[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
Satish Balay
balay at mcs.anl.gov
Wed Apr 14 23:27:50 CDT 2021
On Thu, 15 Apr 2021, TAY wee-beng wrote:
> On 15/4/2021 11:42 am, Satish Balay wrote:
> > The c examples ran fine. However fortran has issues.
> > ex5f.F90(83): error #6405: The same named entity from different modules
> > and/or program units cannot be referenced. [PETSC_COMM_WORLD]
> > call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
> > Is the fortran compiler defaulting to F2008/2018 mode?
> > You can try building 'release' branch of petsc git repo and see if this
> > problem persists.
> I tried and got this error below, configure.log attached.
> export PETSC_DIR=`pwd`
> export PETSC_ARCH=petsc-dev_win64_impi_vs2017
> ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> --with-cxx='win32fe cl' --with-mpi-include=/cygdrive/c/Program\ Files\
> \(x86\)/Intel/oneAPI/mpi/latest/include --with-mpi-lib='[/cygdrive/c/Program\
> Files\
> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\ Files\
> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\
> Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi
> _ilp64.lib]' --download-fblaslapack=1 --with-debugging=1
> --with-fortran-interfaces=1
> Configuring PETSc to compile on your system
> TESTING: alternateConfigureLibrary from
> config.packages.sprng(config/BuildSystem/config/package.py:959)
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Error! sowing on windows requires cygwin/g++. Please install it with cygwin
> setup.exe
yes - this is a requirement for using the git repo.
I guess alternatively - you can try:
https://ftp.mcs.anl.gov/pub/petsc/petsc-main.tar.gz
Satish
> > Satish
> >> Hi Satish,
> >> I use option 1, but the errors I got from make check seems similar. I have
> >> attached the output.
> >> Thank you very much.
> >> Yours sincerely,
> >> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> >> Personal research webpage: _http://tayweebeng.wixsite.com/website_
> >> Youtube research showcase: _https://goo.gl/PtvdwQ_
> >> linkedin: _https://www.linkedin.com/in/tay-weebeng_
> >> On 15/4/2021 9:54 am, Satish Balay wrote:
> >>> 1. You can avoid this complexity if you can use in-place install of PETSc
> >>> [i.e do not use --prefix option to build PETSc]
> >>> 2. For a prefix install - the following patch should fix the issue [i.e
> >>> requires rerunning 'configure; make; make install']
> >>> diff --git a/config/BuildSystem/config/compilerOptions.py
> >>> b/config/BuildSystem/config/compilerOptions.py
> >>> index bdfd209203..b2e02783d9 100644
> >>> --- a/config/BuildSystem/config/compilerOptions.py
> >>> +++ b/config/BuildSystem/config/compilerOptions.py
> >>> @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
> >>> if not status:
> >>> if compiler.find('win32fe') > -1:
> >>> version = '\\n'.join(output.split('\n')[0:2])
> >>> + version = version.replace('\r','')
> >>> else:
> >>> #PGI/Windows writes an empty '\r\n' on the first line of
> >>> output
> >>> if output.count('\n') > 1 and output.split('\n')[0] == '\r':
> >>> 3. For testing a prefix install - you would do:
> >>> cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>> make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>> PETSC_ARCH=""
> >>> [these instructions are printed to the screen when you run 'make install'
> >>> Satish
> >>>> Hi Satish,
> >>>> I tried a few things, not sure if it's correct. But it doesn't seem to
> >>>> work
> >>>> I edit petscvariables in
> >>>> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>> and
> >>>> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >>>> from:
> >>>> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> >>>> 2017 11:10:38 AM
> >>>> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
> >>>> MPICC_SHOW = Unavailable
> >>>> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>> 27,
> >>>> 2017 11:10:38 AM
> >>>> MPICXX_SHOW = Unavailable
> >>>> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb
> >>>> 27,
> >>>> 2017 11:10:38 AM
> >>>> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running
> >>>> on
> >>>> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> >>>> to
> >>>> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
> >>>> 19.16.27045 for x64
> >>>> 27,
> >>>> 19.16.27045 for x64
> >>>> 27,
> >>>> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
> >>>> applications running on Intel(R) 64, Version 2021.2.0 Build
> >>>> 20210228_000000
> >>>> Then in cygwin,
> >>>> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
> >>>> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>> make check
> >>>> make: *** No rule to make target 'check'. Stop.
> >>>> Also:
> >>>> $ export PETSC_DIR=`pwd`
> >>>> make check
> >>>> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: ***
> >>>> target
> >>>> pattern contains no '%'. Stop.
> >>>> Yours sincerely,
> >>>>>> Hi Satish,
> >>>>>> Sorry, what do you mean by "manually fix up this file"?
> >>>>>> Should I edit the petscvariables file?
> >>>>> yes
> >>>>>> Do I need to rebuild the lib?
> >>>>> no
> >>>>> After editing the file - run 'make check'
> >>>>> Satish
> >>>>>> I guess this problem is related to the new Intel oneAPI if I'm not
> >>>>>> wrong.
> >>>>>> No
> >>>>>> such problem previously.
> >>>>>> Yours sincerely,
> >>>>>>> 27,
> >>>>>>> 2017 11:10:38 AM
> >>>>>>> Feb
> >>>>>>> 27,
> >>>>>>> 2017 11:10:38 AM
> >>>>>>> 27,
> >>>>>>> 2017 11:10:38 AM
> >>>>>>> running
> >>>>>>> on
> >>>>>>> I'm not sure what happened here. You might want to just manually fix
> >>>>>>> up
> >>>>>>> this
> >>>>>>> file
> >>>>>>> 27,
> >>>>>>> 19.16.27045 for x64
> >>>>>>> Feb
> >>>>>>> 27,
> >>>>>>> 19.16.27045 for x64
> >>>>>>> 27,
> >>>>>>> 20210228_000000
> >>>>>>> Satish
> >>>>>>>> Hi all,
> >>>>>>>> I have attached the req file
> >>>>>>>> Yours sincerely,
> >>>>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
> >>>>>>>>> Please send the file
> >>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> >>>>>>>>> Satish
> >>>>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
> >>>>>>>>>> Hi,
> >>>>>>>>>> I redo the installation:
> >>>>>>>>>> /*Now to install the libraries do:*//*
> >>>>>>>>>> *//*make
> >>>>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
> >>>>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
> >>>>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
> >>>>>>>>>> *//*$ make
> >>>>>>>>>> *//**** Using
> >>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>>>> *//**** Installing PETSc at prefix location:
> >>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>>>> *//*Install complete.*//*
> >>>>>>>>>> *//*Now to check if the libraries are working do (in current
> >>>>>>>>>> directory):*//*
> >>>>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>> PETSC_ARCH="" check*//*
> >>>>>>>>>> *//*/usr/bin/make --no-print-directory -f makefile
> >>>>>>>>>> mpi4py-install
> >>>>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
> >>>>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
> >>>>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
> >>>>>>>>>> I ran the check:
> >>>>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
> >>>>>>>>>> *** missing separator. Stop.*/
> >>>>>>>>>> Why is this happening?
> >>>>>>>>>> Yours sincerely,
> >>>>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
> >>>>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
> >>>>>>>>>>> When you do the install it will tell you exactly what to run to
> >>>>>>>>>>> run
> >>>>>>>>>>> "check".
> >>>>>>>>>>> You might double check that .
> >>>>>>>>>>> Mark
> >>>>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
> >>>>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
> >>>>>>>>>>> Hi Barry,
> >>>>>>>>>>> Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
> >>>>>>>>>>> Maybe I ran it wrongly initially at where the lib is
> >>>>>>>>>>> stored:
> >>>>>>>>>>> /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
> >>>>>>>>>>> My source is at
> >>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
> >>>>>>>>>>> Now I ran:
> >>>>>>>>>>> *//*cd src/ksp/ksp/tutorials/*//*
> >>>>>>>>>>> *//*make ex2f*/
> >>>>>>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
> >>>>>>>>>>> ifort -MD -Z7 -fpp -MD -Z7 -fpp
> >>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
> >>>>>>>>>>> -I/cygdrive/d/wtay/Downloads/S*//*
> >>>>>>>>>>> *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
> >>>>>>>>>>> -I/cygdrive/c/Program\ Files\
> >>>>>>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/include ex2f.F90
> >>>>>>>>>>> -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
> >>>>>>>>>>> *//*15.0_win64_impi_vs2017/lib
> >>>>>>>>>>> -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>> -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>>> -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
> >>>>>>>>>>> *//*_vs2017/lib -lpetsc -lflapack -lfblas
> >>>>>>>>>>> Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
> >>>>>>>>>>> /cygdrive/c/*//*
> >>>>>>>>>>> *//*Program\ Files\
> >>>>>>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
> >>>>>>>>>>> Gdi32.lib
> >>>>>>>>>>> User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o
> >>>>>>>>>>> ex2f*//*
> >>>>>>>>>>> *//*ifort: command line warning #10006: ignoring unknown
> >>>>>>>>>>> option
> >>>>>>>>>>> '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>> option
> >>>>>>>>>>> '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>>> *//*ex2f.F90(80): error #6405: The same named entity from
> >>>>>>>>>>> different modules and/or program units cannot be
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(80): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> the name of a procedure. [PETSC_COMM_WORLD]*//*
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*ex2f.F90(81): error #6405: The same named entity from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(81): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*ex2f.F90(93): error #6405: The same named entity from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(93): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//*ex2f.F90(159): error #6405: The same named entity
> >>>>>>>>>>> from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(159): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*ex2f.F90(171): error #6405: The same named entity
> >>>>>>>>>>> from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(171): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*ex2f.F90(193): error #6405: The same named entity
> >>>>>>>>>>> from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
> >>>>>>>>>>> *//*ex2f.F90(193): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//*ex2f.F90(319): error #6405: The same named entity
> >>>>>>>>>>> from
> >>>>>>>>>>> referenced.
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*ex2f.F90(319): error #7112: This actual argument must
> >>>>>>>>>>> not
> >>>>>>>>>>> be
> >>>>>>>>>>> *//* call
> >>>>>>>>>>> *//*compilation aborted for ex2f.F90 (code 1)*//*
> >>>>>>>>>>> *//*make: ***
> >>>>>>>>>>> [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
> >>>>>>>>>>> ex2f] Error 1*/
> >>>>>>>>>>> I have also attached the "/*make check*/" output. Seems
> >>>>>>>>>>> like
> >>>>>>>>>>> there's problem with fortran compile.
> >>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>> <http://tayweebeng.wixsite.com/website>_
> >>>>>>>>>>> <https://goo.gl/PtvdwQ>_
> >>>>>>>>>>> <https://www.linkedin.com/in/tay-weebeng>_
> >>>>>>>>>>> On 14/4/2021 3:47 pm, Barry Smith wrote:
> >>>>>>>>>>>> Please send configure.log and make.log and the results
> >>>>>>>>>>>> of
> >>>>>>>>>>>> "make
> >>>>>>>>>>>> check" so we have the details on the build process.
> >>>>>>>>>>>>> /*No rule to make target
> >>>>>>>>>>>>> '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
> >>>>>>>>>>>>> Stop.*/
> >>>>>>>>>>>> Looks funny; it does not seem to separate the PETSc
> >>>>>>>>>>>> directory
> >>>>>>>>>>>> from its configuration directory appropriately.
> >>>>>>>>>>>> Are you sure
> >>>>>>>>>>>>> *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
> >>>>>>>>>>>> are run in the appropriate directory so that PETSC_DIR
> >>>>>>>>>>>> is
> >>>>>>>>>>>> correct.
> >>>>>>>>>>>> Barry
> >>>>>>>>>>>>> On Apr 14, 2021, at 2:20 AM, TAY wee-beng
> >>>>>>>>>>>>> Hi Mark,
> >>>>>>>>>>>>> I'm not sure what's wrong.
> >>>>>>>>>>>>> In VS2017 + Intel oneAPI,
> >>>>>>>>>>>>> even after adding the full path:
> >>>>>>>>>>>>> #include
> >>>>>>>>>>>>> <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
> >>>>>>>>>>>>> I got a new error:
> >>>>>>>>>>>>> /*Compiling with Intel® Fortran Compiler Classic
> >>>>>>>>>>>>> 2021.2.0
> >>>>>>>>>>>>> [Intel(R) 64]...*//*
> >>>>>>>>>>>>> *//*ex2f.F90*//*
> >>>>>>>>>>>>> *//*petscksp.h(8): #error: can't find include file:
> >>>>>>>>>>>>> petsc/finclude/petscpc.h*//*
> >>>>>>>>>>>>> *//*ex2f : error PRJ0019: A tool returned an error
> >>>>>>>>>>>>> code*/
> >>>>>>>>>>>>> Note that I have also specified the include dir in the
> >>>>>>>>>>>>> properties:
> >>>>>>>>>>>>> /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
> >>>>>>>>>>>>> I also tried in cygwin:
> >>>>>>>>>>>>> *//*export
> >>>>>>>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
> >>>>>>>>>>>>> *//*make ex2f*/
> >>>>>>>>>>>>> I got the error:
> >>>>>>>>>>>>> /*$ make ex2f*//*
> >>>>>>>>>>>>> *//*makefile:41:
> >>>>>>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
> >>>>>>>>>>>>> No such file or directory*//*
> >>>>>>>>>>>>> *//*make: *** No rule to make target
> >>>>>>>>>>>>> Stop.*/
> >>>>>>>>>>>>> Somehow it just doesn't work. Building the library has
> >>>>>>>>>>>>> no
> >>>>>>>>>>>>> problem though.
> >>>>>>>>>>>>> I wonder what's wrong.
> >>>>>>>>>>>>> Yours sincerely,
> >>>>>>>>>>>>> On 14/4/2021 9:31 am, Mark Adams wrote:
> >>>>>>>>>>>>>> PETSc has changed Fortran syntax since v3.9. You
> >>>>>>>>>>>>>> should
> >>>>>>>>>>>>>> upgrade. Look at examples for how to use modules etc.
> >>>>>>>>>>>>>> 2021.2.0
> >>>>>>>>>>>>>> *//*global.F90*//*
> >>>>>>>>>>>>>> *//*global.F90(3): #error: can't find include
> >>>>>>>>>>>>>> file:
> >>>>>>>>>>>>>> petsc/finclude/petsc.h*//*
> >>>>>>>>>>>>>> *//*global.F90(937): #error: can't find include
> >>>>>>>>>>>>>> file:
> >>>>>>>>>>>>>> It looks like you might not have your PETSC_ARCH
> >>>>>>>>>>>>>> variable set.
> >>>>>>>>>>>>>> You should get a full path to /finclude/petsc.h. Look
> >>>>>>>>>>>>>> at
> >>>>>>>>>>>>>> the
> >>>>>>>>>>>>>> compile line.
> >>>>>>>>>>>>>> There are PETSc examples that you you can make to see
> >>>>>>>>>>>>>> an
> >>>>>>>>>>>>>> example of a correct make. For example,
> >>>>>>>>>>>>>> > cd petsc/src/ksp/ksp/tutorials
> >>>>>>>>>>>>>> > > > > > > > > > > > > > > > > make
> >>>>>>>>>>>>>> > > > > > > > > > ex2f
> >>>>>>>>>>>>>> should make an executable and you can look at the
> >>>>>>>>>>>>>> compile
> >>>>>>>>>>>>>> and
> >>>>>>>>>>>>>> link lines, and compare to what you are using.
> >>>>>>>>>>>>>> Mark
> >>>>>>>>>>>>>> Yours sincerely,
