msv1_0.mof NCProv.dll ncprov.mof ncsi.mof ndisimplatcim.dll ndistrace.mof NetAdapterCim.dll NetAdapterCim.mof NetAdapterCimTrace.mof NetAdapterCimTraceUninstall.mof NetAdapterCim_uninstall.mof netdacim.dll netdacim.mof netdacim_uninstall.mof NetEventPacketCapture.dll NetEventPacketCapture.mof NetEventPacketCapture_uninstall.mof NetNat.dll NetNat.mof netnccim.dll netnccim.mof netnccim_uninstall.mof NetPeerDistCim.dll NetPeerDistCim.mof NetPeerDistCim_uninstall.mof netprofm.mof NetSwitchTeam.mof netswitchteamcim.dll NetTCPIP.dll NetTCPIP.mof NetTCPIP_Uninstall.mof netttcim.dll netttcim.mof netttcim_uninstall.mof networkitemfactory.mof newdev.mof nlasvc.mof nlmcim.dll nlmcim.mof nlmcim_uninstall.mof nlsvc.mof npivwmi.mof nshipsec.mof ntevt.dll ntevt.mof ntfs.mof OfflineFilesConfigurationWmiProvider.mof OfflineFilesConfigurationWmiProvider_Uninstall.mof OfflineFilesWmiProvider.mof OfflineFilesWmiProvider_Uninstall.mof p2p-mesh.mof p2p-pnrp.mof pcsvDevice.mof pcsvDevice_Uninstall.mof Performance PNPXAssoc.mof PolicMan.dll PolicMan.mof polproc.mof polprocl.mof polprou.mof polstore.mof powermeterprovider.mof PowerPolicyProvider.mof ppcRsopCompSchema.mof ppcRsopUserSchema.mof PrintFilterPipelineSvc.mof PrintManagementProvider.dll PrintManagementProvider.mof profileassociationprovider.mof PS_MMAgent.mof qmgr.mof qoswmi.dll qoswmi.mof qoswmitrc.mof qoswmitrc_uninstall.mof qoswmi_uninstall.mof RacWmiProv.dll RacWmiProv.mof rawxml.xsl rdpendp.mof rdpinit.mof rdpshell.mof refs.mof refsv1.mof regevent.mof Remove.Microsoft.AppV.AppvClientWmi.mof repdrvfs.dll Repository rsop.mof rspndr.mof samsrv.mof scersop.mof schannel.mof schedprov.dll SchedProv.mof scm.mof scrcons.exe scrcons.mof sdbus.mof secrcw32.mof SensorsClassExtension.mof ServDeps.dll ServiceModel.mof ServiceModel.mof.uninstall ServiceModel35.mof ServiceModel35.mof.uninstall services.mof setupapi.mof SmbWitnessWmiv2Provider.mof smbwmiv2.mof SMTPCons.dll smtpcons.mof sppwmi.mof sr.mof sstpsvc.mof stdprov.dll storagewmi.mof storagewmi_passthru.mof storagewmi_passthru_uninstall.mof storagewmi_uninstall.mof stortrace.mof subscrpt.mof system.mof tcpip.mof texttable.xsl textvaluelist.xsl tmf tsallow.mof tscfgwmi.mof tsmf.mof tspkg.mof umb.mof umbus.mof umpass.mof umpnpmgr.mof unsecapp.exe UserProfileConfigurationWmiProvider.mof UserProfileWmiProvider.mof UserStateWMIProvider.mof vds.mof vdswmi.dll viewprov.dll vpnclientpsprovider.dll vpnclientpsprovider.mof vpnclientpsprovider_Uninstall.mof vss.mof vsswmi.dll wbemcntl.dll wbemcons.dll WBEMCons.mof wbemcore.dll wbemdisp.dll wbemdisp.tlb wbemess.dll wbemprox.dll wbemsvc.dll wbemtest.exe wcncsvc.mof WdacEtwProv.mof WdacWmiProv.dll WdacWmiProv.mof WdacWmiProv_Uninstall.mof Wdf01000.mof Wdf01000Uninstall.mof wdigest.mof WFAPIGP.mof wfascim.dll wfascim.mof wfascim_uninstall.mof WFP.MOF wfs.mof whqlprov.mof Win32_DeviceGuard.mof Win32_EncryptableVolume.dll win32_encryptablevolume.mof Win32_EncryptableVolumeUninstall.mof win32_printer.mof Win32_Tpm.dll Win32_Tpm.mof wininit.mof winipsec.mof winlogon.mof WinMgmt.exe WinMgmtR.dll Winsat.mof WinsatUninstall.mof wlan.mof WLanHC.mof wmi.mof WMIADAP.exe WmiApRes.dll WmiApRpl.dll WmiApSrv.exe WMIC.exe WMICOOKR.dll WmiDcPrv.dll wmipcima.dll wmipcima.mof wmipdfs.dll wmipdfs.mof wmipdskq.dll wmipdskq.mof WmiPerfClass.dll WmiPerfClass.mof WmiPerfInst.dll WmiPerfInst.mof WMIPICMP.dll wmipicmp.mof WMIPIPRT.dll wmipiprt.mof WMIPJOBJ.dll wmipjobj.mof wmiprov.dll WmiPrvSD.dll WmiPrvSE.exe WMIPSESS.dll wmipsess.mof WMIsvc.dll wmitimep.dll wmitimep.mof wmiutils.dll WMI_Tracing.mof wscenter.mof WsmAgent.mof WsmAgentUninstall.mof WsmAuto.mof wsp_fs.mof wsp_fs_uninstall.mof wsp_health.mof wsp_health_uninstall.mof wsp_sr.mof wsp_sr_uninstall.mof WUAProvider.dll WUAProvider.mof WUAProvider_Uninstall.mof WUDFx.mof Wudfx02000.mof Wudfx02000Uninstall.mof WUDFxUninstall.mof xml xsl-mappings.xml xwizards.mof
      /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0: Certificate.format.ps1xml Diagnostics.Format.ps1xml DotNetTypes.format.ps1xml en en-US Event.Format.ps1xml Examples FileSystem.format.ps1xml getevent.types.ps1xml Help.format.ps1xml HelpV3.format.ps1xml Modules powershell.exe powershell.exe.config PowerShellCore.format.ps1xml PowerShellTrace.format.ps1xml powershell_ise.exe powershell_ise.exe.config PSEvents.dll pspluginwkr.dll pwrshmsg.dll pwrshsip.dll Registry.format.ps1xml Schemas SessionConfig types.ps1xml typesv3.ps1xml WSMan.Format.ps1xml
      /cygdrive/c/Windows/System32/OpenSSH: scp.exe sftp.exe ssh-add.exe ssh-agent.exe ssh-keygen.exe ssh-keyscan.exe ssh.exe
      /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR: GfeXCode64.dll nvdlisrwrapper.exe nvngx_dlisr.dll
      /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit: Catalog CeLog2ETW.chm celog2etw.exe default.stacktags ecosystem.core.dll ecosystem.windows.dll gpuview HeapAction_CullFunctionsExample.txt kerneltracecontrol.dll KernelTraceControl.h microsoft.assessments.administration.dll microsoft.assessments.administration.presentation.dll microsoft.assessments.dll microsoft.performance.base.dll microsoft.performance.core4.interop.dll microsoft.performance.data.dll microsoft.performance.dataengine.dll microsoft.performance.nt.dll microsoft.performance.nt.shell.dll microsoft.performance.shell.addins.dll microsoft.performance.shell.dll microsoft.performance.ui.dataengine.dll microsoft.performance.ui.dll microsoft.performance.windows.dll msdia120.dll perfcore.dll perfcore.ini perfctrl.dll perfg.dll perf_delay.dll perf_dx.dll perf_frames.dll perf_heap.dll perf_memory.dll perf_nt.dll perf_nt_c.dll perf_nt_g.dll perf_onoff.dll perf_onoff_c.dll perf_onoff_g.dll perf_pep.dll perf_pofx.dll perf_pool.dll perf_ppm.dll perf_regions.dll perf_spinlock.dll perf_tdh.dll perf_va.dll perf_wininet.dll perf_wpr.dll README.TXT SampleGeneralProfileForLargeServers.wprp SampleWPRControlProfiles.wprp WaitClassification_ImportantThreadStartFunctions.txt WaitClassification_WatchFunctions.txt WaitClassification_WatchLocks.txt windowsperformancerecordercontrol.dll WindowsPerformanceRecorderControl.h WindowsPerformanceRecorderControl.idl windowsperformancerecorderui.dll wpa.addins.ini wpa.exe wpa.exe.config wpaexporter.exe wpaexporter.exe.config wpr.config.xml wpr.exe WPRUI.exe xbootmgr.exe xbootmgrsleep.exe xperf.exe
      /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0: docs EULA.txt extras host ncu-ui.bat ncu.bat nv-nsight-cu-cli.bat nv-nsight-cu.bat sections target
      /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn: Resources SqlLocalDB.exe
      /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps: CanonicalGroupLimited.Ubuntu20.04onWindows_79rhkp1fndgsc Microsoft.MicrosoftEdge_8wekyb3d8bbwe MicrosoftEdge.exe ubuntu2004.exe
      /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin: github github.bat
      /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib: debug impicxx.lib impicxxd.lib libmpi_ilp64.lib release
      /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric: bin
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin: cmake.exe cmcldeps.exe cpack.exe ctest.exe
      /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja: ninja.exe
      Warning accessing /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu gives errors: [Errno 2] No such file or directory: '/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu'
      Warning accessing /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin gives errors: [Errno 2] No such file or directory: '/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin'
      /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc: clangFEWrapper.dll iga64.dll igc64.dll igdfcl64.dll ocloc.exe ocloc64.dll ocloc64.lib ocloc_api.h opencl-clang64.dll SPIRVDLL.dll
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:978)
    child config.utilities.macosFirewall 0.000006
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:21)
  Find a default debugger and determine its arguments
Executing: uname -s
stdout: CYGWIN_NT-10.0
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/gdb...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/gdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/gdb...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/gdb...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/gdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/gdb...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/gdb...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/gdb...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/gdb...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/gdb...not found
Checking for program /cygdrive/c/Windows/system32/gdb...not found
Checking for program /cygdrive/c/Windows/gdb...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/gdb...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/gdb...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/gdb...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/gdb...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/gdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/gdb...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/gdb...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/gdb...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/dbx...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/dbx...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/dbx...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/dbx...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/dbx...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/dbx...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/dbx...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/dbx...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/dbx...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/dbx...not found
Checking for program /cygdrive/c/Windows/system32/dbx...not found
Checking for program /cygdrive/c/Windows/dbx...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/dbx...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/dbx...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/dbx...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/dbx...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/dbx...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/dbx...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/dbx...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/dbx...not found
Executing: uname -s
            Defined make macro "DSYMUTIL" to "true"
Executing: uname -s
    child config.utilities.debuggers 1.662651
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
          Version Information:
          #define PETSC_VERSION_RELEASE    1
          #define PETSC_VERSION_MAJOR      3
          #define PETSC_VERSION_MINOR      15
          #define PETSC_VERSION_SUBMINOR   0
          #define PETSC_VERSION_PATCH      0
          #define PETSC_VERSION_DATE       "unknown"
          #define PETSC_VERSION_GIT        "unknown"
          #define PETSC_VERSION_DATE_GIT   "unknown"
          #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_ PETSC_VERSION_EQ
          #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
          #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
    child PETSc.options.petscdir 0.077186
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
    child PETSc.options.dataFilesPath 0.019601
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /usr/local/bin/git...not found
Checking for program /usr/bin/git...found
              Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.31.1
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/hg...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/hg...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/hg...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/hg...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/hg...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/hg...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/hg...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/hg...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/hg...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/hg...not found
Checking for program /cygdrive/c/Windows/system32/hg...not found
Checking for program /cygdrive/c/Windows/hg...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/hg...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/hg...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/hg...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/hg...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/hg...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/hg...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/hg...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/hg...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/hg...not found
    child config.sourceControl 0.799024
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
          lib/petsc/bin/maint exists. This appears to be a repository clone
          .git directory exists
Executing: ['git', 'describe', '--match=v*']
stdout: v3.15.0-115-g500a29e669
Executing: ['git', 'log', '-1', '--pretty=format:%H']
stdout: 500a29e669f39b1a8c26d399c10e4b8afc43c589
Executing: ['git', 'log', '-1', '--pretty=format:%ci']
stdout: 2021-04-14 14:51:36 +0000
Executing: ['git', 'rev-parse', '--abbrev-ref', 'HEAD']
stdout: release
            Defined "VERSION_GIT" to ""v3.15.0-115-g500a29e669""
            Defined "VERSION_DATE_GIT" to ""2021-04-14 14:51:36 +0000""
            Defined "VERSION_BRANCH_GIT" to ""release""
    child PETSc.options.petscclone 2.040731
TESTING: setNativeArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:31)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:43)
  Checks PETSC_ARCH and sets if not set
        No previous hashfile found
          Setting hashfile: petsc-dev_win64_impi_vs2017/lib/petsc/conf/configure-hash
          Deleting configure hash file: petsc-dev_win64_impi_vs2017/lib/petsc/conf/configure-hash
          Unable to delete configure hash file: petsc-dev_win64_impi_vs2017/lib/petsc/conf/configure-hash
    child PETSc.options.arch 0.393732
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:39)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
            Defined make macro "PREFIXDIR" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/petsc-dev_win64_impi_vs2017"
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:85)
TESTING: cleanConfDir from PETSc.options.installDir(config/PETSc/options/installDir.py:78)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:62)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
          Changed persistence directory to /cygdrive/d/wtay/Downloads/Source_codes/petsc/petsc-dev_win64_impi_vs2017/lib/petsc/conf
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:98)
    child PETSc.options.installDir 0.076177
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
    child PETSc.options.externalpackagesdir 0.011692
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
          C language is C
            Defined "CLANGUAGE_C" to "1"
            Defined make macro "CLANGUAGE" to "C"
    child PETSc.options.languages 0.019462
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1957)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1987)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1927)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1948)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:526)
  Initialize the compiler and linker flags
          Initialized CFLAGS to
          Initialized LDFLAGS to
          Initialized CUDAFLAGS to
          Initialized HIPFLAGS to
          Initialized SYCLCXXFLAGS to
          Initialized CXXFLAGS to
          Initialized CXX_CXXFLAGS to
          Initialized FFLAGS to
          Initialized CPPFLAGS to
          Initialized FPPFLAGS to
          Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
          Initialized CXXPPFLAGS to
          Initialized HIPPPFLAGS to -Wno-deprecated-gpu-targets
          Initialized SYCLPPFLAGS to -Wno-deprecated-gpu-targets
          Initialized CC_LINKER_FLAGS to []
          Initialized CXX_LINKER_FLAGS to []
          Initialized FC_LINKER_FLAGS to []
          Initialized CUDAC_LINKER_FLAGS to []
          Initialized HIPC_LINKER_FLAGS to []
          Initialized SYCLCXX_LINKER_FLAGS to []
          Initialized sharedLibraryFlags to []
          Initialized dynamicLibraryFlags to []
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:701)
  Locate a functional C compiler
Checking for program /usr/local/bin/win32fe...not found
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/win32fe...not found
Checking for program /cygdrive/c/Windows/system32/win32fe...not found
Checking for program /cygdrive/c/Windows/win32fe...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/win32fe...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/win32fe...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/win32fe...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/win32fe...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/win32fe...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/win32fe...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/win32fe...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe...found
              Defined make macro "CC" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl"
===== Checking compiler
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
===== Checking linker
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout: LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 2
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Linker output before filtering:
Linker output after filtering:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib':
======== Checking running linked program
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Testing executable /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe to see if it can be run
Executing: /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe
Running Executable with threads to time it out at 60
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl --version
stdout:
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Microsoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:740)
  Locate a functional C preprocessor
              Defined make macro "CPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E"
Preprocessing source:
#include <stdlib.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
Preprocess output before filtering:
Preprocess output after filtering:
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:776)
  Locate a functional CUDA compiler
Checking for program /usr/local/bin/nvcc...not found
Checking for program /usr/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/nvcc...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/nvcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/nvcc...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/nvcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/nvcc...found
              Defined make macro "CUDAC" to "nvcc"
Executing: nvcc -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -Wno-deprecated-gpu-targets /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cu
stdout: conftest.cu
Possible ERROR while running compiler: exit code 2
stdout:
conftest.custderr:
c1xx: fatal error C1083: Cannot open source file: 'D:/tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cu': No such file or directory
Source:
int main() {
  return 0;
          Error testing CUDA compiler: Cannot compile CUDA with nvcc.
            Deleting "CUDAC"
Checking for program /Developer/NVIDIA/CUDA-6.5/bin/nvcc...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/nvcc...not found
  Unable to find programs ['nvcc'] providing listing of the specific search path
      Warning accessing /Developer/NVIDIA/CUDA-6.5/bin gives errors: can only concatenate str (not "builtin_function_or_method") to str
Checking for program /usr/local/cuda/bin/nvcc...not found
      Warning accessing /usr/local/cuda/bin gives errors: can only concatenate str (not "builtin_function_or_method") to str
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:816)
  Locate a functional CUDA preprocessor
TESTING: checkHIPCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:850)
  Locate a functional HIP compiler
Checking for program /usr/local/bin/hipcc...not found
Checking for program /usr/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/hipcc...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/hipcc...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/hipcc...not found
Checking for program /cygdrive/c/Windows/system32/hipcc...not found
Checking for program /cygdrive/c/Windows/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/hipcc...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/hipcc...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/hipcc...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/hipcc...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/hipcc...not found
Checking for program /usr/local/bin/opt/rocm/bin/hipcc...not found
Checking for program /usr/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/system32/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/opt/rocm/bin/hipcc...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/opt/rocm/bin/hipcc...not found
TESTING: checkHIPPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:886)
   Placeholder for now
TESTING: checkSYCLCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:907)
  Locate a functional SYCL compiler
TESTING: checkSYCLPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:933)
   Placeholder for now
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1020)
  Locate a functional Cxx compiler
              Defined make macro "CXX" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:1061)
  Locate a functional Cxx preprocessor
              Defined make macro "CXXPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E"
#include <cstdlib>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1160)
  Locate a functional Fortran compiler
              Defined make macro "FC" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
ipo: error #11018: Cannot open libpetsc-ufod4vtr9mqHvKIQiVAm.lib
Possible ERROR while running linker: exit code 157
stdout:
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort --version
stdout:
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
TESTING: checkFortranPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:1197)
  Locate a functional Fortran preprocessor
              Defined make macro "FPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -E"
            Deleting "FPP"
              Defined make macro "FPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort --use cpp32"
            Deleting "FPP"
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:1219)
  Make sure fortran comment "!" works
Successful compile:
Source:
      program main
! comment
      end
          Fortran comments can use ! in column 1
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1366)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1465)
  Check that the archiver exists and can make a library usable by the compiler
Executing: ar -V
stdout:
GNU ar (GNU Binutils) 2.36.1
Copyright (C) 2021 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
                Defined make macro "FAST_AR_FLAGS" to "Scq"
stdout: conftest.c
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/bin/ar...found
              Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
              Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-v6m0e0sk/config.setCompilers/libconf1.a /tmp/petsc-v6m0e0sk/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-v6m0e0sk/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- c
          Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
stdout: conftest.c
Successful compile:
Source:
int foo(int a) {
  return a+1;
              Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-v6m0e0sk/config.setCompilers/libconf1.a
stdout: conftest.c
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -L/tmp/petsc-v6m0e0sk/config.setCompilers -lconf1
stdout: LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'
stdout:
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'Linker output before filtering:
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib':
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Defined make macro "AR_FLAGS" to "cr"
            Defined make macro "AR_LIB_SUFFIX" to "lib"
TESTING: checkArchiverRecipeArgfile from config.setCompilers(config/BuildSystem/config/setCompilers.py:1529)
  Checks if AR handles @ notation
Executing: /usr/bin/ar cr checkRecipeArgfile.lib @checkRecipeArgfile.args
            Defined make macro "AR_ARGFILE" to "yes"
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1609)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: CYGWIN_NT-10.0
          Checking shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
              Defined make macro "LD_SHARED" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl --help | head -n 20
stdout:
Usage: win32fe <tool> --<win32fe options> -<tool options> <files>
  <tool> must be the first argument to win32fe
<tool>: {cl,icl,df,f90,ifl,bcc32,lib,tlib}
  cl:    Microsoft 32-bit C/C++ Optimizing Compiler
  icl:   Intel C/C++ Optimizing Compiler
  df:    Compaq Visual Fortran Optimizing Compiler
  f90:   Compaq Visual Fortran90 Optimizing Compiler
  ifl:   Intel Fortran Optimizing Compiler
  ifort: Intel Fortran Optimizing Compiler
  nvcc:  NVIDIA CUDA Compiler Driver
  bcc32: Borland C++ for Win32
  lib:   Microsoft Library Manager
  tlib:  Borland Library Manager
<win32fe options>:
  --help:       Output this help message and help for <tool>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -show
stdout:
cl : Command line warning D9002 : ignoring unknown option '-show'
cl : Command line error D8003 : missing source filename
            Skipping checking MPI compiler command for PIC flag since MPI compiler -show causes an exception so is likly not an MPI compiler
          Trying C compiler flag -PIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -PIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-PIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -PIC
conftest.c
              Rejecting compiler flag -PIC  due to
conftest.c
          Rejected C compiler flag -PIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
          Trying C compiler flag -fPIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -fPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-fPIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -fPIC
conftest.c
              Rejecting compiler flag -fPIC  due to
conftest.c
          Rejected C compiler flag -fPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
          Trying C compiler flag -KPIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -KPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-KPIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -KPIC
conftest.c
              Rejecting compiler flag -KPIC  due to
conftest.c
          Rejected C compiler flag -KPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
          Trying C compiler flag -qpic
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -qpic   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-qpic'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -qpic
conftest.c
              Rejecting compiler flag -qpic  due to
conftest.c
          Rejected C compiler flag -qpic because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -shared   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line warning D9002 : ignoring unknown option '-shared'
cl : Command line warning D9002 : ignoring unknown option '-shared':
            Rejecting C linker flag -shared due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void  foo(void){
  fprintf_ptr(stdout,"hello");
  return;
void bar(void){foo();}
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/libconftest.so    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: LINK : fatal error LNK1561: entry point must be defined
stdout:
LINK : fatal error LNK1561: entry point must be definedLinker output before filtering:
LINK : fatal error LNK1561: entry point must be defined:
          Rejected C compiler flag  because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-shared']
            Deleting "LD_SHARED"
          Checking shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
stdout:
<win32fe options>:
stdout:
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -PIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -fPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -KPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -qpic because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -dynamic   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line warning D9002 : ignoring unknown option '-dynamic'
cl : Command line warning D9002 : ignoring unknown option '-dynamic':
            Rejecting C linker flag -dynamic due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
stdout:
          Rejected C compiler flag  because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-dynamic']
          Checking shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout:
<win32fe options>:
stdout:
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -PIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -fPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -KPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -qpic because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -qmkshrobj   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line warning D9002 : ignoring unknown option '-qmkshrobj'
cl : Command line warning D9002 : ignoring unknown option '-qmkshrobj':
            Rejecting C linker flag -qmkshrobj due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
stdout:
          Rejected C compiler flag  because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-qmkshrobj']
stdout:
<win32fe options>:
stdout:
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void __declspec(dllexport)  foo(void){
  return;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/libconftest.dll    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout:
Creating library C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.lib and object C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.exp
stdout:
          Checking shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-LD']
stdout:
<win32fe options>:
stdout:
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -PIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-LD']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -fPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-LD']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -KPIC because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-LD']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
conftest.c
          Rejected C compiler flag -qpic because it was not compatible with shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl using flags ['-LD']
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -LD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
            Valid C linker flag -LD
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
  return;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/libconftest.dll  -LD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: Creating library C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.lib and object C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.exp
stdout: conftest.c
Successful compile:
Source:
__declspec(dllimport) int foo(void);
int main() {
int ret = foo();
if (ret) {}
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o  -L/tmp/petsc-v6m0e0sk/config.setCompilers -lconftest
          Using shared linker /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl with flags ['-LD'] and library extension dll
Executing: uname -s
Executing: uname -s
Detected Cygwin
TESTING: checkLinkerWindows from config.setCompilers(config/BuildSystem/config/setCompilers.py:1704)
  Turns off linker warning about unknown .o files extension
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -Qwd10161   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line warning D9002 : ignoring unknown option '-Qwd10161'
cl : Command line warning D9002 : ignoring unknown option '-Qwd10161':
            Rejecting C linker flag -Qwd10161 due to
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Rejecting Cxx linker flag -Qwd10161 due to
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1309)
  Determine the PIC option for each compiler
stdout:
<win32fe options>:
stdout:
          Trying Cxx compiler flag -PIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   -PIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
conftest.cc
          Rejected Cxx compiler flag -PIC because shared linker cannot handle it
          Trying Cxx compiler flag -fPIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   -fPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
conftest.cc
          Rejected Cxx compiler flag -fPIC because shared linker cannot handle it
          Trying Cxx compiler flag -KPIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   -KPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
conftest.cc
          Rejected Cxx compiler flag -KPIC because shared linker cannot handle it
          Trying Cxx compiler flag -qpic for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers   -qpic   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
conftest.cc
          Rejected Cxx compiler flag -qpic because shared linker cannot handle it
          Trying Cxx for PIC code without any compiler flag
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
stdout: conftest.cc
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
          Accepted Cxx PIC code without compiler flag
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort --help | head -n 20
stdout:
<win32fe options>:
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -show
stdout: ifort: command line error: no files specified; for help type "ifort /help"
          Trying FC compiler flag -PIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -PIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/PIC'
Successful compile:
Source:
      program main
      end
          Rejected FC compiler flag -PIC because shared linker cannot handle it
          Trying FC compiler flag -fPIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -fPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/fPIC'
Successful compile:
Source:
      program main
      end
          Rejected FC compiler flag -fPIC because shared linker cannot handle it
          Trying FC compiler flag -KPIC for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -KPIC   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/KPIC'
Successful compile:
Source:
      program main
      end
          Rejected FC compiler flag -KPIC because shared linker cannot handle it
          Trying FC compiler flag -qpic for PIC code
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -qpic   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/qpic'
Successful compile:
Source:
      program main
      end
          Rejected FC compiler flag -qpic because shared linker cannot handle it
          Trying FC for PIC code without any compiler flag
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
stdout:
conftest.obj : error LNK2019: unresolved external symbol BAR referenced in function FOO
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.dll : fatal error LNK1120: 1 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.dll : fatal error LNK1120: 1 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\libconftest.dll : fatal error LNK1120: 1 unresolved externals:
          Rejected FC compiler flag  because shared linker cannot handle it
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1722)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
Executing: uname -s
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -V
stdout: cl : Command line error D8004 : '/V' requires an argument
          Trying C linker flag -Wl,-rpath,
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line error D8021 : invalid numeric argument '/Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc'
stdout:
cl : Command line error D8021 : invalid numeric argument '/Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc'            Rejecting linker flag -Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc due to nonzero status from link
cl : Command line error D8021 : invalid numeric argument '/Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc':
          Rejected C linker flag -Wl,-rpath,
          Trying C linker flag -R
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -R/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line warning D9002 : ignoring unknown option '-R/cygdrive/d/wtay/Downloads/Source_codes/petsc'
cl : Command line warning D9002 : ignoring unknown option '-R/cygdrive/d/wtay/Downloads/Source_codes/petsc':
            Rejecting C linker flag -R/cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected C linker flag -R
          Trying C linker flag -rpath
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout:
cl : Command line warning D9002 : ignoring unknown option '-rpath'
cl : Command line warning D9024 : unrecognized source file type 'D:\wtay\DOWNLO~1\SOURCE~1\petsc', object file assumed
LINK : fatal error LNK1181: cannot open input file 'D:\wtay\DOWNLO~1\SOURCE~1\petsc.obj'
stdout:
LINK : fatal error LNK1181: cannot open input file 'D:\wtay\DOWNLO~1\SOURCE~1\petsc.obj'            Rejecting linker flag -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc due to nonzero status from link
LINK : fatal error LNK1181: cannot open input file 'D:\wtay\DOWNLO~1\SOURCE~1\petsc.obj':
            Rejecting C linker flag -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected C linker flag -rpath
          Trying C linker flag -Wl,-R,
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: cl : Command line error D8021 : invalid numeric argument '/Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc'
stdout:
cl : Command line error D8021 : invalid numeric argument '/Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc'            Rejecting linker flag -Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc due to nonzero status from link
cl : Command line error D8021 : invalid numeric argument '/Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc':
          Rejected C linker flag -Wl,-R,
Executing: uname -s
          Trying Cxx linker flag -Wl,-rpath,
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
          Rejected Cxx linker flag -Wl,-rpath,
          Trying Cxx linker flag -R
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Rejecting Cxx linker flag -R/cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected Cxx linker flag -R
          Trying Cxx linker flag -rpath
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
stdout:
            Rejecting Cxx linker flag -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected Cxx linker flag -rpath
          Trying Cxx linker flag -Wl,-R,
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
          Rejected Cxx linker flag -Wl,-R,
Executing: uname -s
          Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: ifort: command line warning #10157: ignoring option '/W'; argument is of wrong type
ifort: command line warning #10157: ignoring option '/W'; argument is of wrong type:
            Rejecting FC linker flag -Wl,-rpath,/cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected FC linker flag -Wl,-rpath,
          Trying FC linker flag -R
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -R/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: ifort: command line warning #10006: ignoring unknown option '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc'
ifort: command line warning #10006: ignoring unknown option '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc':
            Rejecting FC linker flag -R/cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected FC linker flag -R
          Trying FC linker flag -rpath
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout:
ifort: command line warning #10006: ignoring unknown option '/rpath'
ifort: command line warning #10161: unrecognized source type 'D:\wtay\DOWNLO~1\SOURCE~1\petsc'; object file assumed
ipo: error #11018: Cannot open D:\wtay\DOWNLO~1\SOURCE~1\petsc
stdout:
            Rejecting FC linker flag -rpath /cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected FC linker flag -rpath
          Trying FC linker flag -Wl,-R,
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe  -Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
            Rejecting FC linker flag -Wl,-R,/cygdrive/d/wtay/Downloads/Source_codes/petsc due to
          Rejected FC linker flag -Wl,-R,
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1761)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
          Shared linking does not require an explicit libc reference
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1807)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
#include <dlfcn.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers  /tmp/petsc-v6m0e0sk/config.headers/conftest.c
Possible ERROR while running preprocessor: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'dlfcn.h': No such file or directory
#line 1 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 9 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 2 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 8 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 9 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 10 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 3 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
Source:
#include <dlfcn.h>
          Dynamic loading disabled since dlfcn.h was missing
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1856)
  Output module data as defines and substitutions
            Substituting "CC" with "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl"
            Substituting "CFLAGS" with ""
            Defined make macro "CC_LINKER_SLFLAG" to "-L"
            Substituting "CPP" with "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E"
            Substituting "CPPFLAGS" with ""
            Substituting "CXX" with "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl"
            Substituting "CXX_CXXFLAGS" with ""
            Substituting "CXXFLAGS" with ""
            Substituting "CXX_LINKER_SLFLAG" with "-L"
            Substituting "CXXPP" with "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E"
            Substituting "CXXPPFLAGS" with ""
            Substituting "FC" with "/cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort"
            Substituting "FFLAGS" with ""
            Defined make macro "FC_LINKER_SLFLAG" to "-L"
            Substituting "LDFLAGS" with ""
            Substituting "LIBS" with ""
            Substituting "SHARED_LIBRARY_FLAG" with "-LD"
    child config.setCompilers 162.043623
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:39)
            Defined make macro "PETSC_INDEX_SIZE" to "32"
    child PETSc.options.indexTypes 0.013151
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:82)
  Get the default compiler flags
              Defined make macro "C_VERSION" to "Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64"
                Defined make macro "MPICC_SHOW" to "Unavailable"
          Trying C compiler flag -MD
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD
conftest.c
Added C compiler flag -MD
          Trying C compiler flag -wd4996
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -wd4996   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD -wd4996
conftest.c
Added C compiler flag -wd4996
          Trying C compiler flag -Z7
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
              Output from compiling with  -MD -wd4996 -Z7
conftest.c
Added C compiler flag -Z7
              Defined make macro "Cxx_VERSION" to "Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
                Defined make macro "MPICXX_SHOW" to "Unavailable"
          Trying Cxx compiler flag -MD
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
Added Cxx compiler flag -MD
          Trying Cxx compiler flag -GR
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD -GR
conftest.cc
Added Cxx compiler flag -GR
          Trying Cxx compiler flag -EHsc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc
conftest.cc
Added Cxx compiler flag -EHsc
          Trying Cxx compiler flag -Z7
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc -Z7
conftest.cc
Added Cxx compiler flag -Z7
          Trying Cxx compiler flag -Zm200
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc -Z7 -Zm200
conftest.cc
Added Cxx compiler flag -Zm200
              Defined make macro "FC_VERSION" to "Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000"
                Defined make macro "MPIFC_SHOW" to "Unavailable"
          Trying FC compiler flag -MD
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -MD
          Trying FC compiler flag -Z7
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -Z7   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
              Output from compiling with  -MD -Z7
Added FC compiler flag -Z7
TESTING: checkIntelHardwareSupport from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:173)
  Use Linux/MacOS commands to determine what operations the hardware supports
Executing: lscpu
Executing: sysctl -a
TESTING: checkCompilerMacros from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:164)
  Save the list of CPP macros defined by the C and C++ compiler, does not work for all compilers
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilerFlags  -MD -wd4996 -Z7  /tmp/petsc-v6m0e0sk/config.compilerFlags/conftest.c  -E -dM
stdout:
cl : Command line warning D9002 : ignoring unknown option '-dM'
conftest.c
#line 1 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.COM\\conftest.c"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilerFlags  -MD -GR -EHsc -Z7 -Zm200   /tmp/petsc-v6m0e0sk/config.compilerFlags/conftest.cc  -E -dM
stdout:
conftest.cc
#line 1 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.COM\\conftest.cc"
    child config.compilerFlags 25.690012
stdout:
<win32fe options>:
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1429)
  Check for -std=c99 or equivalent flag
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
    for (int i=0; i<2; i++){
      x[i] = i*j*y;
  return 0;
conftest.c
          Accepted C99 compile flag:
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:158)
  Check for the C/CXX restrict keyword
===== Checking compiler
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.compilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
float * __restrict x;;
  return 0;
          compilers: Set C restrict keyword to __restrict
            Defined "C_RESTRICT" to "__restrict"
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:413)
  Activate format string checking if using the GNU compilers
TESTING: checkCInline from config.compilers(config/BuildSystem/config/compilers.py:128)
  Check for C inline keyword
stdout: conftest.c
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
          compilers: Set C Inline keyword to inline
            Defined "C_INLINE" to "inline"
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:424)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:222)
  Determines the libraries needed to link with C compiled code
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void asub(void)
{char s[16];printf("testing %s",s);}
===== Checking linker
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -Z7  /tmp/petsc-v6m0e0sk/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
 Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.exe    -MD -Z7 /tmp/petsc-v6m0e0sk/config.compilers/conftest.o /tmp/petsc-v6m0e0sk/config.compilers/confc.o
          C libraries are not needed when using Fortran linker
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void asub(void)
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   /tmp/petsc-v6m0e0sk/config.compilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
 int main(int argc,char **args)
{return 0;}
 Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.exe    -MD -GR -EHsc -Z7 -Zm200 /tmp/petsc-v6m0e0sk/config.compilers/conftest.o /tmp/petsc-v6m0e0sk/config.compilers/confc.o
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~2.COM\conftest.exe not found or not built by the last incremental link; performing full link
Linker output after filtering:
          C libraries are not needed when using C++ linker
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1380)
  Check if -MMD works for dependency generation, and add it if it does
          Trying C compiler flag -MMD -MP
          Rejected C compiler flag -MMD -MP
          Trying C compiler flag -xMMD
          Rejected C compiler flag -xMMD
          Trying C compiler flag -qmakedep=gcc
          Rejected C compiler flag -qmakedep=gcc
          Rejected C compiler flag -MD because no dependency file (/tmp/petsc-v6m0e0sk/config.setCompilers/conftest.d) was generated
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7 -MMD -MP   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-MMD'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -MD -wd4996 -Z7 -MMD -MP
conftest.c
            Rejecting compiler flag -MMD -MP due to
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7 -MMD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejecting compiler flag -MMD due to
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7 -xMMD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-xMMD'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -MD -wd4996 -Z7 -xMMD
conftest.c
            Rejecting compiler flag -xMMD due to
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7 -qmakedep=gcc   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-qmakedep=gcc'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -MD -wd4996 -Z7 -qmakedep=gcc
conftest.c
            Rejecting compiler flag -qmakedep=gcc due to
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7 -MD   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -MD -wd4996 -Z7 -MD
conftest.c
          Trying Cxx compiler flag -MMD -MP
          Rejected Cxx compiler flag -MMD -MP
          Trying Cxx compiler flag -xMMD
          Rejected Cxx compiler flag -xMMD
          Trying Cxx compiler flag -qmakedep=gcc
          Rejected Cxx compiler flag -qmakedep=gcc
          Rejected Cxx compiler flag -MD because no dependency file (/tmp/petsc-v6m0e0sk/config.setCompilers/conftest.d) was generated
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200  -MMD -MP  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -MMD -MP
conftest.cc
conftest.cc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200  -MMD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
conftest.cc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200  -xMMD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -xMMD
conftest.cc
conftest.cc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200  -qmakedep=gcc  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Output from compiling with  -qmakedep=gcc
conftest.cc
conftest.cc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -GR -EHsc -Z7 -Zm200  -MD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
stdout:
<win32fe options>:
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   /tmp/petsc-v6m0e0sk/config.compilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
          compilers: Set Cxx restrict keyword to __restrict
            Defined "CXX_RESTRICT" to "__restrict"
TESTING: checkCxxDialect from config.compilers(config/BuildSystem/config/compilers.py:471)
  Determine the CXX dialect supported by the compiler(language) [and correspoding compiler option - if any].
    isGNU indicates if the compiler is g++.
    -with-<lang>-dialect can take options:
      auto: use highest dialect configure can determine
      cxx17: [future?]
      cxx14: gnu++14 or c++14
      cxx11: gnu++11 or c++11
      0: disable CxxDialect check and use compiler default
          checkCxxDialect: checking CXX14 for Cxx with flag:
            Defined "HAVE_CXX_DIALECT_CXX14" to "1"
            Defined "HAVE_CXX_DIALECT_CXX11" to "1"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
          #include <random>
          #include <iostream>
          #include <complex>
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
          const double x = dist(mt);
          std::cout << x;
          constexpr std::complex<double> I(0.0,1.0);
          auto lambda = [](auto x, auto y) {return x + y;};
          return lambda(3,4) + (int)std::real(I);
  return 0;
conftest.cc
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:443)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.c(5): error C2065: 'class': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.c(5): error C2146: syntax error: missing ';' before identifier 'somename'
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.c(5): error C2065: 'somename': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.c(5): error C2143: syntax error: missing ';' before '{'
Possible ERROR while running compiler: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.c(5): error C2143: syntax error: missing ';' before '{'Source:
int main() {
class somename { int i; };;
  return 0;
conftest.c
PETSc Error: No output file produced
              Rejecting compiler flag   due to nonzero status from link
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200  -+     /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-+'
conftest.c
stdout:
conftest.c
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc -Z7 -Zm200  -+
conftest.c
              Rejecting compiler flag -+  due to nonzero status from link
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200  -x cxx -tlocal     /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: Error: win32fe: Input File Not Found: D:\wtay\DOWNLO~1\SOURCE~1\petsc\cxx
Possible ERROR while running compiler: exit code 127
stdout:
Error: win32fe: Input File Not Found: D:\wtay\DOWNLO~1\SOURCE~1\petsc\cxxSource:
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc -Z7 -Zm200  -x cxx -tlocal
              Rejecting compiler flag -x cxx -tlocal  due to nonzero status from link
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200  -Kc++     /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-Kc++'
conftest.c
stdout:
conftest.c
int main() {
  return 0;
              Output from compiling with  -MD -GR -EHsc -Z7 -Zm200  -Kc++
conftest.c
              Rejecting compiler flag -Kc++  due to nonzero status from link
conftest.c
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   -x c++    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: Error: win32fe: Input File Not Found: D:\wtay\DOWNLO~1\SOURCE~1\petsc\c++
stdout:
Error: win32fe: Input File Not Found: D:\wtay\DOWNLO~1\SOURCE~1\petsc\c++Source:
int main() {
  return 0;
              Output from compiling with  -x c++
              Rejecting compiler flag -x c++  due to nonzero status from link
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   -TP    /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Output from compiling with  -TP
conftest.c
Added Cxx compiler flag -TP
TESTING: checkCxxInline from config.compilers(config/BuildSystem/config/compilers.py:143)
  Check for C++ inline keyword
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   -TP   /tmp/petsc-v6m0e0sk/config.compilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
          compilers: Set Cxx Inline keyword to inline
            Defined "CXX_INLINE" to "inline"
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:566)
  Determines the libraries needed to link with C++ from C and Fortran
stdout: conftest.cc
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
{std::vector<int> v;
try  { throw 20;  }  catch (int e)  { std::cout << "An exception occurred";  }}
stdout: conftest.c
Successful compile:
Source:
{return 0;}
 Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.compilers/conftest.o /tmp/petsc-v6m0e0sk/config.compilers/confc.o
          C++ libraries are not needed when using C linker
stdout: conftest.cc
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
          C++ libraries are not needed when using FC linker
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:873)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
stdout: conftest.c
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
stdout:
conftest.obj : error LNK2019: unresolved external symbol D1CHK referenced in function MAIN__
C:\cygwin64\tmp\PETSC-~2\CONFIG~2.COM\conftest.exe : fatal error LNK1120: 1 unresolved externals
Possible ERROR while running linker: exit code 96
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~2.COM\conftest.exe : fatal error LNK1120: 1 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~2.COM\conftest.exe : fatal error LNK1120: 1 unresolved externals:
Testing Fortran mangling type unchanged with code void d1chk(void){return;}
stdout: conftest.c
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
stdout:
stdout:
Testing Fortran mangling type caps with code void D1CHK(void){return;}
stdout: conftest.c
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
          compilers: Fortran name mangling is caps
            Defined "HAVE_FORTRAN_CAPS" to "1"
stdout:
            Defined "FORTRAN_CHARLEN_T" to "int"
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:911)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
stdout: conftest.c
Successful compile:
Source:
void d1_chk__(void){return;}
Successful compile:
Source:
      program main
       call d1_chk()
      end
stdout:
conftest.obj : error LNK2019: unresolved external symbol D1_CHK referenced in function MAIN__
stdout:
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:921)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~2.COM\conftest.F90(2): warning #5117: Bad # preprocessor line
#include <mpif.h>
Successful compile:
Source:
      program main
#include <mpif.h>
      call MPI_Allreduce()
      end
stdout:
conftest.obj : error LNK2019: unresolved external symbol MPI_ALLREDUCE referenced in function MAIN__
stdout:
Successful compile:
Source:
      subroutine asub()
      print*,'testing'
      return
      end
stdout: conftest.c
Successful compile:
Source:
 extern void ASUB(void);
  ASUB();
  return 0;
          Fortran libraries are not needed when using C linker
Successful compile:
Source:
      subroutine asub()
      print*,'testing'
      return
      end
stdout: conftest.cc
Successful compile:
Source:
  ASUB();
  return 0;
stdout:
conftest.obj : error LNK2019: unresolved external symbol "void __cdecl ASUB(void)" (?ASUB@@YAXXZ) referenced in function main
Possible ERROR while running linker: exit code 2
stdout:
          Fortran code cannot directly be linked with C++ linker, therefore will determine needed Fortran libraries
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.exe  -v   -MD -Z7 /tmp/petsc-v6m0e0sk/config.compilers/conftest.o
stdout: ifort: command line warning #10006: ignoring unknown option '/v'
          compilers: Checking arg ifort:
          compilers: Unknown arg ifort:
          compilers: Checking arg command
          compilers: Unknown arg command
          compilers: Checking arg line
          compilers: Unknown arg line
          compilers: Checking arg warning
          compilers: Unknown arg warning
          compilers: Checking arg #10006:
          compilers: Unknown arg #10006:
          compilers: Checking arg ignoring
          compilers: Unknown arg ignoring
          compilers: Checking arg unknown
          compilers: Unknown arg unknown
          compilers: Checking arg option
          compilers: Unknown arg option
          compilers: Libraries needed to link Fortran code with the C linker: []
          compilers: Libraries needed to link Fortran main with the C linker: []
          compilers: Check that Fortran libraries can be used with C as the linker
LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.exe not found or not built by the last incremental link; performing full link
LINK : fatal error LNK1104: cannot open file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
LINK : fatal error LNK1104: cannot open file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib':
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o   -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
stdout:
LINK : fatal error LNK1104: cannot open file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'======== Checking running linked program
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Testing executable /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe to see if it can be run
Executing: /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe
Running Executable with threads to time it out at 60
          compilers: Check that Fortran libraries can be used with C++ as linker
          compilers: Fortran libraries can be used from C++
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers  -MD -GR -EHsc -Z7 -Zm200   -TP   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    -MD -GR -EHsc -Z7 -Zm200  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.SET\conftest.exe not found or not built by the last incremental link; performing full link
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.exe    -MD -GR -EHsc -Z7 -Zm200  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o   -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
stdout:
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1345)
  Check that Fortran can link C++ libraries
stdout: conftest.cc
Successful compile:
Source:
extern "C" void D1CHK(void);
void foo(void){D1CHK();}
stdout: conftest.cc
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.compilers/conftest.exe    -MD -Z7 /tmp/petsc-v6m0e0sk/config.compilers/conftest.o /tmp/petsc-v6m0e0sk/config.compilers/cxxobj.o  /tmp/petsc-v6m0e0sk/config.compilers/confc.o
          compilers: Fortran can link C++ functions
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1506)
    child config.compilers 97.524887
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:17)
  Determine if Apple ^close syntax is supported in C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.closure/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.utilities.closure/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CLO\conftest.c(6): error C2059: syntax error: '^'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CLO\conftest.c(6): error C2059: syntax error: '^'Source:
#include <stdio.h>
int main() {
int (^closure)(int);;
  return 0;
              Compile failed inside link
    child config.utilities.closure 1.259501
TESTING: checkFortranTypeSizes from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:56)
  Check whether real*8 is supported and suggest flags which will allow support
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7  /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.F90
Successful compile:
Source:
      program main
      real*8 variable
      end
TESTING: checkFortranPreprocessor from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:73)
  Determine if Fortran handles preprocessing properly
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -Z7 -fpp   /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
              Output from compiling with  -MD -Z7 -fpp
Added FC compiler flag -fpp
          compilers: Fortran uses -fpp preprocessor
TESTING: checkFortranDefineCompilerOption from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:96)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -I/tmp/petsc-v6m0e0sk/config.setCompilers  -MD -Z7 -fpp -DTesting  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
            Output from compiling with  -MD -Z7 -fpp -DTesting
            Defined make macro "FC_DEFINE_FLAG" to "-D"
          compilers: Fortran uses -D for defining macro
TESTING: checkFortran90 from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:146)
  Determine whether the Fortran compiler handles F90
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp  /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.F90
Successful compile:
Source:
      program main
        REAL(KIND=SELECTED_REAL_KIND(10)) d
        INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
        INTEGER (KIND=int) :: ierr
        ierr = 1
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.exe    -MD -Z7 -fpp /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o
          Fortran compiler supports F90
TESTING: checkFortran90FreeForm from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:162)
  Determine whether the Fortran compiler handles F90FreeForm
       We also require that the compiler handles lines longer than 132 characters
Successful compile:
Source:
      program main
      INTEGER, PARAMETER ::        int = SELECTED_INT_KIND(8);              INTEGER (KIND=int) :: ierr;       ierr                            =        1
      end
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~3.COM\conftest.exe not found or not built by the last incremental link; performing full link
            Defined "USING_F90FREEFORM" to "1"
          Fortran compiler supports F90FreeForm
TESTING: checkFortran2003 from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:176)
  Determine whether the Fortran compiler handles F2003
Successful compile:
Source:
      module Base_module
        type, public :: base_type
           integer :: A
         contains
           procedure, public :: Print => BasePrint
        end type base_type
      contains
        subroutine BasePrint(this)
          class(base_type) :: this
        end subroutine BasePrint
      end module Base_module
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
            Defined "USING_F2003" to "1"
          Fortran compiler supports F2003
TESTING: checkFortran90Array from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:211)
  Check for F90 array interfaces
Executing: uname -s
stdout: CYGWIN_NT-10.0
Detected Cygwin
          Cygwin detected: ignoring HAVE_F90_2PTR_ARG test
TESTING: checkFortran90AssumedType from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:298)
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -qversion
stdout:
ifort: command line warning #10006: ignoring unknown option '/qversion'
TESTING: checkFortranModuleInclude from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:303)
  Figures out what flag is used to specify the include path for Fortran modules
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -I/tmp/petsc-v6m0e0sk/config.compilersFortran/confdir  -MD -Z7 -fpp  /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.F90
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.exe   -I/tmp/petsc-v6m0e0sk/config.compilersFortran/confdir  -MD -Z7 -fpp /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o /tmp/petsc-v6m0e0sk/config.compilersFortran/configtest.o
          compilers: Fortran module include flag -I found
TESTING: checkFortranModuleOutput from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:369)
  Figures out what flag is used to specify the output path for Fortran modules
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -module /tmp/petsc-v6m0e0sk/config.compilersFortran/confdir  -MD -Z7 -fpp  /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.F90
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module  compile failed
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -module:/tmp/petsc-v6m0e0sk/config.compilersFortran/confdir  -MD -Z7 -fpp  /tmp/petsc-v6m0e0sk/config.compilersFortran/conftest.F90
Successful compile:
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module: found
TESTING: checkFortranTypeStar from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:135)
  Determine whether the Fortran compiler handles type(*)
Successful compile:
Source:
      program main
      interface
      subroutine a(b)
      type(*) :: b(:)
      end subroutine
      end interface
      end
            Defined "HAVE_FORTRAN_TYPE_STAR" to "1"
          Fortran compiler supports type(*)
TESTING: checkFortranTypeInitialize from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:125)
  Determines if PETSc objects in Fortran are initialized by default (doesn't work with common blocks)
            Defined "FORTRAN_TYPE_INITIALIZE" to " = -2"
          Initializing Fortran objects
TESTING: configureFortranFlush from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:116)
Successful compile:
Source:
      program main
      call flush(6)
      end
            Defined "HAVE_FORTRAN_FLUSH" to "1"
TESTING: checkDependencyGenerationFlag from config.compilersFortran(config/BuildSystem/config/compilersFortran.py:414)
          Trying FC compiler flag -MMD -MP
          Rejected FC compiler flag -MMD -MP
          Trying FC compiler flag -xMMD
          Rejected FC compiler flag -xMMD
          Trying FC compiler flag -qmakedep=gcc
          Rejected FC compiler flag -qmakedep=gcc
          Rejected FC compiler flag -MD because no dependency file (/tmp/petsc-v6m0e0sk/config.setCompilers/conftest.d) was generated
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp -MMD -MP  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/MMD'
Successful compile:
Source:
      program main
      end
            Output from compiling with  -MD -Z7 -fpp -MMD -MP
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp -MMD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp -xMMD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/xMMD'
Successful compile:
Source:
      program main
      end
            Output from compiling with  -MD -Z7 -fpp -xMMD
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp -qmakedep=gcc  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/qmakedep=gcc'
Successful compile:
Source:
      program main
      end
            Output from compiling with  -MD -Z7 -fpp -qmakedep=gcc
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran  -MD -Z7 -fpp -MD  /tmp/petsc-v6m0e0sk/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
            Output from compiling with  -MD -Z7 -fpp -MD
    child config.compilersFortran 44.263276
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.headers/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.headers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Preprocessing source:
#include <string.h>
#include <stdlib.h>
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.headers/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.headers/conftest.o
Testing executable /tmp/petsc-v6m0e0sk/config.headers/conftest.exe to see if it can be run
Executing: /tmp/petsc-v6m0e0sk/config.headers/conftest.exe
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(5): fatal error C1083: Cannot open include file: 'sys/wait.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(5): fatal error C1083: Cannot open include file: 'sys/wait.h': No such file or directorySource:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
#include <time.h>
Preprocess output before filtering:
Preprocess output after filtering:
              Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
#include <sys/time.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/time.h': No such file or directory
#line 23 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
Source:
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:201)
  Checks for the math headers and defines
Checking for header: math.h
#include <math.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(6): error C2065: 'M_PI': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(6): error C2065: 'M_PI': undeclared identifierSource:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
stdout: conftest.c
Successful compile:
Source:
#define _USE_MATH_DEFINES 1
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
            Defined "_USE_MATH_DEFINES" to "1"
          Activated Windows math #defines, like M_PI
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: setjmp.h
#include <setjmp.h>
            Defined "HAVE_SETJMP_H" to "1"
Checking for header: dos.h
#include <dos.h>
            Defined "HAVE_DOS_H" to "1"
Checking for header: fcntl.h
#include <fcntl.h>
            Defined "HAVE_FCNTL_H" to "1"
Checking for header: float.h
#include <float.h>
            Defined "HAVE_FLOAT_H" to "1"
Checking for header: io.h
#include <io.h>
            Defined "HAVE_IO_H" to "1"
Checking for header: malloc.h
#include <malloc.h>
            Defined "HAVE_MALLOC_H" to "1"
Checking for header: pwd.h
#include <pwd.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'pwd.h': No such file or directory
#line 30 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
Source:
#include <pwd.h>
Checking for header: strings.h
#include <strings.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'strings.h': No such file or directory
Source:
Checking for header: unistd.h
#include <unistd.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directory
Source:
#include <unistd.h>
Checking for header: sys/sysinfo.h
#include <sys/sysinfo.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/sysinfo.h': No such file or directory
Source:
Checking for header: machine/endian.h
#include <machine/endian.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'machine/endian.h': No such file or directory
Source:
Checking for header: sys/param.h
#include <sys/param.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/param.h': No such file or directory
Source:
Checking for header: sys/procfs.h
#include <sys/procfs.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/procfs.h': No such file or directory
Source:
Checking for header: sys/resource.h
#include <sys/resource.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/resource.h': No such file or directory
Source:
Checking for header: sys/systeminfo.h
#include <sys/systeminfo.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/systeminfo.h': No such file or directory
Source:
Checking for header: sys/times.h
#include <sys/times.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/times.h': No such file or directory
Source:
Checking for header: sys/utsname.h
#include <sys/utsname.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/utsname.h': No such file or directory
Source:
Checking for header: sys/socket.h
#include <sys/socket.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/socket.h': No such file or directory
Source:
Checking for header: sys/wait.h
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/wait.h': No such file or directory
Source:
Checking for header: netinet/in.h
#include <netinet/in.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'netinet/in.h': No such file or directory
Source:
Checking for header: netdb.h
#include <netdb.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'netdb.h': No such file or directory
Source:
#include <netdb.h>
Checking for header: direct.h
#include <direct.h>
            Defined "HAVE_DIRECT_H" to "1"
#include <time.h>
Checking for header: Ws2tcpip.h
#include <Ws2tcpip.h>
            Defined "HAVE_WS2TCPIP_H" to "1"
Checking for header: sys/types.h
            Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: WindowsX.h
#include <WindowsX.h>
            Defined "HAVE_WINDOWSX_H" to "1"
#include <float.h>
Checking for header: ieeefp.h
#include <ieeefp.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'ieeefp.h': No such file or directory
#line 34 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
Source:
#include <ieeefp.h>
Checking for header: stdint.h
#include <stdint.h>
            Defined "HAVE_STDINT_H" to "1"
Checking for header: pthread.h
#include <pthread.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'pthread.h': No such file or directory
#line 35 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
Source:
Checking for header: inttypes.h
#include <inttypes.h>
            Defined "HAVE_INTTYPES_H" to "1"
Checking for header: immintrin.h
#include <immintrin.h>
            Defined "HAVE_IMMINTRIN_H" to "1"
Checking for header: zmmintrin.h
#include <zmmintrin.h>
stdout:
conftest.c
C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\zmmintrin.h(18): fatal error C1189: #error:  "Header should only be included from <immintrin.h>."
#line 37 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\zmmintrin.h"
Source:
#include <setjmp.h>
#include <dos.h>
#include <fcntl.h>
#include <float.h>
#include <io.h>
#include <malloc.h>
#include <pwd.h>
stdout:
conftest.c
Source:
#include <pwd.h>
stdout:
conftest.c
Source:
#include <unistd.h>
stdout:
conftest.c
Source:
#include <unistd.h>
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
#include <netdb.h>
stdout:
conftest.c
Source:
#include <netdb.h>
#include <direct.h>
#include <time.h>
#include <float.h>
#include <ieeefp.h>
stdout:
conftest.c
Source:
#include <ieeefp.h>
#include <stdint.h>
stdout:
conftest.c
Source:
stdout:
conftest.c
Source:
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:216)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
stdout: conftest.c
Successful compile:
Source:
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
    child config.headers 81.592022
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.utilities.cacheDetails/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.c(3): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.c(3): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directorySource:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.c(4): warning C4047: 'initializing': 'FILE *' differs in levels of indirection from 'int'
Successful compile:
Source:
#include <stdio.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val=-1; FILE *f = popen("getconf LEVEL1_DCACHE_LINESIZE","r"); fscanf(f,"%ld",&val); pclose(f); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.c(5): warning C4047: 'initializing': 'FILE *' differs in levels of indirection from 'int'
Successful compile:
Source:
#include <stdio.h>
#include <stdio.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.utilities.cacheDetails/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.utilities.cacheDetails/conftest.o
stdout:
conftest.obj : error LNK2019: unresolved external symbol popen referenced in function getconf_LEVEL1_DCACHE_LINESIZE
conftest.obj : error LNK2019: unresolved external symbol pclose referenced in function getconf_LEVEL1_DCACHE_LINESIZE
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.exe : fatal error LNK1120: 2 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.exe : fatal error LNK1120: 2 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.CAC\conftest.exe : fatal error LNK1120: 2 unresolved externals:
Could not determine LEVEL1_DCACHE_LINESIZE, using default 32
            Defined "LEVEL1_DCACHE_LINESIZE" to "32"
    child config.utilities.cacheDetails 5.147611
TESTING: check_struct_sigaction from config.types(config/BuildSystem/config/types.py:42)
  Checks if "struct sigaction" exists in signal.h. This check is for C89 check.
Checking for type: struct sigaction
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.types/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.types/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2079: 'a' uses undefined struct 'sigaction'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2079: 'a' uses undefined struct 'sigaction'Source:
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
int main() {
struct sigaction a;;
  return 0;
struct sigaction found
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:48)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
__int64 a;;
  return 0;
__int64 found
            Defined "HAVE___INT64" to "1"
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:54)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
size_t a;;
  return 0;
size_t found
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:64)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2065: 'mode_t': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2146: syntax error: missing ';' before identifier 'a'
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2065: 'a': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2065: 'a': undeclared identifierSource:
#include <stdlib.h>
#include <stddef.h>
int main() {
mode_t a;;
  return 0;
              Typedefed "int" to "mode_t"
Checking for type: off_t
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
off_t a;;
  return 0;
off_t found
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:59)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2065: 'int32_t': undeclared identifier
stdout:
conftest.c
#include <stdlib.h>
#include <stddef.h>
int main() {
int32_t a;;
  return 0;
              Typedefed "int" to "int32_t"
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:70)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(11): error C2065: 'pid_t': undeclared identifier
stdout:
conftest.c
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
#include <stddef.h>
int main() {
pid_t a;;
  return 0;
              Typedefed "int" to "pid_t"
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:74)
  Checks for uid_t and gid_t, and defines them if necessary
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types   /tmp/petsc-v6m0e0sk/config.types/conftest.c
            Defined "uid_t" to "int"
            Defined "gid_t" to "int"
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:81)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
stdout:
conftest.c
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\complex.h(30): fatal error C1189: #error:  "This Intel <complex.h> is for use with only the Intel compilers!"
stdout:
conftest.c
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\complex.h(30): fatal error C1189: #error:  "This Intel <complex.h> is for use with only the Intel compilers!"Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:92)
  Check for complex numbers in namespace std
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.types/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.types  -MD -GR -EHsc -Z7 -Zm200   -TP   /tmp/petsc-v6m0e0sk/config.types/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.types/conftest.exe    -MD -GR -EHsc -Z7 -Zm200  /tmp/petsc-v6m0e0sk/config.types/conftest.o
            Defined "HAVE_CXX_COMPLEX" to "1"
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:103)
  Checks for working const, and if not found defines it to empty string
stdout:
conftest.c
c:\cygwin64\tmp\petsc-v6m0e0sk\config.types\conftest.c(30) : warning C4700: uninitialized local variable 't' used
c:\cygwin64\tmp\petsc-v6m0e0sk\config.types\conftest.c(46) : warning C4700: uninitialized local variable 'b' used
Successful compile:
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
      struct s *b; b->j = 5;
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:159)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: void *
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(void *)==8)*2-1];
            Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(short)==2)*2-1];
            Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(int)==4)*2-1];
            Defined "SIZEOF_INT" to "4"
Checking for size of type: long
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(8): error C2118: negative subscript
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(8): error C2118: negative subscriptSource:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(long)==8)*2-1];
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(long)==4)*2-1];
            Defined "SIZEOF_LONG" to "4"
Checking for size of type: long long
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(long long)==8)*2-1];
            Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: enum
===== Checking compiler
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(8): warning C4116: unnamed type definition in parentheses
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(enum{ENUM_DUMMY})==4)*2-1];
            Defined "SIZEOF_ENUM" to "4"
Checking for size of type: size_t
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(size_t)==8)*2-1];
            Defined "SIZEOF_SIZE_T" to "8"
        Defined "USING_64BIT_PTR" to "1"
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:193)
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(5): error C2143: syntax error: missing ';' before 'type'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.c(5): error C2143: syntax error: missing ';' before 'type'Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
  return 0;
Cannot use visibility attributes with C===== Checking compiler
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.cc(5): error C3861: 'visibility': identifier not found
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.cc(5): error C3861: '__attribute__': identifier not found
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.cc(5): error C2144: syntax error: 'int' should be preceded by ';'
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.TYP\conftest.cc(5): error C2144: syntax error: 'int' should be preceded by ';'Source:
int main() {
  return 0;
Cannot use visibility attributes with C++          =============================================================================================
TESTING: checkMaxPathLen from config.types(config/BuildSystem/config/types.py:215)
Determining PETSC_MAX_PATH_LEN
stdout: conftest.c
Successful compile:
Source:
#if defined(MAXPATHLEN)
#  define PETSC_MAX_PATH_LEN MAXPATHLEN
#elif defined(MAX_PATH)
#  define PETSC_MAX_PATH_LEN MAX_PATH
#elif defined(_MAX_PATH)
#  define PETSC_MAX_PATH_LEN _MAX_PATH
#else
#  define PETSC_MAX_PATH_LEN 4096
#endif
#define xstr(s) str(s)
#define str(s) #s
char petsc_max_path_len[] = xstr(PETSC_MAX_PATH_LEN);
int main() {
  return 0;
#else
#endif
#define str(s) #s
            Defined "MAX_PATH_LEN" to "4096"
    child config.types 35.415726
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:29)
  Choose alignment
            Defined "MEMALIGN" to "16"
          Memory alignment is 16
    child PETSc.options.memAlign 0.015666
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:157)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            Checking for functions [handle_sigfpes] in library ['fpe'] []
===== Checking linker
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.libraries  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.libraries/conftest.c
stdout: conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  -lfpe
stdout: LINK : fatal error LNK1104: cannot open file 'libfpe.lib'
stdout:
LINK : fatal error LNK1104: cannot open file 'libfpe.lib'Linker output before filtering:
Linker output after filtering:
LINK : fatal error LNK1104: cannot open file 'libfpe.lib':
            Checking for functions [socket] in library ['socket', 'nsl'] []
stdout: conftest.c
Successful compile:
Source:
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  -lsocket -lnsl
stdout: LINK : fatal error LNK1104: cannot open file 'libsocket.lib'
stdout:
LINK : fatal error LNK1104: cannot open file 'libsocket.lib'Linker output before filtering:
LINK : fatal error LNK1104: cannot open file 'libsocket.lib':
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout:
stdout: conftest.c
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
stdout:
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:264)
  Check for sin() in libm, the math library
            Checking for functions [sin floor log10 pow] in library [''] []
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
double sin(double);
static void _check_sin() { double x,y; scanf("%lf",&x); y = sin(x); printf("%f",y);
#include <stdio.h>
double floor(double);
static void _check_floor() { double x,y; scanf("%lf",&x); y = floor(x); printf("%f",y);
#include <stdio.h>
double log10(double);
static void _check_log10() { double x,y; scanf("%lf",&x); y = log10(x); printf("%f",y);
#include <stdio.h>
double pow(double, double);
static void _check_pow() { double x,y; scanf("%lf",&x); y = pow(x,x); printf("%f",y);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
          CheckMath: using math library []
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:283)
  Check for erf() in libm, the math library
            Checking for functions [erf] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
static void _check_erf() { double (*checkErf)(double) = erf;double x = 0,y; y = (*checkErf)(x); }
int main() {
_check_erf();;
  return 0;
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe not found or not built by the last incremental link; performing full link
          erf() found
            Defined "HAVE_ERF" to "1"
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:292)
  Check for tgamma() in libm, the math library
            Checking for functions [tgamma] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
static void _check_tgamma() { double (*checkTgamma)(double) = tgamma;double x = 0,y; y = (*checkTgamma)(x); }
int main() {
_check_tgamma();;
  return 0;
          tgamma() found
            Defined "HAVE_TGAMMA" to "1"
TESTING: checkMathLgamma from config.libraries(config/BuildSystem/config/libraries.py:301)
  Check for lgamma() in libm, the math library
            Checking for functions [lgamma] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
#include <stdlib.h>
static void _check_lgamma() { double (*checkLgamma)(double) = lgamma;double x = 1,y; y = (*checkLgamma)(x);if (y != 0.) abort(); }
int main() {
_check_lgamma();;
  return 0;
          lgamma() found
            Defined "HAVE_LGAMMA" to "1"
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:314)
  Checks if <fenv.h> can be used with FE_DFL_ENV
            Checking for functions [fesetenv] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
            Defined "HAVE_FENV_H" to "1"
TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:322)
  Check for log2() in libm, the math library
            Checking for functions [log2] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
static void _check_log2() { double (*checkLog2)(double) = log2; double x = 2.5, y = (*checkLog2)(x); }
int main() {
_check_log2();;
  return 0;
          log2() found
            Defined "HAVE_LOG2" to "1"
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:331)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
            Checking for functions [clock_gettime] in library [''] []
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.c(5): error C2065: 'CLOCK_REALTIME': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.c(5): error C2065: 'CLOCK_REALTIME': undeclared identifierSource:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
            Checking for functions [clock_gettime] in library ['rt'] []
stdout:
conftest.c
stdout:
conftest.c
#include <time.h>
int main() {
  return 0;
          Warning: No realtime library found
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:347)
  Check for the header and libraries necessary for dynamic library manipulation
            Checking for functions [dlopen] in library ['dl'] []
stdout: conftest.c
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  -ldl
stdout:
LINK : fatal error LNK1104: cannot open file 'libdl.lib'
stdout:
LINK : fatal error LNK1104: cannot open file 'libdl.lib'Linker output before filtering:
LINK : fatal error LNK1104: cannot open file 'libdl.lib':
Checking for header: dlfcn.h
#include <dlfcn.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types   /tmp/petsc-v6m0e0sk/config.headers/conftest.c
Possible ERROR while running preprocessor: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'dlfcn.h': No such file or directory
#line 1 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 57 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 2 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
typedef int mode_t;
typedef int int32_t;
typedef int pid_t;
#line 11 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 12 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 13 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 3 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
Source:
#include <dlfcn.h>
    child config.libraries 30.889327
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:38)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE, PETSC_USE_FORTRAN_KERNELS, and PETSC_USE_AVX512_KERNELS
            Defined "USE_LOG" to "1"
            Defined "USE_DEBUG" to "1"
            Defined "USE_INFO" to "1"
            Defined "USE_CTABLE" to "1"
conftest.obj : error LNK2019: unresolved external symbol bgl_perfctr_void referenced in function _check_bgl_perfctr_void
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals:
conftest.obj : error LNK2019: unresolved external symbol ADIOI_BGL_Open referenced in function _check_ADIOI_BGL_Open
            Defined "USE_BACKWARD_LOOP" to "1"
            **********Checking if running on BGL/IBM detected
              Checking for functions [bgl_perfctr_void] in library [''] []
stdout: conftest.c
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
stdout:
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals              Checking for functions [ADIOI_BGL_Open] in library [''] []
stdout: conftest.c
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
stdout:
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals            *********BGL/IBM test failure
            Defined "USE_AVX512_KERNELS" to "1"
            Defined "Alignx(a,b)" to "  "
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:99)
  Sets PETSC_IS_COLORING_VALUE_TYPE, PETSC_MPIU_IS_COLORING_VALUE_TYPE, and PETSC_IS_COLORING_MAX as required by ISColoring
            Defined "MPIU_IS_COLORING_VALUE_TYPE" to "MPI_UNSIGNED_SHORT"
            Defined "IS_COLORING_MAX" to "USHRT_MAX"
            Defined "IS_COLORING_VALUE_TYPE" to "short"
            Defined "IS_COLORING_VALUE_TYPE_F" to "integer2"
    child PETSc.options.libraryOptions 4.753476
    child config.atomics 0.000006
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:106)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.functions/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.functions  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.functions/conftest.c
stdout: conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.functions/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.functions/conftest.o
stdout:
conftest.obj : error LNK2019: unresolved external symbol sysinfo referenced in function main
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 1 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 1 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 1 unresolved externals:
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:125)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
stdout:
conftest.c
c:\cygwin64\tmp\petsc-v6m0e0sk\config.functions\conftest.c(8) : warning C4700: uninitialized local variable 'Argp' used
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:131)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
stdout:
conftest.c
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe not found or not built by the last incremental link; performing full link
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:137)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
stdout:
conftest.c
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
            Defined "HAVE_VSNPRINTF" to "1"
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:167)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
stdout: conftest.c
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
stdout:
conftest.obj : error LNK2019: unresolved external symbol nanosleep referenced in function main
stdout:
TESTING: checkMemmove from config.functions(config/BuildSystem/config/functions.py:173)
  Check for functional memmove() - as MS VC requires correct includes to for this test
stdout: conftest.c
Successful compile:
Source:
#include <string.h>
int main() {
 char c1[1], c2[1] = "c";
 size_t n=1;
 memmove(c1,c2,n);
  return 0;
            Defined "HAVE_MEMMOVE" to "1"
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:143)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.functions/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions  -MD -GR -EHsc -Z7 -Zm200   -TP   /tmp/petsc-v6m0e0sk/config.functions/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.functions/conftest.exe    -MD -GR -EHsc -Z7 -Zm200  /tmp/petsc-v6m0e0sk/config.functions/conftest.o
            Defined "SIGNAL_CAST" to " "
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:153)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.c(6): error C2120: 'void' illegal with all types
Possible ERROR while running compiler: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.c(6): error C2120: 'void' illegal with all typesSource:
#include <stdlib.h>
int main() {
int ierr; void *p; ierr = free(p); return 0;
  return 0;
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:159)
  Checks whether the variable argument list functionality is working
stdout:
conftest.c
c:\cygwin64\tmp\petsc-v6m0e0sk\config.functions\conftest.c(7) : warning C4700: uninitialized local variable 'l2' used
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
            Defined "HAVE_VA_COPY" to "1"
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:85)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [lseek rand realpath sleep uname _lseek gethostbyname socket dlclose _pipe dlerror drand48 memalign _sleep time _mkdir popen dlsym getwd usleep getcwd bzero strcasecmp snprintf access getdomainname sbreak _getcwd fpsetsticky dlopen _set_output_format clock gethostname fork fpresetsticky _snprintf PXFGETARG getpagesize readlink stricmp getrusage _access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
char rand();
char realpath();
char sleep();
char uname();
char _lseek();
char gethostbyname();
char socket();
char dlclose();
char _pipe();
char dlerror();
char drand48();
char memalign();
char _sleep();
char time();
char _mkdir();
char popen();
char dlsym();
char getwd();
char usleep();
char getcwd();
char bzero();
char strcasecmp();
char snprintf();
char access();
char getdomainname();
char sbreak();
char _getcwd();
char fpsetsticky();
char dlopen();
char _set_output_format();
char clock();
char gethostname();
char fork();
char fpresetsticky();
char _snprintf();
char PXFGETARG();
char getpagesize();
char readlink();
char stricmp();
char getrusage();
char _access();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_lseek) || defined (__stub___lseek)
lseek_will_always_fail_with_ENOSYS();
#else
lseek();
#endif
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
sleep_will_always_fail_with_ENOSYS();
#else
sleep();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub__pipe) || defined (__stub____pipe)
_pipe_will_always_fail_with_ENOSYS();
#else
_pipe();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
getcwd_will_always_fail_with_ENOSYS();
#else
getcwd();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
snprintf_will_always_fail_with_ENOSYS();
#else
snprintf();
#endif
#if defined (__stub_access) || defined (__stub___access)
access_will_always_fail_with_ENOSYS();
#else
access();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_fpsetsticky) || defined (__stub___fpsetsticky)
fpsetsticky_will_always_fail_with_ENOSYS();
#else
fpsetsticky();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_fpresetsticky) || defined (__stub___fpresetsticky)
fpresetsticky_will_always_fail_with_ENOSYS();
#else
fpresetsticky();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
  return 0;
stdout:
conftest.obj : error LNK2019: unresolved external symbol realpath referenced in function main
conftest.obj : error LNK2019: unresolved external symbol sleep referenced in function main
conftest.obj : error LNK2019: unresolved external symbol uname referenced in function main
conftest.obj : error LNK2019: unresolved external symbol gethostbyname referenced in function main
conftest.obj : error LNK2019: unresolved external symbol socket referenced in function main
conftest.obj : error LNK2019: unresolved external symbol dlclose referenced in function main
conftest.obj : error LNK2019: unresolved external symbol dlerror referenced in function main
conftest.obj : error LNK2019: unresolved external symbol drand48 referenced in function main
conftest.obj : error LNK2019: unresolved external symbol memalign referenced in function main
conftest.obj : error LNK2019: unresolved external symbol popen referenced in function main
conftest.obj : error LNK2019: unresolved external symbol dlsym referenced in function main
conftest.obj : error LNK2019: unresolved external symbol getwd referenced in function main
conftest.obj : error LNK2019: unresolved external symbol usleep referenced in function main
conftest.obj : error LNK2019: unresolved external symbol bzero referenced in function main
conftest.obj : error LNK2019: unresolved external symbol strcasecmp referenced in function main
conftest.obj : error LNK2019: unresolved external symbol snprintf referenced in function main
conftest.obj : error LNK2019: unresolved external symbol getdomainname referenced in function main
conftest.obj : error LNK2019: unresolved external symbol sbreak referenced in function main
conftest.obj : error LNK2019: unresolved external symbol fpsetsticky referenced in function main
conftest.obj : error LNK2019: unresolved external symbol dlopen referenced in function main
conftest.obj : error LNK2019: unresolved external symbol _set_output_format referenced in function main
conftest.obj : error LNK2019: unresolved external symbol gethostname referenced in function main
conftest.obj : error LNK2019: unresolved external symbol fork referenced in function main
conftest.obj : error LNK2019: unresolved external symbol fpresetsticky referenced in function main
conftest.obj : error LNK2019: unresolved external symbol _snprintf referenced in function main
conftest.obj : error LNK2019: unresolved external symbol PXFGETARG referenced in function main
conftest.obj : error LNK2019: unresolved external symbol getpagesize referenced in function main
conftest.obj : error LNK2019: unresolved external symbol readlink referenced in function main
conftest.obj : error LNK2019: unresolved external symbol getrusage referenced in function main
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 29 unresolved externals
Possible ERROR while running linker: exit code 2
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 29 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 29 unresolved externals:
Checking for functions [lseek rand realpath sleep uname _lseek gethostbyname socket dlclose _pipe dlerror drand48 memalign _sleep time _mkdir popen dlsym getwd usleep getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
char rand();
char realpath();
char sleep();
char uname();
char _lseek();
char socket();
char dlclose();
char _pipe();
char dlerror();
char drand48();
char memalign();
char _sleep();
char time();
char _mkdir();
char popen();
char dlsym();
char getwd();
char usleep();
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
#else
rand();
#endif
#else
realpath();
#endif
#else
sleep();
#endif
#else
uname();
#endif
#else
_lseek();
#endif
#else
gethostbyname();
#endif
#else
socket();
#endif
#else
dlclose();
#endif
#else
_pipe();
#endif
#else
dlerror();
#endif
#else
drand48();
#endif
#else
memalign();
#endif
#else
_sleep();
#endif
#else
time();
#endif
#else
_mkdir();
#endif
#else
popen();
#endif
#else
dlsym();
#endif
#else
getwd();
#endif
#else
usleep();
#endif
#else
getcwd();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 13 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 13 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 13 unresolved externals:
Checking for functions [lseek rand realpath sleep uname _lseek gethostbyname socket dlclose _pipe]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
char rand();
char realpath();
char sleep();
char uname();
char _lseek();
char socket();
char dlclose();
char _pipe();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
#else
rand();
#endif
#else
realpath();
#endif
#else
sleep();
#endif
#else
uname();
#endif
#else
_lseek();
#endif
#else
gethostbyname();
#endif
#else
socket();
#endif
#else
dlclose();
#endif
#else
_pipe();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 6 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 6 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 6 unresolved externals:
Checking for functions [lseek rand realpath sleep uname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
char rand();
char realpath();
char sleep();
char uname();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
#else
rand();
#endif
#else
realpath();
#endif
#else
sleep();
#endif
#else
uname();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 3 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 3 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 3 unresolved externals:
Checking for functions [lseek rand]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
char rand();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
#else
rand();
#endif
  return 0;
                          Defined "HAVE_LSEEK" to "1"
                          Defined "HAVE_RAND" to "1"
Checking for functions [realpath sleep uname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char realpath();
char sleep();
char uname();
#ifdef __cplusplus
#endif
int main() {
#else
realpath();
#endif
#else
sleep();
#endif
#else
uname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [realpath]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char realpath();
#ifdef __cplusplus
#endif
int main() {
#else
realpath();
#endif
  return 0;
stdout:
stdout:
Checking for functions [sleep]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
stdout:
stdout:
Checking for functions [uname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char uname();
#ifdef __cplusplus
#endif
int main() {
#else
uname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_lseek gethostbyname socket dlclose _pipe]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
char socket();
char dlclose();
char _pipe();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
#else
gethostbyname();
#endif
#else
socket();
#endif
#else
dlclose();
#endif
#else
_pipe();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_lseek gethostbyname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
#else
gethostbyname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_lseek]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                            Defined "HAVE__LSEEK" to "1"
Checking for functions [gethostbyname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
gethostbyname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [socket dlclose _pipe]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char socket();
char dlclose();
char _pipe();
#ifdef __cplusplus
#endif
int main() {
#else
socket();
#endif
#else
dlclose();
#endif
#else
_pipe();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 2 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 2 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 2 unresolved externals:
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char socket();
#ifdef __cplusplus
#endif
int main() {
#else
socket();
#endif
  return 0;
stdout:
stdout:
Checking for functions [dlclose]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlclose();
#ifdef __cplusplus
#endif
int main() {
#else
dlclose();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_pipe]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _pipe();
#ifdef __cplusplus
#endif
int main() {
#else
_pipe();
#endif
  return 0;
                            Defined "HAVE__PIPE" to "1"
Checking for functions [dlerror drand48 memalign _sleep time _mkdir popen dlsym getwd usleep getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlerror();
char drand48();
char memalign();
char _sleep();
char time();
char _mkdir();
char popen();
char dlsym();
char getwd();
char usleep();
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
dlerror();
#endif
#else
drand48();
#endif
#else
memalign();
#endif
#else
_sleep();
#endif
#else
time();
#endif
#else
_mkdir();
#endif
#else
popen();
#endif
#else
dlsym();
#endif
#else
getwd();
#endif
#else
usleep();
#endif
#else
getcwd();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 7 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 7 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 7 unresolved externals:
Checking for functions [dlerror drand48 memalign _sleep time]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlerror();
char drand48();
char memalign();
char _sleep();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
dlerror();
#endif
#else
drand48();
#endif
#else
memalign();
#endif
#else
_sleep();
#endif
#else
time();
#endif
  return 0;
stdout:
stdout:
Checking for functions [dlerror drand48]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlerror();
char drand48();
#ifdef __cplusplus
#endif
int main() {
#else
dlerror();
#endif
#else
drand48();
#endif
  return 0;
stdout:
stdout:
Checking for functions [dlerror]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlerror();
#ifdef __cplusplus
#endif
int main() {
#else
dlerror();
#endif
  return 0;
stdout:
stdout:
Checking for functions [drand48]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char drand48();
#ifdef __cplusplus
#endif
int main() {
#else
drand48();
#endif
  return 0;
stdout:
stdout:
Checking for functions [memalign _sleep time]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char _sleep();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
_sleep();
#endif
#else
time();
#endif
  return 0;
stdout:
stdout:
Checking for functions [memalign]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_sleep]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                            Defined "HAVE__SLEEP" to "1"
Checking for functions [time]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char time();
#ifdef __cplusplus
#endif
int main() {
#else
time();
#endif
  return 0;
                            Defined "HAVE_TIME" to "1"
Checking for functions [_mkdir popen dlsym getwd usleep getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
char popen();
char dlsym();
char getwd();
char usleep();
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
#else
popen();
#endif
#else
dlsym();
#endif
#else
getwd();
#endif
#else
usleep();
#endif
#else
getcwd();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 4 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 4 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 4 unresolved externals:
Checking for functions [_mkdir popen dlsym]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
char popen();
char dlsym();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
#else
popen();
#endif
#else
dlsym();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_mkdir]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
  return 0;
                            Defined "HAVE__MKDIR" to "1"
Checking for functions [popen]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char popen();
#ifdef __cplusplus
#endif
int main() {
#else
popen();
#endif
  return 0;
stdout:
stdout:
Checking for functions [dlsym]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlsym();
#ifdef __cplusplus
#endif
int main() {
#else
dlsym();
#endif
  return 0;
stdout:
stdout:
Checking for functions [getwd usleep getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
char usleep();
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
#else
usleep();
#endif
#else
getcwd();
#endif
  return 0;
stdout:
stdout:
Checking for functions [getwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
  return 0;
stdout:
stdout:
Checking for functions [usleep]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char usleep();
#ifdef __cplusplus
#endif
int main() {
#else
usleep();
#endif
  return 0;
stdout:
stdout:
Checking for functions [getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                            Defined "HAVE_GETCWD" to "1"
Checking for functions [bzero strcasecmp snprintf access getdomainname sbreak _getcwd fpsetsticky dlopen _set_output_format clock gethostname fork fpresetsticky _snprintf PXFGETARG getpagesize readlink stricmp getrusage _access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char bzero();
char strcasecmp();
char snprintf();
char access();
char sbreak();
char _getcwd();
char fpsetsticky();
char dlopen();
char clock();
char gethostname();
char fork();
char _snprintf();
char PXFGETARG();
char getpagesize();
char readlink();
char stricmp();
char getrusage();
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
bzero();
#endif
#else
strcasecmp();
#endif
#else
snprintf();
#endif
#else
access();
#endif
#else
getdomainname();
#endif
#else
sbreak();
#endif
#else
_getcwd();
#endif
#else
fpsetsticky();
#endif
#else
dlopen();
#endif
#else
#endif
#else
clock();
#endif
#else
gethostname();
#endif
#else
fork();
#endif
#else
fpresetsticky();
#endif
#else
_snprintf();
#endif
#else
PXFGETARG();
#endif
#else
getpagesize();
#endif
#else
readlink();
#endif
#else
stricmp();
#endif
#else
getrusage();
#endif
#else
_access();
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 16 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 16 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 16 unresolved externals:
Checking for functions [bzero strcasecmp snprintf access getdomainname sbreak _getcwd fpsetsticky dlopen _set_output_format]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char bzero();
char strcasecmp();
char snprintf();
char access();
char sbreak();
char _getcwd();
char fpsetsticky();
char dlopen();
#ifdef __cplusplus
#endif
int main() {
#else
bzero();
#endif
#else
strcasecmp();
#endif
#else
snprintf();
#endif
#else
access();
#endif
#else
getdomainname();
#endif
#else
sbreak();
#endif
#else
_getcwd();
#endif
#else
fpsetsticky();
#endif
#else
dlopen();
#endif
#else
#endif
  return 0;
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 8 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 8 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.exe : fatal error LNK1120: 8 unresolved externals:
Checking for functions [bzero strcasecmp snprintf access getdomainname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char bzero();
char strcasecmp();
char snprintf();
char access();
#ifdef __cplusplus
#endif
int main() {
#else
bzero();
#endif
#else
strcasecmp();
#endif
#else
snprintf();
#endif
#else
access();
#endif
#else
getdomainname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [bzero strcasecmp]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char bzero();
char strcasecmp();
#ifdef __cplusplus
#endif
int main() {
#else
bzero();
#endif
#else
strcasecmp();
#endif
  return 0;
stdout:
stdout:
Checking for functions [bzero]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char bzero();
#ifdef __cplusplus
#endif
int main() {
#else
bzero();
#endif
  return 0;
stdout:
stdout:
Checking for functions [strcasecmp]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char strcasecmp();
#ifdef __cplusplus
#endif
int main() {
#else
strcasecmp();
#endif
  return 0;
stdout:
stdout:
Checking for functions [snprintf access getdomainname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
char access();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
#else
access();
#endif
#else
getdomainname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [snprintf]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
stdout:
stdout:
Checking for functions [access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                            Defined "HAVE_ACCESS" to "1"
Checking for functions [getdomainname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
getdomainname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [sbreak _getcwd fpsetsticky dlopen _set_output_format]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
char _getcwd();
char fpsetsticky();
char dlopen();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
#else
_getcwd();
#endif
#else
fpsetsticky();
#endif
#else
dlopen();
#endif
#else
#endif
  return 0;
stdout:
stdout:
Checking for functions [sbreak _getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
#else
_getcwd();
#endif
  return 0;
stdout:
stdout:
Checking for functions [sbreak]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_getcwd]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                            Defined "HAVE__GETCWD" to "1"
Checking for functions [fpsetsticky dlopen _set_output_format]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char fpsetsticky();
char dlopen();
#ifdef __cplusplus
#endif
int main() {
#else
fpsetsticky();
#endif
#else
dlopen();
#endif
#else
#endif
  return 0;
stdout:
stdout:
Checking for functions [fpsetsticky]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char fpsetsticky();
#ifdef __cplusplus
#endif
int main() {
#else
fpsetsticky();
#endif
  return 0;
stdout:
stdout:
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlopen();
#ifdef __cplusplus
#endif
int main() {
#else
dlopen();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_set_output_format]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
stdout:
stdout:
Checking for functions [clock gethostname fork fpresetsticky _snprintf PXFGETARG getpagesize readlink stricmp getrusage _access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char clock();
char gethostname();
char fork();
char _snprintf();
char PXFGETARG();
char getpagesize();
char readlink();
char stricmp();
char getrusage();
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
clock();
#endif
#else
gethostname();
#endif
#else
fork();
#endif
#else
fpresetsticky();
#endif
#else
_snprintf();
#endif
#else
PXFGETARG();
#endif
#else
getpagesize();
#endif
#else
readlink();
#endif
#else
stricmp();
#endif
#else
getrusage();
#endif
#else
_access();
#endif
  return 0;
stdout:
stdout:
Checking for functions [clock gethostname fork fpresetsticky _snprintf]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char clock();
char gethostname();
char fork();
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
clock();
#endif
#else
gethostname();
#endif
#else
fork();
#endif
#else
fpresetsticky();
#endif
#else
_snprintf();
#endif
  return 0;
stdout:
stdout:
Checking for functions [clock gethostname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char clock();
char gethostname();
#ifdef __cplusplus
#endif
int main() {
#else
clock();
#endif
#else
gethostname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [clock]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char clock();
#ifdef __cplusplus
#endif
int main() {
#else
clock();
#endif
  return 0;
                            Defined "HAVE_CLOCK" to "1"
Checking for functions [gethostname]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char gethostname();
#ifdef __cplusplus
#endif
int main() {
#else
gethostname();
#endif
  return 0;
stdout:
stdout:
Checking for functions [fork fpresetsticky _snprintf]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char fork();
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
fork();
#endif
#else
fpresetsticky();
#endif
#else
_snprintf();
#endif
  return 0;
stdout:
stdout:
Checking for functions [fork]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char fork();
#ifdef __cplusplus
#endif
int main() {
#else
fork();
#endif
  return 0;
stdout:
stdout:
Checking for functions [fpresetsticky]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
fpresetsticky();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_snprintf]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
stdout:
stdout:
Checking for functions [PXFGETARG getpagesize readlink stricmp getrusage _access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
char getpagesize();
char readlink();
char stricmp();
char getrusage();
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
#else
getpagesize();
#endif
#else
readlink();
#endif
#else
stricmp();
#endif
#else
getrusage();
#endif
#else
_access();
#endif
  return 0;
stdout:
stdout:
Checking for functions [PXFGETARG getpagesize readlink]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
char getpagesize();
char readlink();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
#else
getpagesize();
#endif
#else
readlink();
#endif
  return 0;
stdout:
stdout:
Checking for functions [PXFGETARG]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
stdout:
stdout:
Checking for functions [getpagesize]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
getpagesize();
#endif
  return 0;
stdout:
stdout:
Checking for functions [readlink]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char readlink();
#ifdef __cplusplus
#endif
int main() {
#else
readlink();
#endif
  return 0;
stdout:
stdout:
Checking for functions [stricmp getrusage _access]
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
char getrusage();
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
#else
getrusage();
#endif
#else
_access();
#endif
  return 0;
stdout:
stdout:
Checking for functions [stricmp]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                            Defined "HAVE_STRICMP" to "1"
Checking for functions [getrusage]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getrusage();
#ifdef __cplusplus
#endif
int main() {
#else
getrusage();
#endif
  return 0;
stdout:
stdout:
Checking for functions [_access]
stdout: conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                            Defined "HAVE__ACCESS" to "1"
TESTING: checkMmap from config.functions(config/BuildSystem/config/functions.py:179)
  Check for functional mmap() to allocate shared memory and define HAVE_MMAP
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/mman.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FUN\conftest.c(3): fatal error C1083: Cannot open include file: 'sys/mman.h': No such file or directorySource:
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
int main() {
int fd;
 fd=open("/tmp/file",O_RDWR);
 mmap((void*)0,100,PROT_READ|PROT_WRITE,MAP_SHARED,fd,0);
  return 0;
              Compile failed inside link
    child config.functions 200.781771
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
            Defined "USE_PROC_FOR_SIZE" to "1"
          Using /proc for PetscMemoryGetCurrentUsage()
    child config.utilities.getResidentSetSize 0.014208
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
            Checking for functions [] in library [''] []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -I/tmp/petsc-v6m0e0sk/config.libraries  -MD -Z7 -fpp  /tmp/petsc-v6m0e0sk/config.libraries/conftest.F90
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       i = command_argument_count()
       call get_command_argument(i,arg)
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -Z7 -fpp /tmp/petsc-v6m0e0sk/config.libraries/conftest.o
            Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
    child config.utilities.fortranCommandLine 2.746887
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
Preprocessing source:
#include <sigfpe.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'sigfpe.h': No such file or directory
#line 87 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
typedef int mode_t;
typedef int pid_t;
Source:
#include <sigfpe.h>
Preprocess output before filtering:
Preprocess output after filtering:
Checking for header: fpxcp.h
#include <fpxcp.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'fpxcp.h': No such file or directory
typedef int mode_t;
typedef int pid_t;
Source:
#include <fpxcp.h>
Checking for header: floatingpoint.h
#include <floatingpoint.h>
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'floatingpoint.h': No such file or directory
typedef int mode_t;
typedef int pid_t;
Source:
    child config.utilities.FPTrap 2.719238
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(4): fatal error C1083: Cannot open include file: 'sysctl.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(4): fatal error C1083: Cannot open include file: 'sysctl.h': No such file or directorySource:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_BSD_SOURCE" to "1"
stdout: conftest.c
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_DEFAULT_SOURCE" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(4): fatal error C1083: Cannot open include file: 'sched.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(4): fatal error C1083: Cannot open include file: 'sched.h': No such file or directorySource:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(5): fatal error C1083: Cannot open include file: 'dlfcn.h': No such file or directory
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.FEA\conftest.c(5): fatal error C1083: Cannot open include file: 'dlfcn.h': No such file or directorySource:
#define _GNU_SOURCE
#include <stdlib.h>
#include <dlfcn.h>
int main() {
Dl_info info;
if (dladdr(exit, &info));;
  return 0;
    child config.utilities.featureTestMacros 8.759875
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:55)
   Checks if u_short is undefined
===== Checking compiler
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'u_short': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2146: syntax error: missing ';' before identifier 'foo'
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'foo': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'foo': undeclared identifierSource:
int main() {
u_short foo;
  return 0;
            Defined "NEEDS_UTYPE_TYPEDEFS" to "1"
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:61)
  Checks for SOCKETS
              Checking for functions [socket] in library ['Ws2_32.lib'] []
===== Checking linker
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.libraries/conftest.c
stdout: conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
#include <Winsock2.h>
static void _check_socket() { socket(0,0,0);; }
int main() {
_check_socket();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  Ws2_32.lib
Linker output after filtering:
                Defined "HAVE_LIBWS2_32" to "1"
            Adding ['Ws2_32.lib'] to LIBS
            Defined "HAVE_WINSOCK2_H" to "1"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.utilities.missing  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
closesocket(0);
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.o Ws2_32.lib
            Defined "HAVE_CLOSESOCKET" to "1"
stdout: conftest.c
Successful compile:
Source:
int main() {
WSAGetLastError();
  return 0;
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.exe not found or not built by the last incremental link; performing full link
            Defined "HAVE_WSAGETLASTERROR" to "1"
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:79)
  Check for missing signals, and define MISSING_<signal name> if necessary
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGALRM': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGALRM': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
            Defined "MISSING_SIGALRM" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGBUS': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGBUS': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
            Defined "MISSING_SIGBUS" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGCHLD': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGCHLD': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
            Defined "MISSING_SIGCHLD" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGCONT': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGCONT': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
            Defined "MISSING_SIGCONT" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGHUP': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGHUP': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
            Defined "MISSING_SIGHUP" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGKILL': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGKILL': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
            Defined "MISSING_SIGKILL" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGPIPE': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGPIPE': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
            Defined "MISSING_SIGPIPE" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGQUIT': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGQUIT': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
            Defined "MISSING_SIGQUIT" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGSTOP': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGSTOP': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
            Defined "MISSING_SIGSTOP" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGSYS': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGSYS': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
            Defined "MISSING_SIGSYS" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGTRAP': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGTRAP': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
            Defined "MISSING_SIGTRAP" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGTSTP': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGTSTP': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
            Defined "MISSING_SIGTSTP" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGURG': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGURG': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
            Defined "MISSING_SIGURG" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGUSR1': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGUSR1': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
            Defined "MISSING_SIGUSR1" to "1"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGUSR2': undeclared identifier
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(6): error C2065: 'SIGUSR2': undeclared identifierSource:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
            Defined "MISSING_SIGUSR2" to "1"
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:96)
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(21): error C2065: 'getdomainname': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(21): warning C4047: 'initializing': 'int (__cdecl *)(char *,size_t)' differs in levels of indirection from 'int'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(21): warning C4047: 'initializing': 'int (__cdecl *)(char *,size_t)' differs in levels of indirection from 'int'Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(21): warning C4047: 'initializing': 'int (__cdecl *)(char *,int)' differs in levels of indirection from 'int'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(21): warning C4047: 'initializing': 'int (__cdecl *)(char *,int)' differs in levels of indirection from 'int'Source:
#define _BSD_SOURCE
#endif
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,int) = getdomainname;
char test[10];
  return 0;
            Added prototype #include <stddef.h>
int getdomainname(char *, size_t); to language C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.missing  -MD -GR -EHsc -Z7 -Zm200   -TP   /tmp/petsc-v6m0e0sk/config.utilities.missing/conftest.cc
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.cc(21): error C2065: 'getdomainname': undeclared identifier
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.cc(21): error C2065: 'getdomainname': undeclared identifierSource:
#define _BSD_SOURCE
#endif
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
stdout:
conftest.cc
stdout:
conftest.cc
#define _BSD_SOURCE
#endif
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
int getdomainname(char *, size_t); to language extern C
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:121)
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(16): error C2065: 'drand48': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(17): error C2065: 'srand48': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(16): warning C4047: 'initializing': 'double (__cdecl *)(void)' differs in levels of indirection from 'int'
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(17): warning C4047: 'initializing': 'void (__cdecl *)(long)' differs in levels of indirection from 'int'
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.c(17): warning C4047: 'initializing': 'void (__cdecl *)(long)' differs in levels of indirection from 'int'Source:
#define _BSD_SOURCE
#endif
#endif
#include <stdlib.h>
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
            Added prototype double drand48(void); to language C
            Added prototype void   srand48(long int); to language C
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.cc(16): error C2065: 'drand48': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.cc(17): error C2065: 'srand48': undeclared identifier
stdout:
conftest.cc
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MIS\conftest.cc(17): error C2065: 'srand48': undeclared identifierSource:
#define _BSD_SOURCE
#endif
#endif
#include <stdlib.h>
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
            Added prototype double drand48(void); to language extern C
            Added prototype void   srand48(long int); to language extern C
    child config.utilities.missing 63.345037
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:34)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:49)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
Executing: uname -s
stdout: CYGWIN_NT-10.0
            Defined make macro "SONAME_FUNCTION" to "$(1).dll"
            Defined make macro "SL_LINKER_FUNCTION" to "-LD"
            Defined make macro "PETSC_DLL_EXPORTS" to "1"
            Defined make macro "BUILDSHAREDLIB" to "yes"
            Defined "USE_SHARED_LIBRARIES" to "1"
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:94)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:100)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TESTING: checkSymbolResolution from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:109)
  Checks that dladdr() works
    child PETSc.options.sharedLibraries 0.454692
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:40)
  Choose between real and complex numbers
          Scalar type is real
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes/conftest.o Ws2_32.lib
            Defined "HAVE_ISNORMAL" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
  return 0;
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\PETSCO~1.SCA\conftest.exe not found or not built by the last incremental link; performing full link
            Defined "HAVE_ISNAN" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
  return 0;
            Defined "HAVE_ISINF" to "1"
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:81)
  Set the default real number precision for PETSc objects
Checking C compiler works with __float128
            Checking for functions [logq] in library ['quadmath'] []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.libraries/conftest.c
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.c(4): fatal error C1083: Cannot open include file: 'quadmath.h': No such file or directory
Possible ERROR while running compiler: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.c(4): fatal error C1083: Cannot open include file: 'quadmath.h': No such file or directorySource:
#include <quadmath.h>
static void _check_logq() { __float128 f; logq(f);; }
int main() {
_check_logq();;
  return 0;
            Defined "USE_REAL_DOUBLE" to "1"
            Defined make macro "PETSC_SCALAR_SIZE" to "64"
          Precision is double
    child PETSc.options.scalarTypes 10.496898
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:22)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /usr/local/bin/mkdir...not found
Checking for program /usr/bin/mkdir...found
Executing: /usr/bin/mkdir -p .conftest/tmp
          Adding -p flag to /usr/bin/mkdir -p to automatically create directories
            Defined make macro "MKDIR" to "/usr/bin/mkdir -p"
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:44)
  Check for autoreconf
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/autoreconf...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/autoreconf...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/autoreconf...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/autoreconf...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/autoreconf...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/autoreconf...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/autoreconf...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/autoreconf...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/autoreconf...not found
Checking for program /cygdrive/c/Windows/system32/autoreconf...not found
Checking for program /cygdrive/c/Windows/autoreconf...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/autoreconf...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/autoreconf...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/autoreconf...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/autoreconf...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/autoreconf...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/autoreconf...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/autoreconf...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/autoreconf...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/autoreconf...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/autoreconf...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/libtoolize...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/libtoolize...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/libtoolize...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/libtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/libtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/libtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/libtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/libtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/libtoolize...not found
Checking for program /cygdrive/c/Windows/system32/libtoolize...not found
Checking for program /cygdrive/c/Windows/libtoolize...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/libtoolize...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/libtoolize...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/libtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/libtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/libtoolize...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/libtoolize...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/libtoolize...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/libtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/libtoolize...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/libtoolize...not found
Checking for program /usr/local/bin/glibtoolize...not found
Checking for program /usr/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/glibtoolize...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/glibtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/glibtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/glibtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/glibtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/glibtoolize...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/glibtoolize...not found
Checking for program /cygdrive/c/Windows/system32/glibtoolize...not found
Checking for program /cygdrive/c/Windows/glibtoolize...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/glibtoolize...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/glibtoolize...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/glibtoolize...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/glibtoolize...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/glibtoolize...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/glibtoolize...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/glibtoolize...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/glibtoolize...not found
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:71)
  Check for the programs needed to build and run PETSc
Checking for program /usr/local/bin/bash...not found
Checking for program /usr/bin/bash...found
              Defined make macro "SHELL" to "/usr/bin/bash"
Checking for program /usr/local/bin/sed...not found
Checking for program /usr/bin/sed...found
              Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/tmp/petsc-v6m0e0sk/config.programs/sed1"
          Adding SEDINPLACE cmd: /usr/bin/sed -i
            Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
Checking for program /usr/local/bin/mv...not found
Checking for program /usr/bin/mv...found
              Defined make macro "MV" to "/usr/bin/mv"
Checking for program /usr/local/bin/cp...not found
Checking for program /usr/bin/cp...found
              Defined make macro "CP" to "/usr/bin/cp"
Checking for program /usr/local/bin/grep...not found
Checking for program /usr/bin/grep...found
              Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /usr/local/bin/rm...not found
Checking for program /usr/bin/rm...found
              Defined make macro "RM" to "/usr/bin/rm -f"
Checking for program /usr/local/bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-v6m0e0sk/config.programs/diff1" "/tmp/petsc-v6m0e0sk/config.programs/diff2"
            Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/ps...not found
  Unable to find programs ['ps'] providing listing of the specific search path
      Warning accessing /usr/ucb gives errors: can only concatenate str (not "builtin_function_or_method") to str
      Warning accessing /usr/usb gives errors: can only concatenate str (not "builtin_function_or_method") to str
            Defined make macro "PYTHON" to "/usr/bin/python3"
Checking for program /usr/local/bin/m4...not found
Checking for program /usr/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/m4...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/m4...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/m4...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/m4...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/m4...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/m4...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/m4...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/m4...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/m4...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/m4...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/m4...not found
Checking for program /cygdrive/c/Windows/system32/m4...not found
Checking for program /cygdrive/c/Windows/m4...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/m4...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/m4...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/m4...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/m4...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/m4...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/m4...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/m4...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/m4...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/m4...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/m4...not found
    child config.programs 1.859174
TESTING: consistencyChecks from config.packages.make(config/BuildSystem/config/package.py:963)
  Checks run on the system and currently installed packages that need to be correct for the package now being configured
TESTING: alternateConfigureLibrary from config.packages.make(config/BuildSystem/config/package.py:959)
  Called if --with-packagename=0; does nothing by default
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:96)
  Check Guesses for GNU make
Executing: gmake --version
GNUMake check failed: Could not execute "['gmake --version']":
/bin/sh: gmake: command not found
Executing: make --version
stdout:
GNU Make 4.3
Built for x86_64-pc-cygwin
Copyright (C) 1988-2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Checking for program /usr/local/bin/make...not found
Checking for program /usr/bin/make...found
              Defined make macro "MAKE" to "/usr/bin/make"
              Defined make macro "MAKE_USER" to "make"
TESTING: setupGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:150)
  Setup other GNU make stuff
Executing: uname -s
Executing: uname -s
            Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
            Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
            Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
            Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
            Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/make  --print-directory"
            Defined make macro "OMAKE" to "/usr/bin/make  --no-print-directory"
            Defined make macro "MAKE_PAR_OUT_FLG" to "--output-sync=recurse"
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:197)
  check no of cores on the build machine [perhaps to do make '-j ncores']
          module multiprocessing found 48 cores: using make_np = 32
            Defined make macro "MAKE_NP" to "32"
            Defined make macro "MAKE_TEST_NP" to "21"
            Defined make macro "MAKE_LOAD" to "72.0"
            Defined make macro "NPMAX" to "48"
    child config.packages.make 1.672943
TESTING: consistencyChecks from config.packages.X(config/BuildSystem/config/package.py:963)
TESTING: checkDependencies from config.packages.X(config/BuildSystem/config/package.py:872)
TESTING: configureLibrary from config.packages.X(config/BuildSystem/config/package.py:897)
  Find an installation and check if it can work with PETSc
          Checking for a functional X
          Checking for library in Compiler specific search X: []
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:157)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
Linker output before filtering:
LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe not found or not built by the last incremental link; performing full link
conftest.obj : error LNK2019: unresolved external symbol XSetWMName referenced in function _check_XSetWMName
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals:
              Checking for functions [XSetWMName] in library [] []
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
char XSetWMName();
static void _check_XSetWMName() { XSetWMName(); }
int main() {
_check_XSetWMName();;
  return 0;
stdout:
Possible ERROR while running linker: exit code 2
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals          Checking for library in Compiler specific search X: ['libX11.a']
LINK : fatal error LNK1104: cannot open file 'libX11.lib'
LINK : fatal error LNK1104: cannot open file 'libX11.lib':
              Checking for functions [XSetWMName] in library ['libX11.a'] []
stdout: conftest.c
Successful compile:
Source:
char XSetWMName();
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  -lX11 Ws2_32.lib
stdout: LINK : fatal error LNK1104: cannot open file 'libX11.lib'
stdout:
LINK : fatal error LNK1104: cannot open file 'libX11.lib'            X: SearchDir DirPath not found.. skipping: /opt/X11
            X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.5.sdk/usr/X11
            X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.4u.sdk/usr/X11R6
            X: SearchDir DirPath not found.. skipping: /usr/X11
            X: SearchDir DirPath not found.. skipping: /usr/X11R6
            X: SearchDir DirPath not found.. skipping: /usr/X11R5
            X: SearchDir DirPath not found.. skipping: /usr/X11R4
            X: SearchDir DirPath not found.. skipping: /usr/local/X11
            X: SearchDir DirPath not found.. skipping: /usr/local/X11R6
            X: SearchDir DirPath not found.. skipping: /usr/local/X11R5
            X: SearchDir DirPath not found.. skipping: /usr/local/X11R4
            X: SearchDir DirPath not found.. skipping: /usr/X386
            X: SearchDir DirPath not found.. skipping: /usr/x386
            X: SearchDir DirPath not found.. skipping: /usr/XFree86/X11
          Checking for library in Package specific search directory X: ['/usr/local/lib/libX11.a']
          Contents: ['bin', 'etc', 'lib']
              Checking for functions [XSetWMName] in library ['/usr/local/lib/libX11.a'] []
stdout: conftest.c
Successful compile:
Source:
char XSetWMName();
int main() {
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  -L/usr/local/lib -L/usr/local/lib -lX11 Ws2_32.lib
stdout:
LINK : fatal error LNK1104: cannot open file 'libX11.lib'            X: DirPath not found.. skipping: /usr/local/lib64
            X: SearchDir DirPath not found.. skipping: /usr/local/x11r5
            X: SearchDir DirPath not found.. skipping: /usr/lpp/Xamples
            X: SearchDir DirPath not found.. skipping: /usr/openwin
            X: SearchDir DirPath not found.. skipping: /usr/openwin/share
TESTING: checkVersion from config.packages.X(config/BuildSystem/config/package.py:1026)
  Uses self.version, self.minversion, self.maxversion, self.versionname, and self.versioninclude to determine if package has required version
For x unable to run preprocessor to obtain version information, skipping version check
TESTING: checkSharedLibrary from config.packages.X(config/BuildSystem/config/package.py:955)
  By default we don't care about checking if the library is shared
    child config.packages.X 8.450541
TESTING: consistencyChecks from config.packages.hwloc(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:959)
    child config.packages.hwloc 0.009799
TESTING: consistencyChecks from config.packages.valgrind(config/BuildSystem/config/package.py:963)
TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:897)
          Checking for a functional valgrind
          Not checking for library in Compiler specific search VALGRIND: [] because no functions given to check for
              No functions to check for in library [] []
          Checking for optional headers [] in Compiler specific search VALGRIND: []
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files [] in []
Found header files [] in []
          Checking for headers ['valgrind/valgrind.h'] in Compiler specific search VALGRIND: []
Checking for header files ['valgrind/valgrind.h'] in []
                Checking include with compiler flags var CPPFLAGS []
Preprocessing source:
#include <valgrind/valgrind.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types    /tmp/petsc-v6m0e0sk/config.headers/conftest.c
Possible ERROR while running preprocessor: exit code 2
stdout:
conftest.c
#line 1 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 113 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\confdefs.h"
#line 2 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
typedef int mode_t;
typedef int int32_t;
typedef int pid_t;
#line 15 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#pragma once
#line 29 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 39 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
        #line 44 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 45 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 46 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#pragma once
#line 151 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 155 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 185 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 190 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 196 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 200 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 207 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 219 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 228 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 229 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1586 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1611 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1624 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1663 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1775 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1878 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2047 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2149 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2366 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2367 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2595 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2634 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2868 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2878 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2883 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2890 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2891 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2898 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2899 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2911 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 2945 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\concurrencysal.h"
#pragma once
#line 265 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\concurrencysal.h"
#line 269 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\concurrencysal.h"
#line 352 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\concurrencysal.h"
#line 358 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\concurrencysal.h"
#line 2971 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\sal.h"
#line 48 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
        typedef unsigned __int64  uintptr_t;
#line 32 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 33 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
        typedef char* va_list;
    #line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 42 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 48 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 54 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 58 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 61 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 73 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 81 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 93 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 99 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 111 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 122 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 159 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#line 163 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 64 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 74 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 82 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
__pragma(pack(push, 8))
    #line 93 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 94 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 113 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 115 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 117 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 118 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 123 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 125 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 126 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 132 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 135 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 141 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 153 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 157 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 159 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 165 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 173 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 174 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 192 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 196 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
#line 198 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 203 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 207 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 211 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    typedef unsigned short wchar_t;
#line 217 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 224 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 225 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 231 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 243 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 250 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    #line 261 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 262 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 266 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 274 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 275 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie(  uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure(  uintptr_t _StackCookie);
    #line 286 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 287 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
extern uintptr_t __security_cookie;
#line 295 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
__pragma(pack(pop))
#line 299 "C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Tools\\MSVC\\14.16.27023\\include\\vcruntime.h"
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 25 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 29 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 36 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 43 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 58 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 73 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 77 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 79 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 90 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 108 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 109 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 115 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 119 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 121 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 125 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 127 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 152 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 156 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 158 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 170 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 192 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 194 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 195 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 199 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 203 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 215 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
  #line 217 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
 #line 218 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 219 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 240 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 241 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 245 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 253 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
      wchar_t const* _Expression,
      wchar_t const* _FunctionName,
      wchar_t const* _FileName,
            unsigned int _LineNo,
            uintptr_t _Reserved);
    #line 308 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 309 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 329 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 339 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 357 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 358 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 365 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 366 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 370 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 384 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 400 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 407 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 411 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 416 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 417 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
        #line 427 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 428 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 429 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 433 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 439 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 449 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 450 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 459 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 469 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 476 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 481 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 489 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 497 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 498 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 502 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
      int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
#line 542 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 546 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
        typedef __time64_t time_t;
    #line 553 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 554 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 559 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    typedef size_t rsize_t;
#line 563 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 724 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 739 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 740 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 1815 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 2005 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
    #line 2006 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
#line 2007 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
     int* __cdecl _errno(void);
     errno_t __cdeC:\cygwin64\tmp\PETSC-~2\CONFIG~1.HEA\conftest.c(3): fatal error C1083: Cannot open include file: 'valgrind/valgrind.h': No such file or directory
cl _set_errno(  int _Value);
     errno_t __cdecl _get_errno(  int* _Value);
#line 38 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
    #line 47 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
 extern unsigned long  __cdecl __threadid(void);
 extern uintptr_t __cdecl __threadhandle(void);
__pragma(pack(pop))
#line 59 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17763.0\\ucrt\\stddef.h"
#line 16 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
int getdomainname(char *, size_t);
double drand48(void);
void   srand48(long int);
#line 20 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 21 "c:\\cygwin64\\tmp\\petsc-v6m0e0sk\\config.headers\\conffix.h"
#line 3 "C:\\cygwin64\\tmp\\PETSC-~2\\CONFIG~1.HEA\\conftest.c"
Source:
Preprocess output before filtering:
Preprocess output after filtering:
          Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
          Checking for optional headers [] in Package specific search directory VALGRIND: ['/usr/local/include']
Checking for header files [] in ['/usr/local/include']
Found header files [] in ['/usr/local/include']
          Checking for headers ['valgrind/valgrind.h'] in Package specific search directory VALGRIND: ['/usr/local/include']
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include']
                Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types   -I/usr/local/include /tmp/petsc-v6m0e0sk/config.headers/conftest.c
stdout:
Warning: win32fe: Include Path Not Found: /usr/local/include
conftest.c
typedef int mode_t;
typedef int pid_t;
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
__pragma(pack(pop))
Source:
            VALGRIND: DirPath not found.. skipping: /usr/local/lib64
            VALGRIND: SearchDir DirPath not found.. skipping: /opt/local
Executing: uname -s
stdout: CYGWIN_NT-10.0
    child config.packages.valgrind 2.507000
TESTING: consistencyChecks from config.packages.thrust(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.thrust(config/BuildSystem/config/package.py:959)
    child config.packages.thrust 0.008874
TESTING: consistencyChecks from config.packages.cuda(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.cuda(config/BuildSystem/config/package.py:959)
    child config.packages.cuda 0.008119
TESTING: consistencyChecks from config.packages.OpenMPI(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:959)
    child config.packages.OpenMPI 0.007984
TESTING: consistencyChecks from config.packages.MPICH(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:959)
    child config.packages.MPICH 0.010133
TESTING: consistencyChecks from config.packages.MPI(config/BuildSystem/config/package.py:963)
TESTING: checkDependencies from config.packages.MPI(config/BuildSystem/config/package.py:872)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:691)
            Checking for a functional MPI
            Checking for library in User specified MPI libraries: ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib']
            Contents: ['benchmarks', 'bin', 'env', 'etc', 'include', 'lib', 'libfabric', 'licensing', 'test']
                Checking for functions [MPI_Init MPI_Comm_create] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
===== Checking linker
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.libraries/conftest.c
stdout: conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Ws2_32.lib
                  Defined "HAVE_LIBIMPI" to "1"
                  Defined "HAVE_LIBIMPICXX" to "1"
                  Defined "HAVE_LIBMPI_ILP64" to "1"
            Checking for optional headers [] in User specified MPI libraries: ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
Checking for header files [] in ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
Found header files [] in ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
            Checking for headers ['mpi.h'] in User specified MPI libraries: ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
Checking for header files ['mpi.h'] in ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
                  Checking include with compiler flags var CPPFLAGS ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
#include <mpi.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types   -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.headers/conftest.c
Found header files ['mpi.h'] in ['/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include']
            Defined "HAVE_MPI_F90MODULE_VISIBILITY" to "1"
TESTING: checkMPIDistro from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:544)
  Determine if MPICH_NUMVERSION, OMPI_MAJOR_VERSION or MSMPI_VER exist in mpi.h
       Used for consistency checking of MPI installation at compile time
===== Checking compiler
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes -I/tmp/petsc-v6m0e0sk/config.packages.MPI  -MD -wd4996 -Z7   -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
const char *mpich_ver = I_MPI_VERSION;
int main() {
  return 0;
#include <mpi.h>
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -E  -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.packages.MPI   -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.c
              Unable to parse I_MPI version from header. Probably a buggy preprocessor
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int mpich_ver = I_MPI_NUMVERSION;
int main() {
  return 0;
#include <mpi.h>
                Defined "HAVE_I_MPI_NUMVERSION" to "20210200300"
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.c(4): error C2065: 'MVAPICH2_NUMVERSION': undeclared identifier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.c(4): error C2099: initializer is not a constant
Possible ERROR while running compiler: exit code 2
stdout:
conftest.c
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.c(4): error C2099: initializer is not a constantSource:
#include <mpi.h>
int mpich_ver = MVAPICH2_NUMVERSION;
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int mpich_ver = MPICH_NUMVERSION;
int main() {
  return 0;
#include <mpi.h>
                Defined "HAVE_MPICH_NUMVERSION" to "30300300"
TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:332)
  Check for functions added to the interface in MPI-2
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.o /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Ws2_32.lib
                Defined "HAVE_MPI_FINALIZED" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
  return 0;
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.exe not found or not built by the last incremental link; performing full link
                Defined "HAVE_MPI_IN_PLACE" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={MPI_INT,MPI_DOUBLE}; MPI_Datatype *newtype = 0;
                                              if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Reduce_local(0, 0, 0, MPI_INT, MPI_SUM));;
  return 0;
                Defined "HAVE_MPI_REDUCE_LOCAL" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
char version[MPI_MAX_LIBRARY_VERSION_STRING];int verlen;if (MPI_Get_library_version(version,&verlen));
  return 0;
                Defined "HAVE_MPI_GET_LIBRARY_VERSION" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int base[100]; MPI_Win win; if (MPI_Win_create(base,100,4,MPI_INFO_NULL,MPI_COMM_WORLD,&win));
  return 0;
                Defined "HAVE_MPI_WIN_CREATE" to "1"
stdout:
conftest.c
c:\cygwin64\tmp\petsc-v6m0e0sk\config.packages.mpi\conftest.c(6) : warning C4700: uninitialized local variable 'win' used
Successful compile:
Source:
#include <mpi.h>
int main() {
int ptr[1]; MPI_Win win; if (MPI_Accumulate(ptr,1,MPI_INT,0,0,1,MPI_INT,MPI_REPLACE,win));
  return 0;
                Defined "HAVE_MPI_ONE_SIDED" to "1"
Linker output after filtering:
TESTING: configureMPI3 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:379)
  Check for functions added to the interface in MPI-3
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm scomm; MPI_Aint size=128; int disp_unit=8,*baseptr; MPI_Win win;
                       if (MPI_Comm_split_type(MPI_COMM_WORLD, MPI_COMM_TYPE_SHARED, 0, MPI_INFO_NULL, &scomm));
                       if (MPI_Win_allocate_shared(size,disp_unit,MPI_INFO_NULL,MPI_COMM_WORLD,&baseptr,&win));
                       if (MPI_Win_shared_query(win,0,&size,&disp_unit,&baseptr));
  return 0;
                Defined "HAVE_MPI_PROCESS_SHARED_MEMORY" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int send=0,recv,counts[2]={1,1},displs[2]={1,2}; MPI_Request req;
                       if (MPI_Iscatter(&send,1,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Iscatterv(&send,counts,displs,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Igather(&send,1,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Igatherv(&send,1,MPI_INT,&recv,counts,displs,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Iallgather(&send,1,MPI_INT,&recv,1,MPI_INT,MPI_COMM_WORLD,&req));
                        if (MPI_Iallgatherv(&send,1,MPI_INT,&recv,counts,displs,MPI_INT,MPI_COMM_WORLD,&req));
                        if (MPI_Ialltoall(&send,1,MPI_INT,&recv,1,MPI_INT,MPI_COMM_WORLD,&req));
  return 0;
                Defined "HAVE_MPI_NONBLOCKING_COLLECTIVES" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm distcomm;
                       MPI_Request req;
                       if (MPI_Dist_graph_create_adjacent(MPI_COMM_WORLD,0,0,MPI_WEIGHTS_EMPTY,0,0,MPI_WEIGHTS_EMPTY,MPI_INFO_NULL,0,&distcomm));
                       if (MPI_Neighbor_alltoallv(0,0,0,MPI_INT,0,0,0,MPI_INT,distcomm));
                       if (MPI_Ineighbor_alltoallv(0,0,0,MPI_INT,0,0,0,MPI_INT,distcomm,&req));
  return 0;
                Defined "HAVE_MPI_NEIGHBORHOOD_COLLECTIVES" to "1"
stdout:
conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int ptr[1]; MPI_Win win; if (MPI_Get_accumulate(ptr,1,MPI_INT,ptr,1,MPI_INT,0,0,1,MPI_INT,MPI_SUM,win));
  return 0;
                Defined "HAVE_MPI_GET_ACCUMULATE" to "1"
stdout:
conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int ptr[1]; MPI_Win win; MPI_Request req; if (MPI_Rget(ptr,1,MPI_INT,0,1,1,MPI_INT,win,&req));
  return 0;
                Defined "HAVE_MPI_RGET" to "1"
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:177)
  Checking for location of mpiexec
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/mpiexec...found
                  Defined make macro "MPIEXECEXECUTABLE" to "/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/bin/mpiexec"
Running Executable with threads to time it out at 120
Executing: /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/bin/mpiexec -n 1 printenv
stdout:
!C:=C:\cygwin64\bin
!ExitCode=00000000
!D:=D:\wtay\Downloads\Source_codes\petsc
ALLUSERSPROFILE=C:\ProgramData
ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
ANSYS_SYSDIR32=win32
ANSYS_SYSDIR=winx64
ANS_OLD_ATTACH=1
APPDATA=C:\Users\wtay\AppData\Roaming
AWP_LOCALE202=en-us
AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
CMAKE_PREFIX_PATH=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..;
CMPLR_ROOT=C:\Program Files (x86)\Intel\oneAPI\compiler\latest
COLUMNS=211
COMMONPROGRAMFILES=C:\Program Files\Common Files
COMPUTERNAME=DELL-T7610
COMSPEC=C:\Windows\system32\cmd.exe
CPATH=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dpl\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dev-utilities\latest\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64;
CUDA_PATH=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2
CUDA_PATH_V11_2=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2
CommandPromptType=Native
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
DPCPP_ROOT=C:\Program Files (x86)\Intel\oneAPI
DPL_ROOT=C:\Program Files (x86)\Intel\oneAPI\dpl\latest
DevEnvDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\
DriverData=C:\Windows\System32\Drivers\DriverData
ERRORSTATE=0
EXECIGNORE=*.dll
ExtensionSdkDir=C:\Program Files (x86)\Microsoft SDKs\Windows Kits\10\ExtensionSDKs
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
Framework40Version=v4.0
FrameworkDIR64=C:\Windows\Microsoft.NET\Framework64
FrameworkDir=C:\Windows\Microsoft.NET\Framework64\
FrameworkVersion64=v4.0.30319
FrameworkVersion=v4.0.30319
GFORTRAN_UNBUFFERED_PRECONNECTED=y
HCPAW=D:\wtay\nBox
HOME=/home/wtay
HOMEDRIVE=C:
HOMEPATH=\Users\wtay
HOSTNAME=DELL-T7610
HYDRA_BSTRAP_DEBUG=0
HYDRA_BSTRAP_DOWNSTREAM_STDIN=-1
HYDRA_BSTRAP_LAUNCHER=service
HYDRA_BSTRAP_LOCALHOST=DELL-T7610
HYDRA_BSTRAP_NODE_ID=0
HYDRA_BSTRAP_NUM_DOWNSTREAM_PROXIES=0
HYDRA_BSTRAP_NUM_LAUNCHES=-1
HYDRA_BSTRAP_PGID=0
HYDRA_BSTRAP_PROXY_ID=0
HYDRA_BSTRAP_SUBTREE_SIZE=1
HYDRA_BSTRAP_TREE_WIDTH=16
HYDRA_BSTRAP_UPSTREAM_FD=764
HYDRA_IP_VERSION=2
HYDRA_LAUNCH_TYPE=2
IFORT_COMPILER21=C:\Program Files (x86)\Intel\oneAPI\compiler\2021.2.0\windows\
INCLUDE=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\latest\env\..\include;C:\Program Files (x86)\Intel\oneAPI\dev-utilities\latest\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\ucrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\shared;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\winrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\cppwinrt
INFOPATH=/usr/local/info:/usr/share/info:/usr/info
INTELFPGAOCLSDKROOT=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\oclfpga
INTELGTDEBUGGERROOT=C:\Program Files (x86)\Intel\oneAPI\debugger\latest\env\\..
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses
INTEL_TARGET_ARCH=intel64
INTEL_TARGET_PLATFORM=windows
I_MPI_HYDRA_TOPOLIB=hwloc
I_MPI_HYDRA_UUID=7960790000-be2475be-e475e4-0000-00005
I_MPI_INFO_BRAND=Intel(R) Xeon(R)
I_MPI_INFO_CACHE1=0,0,1,1,2,2,3,3,4,4,5,5,8,8,9,9,10,10,11,11,12,12,13,13,16,16,17,17,18,18,19,19,20,20,21,21,24,24,25,25,26,26,27,27,28,28,29,29
I_MPI_INFO_CACHE2=0,0,1,1,2,2,3,3,4,4,5,5,8,8,9,9,10,10,11,11,12,12,13,13,16,16,17,17,18,18,19,19,20,20,21,21,24,24,25,25,26,26,27,27,28,28,29,29
I_MPI_INFO_CACHE3=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
I_MPI_INFO_CACHES=3
I_MPI_INFO_CACHE_SHARE=2,2,32
I_MPI_INFO_CACHE_SIZE=32768,262144,31457280
I_MPI_INFO_CORE=0,0,1,1,2,2,3,3,4,4,5,5,8,8,9,9,10,10,11,11,12,12,13,13,0,0,1,1,2,2,3,3,4,4,5,5,8,8,9,9,10,10,11,11,12,12,13,13
I_MPI_INFO_C_NAME=Unknown
I_MPI_INFO_DESC=1342177285
I_MPI_INFO_FLGB=641
I_MPI_INFO_FLGC=2143216639
I_MPI_INFO_FLGCEXT=0
I_MPI_INFO_FLGD=-1075053569
I_MPI_INFO_FLGDEXT=-1677720576
I_MPI_INFO_LCPU=48
I_MPI_INFO_MODE=775
I_MPI_INFO_NC=24
I_MPI_INFO_NP=2
I_MPI_INFO_PACK=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
I_MPI_INFO_SERIAL=E5-2697 v2
I_MPI_INFO_SIGN=198372
I_MPI_INFO_STATE=0
I_MPI_INFO_THREAD=0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1
I_MPI_INFO_VEND=1
I_MPI_ONEAPI_ROOT=C:\Program Files (x86)\Intel\oneAPI\mpi\2021.2.0
I_MPI_ROOT=C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..
LANG=en_US.UTF-8
LIB=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\lib\intel64\vc14;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib\release;C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\intel64_win;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17763.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17763.0\um\x64;
LIBPATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x86\store\references;C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17763.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17763.0;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;
LINES=71
LOCALAPPDATA=C:\Users\wtay\AppData\Local
LOGONSERVER=\\DELL-T7610
LSTC_LICENSE=ANSYS
MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\mic;
MIC_LIBRARY_PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\lib\mic;
MOZ_PLUGIN_PATH=C:\PROGRAM FILES (X86)\FOXIT SOFTWARE\FOXIT READER\plugins\
MPI_LOCALNRANKS=1
MPI_LOCALRANKID=0
MSMPI_BENCHMARKS=C:\Program Files\Microsoft MPI\Benchmarks\
MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
NUMBER_OF_PROCESSORS=48
NVCUDASAMPLES11_2_ROOT=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v11.2
NVCUDASAMPLES_ROOT=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v11.2
NVTOOLSEXT_PATH=C:\Program Files\NVIDIA Corporation\NvToolsExt\
OCL_ICD_FILENAMES=C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\emu\intelocl64_emu.dll;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\lib\x64\intelocl64.dll
OLDPWD=/cygdrive/d/wtay/Downloads/Source_codes
ORIGINAL_PATH=/cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Miniconda3:/cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin:/cygdrive/c/ProgramData/Miniconda3/Library/usr/bin:/cygdrive/c/ProgramData/Miniconda3/Library/bin:/cygdrive/c/ProgramData/Miniconda3/Scripts:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0:/cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn:/cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc
OS=Windows_NT
OneDrive=D:\wtay\OneDrive
OneDriveCommercial=D:\wtay\OneDrive
PATH=/usr/local/bin:/usr/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release:/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin:/cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Miniconda3:/cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin:/cygdrive/c/ProgramData/Miniconda3/Library/usr/bin:/cygdrive/c/ProgramData/Miniconda3/Library/bin:/cygdrive/c/ProgramData/Miniconda3/Scripts:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0:/cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn:/cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin:/cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PETSC_ARCH=petsc-dev_win64_impi_vs2017
PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc
PETSC_DIR_OLD=D:\wtay\Lib\petsc-3.9.3_win64_impi_vs2017
PMI_FD=724
PMI_RANK=0
PMI_SIZE=1
PRINTER=\\http://172.18.66.189:631\tsl_ljlvl2
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=3e04
PROFILEREAD=true
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files\Intel\Wired Networking\
PUBLIC=C:\Users\Public
PWD=/cygdrive/d/wtay/Downloads/Source_codes/petsc
Platform=x64
ProgramData=C:\ProgramData
SESSIONNAME=Console
SETVARS_COMPLETED=1
SHELL=/bin/bash
SHLVL=2
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
SW_SIM_MPIT=INTELMPI
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
SYSTEMDRIVE=C:
SYSTEMROOT=C:\Windows
TARGET_VS=vs2017
TARGET_VS_ARCH=amd64
TBBROOT=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..
TBB_BIN_DIR=C:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\
TBB_TARGET_ARCH=intel64
TBB_TARGET_VS=vc14
TEC_360_2020R2=C:\Program Files\Tecplot\Tecplot 360 EX 2020 R2\
TEMP=/tmp
TERM=xterm-256color
TMP=/tmp
TZ=Asia/Singapore
UATDATA=C:\Windows\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
UCRTVersion=10.0.17763.0
USER=DELL-T7610+wtay
USERDOMAIN=DELL-T7610
USERDOMAIN_ROAMINGPROFILE=DELL-T7610
USERNAME=wtay
USERPROFILE=C:\Users\wtay
UniversalCRTSdkDir=C:\Program Files (x86)\Windows Kits\10\
VARSDIR=C:\Program Files (x86)\Intel\oneAPI\dpl\latest\env\
VCIDEInstallDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\
VCINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\
VCToolsInstallDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\
VCToolsRedistDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Redist\MSVC\14.16.27012\
VCToolsVersion=14.16.27023
VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\
VS150COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\Tools\
VS2017INSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional
VSCMD_ARG_HOST_ARCH=x64
VSCMD_ARG_TGT_ARCH=x64
VSCMD_ARG_app_plat=Desktop
VSCMD_START_DIR=C:\Program Files (x86)\Intel\oneAPI
VSCMD_VER=15.9.35
VSINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\
VisualStudioVersion=15.0
WINDIR=C:\Windows
WindowsLibPath=C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17763.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17763.0
WindowsSDKLibVersion=10.0.17763.0\
WindowsSDKVersion=10.0.17763.0\
WindowsSdkBinPath=C:\Program Files (x86)\Windows Kits\10\bin\
WindowsSdkDir=C:\Program Files (x86)\Windows Kits\10\
WindowsSdkVerBinPath=C:\Program Files (x86)\Windows Kits\10\bin\10.0.17763.0\
_=/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/mpiexec
__DOTNET_ADD_64BIT=1
__DOTNET_PREFERRED_BITNESS=64
__MS_VC_INSTALL_PATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\
__VSCMD_PREINIT_PATH=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.2\libnvvp;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Tecplot\Tecplot 360 EX 2020 R2\bin;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\bin;C:\ProgramData\Miniconda3;C:\ProgramData\Miniconda3\Library\mingw-w64\bin;C:\ProgramData\Miniconda3\Library\usr\bin;C:\ProgramData\Miniconda3\Library\bin;C:\ProgramData\Miniconda3\Scripts;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\NVIDIA Corporation\Nsight Compute 2020.3.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Users\wtay\AppData\Local\Microsoft\WindowsApps;C:\Users\wtay\AppData\Local\GitHubDesktop\bin;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\lib;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\mpi\intel64\libfabric;
library_kind=release
                Defined make macro "MPIEXEC" to "/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/bin/mpiexec"
Checking for program /usr/libexec/ApplicationFirewall/socketfilterfw...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/socketfilterfw...not found
  Unable to find programs ['socketfilterfw'] providing listing of the specific search path
      Warning accessing /usr/libexec/ApplicationFirewall gives errors: can only concatenate str (not "builtin_function_or_method") to str
Checking for program /usr/local/bin/hostname...not found
Checking for program /usr/bin/hostname...found
                  Defined make macro "HOSTNAME" to "hostname"
Running Executable with threads to time it out at 60
Executing: hostname
stdout: DELL-T7610
              Return code from hostname: 0
              Hostname works, running network checks
Checking for program /sbin/ping...not found
Checking for program /usr/local/bin/ping...not found
Checking for program /usr/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/ping...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/ping...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/ping...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/ping...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/ping...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/ping...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/ping...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/ping...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/ping...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/ping...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/ping...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/ping...not found
Checking for program /cygdrive/c/Windows/system32/ping...found
                  Defined make macro "PING" to "ping"
Executing: uname -s
Detected Cygwin
Executing: ping -n 2 DELL-T7610
stdout:
Pinging DELL-T7610.stf.nus.edu.sg [fe80::3434:9188:334c:54aa%18] with 32 bytes of data:
Reply from fe80::3434:9188:334c:54aa%18: time=1ms
Reply from fe80::3434:9188:334c:54aa%18: time<1ms
Ping statistics for fe80::3434:9188:334c:54aa%18:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
              Return code from ping: 0
======== Checking running linked program
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes -I/tmp/petsc-v6m0e0sk/config.packages.MPI  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
MPI_Init(0,0);
MPI_Finalize();
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.exe    -MD -wd4996 -Z7 /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.o Ws2_32.lib
stdout:
conftest.obj : error LNK2019: unresolved external symbol MPI_Init referenced in function main
conftest.obj : error LNK2019: unresolved external symbol MPI_Finalize referenced in function main
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.exe : fatal error LNK1120: 2 unresolved externals
Possible ERROR while running linker: exit code 2
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.exe : fatal error LNK1120: 2 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.MPI\conftest.exe : fatal error LNK1120: 2 unresolved externals:
TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:426)
  Checking for MPI Datatype handles
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <mpi.h>
int main() {
int size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_size(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
  return 0;
                Defined "HAVE_MPI_LONG_DOUBLE" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <mpi.h>
int main() {
int size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_size(MPI_INT64_T, &size);
MPI_Finalize();
  return 0;
                Defined "HAVE_MPI_INT64_T" to "1"
TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:472)
  Returns true if SGI MPI is used
                Checking for functions [MPI_SGI_barrier] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.packages.MPI  -MD -wd4996 -Z7   /tmp/petsc-v6m0e0sk/config.libraries/conftest.c
stdout: conftest.c
Successful compile:
Source:
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
  return 0;
stdout:
LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe not found or not built by the last incremental link; performing full link
conftest.obj : error LNK2019: unresolved external symbol MPI_SGI_barrier referenced in function _check_MPI_SGI_barrier
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals
stdout:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externalsLinker output before filtering:
C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe : fatal error LNK1120: 1 unresolved externals:
              SGI MPI test failure
TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:482)
  Make sure C++ can compile and link
Checking for header mpi.h
Checking for C++ MPI_Finalize()
                Checking for functions [MPI_Finalize] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/config.libraries  -MD -GR -EHsc -Z7 -Zm200   -TP   -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.libraries/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
#include <mpi.h>
static void _check_MPI_Finalize() { int ierr;
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
  return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -GR -EHsc -Z7 -Zm200  /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Ws2_32.lib
TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:498)
  Make sure fortran include [mpif.h] and library symbols are found
Checking for fortran mpi_init()
                Checking for functions [] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort -c -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilersFortran -I/tmp/petsc-v6m0e0sk/config.libraries  -MD -Z7 -fpp  -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.libraries/conftest.F90
Successful compile:
Source:
      program main
#include "mpif.h"
       integer ierr
       call mpi_init(ierr)
      end
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe ifort  -o /tmp/petsc-v6m0e0sk/config.libraries/conftest.exe    -MD -Z7 -fpp /tmp/petsc-v6m0e0sk/config.libraries/conftest.o  /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Ws2_32.lib
stdout: LINK : C:\cygwin64\tmp\PETSC-~2\CONFIG~1.LIB\conftest.exe not found or not built by the last incremental link; performing full link
Checking for mpi.mod
Successful compile:
Source:
      program main
       use mpi
       integer(kind=selected_int_kind(5)) ierr,rank
       call mpi_init(ierr)
       call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
      end
                Defined "HAVE_MPI_F90MODULE" to "1"
TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:520)
  Check for the functions in MPI/IO
       - Define HAVE_MPIIO if they are present
       - Some older MPI 1 implementations are missing these
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/win32fe cl -c -o /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.o -I/tmp/petsc-v6m0e0sk/config.compilerFlags -I/tmp/petsc-v6m0e0sk/config.setCompilers -I/tmp/petsc-v6m0e0sk/config.compilers -I/tmp/petsc-v6m0e0sk/config.utilities.closure -I/tmp/petsc-v6m0e0sk/config.headers -I/tmp/petsc-v6m0e0sk/config.utilities.cacheDetails -I/tmp/petsc-v6m0e0sk/config.types -I/tmp/petsc-v6m0e0sk/config.functions -I/tmp/petsc-v6m0e0sk/config.utilities.featureTestMacros -I/tmp/petsc-v6m0e0sk/config.utilities.missing -I/tmp/petsc-v6m0e0sk/PETSc.options.scalarTypes -I/tmp/petsc-v6m0e0sk/config.libraries -I/tmp/petsc-v6m0e0sk/config.packages.MPI  -MD -wd4996 -Z7   -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include /tmp/petsc-v6m0e0sk/config.packages.MPI/conftest.c
stdout:
conftest.c
c:\cygwin64\tmp\petsc-v6m0e0sk\config.packages.mpi\conftest.c(12) : warning C4700: uninitialized local variable 'buf' used
c:\cygwin64\tmp\petsc-v6m0e0sk\config.packages.mpi\conftest.c(12) : warning C4700: uninitialized local variable 'fh' used
c:\cygwin64\tmp\petsc-v6m0e0sk\config.packages.mpi\conftest.c(18) : warning C4700: uninitialized local variable 'info' used
c:\cygwin64\tmp\petsc-v6m0e0sk\config.packages.mpi\conftest.c(18) : warning C4700: uninitialized local variable 'disp' used
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
                                                 MPI_File fh;
void *buf;
MPI_Status status;
if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
                                                 if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
                                                 MPI_Offset disp;
MPI_Info info;
if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
                                                 if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
                                                 if (MPI_File_close(&fh));
  return 0;
                Defined "HAVE_MPIIO" to "1"
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:624)
  Find MPI include paths from "mpicc -show" and use with CUDAC_FLAGS
TESTING: PetscArchMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:666)
                  Checking for functions [MPI_Type_get_envelope MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan MPI_Reduce_scatter MPI_Reduce_scatter_block] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
stdout: conftest.c
Successful compile:
Source:
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
char MPI_Reduce_scatter();
static void _check_MPI_Reduce_scatter() { MPI_Reduce_scatter(); }
char MPI_Reduce_scatter_block();
static void _check_MPI_Reduce_scatter_block() { MPI_Reduce_scatter_block(); }
int main() {
_check_MPI_Type_get_envelope();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();
_check_MPI_Reduce_scatter();
_check_MPI_Reduce_scatter_block();;
  return 0;
            Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
            Defined "HAVE_MPI_TYPE_DUP" to "1"
            Defined "HAVE_MPI_INIT_THREAD" to "1"
            Defined "HAVE_MPI_IALLREDUCE" to "1"
            Defined "HAVE_MPI_IBARRIER" to "1"
            Defined "HAVE_MPI_EXSCAN" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER_BLOCK" to "1"
            Checking for functions [MPIX_Iallreduce] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
stdout: conftest.c
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
  return 0;
stdout:
conftest.obj : error LNK2019: unresolved external symbol MPIX_Iallreduce referenced in function _check_MPIX_Iallreduce
stdout:
            Checking for functions [MPIX_Ibarrier] in library ['/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib', '/cygdrive/c/Program\\ Files\\ \\(x86\\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib'] []
stdout: conftest.c
Successful compile:
Source:
char MPIX_Ibarrier();
static void _check_MPIX_Ibarrier() { MPIX_Ibarrier(); }
int main() {
_check_MPIX_Ibarrier();;
  return 0;
stdout:
conftest.obj : error LNK2019: unresolved external symbol MPIX_Ibarrier referenced in function _check_MPIX_Ibarrier
stdout:
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int combiner = MPI_COMBINER_DUP;;
  return 0;
            Defined "HAVE_MPI_COMBINER_DUP" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int combiner = MPI_COMBINER_CONTIGUOUS;;
  return 0;
            Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
stdout: conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int combiner = MPI_COMBINER_NAMED;;
  return 0;
            Defined "HAVE_MPI_COMBINER_NAMED" to "1"
TESTING: checkVersion from config.packages.MPI(config/BuildSystem/config/package.py:1026)
  Uses self.version, self.minversion, self.maxversion, self.versionname, and self.versioninclude to determine if package has required version
Preprocessing source:
#include "mpi.h"
;petscpkgver(MPI_VERSION);
For mpi need 2 <= 3 <=
TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/package.py:955)
  By default we don't care about checking if the library is shared
    child config.packages.MPI 106.262847
TESTING: consistencyChecks from config.packages.zstd(config/BuildSystem/config/package.py:963)
  Checks run on the system and currently installed packages that need to be correct for the package now being configured
TESTING: alternateConfigureLibrary from config.packages.zstd(config/BuildSystem/config/package.py:959)
  Called if --with-packagename=0; does nothing by default
    child config.packages.zstd 0.008236
TESTING: consistencyChecks from config.packages.yaml(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:959)
    child config.packages.yaml 0.007603
TESTING: consistencyChecks from config.packages.sycl(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.sycl(config/BuildSystem/config/package.py:959)
    child config.packages.sycl 0.007421
TESTING: consistencyChecks from config.packages.ssl(config/BuildSystem/config/packages/ssl.py:31)
TESTING: alternateConfigureLibrary from config.packages.ssl(config/BuildSystem/config/package.py:959)
    child config.packages.ssl 0.009005
TESTING: consistencyChecks from config.packages.sprng(config/BuildSystem/config/package.py:963)
TESTING: alternateConfigureLibrary from config.packages.sprng(config/BuildSystem/config/package.py:959)
    child config.packages.sprng 0.007853
      PETSc clone, checking for Sowing
Checking for program /usr/local/bin/pdflatex...not found
Checking for program /usr/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/pdflatex...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/pdflatex...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/pdflatex...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/pdflatex...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/pdflatex...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/pdflatex...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/pdflatex...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/pdflatex...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/pdflatex...not found
Checking for program /cygdrive/c/Windows/system32/pdflatex...not found
Checking for program /cygdrive/c/Windows/pdflatex...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/pdflatex...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/pdflatex...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/pdflatex...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/pdflatex...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/pdflatex...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/pdflatex...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/pdflatex...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/pdflatex...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/pdflatex...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/pdflatex...not found
Checking for program /usr/local/bin/bfort...not found
Checking for program /usr/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/bfort...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/bfort...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/bfort...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/bfort...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/bfort...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/bfort...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/bfort...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/bfort...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/bfort...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/bfort...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/bfort...not found
Checking for program /cygdrive/c/Windows/system32/bfort...not found
Checking for program /cygdrive/c/Windows/bfort...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/bfort...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/bfort...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/bfort...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/bfort...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/bfort...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/bfort...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/bfort...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/bfort...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/bfort...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/bfort...not found
Checking for program /usr/local/bin/doctext...not found
Checking for program /usr/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/doctext...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/doctext...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/doctext...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/doctext...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/doctext...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/doctext...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/doctext...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/doctext...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/doctext...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/doctext...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/doctext...not found
Checking for program /cygdrive/c/Windows/system32/doctext...not found
Checking for program /cygdrive/c/Windows/doctext...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/doctext...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/doctext...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/doctext...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/doctext...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/doctext...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/doctext...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/doctext...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/doctext...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/doctext...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/doctext...not found
Checking for program /usr/local/bin/mapnames...not found
Checking for program /usr/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/mapnames...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/mapnames...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/mapnames...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/mapnames...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/mapnames...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/mapnames...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/mapnames...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/mapnames...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/mapnames...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/mapnames...not found
Checking for program /cygdrive/c/Windows/system32/mapnames...not found
Checking for program /cygdrive/c/Windows/mapnames...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/mapnames...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/mapnames...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/mapnames...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/mapnames...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/mapnames...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/mapnames...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/mapnames...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/mapnames...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/mapnames...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/mapnames...not found
Checking for program /usr/local/bin/bib2html...not found
Checking for program /usr/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/tbb/latest/redist/intel64/vc14/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/utils/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/libfabric/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/release/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dpcpp-ct/latest/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/dev-utilities/latest/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/debugger/latest/gdb/intel64/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin/intel64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/redist/intel64_win/compiler/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/host/windows64/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/llvm/aocl-bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/windows64/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclfpga/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/VC/Tools/MSVC/14.16.27023/bin/HostX64/x64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/VC/VCPackages/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TestWindow/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/Roslyn/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/x64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Team Tools/Performance Tools/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17763.0/x64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/MSBuild/15.0/bin/bib2html...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/Tools/bib2html...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/bib2html...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/libnvvp/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/bib2html...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2020 R2/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/bin/bib2html...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/bib2html...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/mingw-w64/bin/bib2html...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/usr/bin/bib2html...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Library/bin/bib2html...not found
Checking for program /cygdrive/c/ProgramData/Miniconda3/Scripts/bib2html...not found
Checking for program /cygdrive/c/Windows/system32/bib2html...not found
Checking for program /cygdrive/c/Windows/bib2html...not found
Checking for program /cygdrive/c/Windows/System32/Wbem/bib2html...not found
Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/bib2html...not found
Checking for program /cygdrive/c/Windows/System32/OpenSSH/bib2html...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/bib2html...not found
Checking for program /cygdrive/c/Program Files/NVIDIA Corporation/Nsight Compute 2020.3.0/bib2html...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/110/Tools/Binn/bib2html...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/Microsoft/WindowsApps/bib2html...not found
Checking for program /cygdrive/c/Users/wtay/AppData/Local/GitHubDesktop/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/lib/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2020.4.311/windows/mpi/intel64/libfabric/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/oclgpu/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/ioc/bin/bib2html...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/lib/ocloc/bib2html...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc/lib/petsc/bin/win32fe/bib2html...not found
      Bfort not found. Installing sowing for FortranStubs
**** Configure header /tmp/petsc-v6m0e0sk/confdefs.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#define PETSC_Alignx(a,b)
#define PETSC_CLANGUAGE_C 1
#define PETSC_CXX_INLINE inline
#define PETSC_CXX_RESTRICT __restrict
#define PETSC_C_INLINE inline
#define PETSC_C_RESTRICT __restrict
#define PETSC_FORTRAN_CHARLEN_T int
#define PETSC_FORTRAN_TYPE_INITIALIZE  = -2
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_CLOSESOCKET 1
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_HAVE_CXX_DIALECT_CXX11 1
#define PETSC_HAVE_CXX_DIALECT_CXX14 1
#define PETSC_HAVE_DIRECT_H 1
#define PETSC_HAVE_DOS_H 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_FORTRAN_CAPS 1
#define PETSC_HAVE_FORTRAN_FLUSH 1
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_FORTRAN_TYPE_STAR 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_IMMINTRIN_H 1
#define PETSC_HAVE_INTTYPES_H 1
#define PETSC_HAVE_IO_H 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_HAVE_ISNORMAL 1
#define PETSC_HAVE_I_MPI_NUMVERSION 20210200300
#define PETSC_HAVE_LGAMMA 1
#define PETSC_HAVE_LOG2 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE_MPICH_NUMVERSION 30300300
#define PETSC_HAVE_MPIIO 1
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#define PETSC_HAVE_MPI_COMBINER_NAMED 1
#define PETSC_HAVE_MPI_EXSCAN 1
#define PETSC_HAVE_MPI_F90MODULE 1
#define PETSC_HAVE_MPI_F90MODULE_VISIBILITY 1
#define PETSC_HAVE_MPI_FINALIZED 1
#define PETSC_HAVE_MPI_GET_ACCUMULATE 1
#define PETSC_HAVE_MPI_GET_LIBRARY_VERSION 1
#define PETSC_HAVE_MPI_IALLREDUCE 1
#define PETSC_HAVE_MPI_IBARRIER 1
#define PETSC_HAVE_MPI_INIT_THREAD 1
#define PETSC_HAVE_MPI_INT64_T 1
#define PETSC_HAVE_MPI_IN_PLACE 1
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#define PETSC_HAVE_MPI_NEIGHBORHOOD_COLLECTIVES 1
#define PETSC_HAVE_MPI_NONBLOCKING_COLLECTIVES 1
#define PETSC_HAVE_MPI_ONE_SIDED 1
#define PETSC_HAVE_MPI_PROCESS_SHARED_MEMORY 1
#define PETSC_HAVE_MPI_REDUCE_LOCAL 1
#define PETSC_HAVE_MPI_REDUCE_SCATTER 1
#define PETSC_HAVE_MPI_REDUCE_SCATTER_BLOCK 1
#define PETSC_HAVE_MPI_RGET 1
#define PETSC_HAVE_MPI_TYPE_DUP 1
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#define PETSC_HAVE_MPI_WIN_CREATE 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_STRICMP 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_WINDOWSX_H 1
#define PETSC_HAVE_WINSOCK2_H 1
#define PETSC_HAVE_WS2TCPIP_H 1
#define PETSC_HAVE_WSAGETLASTERROR 1
#define PETSC_HAVE__ACCESS 1
#define PETSC_HAVE__GETCWD 1
#define PETSC_HAVE__LSEEK 1
#define PETSC_HAVE__MKDIR 1
#define PETSC_HAVE__PIPE 1
#define PETSC_HAVE__SLEEP 1
#define PETSC_HAVE___INT64 1
#define PETSC_IS_COLORING_MAX USHRT_MAX
#define PETSC_IS_COLORING_VALUE_TYPE short
#define PETSC_IS_COLORING_VALUE_TYPE_F integer2
#define PETSC_LEVEL1_DCACHE_LINESIZE 32
#define PETSC_MAX_PATH_LEN 4096
#define PETSC_MEMALIGN 16
#define PETSC_MISSING_SIGALRM 1
#define PETSC_MISSING_SIGBUS 1
#define PETSC_MISSING_SIGCHLD 1
#define PETSC_MISSING_SIGCONT 1
#define PETSC_MISSING_SIGHUP 1
#define PETSC_MISSING_SIGKILL 1
#define PETSC_MISSING_SIGPIPE 1
#define PETSC_MISSING_SIGQUIT 1
#define PETSC_MISSING_SIGSTOP 1
#define PETSC_MISSING_SIGSYS 1
#define PETSC_MISSING_SIGTRAP 1
#define PETSC_MISSING_SIGTSTP 1
#define PETSC_MISSING_SIGURG 1
#define PETSC_MISSING_SIGUSR1 1
#define PETSC_MISSING_SIGUSR2 1
#define PETSC_MPIU_IS_COLORING_VALUE_TYPE MPI_UNSIGNED_SHORT
#define PETSC_NEEDS_UTYPE_TYPEDEFS 1
#define PETSC_SIGNAL_CAST
#define PETSC_SIZEOF_ENUM 4
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_USE_AVX512_KERNELS 1
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_CTABLE 1
#define PETSC_USE_DEBUG 1
#define PETSC_USE_INFO 1
#define PETSC_USE_LOG 1
#define PETSC_USE_PROC_FOR_SIZE 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_USING_64BIT_PTR 1
#define PETSC_USING_F2003 1
#define PETSC_USING_F90FREEFORM 1
#define PETSC_VERSION_BRANCH_GIT "release"
#define PETSC_VERSION_DATE_GIT "2021-04-14 14:51:36 +0000"
#define PETSC_VERSION_GIT "v3.15.0-115-g500a29e669"
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC_gid_t int
#define PETSC_uid_t int
#define _USE_MATH_DEFINES 1
#endif
**** C specific Configure header /tmp/petsc-v6m0e0sk/conffix.h ****
typedef int mode_t;
typedef int int32_t;
typedef int pid_t;
#if defined(__cplusplus)
extern "C" {
#include <stddef.h>
int getdomainname(char *, size_t);
double drand48(void);
void   srand48(long int);
#else
#include <stddef.h>
#endif
#endif
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error! sowing on windows requires cygwin/g++. Please install it with cygwin setup.exe
  File "/cygdrive/d/wtay/Downloads/Source_codes/petsc/config/configure.py", line 458, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/cygdrive/d/wtay/Downloads/Source_codes/petsc/config/BuildSystem/config/framework.py", line 1300, in configure
    self.processChildren()
  File "/cygdrive/d/wtay/Downloads/Source_codes/petsc/config/BuildSystem/config/framework.py", line 1288, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/cygdrive/d/wtay/Downloads/Source_codes/petsc/config/BuildSystem/config/framework.py", line 1263, in serialEvaluation
    child.configure()
  File "/cygdrive/d/wtay/Downloads/Source_codes/petsc/config/BuildSystem/config/packages/sowing.py", line 111, in configure
    raise RuntimeError('Error! sowing on windows requires cygwin/g++. Please install it with cygwin setup.exe')
Finishing configure run at Thu, 15 Apr 2021 12:19:45 +0800
