[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
TAY wee-beng zonexo at gmail.com
Wed Apr 14 22:49:31 CDT 2021
On 15/4/2021 11:42 am, Satish Balay wrote:
> The c examples ran fine. However fortran has issues.
> ex5f.F90(83): error #6405: The same named entity from different modules and/or program units cannot be referenced.   [PETSC_COMM_WORLD]
>        call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
> Is the fortran compiler defaulting to F2008/2018 mode?
So how can I check it?
> You can try building 'release' branch of petsc git repo and see if this problem persists.
> Satish
> On Thu, 15 Apr 2021, TAY wee-beng wrote:
>> Hi Satish,
>> I use option 1, but the errors I got from make check seems similar. I have
>> attached the output.
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>> Personal research webpage: _http://tayweebeng.wixsite.com/website_
>> Youtube research showcase: _https://goo.gl/PtvdwQ_
>> linkedin: _https://www.linkedin.com/in/tay-weebeng_
>> On 15/4/2021 9:54 am, Satish Balay wrote:
>>> 1. You can avoid this complexity if you can use in-place install of PETSc
>>> [i.e do not use --prefix option to build PETSc]
>>> 2. For a prefix install - the following patch should fix the issue [i.e
>>> requires rerunning 'configure; make; make install']
>>> diff --git a/config/BuildSystem/config/compilerOptions.py
>>> b/config/BuildSystem/config/compilerOptions.py
>>> index bdfd209203..b2e02783d9 100644
>>> --- a/config/BuildSystem/config/compilerOptions.py
>>> +++ b/config/BuildSystem/config/compilerOptions.py
>>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
>>>          if not status:
>>>            if compiler.find('win32fe') > -1:
>>>              version = '\\n'.join(output.split('\n')[0:2])
>>> +          version = version.replace('\r','')
>>>            else:
>>>              #PGI/Windows writes an empty '\r\n' on the first line of output
>>>              if output.count('\n') > 1 and output.split('\n')[0] == '\r':
>>> 3. For testing a prefix install - you would do:
>>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>> PETSC_ARCH=""
>>> [these instructions are printed to the screen when you run 'make install'
>>> Satish
>>>> Hi Satish,
>>>> I tried a few things, not sure if it's correct. But it doesn't seem to work
>>>> I edit petscvariables in
>>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>> and
>>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
>>>> from:
>>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
>>>> MPICC_SHOW = Unavailable
>>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> MPICXX_SHOW = Unavailable
>>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
>>>> 2017 11:10:38 AM
>>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
>>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
>>>> to
>>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
>>>> 19.16.27045 for x64
>>>> 19.16.27045 for x64
>>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
>>>> applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
>>>> Then in cygwin,
>>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
>>>> export PETSC_DIR=`pwd`
>>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>> make check
>>>> make: *** No rule to make target 'check'.  Stop.
>>>> Also:
>>>> $ export PETSC_DIR=`pwd`
>>>> make check
>>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: *** target
>>>> pattern contains no '%'.  Stop.
>>>> Yours sincerely,
>>>>>> Hi Satish,
>>>>>> Sorry, what do you mean by "manually fix up this file"?
>>>>>> Should I edit the petscvariables file?
>>>>> yes
>>>>>> Do I need to rebuild the lib?
>>>>> no
>>>>> After editing the file - run 'make check'
>>>>> Satish
>>>>>> I guess this problem is related to the new Intel oneAPI if I'm not wrong.
>>>>>> No
>>>>>> such problem previously.
>>>>>> Yours sincerely,
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> 27,
>>>>>>> 2017 11:10:38 AM
>>>>>>> on
>>>>>>> I'm not sure what happened here. You might want to just manually fix up
>>>>>>> this
>>>>>>> file
>>>>>>> 27,
>>>>>>> 19.16.27045 for x64
>>>>>>> 27,
>>>>>>> 19.16.27045 for x64
>>>>>>> 27,
>>>>>>> 20210228_000000
>>>>>>> Satish
>>>>>>>> Hi all,
>>>>>>>> I have attached the req file
>>>>>>>> Yours sincerely,
>>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
>>>>>>>>> Please send the file
>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
>>>>>>>>> Satish
>>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I redo the installation:
>>>>>>>>>> /*Now to install the libraries do:*//*
>>>>>>>>>> *//*make
>>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
>>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
>>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
>>>>>>>>>> *//*$ make
>>>>>>>>>> *//**** Using
>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
>>>>>>>>>> *//**** Installing PETSc at prefix location:
>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
>>>>>>>>>> *//*Install complete.*//*
>>>>>>>>>> *//*Now to check if the libraries are working do (in current
>>>>>>>>>> directory):*//*
>>>>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>> PETSC_ARCH="" check*//*
>>>>>>>>>> *//*/usr/bin/make  --no-print-directory -f makefile
>>>>>>>>>> mpi4py-install
>>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
>>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
>>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
>>>>>>>>>> I ran the check:
>>>>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
>>>>>>>>>> *** missing separator.  Stop.*/
>>>>>>>>>> Why is this happening?
>>>>>>>>>> Yours sincerely,
>>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
>>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
>>>>>>>>>>> When you do the install it will tell you exactly what to run to run
>>>>>>>>>>> "check".
>>>>>>>>>>> You might double check that .
>>>>>>>>>>> Mark
>>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
>>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
>>>>>>>>>>>          Hi Barry,
>>>>>>>>>>>          Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
>>>>>>>>>>>          Maybe I ran it wrongly initially at where the lib is stored:
>>>>>>>>>>>          /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
>>>>>>>>>>>          My source is at
>>>>>>>>>>>          /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
>>>>>>>>>>>          Now I ran:
>>>>>>>>>>>          *//*cd src/ksp/ksp/tutorials/*//*
>>>>>>>>>>>          *//*make ex2f*/
>>>>>>>>>>>          /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
>>>>>>>>>>>          ifort -MD -Z7 -fpp  -MD -Z7 -fpp
>>>>>>>>>>>          -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
>>>>>>>>>>>          -I/cygdrive/d/wtay/Downloads/S*//*
>>>>>>>>>>>          *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
>>>>>>>>>>>          -I/cygdrive/c/Program\ Files\
>>>>>>>>>>>          \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
>>>>>>>>>>>          -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
>>>>>>>>>>>          *//*15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>>>>>          -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
>>>>>>>>>>>          *//*_vs2017/lib -lpetsc -lflapack -lfblas
>>>>>>>>>>>          Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
>>>>>>>>>>>          \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib
>>>>>>>>>>>          /cygdrive/c/*//*
>>>>>>>>>>>          *//*Program\ Files\
>>>>>>>>>>>          \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
>>>>>>>>>>>          Gdi32.lib
>>>>>>>>>>>          User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
>>>>>>>>>>>          *//*ifort: command line warning #10006: ignoring unknown
>>>>>>>>>>>          option
>>>>>>>>>>>          '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>          option
>>>>>>>>>>>          '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>>>>>          *//*ex2f.F90(80): error #6405: The same named entity from
>>>>>>>>>>>          [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>          *//*      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(80): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          the name of a procedure. [PETSC_COMM_WORLD]*//*
>>>>>>>>>>>          *//*ex2f.F90(81): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(81): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(93): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(93): error #7112: This actual argument must not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(159): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call
>>>>>>>>>>>          VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(159): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*      call
>>>>>>>>>>>          *//*ex2f.F90(171): error #6405: The same named entity from
>>>>>>>>>>>          *//*         call
>>>>>>>>>>>          PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(171): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*         call
>>>>>>>>>>>          *//*ex2f.F90(193): error #6405: The same named entity from
>>>>>>>>>>>          *//*      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
>>>>>>>>>>>          *//*ex2f.F90(193): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*ex2f.F90(319): error #6405: The same named entity from
>>>>>>>>>>>          *//*ex2f.F90(319): error #7112: This actual argument must
>>>>>>>>>>>          not
>>>>>>>>>>>          be
>>>>>>>>>>>          *//*compilation aborted for ex2f.F90 (code 1)*//*
>>>>>>>>>>>          *//*make: ***
>>>>>>>>>>>          [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
>>>>>>>>>>>          ex2f] Error 1*/
>>>>>>>>>>>          I have also attached the "/*make check*/" output. Seems like
>>>>>>>>>>>          there's problem with fortran compile.
>>>>>>>>>>>          Yours sincerely,
>>>>>>>>>>>          <http://tayweebeng.wixsite.com/website>_
>>>>>>>>>>>          <https://goo.gl/PtvdwQ>_
>>>>>>>>>>>          <https://www.linkedin.com/in/tay-weebeng>_
>>>>>>>>>>>          On 14/4/2021 3:47 pm, Barry Smith wrote:
>>>>>>>>>>>>           Please send configure.log and make.log and the results of
>>>>>>>>>>>>          "make
>>>>>>>>>>>>          check" so we have the details on the build process.
>>>>>>>>>>>>>          /*No rule to make target
>>>>>>>>>>>>>          '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
>>>>>>>>>>>>>          Stop.*/
>>>>>>>>>>>>           Looks funny; it does not seem to separate the PETSc
>>>>>>>>>>>>          directory
>>>>>>>>>>>>          from its configuration directory appropriately.
>>>>>>>>>>>>            Are you sure
>>>>>>>>>>>>>          *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
>>>>>>>>>>>>          are run in the appropriate directory so that PETSC_DIR is
>>>>>>>>>>>>          correct.
>>>>>>>>>>>>          Barry
>>>>>>>>>>>>>          On Apr 14, 2021, at 2:20 AM, TAY wee-beng
>>>>>>>>>>>>>          Hi Mark,
>>>>>>>>>>>>>          I'm not sure what's wrong.
>>>>>>>>>>>>>          In VS2017 + Intel oneAPI,
>>>>>>>>>>>>>          even after adding the full path:
>>>>>>>>>>>>>          #include
>>>>>>>>>>>>>          <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
>>>>>>>>>>>>>          I got a new error:
>>>>>>>>>>>>>          /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
>>>>>>>>>>>>>          [Intel(R) 64]...*//*
>>>>>>>>>>>>>          *//*ex2f.F90*//*
>>>>>>>>>>>>>          *//*petscksp.h(8): #error: can't find include file:
>>>>>>>>>>>>>          petsc/finclude/petscpc.h*//*
>>>>>>>>>>>>>          *//*ex2f : error PRJ0019: A tool returned an error code*/
>>>>>>>>>>>>>          Note that I have also specified the include dir in the
>>>>>>>>>>>>>          properties:
>>>>>>>>>>>>>          /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
>>>>>>>>>>>>>          I also tried in cygwin:
>>>>>>>>>>>>>          *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
>>>>>>>>>>>>>          *//*make ex2f*/
>>>>>>>>>>>>>          I got the error:
>>>>>>>>>>>>>          /*$ make ex2f*//*
>>>>>>>>>>>>>          *//*makefile:41:
>>>>>>>>>>>>>          /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
>>>>>>>>>>>>>          No such file or directory*//*
>>>>>>>>>>>>>          *//*make: *** No rule to make target
>>>>>>>>>>>>>          Stop.*/
>>>>>>>>>>>>>          Somehow it just doesn't work. Building the library has no
>>>>>>>>>>>>>          problem though.
>>>>>>>>>>>>>          I wonder what's wrong.
>>>>>>>>>>>>>          Yours sincerely,
>>>>>>>>>>>>>          On 14/4/2021 9:31 am, Mark Adams wrote:
>>>>>>>>>>>>>>          PETSc has changed Fortran syntax since v3.9. You should
>>>>>>>>>>>>>>          upgrade. Look at examples for how to use modules etc.
>>>>>>>>>>>>>>              2021.2.0
>>>>>>>>>>>>>>              *//*global.F90*//*
>>>>>>>>>>>>>>              *//*global.F90(3): #error: can't find include file:
>>>>>>>>>>>>>>              petsc/finclude/petsc.h*//*
>>>>>>>>>>>>>>              *//*global.F90(937): #error: can't find include file:
>>>>>>>>>>>>>>          It looks like you might not have your PETSC_ARCH
>>>>>>>>>>>>>>          variable set.
>>>>>>>>>>>>>>          You should get a full path to /finclude/petsc.h. Look at
>>>>>>>>>>>>>>          the
>>>>>>>>>>>>>>          compile line.
>>>>>>>>>>>>>>          There are PETSc examples that you you can make to see an
>>>>>>>>>>>>>>          example of a correct make. For example,
>>>>>>>>>>>>>>          > cd petsc/src/ksp/ksp/tutorials
>>>>>>>>>>>>>>           >  >  >  >  >  >  >  >  >  >  >  >  >  >  >  > make
>>>>>>>>>>>>>>           >  >  >  >  >  >  >  > ex2f
>>>>>>>>>>>>>>          should make an executable and you can look at the compile
>>>>>>>>>>>>>>          and
>>>>>>>>>>>>>>          link lines, and compare to what you are using.
>>>>>>>>>>>>>>          Mark
>>>>>>>>>>>>>>              Yours sincerely,
