[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
Wed Apr 14 22:42:33 CDT 2021
The c examples ran fine. However fortran has issues.
ex5f.F90(83): error #6405: The same named entity from different modules and/or program units cannot be referenced.   [PETSC_COMM_WORLD]
      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
Is the fortran compiler defaulting to F2008/2018 mode?
You can try building 'release' branch of petsc git repo and see if this problem persists.
Satish
On Thu, 15 Apr 2021, TAY wee-beng wrote:
> Hi Satish,
> I use option 1, but the errors I got from make check seems similar. I have
> attached the output.
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> Personal research webpage: _http://tayweebeng.wixsite.com/website_
> Youtube research showcase: _https://goo.gl/PtvdwQ_
> linkedin: _https://www.linkedin.com/in/tay-weebeng_
> On 15/4/2021 9:54 am, Satish Balay wrote:
> > 1. You can avoid this complexity if you can use in-place install of PETSc
> > [i.e do not use --prefix option to build PETSc]
> > 2. For a prefix install - the following patch should fix the issue [i.e
> > requires rerunning 'configure; make; make install']
> > diff --git a/config/BuildSystem/config/compilerOptions.py
> > b/config/BuildSystem/config/compilerOptions.py
> > index bdfd209203..b2e02783d9 100644
> > --- a/config/BuildSystem/config/compilerOptions.py
> > +++ b/config/BuildSystem/config/compilerOptions.py
> > @@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
> >         if not status:
> >           if compiler.find('win32fe') > -1:
> >             version = '\\n'.join(output.split('\n')[0:2])
> > +          version = version.replace('\r','')
> >           else:
> >             #PGI/Windows writes an empty '\r\n' on the first line of output
> >             if output.count('\n') > 1 and output.split('\n')[0] == '\r':
> > 3. For testing a prefix install - you would do:
> > cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> > make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> > PETSC_ARCH=""
> > [these instructions are printed to the screen when you run 'make install'
> > Satish
> >> Hi Satish,
> >> I tried a few things, not sure if it's correct. But it doesn't seem to work
> >> I edit petscvariables in
> >> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >> and
> >> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> >> from:
> >> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> >> 2017 11:10:38 AM
> >> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
> >> MPICC_SHOW = Unavailable
> >> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> >> 2017 11:10:38 AM
> >> MPICXX_SHOW = Unavailable
> >> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> >> 2017 11:10:38 AM
> >> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
> >> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> >> to
> >> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
> >> 19.16.27045 for x64
> >> 19.16.27045 for x64
> >> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
> >> applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> >> Then in cygwin,
> >> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
> >> export PETSC_DIR=`pwd`
> >> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >> make check
> >> make: *** No rule to make target 'check'.  Stop.
> >> Also:
> >> $ export PETSC_DIR=`pwd`
> >> make check
> >> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: *** target
> >> pattern contains no '%'.  Stop.
> >> Yours sincerely,
> >>>> Hi Satish,
> >>>> Sorry, what do you mean by "manually fix up this file"?
> >>>> Should I edit the petscvariables file?
> >>> yes
> >>>> Do I need to rebuild the lib?
> >>> no
> >>> After editing the file - run 'make check'
> >>> Satish
> >>>> I guess this problem is related to the new Intel oneAPI if I'm not wrong.
> >>>> No
> >>>> such problem previously.
> >>>> Yours sincerely,
> >>>>> 27,
> >>>>> 2017 11:10:38 AM
> >>>>> 27,
> >>>>> 2017 11:10:38 AM
> >>>>> 27,
> >>>>> 2017 11:10:38 AM
> >>>>> on
> >>>>> I'm not sure what happened here. You might want to just manually fix up
> >>>>> this
> >>>>> file
> >>>>> 27,
> >>>>> 19.16.27045 for x64
> >>>>> 27,
> >>>>> 19.16.27045 for x64
> >>>>> 27,
> >>>>> 20210228_000000
> >>>>> Satish
> >>>>>> Hi all,
> >>>>>> I have attached the req file
> >>>>>> Yours sincerely,
> >>>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
> >>>>>>> Please send the file
> >>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> >>>>>>> Satish
> >>>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
> >>>>>>>> Hi,
> >>>>>>>> I redo the installation:
> >>>>>>>> /*Now to install the libraries do:*//*
> >>>>>>>> *//*make
> >>>>>>>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
> >>>>>>>> *//*DELL-T7610+wtay at DELL-T7610
> >>>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
> >>>>>>>> *//*$ make
> >>>>>>>> *//**** Using
> >>>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>>>> *//**** Installing PETSc at prefix location:
> >>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
> >>>>>>>> *//*Install complete.*//*
> >>>>>>>> *//*Now to check if the libraries are working do (in current
> >>>>>>>> directory):*//*
> >>>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>> PETSC_ARCH="" check*//*
> >>>>>>>> *//*/usr/bin/make  --no-print-directory -f makefile
> >>>>>>>> mpi4py-install
> >>>>>>>> petsc4py-install libmesh-install mfem-insta*//*
> >>>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
> >>>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
> >>>>>>>> I ran the check:
> >>>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
> >>>>>>>> *** missing separator.  Stop.*/
> >>>>>>>> Why is this happening?
> >>>>>>>> Yours sincerely,
> >>>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
> >>>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>>>> I think you use PETSC_ARCH="" for installed libs.
> >>>>>>>>> When you do the install it will tell you exactly what to run to run
> >>>>>>>>> "check".
> >>>>>>>>> You might double check that .
> >>>>>>>>> Mark
> >>>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
> >>>>>>>>> <mailto:zonexo at gmail.com>> wrote:
> >>>>>>>>>         Hi Barry,
> >>>>>>>>>         Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
> >>>>>>>>>         Maybe I ran it wrongly initially at where the lib is stored:
> >>>>>>>>>         /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
> >>>>>>>>>         My source is at
> >>>>>>>>>         /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
> >>>>>>>>>         Now I ran:
> >>>>>>>>>         *//*cd src/ksp/ksp/tutorials/*//*
> >>>>>>>>>         *//*make ex2f*/
> >>>>>>>>>         /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
> >>>>>>>>>         ifort -MD -Z7 -fpp  -MD -Z7 -fpp
> >>>>>>>>>         -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
> >>>>>>>>>         -I/cygdrive/d/wtay/Downloads/S*//*
> >>>>>>>>>         *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
> >>>>>>>>>         -I/cygdrive/c/Program\ Files\
> >>>>>>>>>         \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
> >>>>>>>>>         -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
> >>>>>>>>>         *//*15.0_win64_impi_vs2017/lib
> >>>>>>>>>         -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>         -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>>>>         -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
> >>>>>>>>>         *//*_vs2017/lib -lpetsc -lflapack -lfblas
> >>>>>>>>>         Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
> >>>>>>>>>         \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib
> >>>>>>>>>         /cygdrive/c/*//*
> >>>>>>>>>         *//*Program\ Files\
> >>>>>>>>>         \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
> >>>>>>>>>         Gdi32.lib
> >>>>>>>>>         User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
> >>>>>>>>>         *//*ifort: command line warning #10006: ignoring unknown
> >>>>>>>>>         option
> >>>>>>>>>         '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>         option
> >>>>>>>>>         '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>>>>         *//*ex2f.F90(80): error #6405: The same named entity from
> >>>>>>>>>         [PETSC_COMM_WORLD]*//*
> >>>>>>>>>         *//*      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(80): error #7112: This actual argument must not
> >>>>>>>>>         be
> >>>>>>>>>         the name of a procedure. [PETSC_COMM_WORLD]*//*
> >>>>>>>>>         *//*ex2f.F90(81): error #6405: The same named entity from
> >>>>>>>>>         *//*      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(81): error #7112: This actual argument must not
> >>>>>>>>>         be
> >>>>>>>>>         *//*ex2f.F90(93): error #6405: The same named entity from
> >>>>>>>>>         *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(93): error #7112: This actual argument must not
> >>>>>>>>>         be
> >>>>>>>>>         *//*ex2f.F90(159): error #6405: The same named entity from
> >>>>>>>>>         *//*      call
> >>>>>>>>>         VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(159): error #7112: This actual argument must
> >>>>>>>>>         not
> >>>>>>>>>         be
> >>>>>>>>>         *//*      call
> >>>>>>>>>         *//*ex2f.F90(171): error #6405: The same named entity from
> >>>>>>>>>         *//*         call
> >>>>>>>>>         PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(171): error #7112: This actual argument must
> >>>>>>>>>         not
> >>>>>>>>>         be
> >>>>>>>>>         *//*         call
> >>>>>>>>>         *//*ex2f.F90(193): error #6405: The same named entity from
> >>>>>>>>>         *//*      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
> >>>>>>>>>         *//*ex2f.F90(193): error #7112: This actual argument must
> >>>>>>>>>         not
> >>>>>>>>>         be
> >>>>>>>>>         *//*ex2f.F90(319): error #6405: The same named entity from
> >>>>>>>>>         *//*ex2f.F90(319): error #7112: This actual argument must
> >>>>>>>>>         not
> >>>>>>>>>         be
> >>>>>>>>>         *//*compilation aborted for ex2f.F90 (code 1)*//*
> >>>>>>>>>         *//*make: ***
> >>>>>>>>>         [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
> >>>>>>>>>         ex2f] Error 1*/
> >>>>>>>>>         I have also attached the "/*make check*/" output. Seems like
> >>>>>>>>>         there's problem with fortran compile.
> >>>>>>>>>         Yours sincerely,
> >>>>>>>>>         <http://tayweebeng.wixsite.com/website>_
> >>>>>>>>>         <https://goo.gl/PtvdwQ>_
> >>>>>>>>>         <https://www.linkedin.com/in/tay-weebeng>_
> >>>>>>>>>         On 14/4/2021 3:47 pm, Barry Smith wrote:
> >>>>>>>>>>          Please send configure.log and make.log and the results of
> >>>>>>>>>>         "make
> >>>>>>>>>>         check" so we have the details on the build process.
> >>>>>>>>>>>         /*No rule to make target
> >>>>>>>>>>>         '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
> >>>>>>>>>>>         Stop.*/
> >>>>>>>>>>          Looks funny; it does not seem to separate the PETSc
> >>>>>>>>>>         directory
> >>>>>>>>>>         from its configuration directory appropriately.
> >>>>>>>>>>           Are you sure
> >>>>>>>>>>>         *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
> >>>>>>>>>>         are run in the appropriate directory so that PETSC_DIR is
> >>>>>>>>>>         correct.
> >>>>>>>>>>         Barry
> >>>>>>>>>>>         On Apr 14, 2021, at 2:20 AM, TAY wee-beng
> >>>>>>>>>>>         Hi Mark,
> >>>>>>>>>>>         I'm not sure what's wrong.
> >>>>>>>>>>>         In VS2017 + Intel oneAPI,
> >>>>>>>>>>>         even after adding the full path:
> >>>>>>>>>>>         #include
> >>>>>>>>>>>         <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
> >>>>>>>>>>>         I got a new error:
> >>>>>>>>>>>         /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
> >>>>>>>>>>>         [Intel(R) 64]...*//*
> >>>>>>>>>>>         *//*ex2f.F90*//*
> >>>>>>>>>>>         *//*petscksp.h(8): #error: can't find include file:
> >>>>>>>>>>>         petsc/finclude/petscpc.h*//*
> >>>>>>>>>>>         *//*ex2f : error PRJ0019: A tool returned an error code*/
> >>>>>>>>>>>         Note that I have also specified the include dir in the
> >>>>>>>>>>>         properties:
> >>>>>>>>>>>         /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
> >>>>>>>>>>>         I also tried in cygwin:
> >>>>>>>>>>>         *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
> >>>>>>>>>>>         *//*make ex2f*/
> >>>>>>>>>>>         I got the error:
> >>>>>>>>>>>         /*$ make ex2f*//*
> >>>>>>>>>>>         *//*makefile:41:
> >>>>>>>>>>>         /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
> >>>>>>>>>>>         No such file or directory*//*
> >>>>>>>>>>>         *//*make: *** No rule to make target
> >>>>>>>>>>>         Stop.*/
> >>>>>>>>>>>         Somehow it just doesn't work. Building the library has no
> >>>>>>>>>>>         problem though.
> >>>>>>>>>>>         I wonder what's wrong.
> >>>>>>>>>>>         Yours sincerely,
> >>>>>>>>>>>         On 14/4/2021 9:31 am, Mark Adams wrote:
> >>>>>>>>>>>>         PETSc has changed Fortran syntax since v3.9. You should
> >>>>>>>>>>>>         upgrade. Look at examples for how to use modules etc.
> >>>>>>>>>>>>             2021.2.0
> >>>>>>>>>>>>             *//*global.F90*//*
> >>>>>>>>>>>>             *//*global.F90(3): #error: can't find include file:
> >>>>>>>>>>>>             petsc/finclude/petsc.h*//*
> >>>>>>>>>>>>             *//*global.F90(937): #error: can't find include file:
> >>>>>>>>>>>>         It looks like you might not have your PETSC_ARCH
> >>>>>>>>>>>>         variable set.
> >>>>>>>>>>>>         You should get a full path to /finclude/petsc.h. Look at
> >>>>>>>>>>>>         the
> >>>>>>>>>>>>         compile line.
> >>>>>>>>>>>>         There are PETSc examples that you you can make to see an
> >>>>>>>>>>>>         example of a correct make. For example,
> >>>>>>>>>>>>         > cd petsc/src/ksp/ksp/tutorials
> >>>>>>>>>>>>          >  >  >  >  >  >  >  >  >  >  >  >  >  >  >  > make
> >>>>>>>>>>>>          >  >  >  >  >  >  >  > ex2f
> >>>>>>>>>>>>         should make an executable and you can look at the compile
> >>>>>>>>>>>>         and
> >>>>>>>>>>>>         link lines, and compare to what you are using.
> >>>>>>>>>>>>         Mark
> >>>>>>>>>>>>             Yours sincerely,
